root/radiance/ray/src/util/eplus_idf.c
Wed Mar 5 19:49:39 2014 UTC (11 years ago) by greg
Changes since 2.11: +13 -4 lines
Changed idf_free() to make it faster
Tue Mar 4 17:06:42 2014 UTC (11 years ago) by greg
Changes since 2.10: +23 -4 lines
Fixed issue with missing EOL in last object
Thu Feb 13 17:39:39 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.9: +7 -5 lines
Append EOL to comment if it overruns buffer
Thu Feb 13 17:33:37 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.8: +4 -4 lines
Increased allowed comment length and corrected name of view factors object
Wed Feb 12 17:40:07 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.7: +39 -39 lines
Changed all "parameter" references to "object"
Tue Feb 11 23:30:11 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.6: +6 -8 lines
Slight logic simplification should not affect operation
Mon Feb 10 04:51:26 2014 UTC (11 years, 1 month ago) by greg
Complete but untested implmentation of eplus_adduvf
Sun Feb 9 22:19:30 2014 UTC (11 years, 1 month ago) by greg
Partial implementation of eplus_adduvf
Sun Feb 9 05:49:21 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.3: +77 -13 lines
Unfinished implementation of EnergyPlus User View Factors calculation
Sun Feb 9 02:18:16 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.2: +21 -10 lines
Fixed bug in comment reader and added idf_getfield() call
Sat Feb 1 02:13:24 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.1: +20 -5 lines
Made sure parameter names are case-insensitive in lookups
Sat Feb 1 01:28:43 2014 UTC (11 years, 1 month ago) by greg
Added (thus far) untested routines for reading and writing EnergyPlus IDFs
