root/radiance/ray/src/util/eplus_adduvf.c
Fri Feb 28 05:18:49 2020 UTC (4 years, 1 month ago) by greg
Diff to previous 2.21 , to selected 2.12
Mon Jan 20 17:53:40 2020 UTC (4 years, 2 months ago) by greg
Changes since 2.20: +6 -5 lines
Diff to previous 2.20 , to selected 2.12
Updated eplus_adduvf to work with version 9.x
Fri Jan 17 17:33:48 2020 UTC (4 years, 3 months ago) by greg
Changes since 2.19: +10 -1 lines
Diff to previous 2.19 , to selected 2.12
Added warning about incompatible input versions
Fri Dec 13 16:00:33 2019 UTC (4 years, 4 months ago) by greg
Diff to previous 2.18 , to selected 2.12
Fixed potential bug when deleting previous UVFs
Sun Mar 6 01:13:18 2016 UTC (8 years, 1 month ago) by schorsch
CVS Tags: rad5R1, rad5R2
Diff to previous 2.17 , to selected 2.12
Fri Apr 4 17:56:45 2014 UTC (10 years ago) by greg
Fixed major bug in subsurface calculation
Mon Mar 3 17:51:50 2014 UTC (10 years, 1 month ago) by greg
Changed single-quotes to double-quotes for Windows command handler
Fri Feb 28 19:14:10 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.14: +3 -2 lines
Changed const int to #define for Windoze
Thu Feb 27 22:42:53 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.13: +7 -7 lines
Bug fix in last change for subsurfaces
Thu Feb 27 20:39:04 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.12: +33 -13 lines
Diff to previous 2.12
Added hack for missing number of vertices
Fri Feb 21 13:17:45 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.11: +49 -15 lines
Added adjustments for area reduction due to subsurfaces
Sat Feb 15 01:31:36 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.10: +242 -84 lines
Trial implementation of subsurface sampling -- needs work
Thu Feb 13 17:33:37 2014 UTC (10 years, 2 months ago) by greg
Increased allowed comment length and corrected name of view factors object
Wed Feb 12 17:40:07 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.8: +22 -22 lines
Changed all "parameter" references to "object"
Wed Feb 12 00:12:38 2014 UTC (10 years, 2 months ago) by greg
Fixed error-checking
Tue Feb 11 23:44:11 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.6: +42 -26 lines
Added -s option to change number of samples (in 1000's)
Tue Feb 11 22:01:44 2014 UTC (10 years, 2 months ago) by greg
Tue Feb 11 21:17:29 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.4: +31 -28 lines
Initial working version -- needs man page and accuracy testing
Mon Feb 10 17:50:02 2014 UTC (10 years, 2 months ago) by greg
Rob updated cmake for eplus_adduvf and I added check for missing energy
Mon Feb 10 04:51:26 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.2: +246 -32 lines
Complete but untested implmentation of eplus_adduvf
Sun Feb 9 22:19:30 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.1: +175 -18 lines
Partial implementation of eplus_adduvf
Sun Feb 9 05:49:21 2014 UTC (10 years, 2 months ago) by greg
Diff to selected 2.12
Unfinished implementation of EnergyPlus User View Factors calculation
