root/radiance/ray/src/util/eplus_idf.c
Revision: 2.6
Committed: Mon Feb 10 04:51:26 2014 UTC (11 years, 2 months ago) by greg
Complete but untested implmentation of eplus_adduvf
2 static const char RCSid[] = "$Id: eplus_idf.c,v 2.5 2014/02/09 22:19:30 greg Exp $";
5 * eplus_idf.c
6 *
7 * EnergyPlus Input Data File i/o routines
8 *
9 * Created by Greg Ward on 1/31/14.
10 */
11
12 #include <stdio.h>
13 #include <string.h>
14 #include <ctype.h>
15 #include <stdlib.h>
16 #include "eplus_idf.h"
17
18 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
19 #undef getc
20 #define getc getc_unlocked
21 #endif
22
23 /* Create a new parameter with empty field list (comment optional) */
24 IDF_PARAMETER *
25 idf_newparam(IDF_LOADED *idf, const char *pname, const char *comm,
26 IDF_PARAMETER *prev)
27 {
28 LUENT *pent;
29 IDF_PARAMETER *pnew;
30
31 if ((idf == NULL) | (pname == NULL))
32 return(NULL);
33 if (comm == NULL) comm = "";
34 pent = lu_find(&idf->ptab, pname);
35 if (pent == NULL)
36 return(NULL);
37 if (pent->key == NULL) { /* new parameter name/type? */
38 pent->key = (char *)malloc(strlen(pname)+1);
39 if (pent->key == NULL)
40 return(NULL);
41 strcpy(pent->key, pname);
42 }
43 pnew = (IDF_PARAMETER *)malloc(sizeof(IDF_PARAMETER)+strlen(comm));
44 if (pnew == NULL)
45 return(NULL);
46 strcpy(pnew->rem, comm);
47 pnew->nfield = 0;
48 pnew->flist = NULL;
49 pnew->pname = pent->key; /* add to table */
50 pnew->pnext = (IDF_PARAMETER *)pent->data;
51 pent->data = (char *)pnew;
52 pnew->dnext = NULL; /* add to file list */
53 if (prev != NULL || (prev = idf->plast) != NULL) {
54 pnew->dnext = prev->dnext;
55 if (prev == idf->plast)
56 idf->plast = pnew;
57 }
58 if (idf->pfirst == NULL)
59 idf->pfirst = idf->plast = pnew;
60 else
61 prev->dnext = pnew;
62 return(pnew);
63 }
64
65 /* Add a field to the given parameter and follow with the given text */
66 int
67 idf_addfield(IDF_PARAMETER *param, const char *fval, const char *comm)
68 {
69 int fnum = 1; /* returned argument number */
70 IDF_FIELD *fnew, *flast;
71 char *cp;
72
73 if ((param == NULL) | (fval == NULL))
74 return(0);
75 if (comm == NULL) comm = "";
76 fnew = (IDF_FIELD *)malloc(sizeof(IDF_FIELD)+strlen(fval)+strlen(comm));
77 if (fnew == NULL)
78 return(0);
79 fnew->next = NULL;
80 cp = fnew->val; /* copy value and comments */
81 while ((*cp++ = *fval++))
82 ;
83 fnew->rem = cp;
84 while ((*cp++ = *comm++))
85 ;
86 /* add to parameter's field list */
87 if ((flast = param->flist) != NULL) {
88 ++fnum;
89 while (flast->next != NULL) {
90 flast = flast->next;
91 ++fnum;
92 }
93 }
94 if (flast == NULL)
95 param->flist = fnew;
96 else
97 flast->next = fnew;
98 param->nfield++;
99 return(fnum);
100 }
101
102 /* Retrieve the indexed field from parameter (first field index is 1) */
103 IDF_FIELD *
104 idf_getfield(IDF_PARAMETER *param, int fn)
105 {
106 IDF_FIELD *fld;
107
108 if ((param == NULL) | (fn <= 0))
109 return(NULL);
110 fld = param->flist;
111 while ((--fn > 0) & (fld != NULL))
112 fld = fld->next;
113 return(fld);
114 }
115
116 /* Delete the specified parameter from loaded IDF */
117 int
118 idf_delparam(IDF_LOADED *idf, IDF_PARAMETER *param)
119 {
120 LUENT *pent;
121 IDF_PARAMETER *pptr, *plast;
122
123 if ((idf == NULL) | (param == NULL))
124 return(0);
125 /* remove from parameter table */
126 pent = lu_find(&idf->ptab, param->pname);
127 for (plast = NULL, pptr = (IDF_PARAMETER *)pent->data;
128 pptr != NULL; plast = pptr, pptr = pptr->pnext)
129 if (pptr == param)
130 break;
131 if (pptr == NULL)
132 return(0);
133 if (plast == NULL)
134 pent->data = (char *)param->pnext;
135 else
136 plast->pnext = param->pnext;
137 /* remove from global list */
138 for (plast = NULL, pptr = idf->pfirst;
139 pptr != param; plast = pptr, pptr = pptr->dnext)
140 if (pptr == NULL)
141 return(0);
142 if (plast == NULL)
143 idf->pfirst = param->dnext;
144 else
145 plast->dnext = param->dnext;
146 if (idf->plast == param)
147 idf->plast = plast;
148 /* free field list */
149 while (param->flist != NULL) {
150 IDF_FIELD *fdel = param->flist;
151 param->flist = fdel->next;
152 free(fdel);
153 }
154 free(param); /* free parameter struct */
155 return(1);
156 }
157
158 /* Move the specified parameter to the given position in the IDF */
159 int
160 idf_movparam(IDF_LOADED *idf, IDF_PARAMETER *param, IDF_PARAMETER *prev)
161 {
162 IDF_PARAMETER *pptr, *plast;
163
164 if ((idf == NULL) | (param == NULL))
165 return(0);
166 /* find in IDF list, first*/
167 for (plast = NULL, pptr = idf->pfirst;
168 pptr != param; plast = pptr, pptr = pptr->dnext)
169 if (pptr == NULL)
170 return(0);
171 if (plast == NULL) {
172 if (prev == NULL)
173 return(1); /* already in place */
174 idf->pfirst = param->dnext;
175 } else {
176 if (prev == plast)
177 return(1); /* already in place */
178 plast->dnext = param->dnext;
179 }
180 if (idf->plast == param)
181 idf->plast = plast;
182 if (prev == NULL) { /* means they want it at beginning */
183 param->dnext = idf->pfirst;
184 idf->pfirst = param;
185 } else {
186 param->dnext = prev->dnext;
187 prev->dnext = param;
188 }
189 return(1);
190 }
191
192 /* Get a named parameter list */
193 IDF_PARAMETER *
194 idf_getparam(IDF_LOADED *idf, const char *pname)
195 {
196 if ((idf == NULL) | (pname == NULL))
197 return(NULL);
198
199 return((IDF_PARAMETER *)lu_find(&idf->ptab,pname)->data);
200 }
201
202 /* Read an argument including terminating ',' or ';' -- return which */
203 static int
204 idf_read_argument(char *buf, FILE *fp, int trim)
205 {
206 int skipwhite = trim;
207 char *cp = buf;
208 int c;
209
210 while ((c = getc(fp)) != EOF && (c != ',') & (c != ';')) {
211 if (skipwhite && isspace(c))
212 continue;
213 skipwhite = 0;
214 if (cp-buf < IDF_MAXARGL-1)
215 *cp++ = c;
216 }
217 if (trim)
218 while (cp > buf && isspace(cp[-1]))
219 --cp;
220 *cp = '\0';
221 return(c);
222 }
223
224 /* Read a comment, including all white space up to next alpha character */
225 static void
226 idf_read_comment(char *buf, int len, FILE *fp)
227 {
228 int incomm = 0;
229 char *cp = buf;
230 char dummyc;
231 int c;
232
233 if ((buf == NULL) | (len <= 0)) {
234 buf = &dummyc;
235 len = 1;
236 }
237 while ((c = getc(fp)) != EOF &&
238 (isspace(c) || (incomm += (c == '!')))) {
239 if (c == '\n')
240 incomm = 0;
241 if (cp-buf < len-1)
242 *cp++ = c;
243 }
244 *cp = '\0';
245 if (c != EOF)
246 ungetc(c, fp);
247 }
248
249 /* Read a parameter and fields from an open file and add to end of list */
250 IDF_PARAMETER *
251 idf_readparam(IDF_LOADED *idf, FILE *fp)
252 {
253 char abuf[IDF_MAXARGL], cbuf[IDF_MAXLINE];
254 int delim;
255 IDF_PARAMETER *pnew;
256
257 if ((delim = idf_read_argument(abuf, fp, 1)) == EOF)
258 return(NULL);
259 idf_read_comment(cbuf, IDF_MAXLINE, fp);
260 pnew = idf_newparam(idf, abuf, cbuf, NULL);
261 while (delim == ',')
262 if ((delim = idf_read_argument(abuf, fp, 1)) != EOF) {
263 idf_read_comment(cbuf, IDF_MAXLINE, fp);
264 idf_addfield(pnew, abuf, cbuf);
265 }
266 if (delim != ';')
267 fputs("Expected ';' at end of parameter list!\n", stderr);
268 return(pnew);
269 }
270
271 /* Upper-case string hashing function */
272 static unsigned long
273 strcasehash(const char *s)
274 {
275 char strup[IDF_MAXARGL];
276 char *cdst = strup;
277
278 while ((*cdst++ = toupper(*s++)))
279 if (cdst >= strup+(sizeof(strup)-1)) {
280 *cdst = '\0';
281 break;
282 }
283 return(lu_shash(strup));
284 }
285
286 /* Initialize an IDF struct */
287 IDF_LOADED *
288 idf_create(const char *hdrcomm)
289 {
290 IDF_LOADED *idf = (IDF_LOADED *)calloc(1, sizeof(IDF_LOADED));
291
292 if (idf == NULL)
293 return(NULL);
294 idf->ptab.hashf = &strcasehash;
295 idf->ptab.keycmp = &strcasecmp;
296 idf->ptab.freek = &free;
297 lu_init(&idf->ptab, 200);
298 if (hdrcomm != NULL && *hdrcomm) {
299 idf->hrem = (char *)malloc(strlen(hdrcomm)+1);
300 if (idf->hrem != NULL)
301 strcpy(idf->hrem, hdrcomm);
302 }
303 return(idf);
304 }
305
306 /* Add comment(s) to header */
307 int
308 idf_add2hdr(IDF_LOADED *idf, const char *hdrcomm)
309 {
310 int olen, len;
311
312 if ((idf == NULL) | (hdrcomm == NULL))
313 return(0);
314 len = strlen(hdrcomm);
315 if (!len)
316 return(0);
317 if (idf->hrem == NULL)
318 olen = 0;
319 else
320 olen = strlen(idf->hrem);
321 if (olen)
322 idf->hrem = (char *)realloc(idf->hrem, olen+len+1);
323 else
324 idf->hrem = (char *)malloc(len+1);
325 if (idf->hrem == NULL)
326 return(0);
327 strcpy(idf->hrem+olen, hdrcomm);
328 return(1);
329 }
330
331 /* Load an Input Data File */
332 IDF_LOADED *
333 idf_load(const char *fname)
334 {
335 char hdrcomm[256*IDF_MAXLINE];
336 FILE *fp;
337 IDF_LOADED *idf;
338
339 if (fname == NULL)
340 fp = stdin; /* open file if not stdin */
341 else if ((fp = fopen(fname, "r")) == NULL)
342 return(NULL);
343 /* read header comments */
344 idf_read_comment(hdrcomm, sizeof(hdrcomm), fp);
345 idf = idf_create(hdrcomm); /* create IDF struct */
346 if (idf == NULL)
347 return(NULL);
348 /* read each parameter */
349 while (idf_readparam(idf, fp) != NULL)
350 ;
351 if (fp != stdin) /* close file if not stdin */
352 fclose(fp);
353 return(idf); /* success! */
354 }
355
356 /* Write a parameter and fields to an open file */
357 int
358 idf_writeparam(IDF_PARAMETER *param, FILE *fp, int incl_comm)
359 {
360 IDF_FIELD *fptr;
361
362 if ((param == NULL) | (fp == NULL))
363 return(0);
364 fputs(param->pname, fp);
365 fputc(',', fp);
366 if (incl_comm)
367 fputs(param->rem, fp);
368 for (fptr = param->flist; fptr != NULL; fptr = fptr->next) {
369 if (!incl_comm)
370 fputs("\n ", fp);
371 fputs(fptr->val, fp);
372 fputc((fptr->next==NULL ? ';' : ','), fp);
373 if (incl_comm)
374 fputs(fptr->rem, fp);
375 }
376 if (!incl_comm)
377 fputs("\n\n", fp);
378 return(!ferror(fp));
379 }
380
381 /* Write out an Input Data File */
382 int
383 idf_write(IDF_LOADED *idf, const char *fname, int incl_comm)
384 {
385 FILE *fp;
386 IDF_PARAMETER *pptr;
387
388 if (idf == NULL)
389 return(0);
390 if (fname == NULL)
391 fp = stdout; /* open file if not stdout */
392 else if ((fp = fopen(fname, "w")) == NULL)
393 return(0);
394 if (incl_comm)
395 fputs(idf->hrem, fp); /* write header then parameters */
396 for (pptr = idf->pfirst; pptr != NULL; pptr = pptr->dnext)
397 if (!idf_writeparam(pptr, fp, incl_comm>0)) {
398 fclose(fp);
399 return(0);
400 }
401 if (fp == stdout) /* flush/close file & check status */
402 return(fflush(fp) == 0);
403 return(fclose(fp) == 0);
404 }
405
406 /* Free a loaded IDF */
407 void
408 idf_free(IDF_LOADED *idf)
409 {
410 if (idf == NULL)
411 return;
412 if (idf->hrem != NULL)
413 free(idf->hrem);
414 while (idf->pfirst != NULL)
415 idf_delparam(idf, idf->pfirst);
416 lu_done(&idf->ptab);
417 }
