root/radiance/ray/src/util/eplus_adduvf.c
Revision: 2.15
Committed: Fri Feb 28 19:14:10 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.14: +3 -2 lines
Changed const int to #define for Windoze
2 static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.14 2014/02/27 22:42:53 greg Exp $";
5 * Add User View Factors to EnergyPlus Input Data File
6 *
7 * G.Ward for LBNL
8 */
9
10 #include <stdlib.h>
11 #include "rtio.h"
12 #include "rtmath.h"
13 #include "random.h"
14 #include "eplus_idf.h"
15 #include "triangulate.h"
16 #include "rtprocess.h"
17
18 #ifndef NSAMPLES
19 #define NSAMPLES 80000 /* default number of samples */
20 #endif
21
22 #define SURF_EPS 0.0005 /* surface testing epsilon */
23
24 char *progname; /* global argv[0] */
25
26 int nsamps = NSAMPLES; /* number of samples to use */
27
28 char temp_octree[128]; /* temporary octree */
29
30 const char UVF_PNAME[] =
31 "ZoneProperty:UserViewFactors:bySurfaceName";
32
33 const char SUBSURF_PNAME[] =
34 "FenestrationSurface:Detailed";
35
36 const char ADD_HEADER[] =
37 "\n!+++ User View Factors computed by Radiance +++!\n\n";
38
39 #define NAME_FLD 1 /* name field always first? */
40
41 #define SS_BASE_FLD 4 /* subsurface base surface */
42 #define SS_VERT_FLD 10 /* subsurface vertex count */
43
44 typedef struct {
45 const char *pname; /* object type name */
46 short zone_fld; /* zone field index */
47 short vert_fld; /* vertex field index */
48 } SURF_PTYPE; /* surface type we're interested in */
49
50 const SURF_PTYPE surf_type[] = {
51 {"BuildingSurface:Detailed", 4, 10},
52 {"Floor:Detailed", 3, 9},
53 {"RoofCeiling:Detailed", 3, 9},
54 {"Wall:Detailed", 3, 9},
55 {NULL}
56 }; /* IDF surface types */
57
58 typedef struct s_zone {
59 const char *zname; /* zone name */
60 struct s_zone *next; /* next zone in list */
61 int nsurf; /* surface count */
62 int ntotal; /* surfaces+subsurfaces */
63 IDF_OBJECT *pfirst; /* first matching object */
64 IDF_OBJECT *plast; /* last before subsurfaces */
65 float *area_redu; /* subsurface area per surf. */
66 } ZONE; /* a list of collected zone surfaces */
67
68 ZONE *zone_list = NULL; /* our list of zones */
69
70 LUTAB zonesurf_lut = /* zone surface lookup table */
71 LU_SINIT(NULL,NULL);
72
73 IDF_LOADED *our_idf = NULL; /* loaded/modified IDF */
74
75 typedef struct {
76 FVECT norm; /* surface normal */
77 double area; /* surface area */
78 int nv; /* number of vertices */
79 FVECT vl[3]; /* vertex list (extends struct) */
80 } SURFACE; /* a polygonal surface */
81
82 typedef struct {
83 FVECT sdir[3]; /* UVW unit sampling vectors */
84 double poff; /* W-offset for plane of polygon */
85 double area_left; /* area left to sample */
86 int samp_left; /* remaining samples */
87 int wd; /* output file descriptor */
88 } POLYSAMP; /* structure for polygon sampling */
89
90 /* Create a new zone and push to top of our list */
91 static ZONE *
92 new_zone(const char *zname, IDF_OBJECT *param)
93 {
94 ZONE *znew = (ZONE *)malloc(sizeof(ZONE));
95
96 if (znew == NULL)
97 return(NULL);
98 znew->zname = zname; /* assumes static */
99 znew->next = zone_list;
100 znew->pfirst = znew->plast = param;
101 znew->ntotal = znew->nsurf = 1;
102 znew->area_redu = NULL;
103 return(zone_list = znew);
104 }
105
106 /* Add the detailed surface (polygon) to the named zone */
107 static ZONE *
108 add2zone(IDF_OBJECT *param, const char *zname)
109 {
110 IDF_FIELD *nfp = idf_getfield(param, NAME_FLD);
111 ZONE *zptr;
112 LUENT *lep;
113
114 if (nfp == NULL) {
115 fputs(progname, stderr);
116 fputs(": surface missing name field!\n", stderr);
117 return(NULL);
118 }
119 for (zptr = zone_list; zptr != NULL; zptr = zptr->next)
120 if (!strcmp(zptr->zname, zname))
121 break;
122 if (zptr == NULL) {
123 zptr = new_zone(zname, param);
124 } else { /* keep surfaces together */
125 if (!idf_movobject(our_idf, param, zptr->plast))
126 return(NULL);
127 zptr->plast = param;
128 zptr->nsurf++;
129 zptr->ntotal++;
130 }
131 /* add to lookup table */
132 lep = lu_find(&zonesurf_lut, nfp->val);
133 if (lep == NULL)
134 return(NULL);
135 if (lep->data != NULL) {
136 fputs(progname, stderr);
137 fputs(": duplicate surface name '", stderr);
138 fputs(nfp->val, stderr);
139 fputs("'\n", stderr);
140 return(NULL);
141 }
142 lep->key = nfp->val;
143 lep->data = (char *)zptr;
144 return(zptr);
145 }
146
147 /* Add a subsurface by finding its base surface and the corresponding zone */
148 static ZONE *
149 add_subsurf(IDF_OBJECT *param)
150 {
151 IDF_FIELD *bfp = idf_getfield(param, SS_BASE_FLD);
152 ZONE *zptr;
153 LUENT *lep;
154
155 if (bfp == NULL) {
156 fputs(progname, stderr);
157 fputs(": missing base field name in subsurface!\n", stderr);
158 return(NULL);
159 }
160 lep = lu_find(&zonesurf_lut, bfp->val); /* find base zone */
161 if (lep == NULL || lep->data == NULL) {
162 fputs(progname, stderr);
163 fputs(": cannot find referenced base surface '", stderr);
164 fputs(bfp->val, stderr);
165 fputs("'\n", stderr);
166 return(NULL);
167 }
168 zptr = (ZONE *)lep->data; /* add this subsurface */
169 if (!idf_movobject(our_idf, param, zptr->plast))
170 return(NULL);
171 zptr->ntotal++;
172 return(zptr);
173 }
174
175 /* Return field for vertices in the given object */
176 static IDF_FIELD *
177 get_vlist(IDF_OBJECT *param, const char *zname)
178 {
179 #define itm_len (sizeof(IDF_FIELD)+6)
180 static char fld_buf[4*itm_len];
181 static char *next_fbp = fld_buf;
182 int i;
183 IDF_FIELD *res;
184 /* check if subsurface */
185 if (!strcmp(param->pname, SUBSURF_PNAME)) {
186 if (zname != NULL) {
187 LUENT *lep = lu_find(&zonesurf_lut,
188 idf_getfield(param,SS_BASE_FLD)->val);
189 if (strcmp((*(ZONE *)lep->data).zname, zname))
190 return(NULL);
191 }
192 res = idf_getfield(param, SS_VERT_FLD);
193 } else {
194 i = 0; /* check for surface type */
195 while (strcmp(surf_type[i].pname, param->pname))
196 if (surf_type[++i].pname == NULL)
197 return(NULL);
198
199 if (zname != NULL) { /* matches specified zone? */
200 IDF_FIELD *fptr = idf_getfield(param, surf_type[i].zone_fld);
201 if (fptr == NULL || strcmp(fptr->val, zname))
202 return(NULL);
203 }
204 res = idf_getfield(param, surf_type[i].vert_fld);
205 }
206 if (!res->val[0]) { /* hack for missing #vert */
207 IDF_FIELD *fptr;
208 if (next_fbp >= fld_buf+sizeof(fld_buf))
209 next_fbp = fld_buf;
210 i = 0; /* count vertices */
211 for (fptr = res->next; fptr != NULL; fptr = fptr->next)
212 ++i;
213 if (i % 3)
214 return(NULL);
215 fptr = res->next;
216 res = (IDF_FIELD *)next_fbp; next_fbp += itm_len;
217 res->next = fptr;
218 res->rem = "";
219 sprintf(res->val, "%d", i/3);
220 }
221 return(res);
222 #undef itm_len
223 }
224
225 /* Get/allocate surface polygon */
226 static SURFACE *
227 get_surface(IDF_FIELD *fptr)
228 {
229 SURFACE *surf;
230 int nv;
231 FVECT e1, e2, vc;
232 int i, j;
233 /* get number of vertices */
234 if (fptr == NULL || (nv = atoi(fptr->val)) < 3) {
235 fputs(progname, stderr);
236 fputs(": bad vertex count for surface!\n", stderr);
237 return(NULL);
238 }
239 surf = (SURFACE *)malloc(sizeof(SURFACE)+sizeof(FVECT)*(nv-3));
240 if (surf == NULL)
241 return(NULL);
242 surf->nv = nv;
243 for (i = nv; i--; ) /* reverse vertex order/orientation */
244 for (j = 0; j < 3; j++) {
245 fptr = fptr->next;
246 if (fptr == NULL) {
247 fputs(progname, stderr);
248 fputs(": missing vertex in get_surface()\n", stderr);
249 free(surf);
250 return(NULL);
251 }
252 if ((surf->vl[i][j] = atof(fptr->val)) == 0 &&
253 !isflt(fptr->val)) {
254 fputs(progname, stderr);
255 fputs(": bad vertex in get_surface()\n", stderr);
256 free(surf);
257 return(NULL);
258 }
259 }
260 /* compute area and normal */
261 surf->norm[0] = surf->norm[1] = surf->norm[2] = 0;
262 VSUB(e1, surf->vl[1], surf->vl[0]);
263 for (i = 2; i < nv; i++) {
264 VSUB(e2, surf->vl[i], surf->vl[0]);
265 fcross(vc, e1, e2);
266 surf->norm[0] += vc[0];
267 surf->norm[1] += vc[1];
268 surf->norm[2] += vc[2];
269 VCOPY(e1, e2);
270 }
271 surf->area = .5 * normalize(surf->norm);
272 if (surf->area == 0) {
273 fputs(progname, stderr);
274 fputs(": degenerate polygon in get_surface()\n", stderr);
275 free(surf);
276 return(NULL);
277 }
278 return(surf);
279 }
280
281 /* Convert surface to Radiance with modifier based on unique name */
282 static int
283 rad_surface(IDF_OBJECT *param, FILE *ofp)
284 {
285 const char *sname = idf_getfield(param,NAME_FLD)->val;
286 IDF_FIELD *fptr = get_vlist(param, NULL);
287 const char **fargs;
288 int nvert, i, j;
289
290 if (fptr == NULL || (nvert = atoi(fptr->val)) < 3) {
291 fprintf(stderr, "%s: bad surface '%s'\n", progname, sname);
292 return(0);
293 }
294 fargs = (const char **)malloc(sizeof(const char *)*3*nvert);
295 if (fargs == NULL)
296 return(0);
297 fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname);
298 fprintf(ofp, "\n'%s' polygon 's_%s'\n0\n0\n%d\n", sname, sname, 3*nvert);
299 for (j = nvert; j--; ) { /* get arguments in reverse */
300 for (i = 0; i < 3; i++) {
301 fptr = fptr->next;
302 if (fptr == NULL || !isflt(fptr->val)) {
303 fprintf(stderr,
304 "%s: missing/bad vertex for %s '%s'\n",
305 progname, param->pname, sname);
306 return(0);
307 }
308 fargs[3*j + i] = fptr->val;
309 }
310 }
311 for (j = 0; j < nvert; j++) { /* output reversed verts */
312 for (i = 0; i < 3; i++) {
313 fputc('\t', ofp);
314 fputs(fargs[3*j + i], ofp);
315 }
316 fputc('\n', ofp);
317 }
318 free(fargs);
319 return(!ferror(ofp));
320 }
321
322 /* Convert subsurface to Radiance with modifier based on unique name */
323 static double
324 rad_subsurface(IDF_OBJECT *param, FILE *ofp)
325 {
326 const char *sname = idf_getfield(param,NAME_FLD)->val;
327 SURFACE *surf = get_surface(get_vlist(param, NULL));
328 double area;
329 int i;
330
331 if (surf == NULL) {
332 fprintf(stderr, "%s: bad subsurface '%s'\n", progname, sname);
333 return(-1.);
334 }
335 fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname);
336 fprintf(ofp, "\n'%s' polygon 'ss_%s'\n0\n0\n%d\n",
337 sname, sname, 3*surf->nv);
338 for (i = 0; i < surf->nv; i++) { /* offset vertices */
339 FVECT vert;
340 VSUM(vert, surf->vl[i], surf->norm, 2.*SURF_EPS);
341 fprintf(ofp, "\t%.12f %.12f %.12f\n", vert[0], vert[1], vert[2]);
342 }
343 area = surf->area;
344 free(surf);
345 if (ferror(ofp))
346 return(-1.);
347 return(area);
348 }
349
350 /* Start rcontrib process */
351 static int
352 start_rcontrib(SUBPROC *pd, ZONE *zp)
353 {
354 #define BASE_AC 6
355 static char *base_av[BASE_AC] = {
356 "rcontrib", "-V+", "-fff", "-h", "-x", "1"
357 };
358 char cbuf[300];
359 char **av;
360 FILE *ofp;
361 IDF_OBJECT *pptr;
362 IDF_FIELD *fptr;
363 int i, j, n;
364 /* start oconv command */
365 sprintf(cbuf, "oconv - > '%s'", temp_octree);
366 if ((ofp = popen(cbuf, "w")) == NULL) {
367 fputs(progname, stderr);
368 fputs(": cannot open oconv process\n", stderr);
369 return(0);
370 }
371 /* allocate argument list */
372 av = (char **)malloc(sizeof(char *)*(BASE_AC+4+2*(zp->ntotal)));
373 if (av == NULL)
374 return(0);
375 for (i = 0; i < BASE_AC; i++)
376 av[i] = base_av[i];
377 sprintf(cbuf, "%d", nsamps);
378 av[i++] = "-c";
379 av[i++] = cbuf; /* add modifiers & surfaces */
380 for (n = 0, pptr = zp->pfirst; n < zp->nsurf; n++, pptr = pptr->dnext) {
381 fptr = idf_getfield(pptr,NAME_FLD);
382 if (fptr == NULL || !fptr->val[0]) {
383 fputs(progname, stderr);
384 fputs(": missing name for surface object\n", stderr);
385 return(0);
386 }
387 if (!rad_surface(pptr, ofp)) /* add surface to octree */
388 return(0);
389 av[i++] = "-m";
390 av[i++] = fptr->val;
391 }
392 /* now subsurfaces */
393 if (zp->ntotal > zp->nsurf) {
394 if (zp->area_redu != NULL)
395 memset(zp->area_redu, 0, sizeof(float)*zp->nsurf);
396 else if ((zp->area_redu = (float *)calloc(zp->nsurf,
397 sizeof(float))) == NULL)
398 return(0);
399 }
400 for ( ; n < zp->ntotal; n++, pptr = pptr->dnext) {
401 double ssarea;
402 const char *bname;
403 IDF_OBJECT *pptr1;
404 fptr = idf_getfield(pptr,NAME_FLD);
405 if (fptr == NULL || !fptr->val[0]) {
406 fputs(progname, stderr);
407 fputs(": missing name for subsurface object\n", stderr);
408 return(0);
409 }
410 /* add subsurface to octree */
411 if ((ssarea = rad_subsurface(pptr, ofp)) < 0)
412 return(0);
413 /* mark area for subtraction */
414 bname = idf_getfield(pptr,SS_BASE_FLD)->val;
415 for (j = 0, pptr1 = zp->pfirst;
416 j < zp->nsurf; j++, pptr1 = pptr1->dnext)
417 if (!strcmp(idf_getfield(pptr1,NAME_FLD)->val, bname)) {
418 zp->area_redu[j] += ssarea;
419 break;
420 }
421 av[i++] = "-m";
422 av[i++] = fptr->val;
423 }
424 if (pclose(ofp) != 0) { /* finish oconv */
425 fputs(progname, stderr);
426 fputs(": error running oconv process\n", stderr);
427 return(0);
428 }
429 av[i++] = temp_octree; /* add final octree argument */
430 av[i] = NULL;
431 if (open_process(pd, av) <= 0) { /* start process */
432 fputs(progname, stderr);
433 fputs(": cannot start rcontrib process\n", stderr);
434 return(0);
435 }
436 free(av); /* all done -- clean up */
437 return(1);
438 #undef BASE_AC
439 }
440
441 /* Initialize polygon sampling */
442 static Vert2_list *
443 init_poly(POLYSAMP *ps, IDF_FIELD *f0)
444 {
445 SURFACE *surf;
446 Vert2_list *vl2;
447 int i;
448 /* get 3-D polygon vertices */
449 if ((surf = get_surface(f0)) == NULL)
450 return(NULL);
451 vl2 = polyAlloc(surf->nv);
452 if (vl2 == NULL)
453 return(NULL);
454 /* create X & Y axes */
455 VCOPY(ps->sdir[2], surf->norm);
456 VSUB(ps->sdir[0], surf->vl[1], surf->vl[0]);
457 if (normalize(ps->sdir[0]) == 0)
458 return(NULL);
459 fcross(ps->sdir[1], ps->sdir[2], ps->sdir[0]);
460 /* compute plane offset */
461 ps->poff = DOT(surf->vl[0], ps->sdir[2]);
462 /* assign 2-D vertices */
463 for (i = 0; i < surf->nv; i++) {
464 vl2->v[i].mX = DOT(surf->vl[i], ps->sdir[0]);
465 vl2->v[i].mY = DOT(surf->vl[i], ps->sdir[1]);
466 }
467 ps->area_left = surf->area;
468 free(surf); /* it's ready! */
469 vl2->p = (void *)ps;
470 return(vl2);
471 }
472
473 /* Generate samples on 2-D triangle */
474 static int
475 sample_triangle(const Vert2_list *vl2, int a, int b, int c)
476 {
477 POLYSAMP *ps = (POLYSAMP *)vl2->p;
478 float *samp;
479 FVECT orig;
480 FVECT ab, ac;
481 double area;
482 int i, j, ns;
483 /* compute sampling axes */
484 for (i = 3; i--; ) {
485 orig[i] = vl2->v[a].mX*ps->sdir[0][i] +
486 vl2->v[a].mY*ps->sdir[1][i] +
487 (ps->poff+SURF_EPS)*ps->sdir[2][i];
488 ab[i] = (vl2->v[b].mX - vl2->v[a].mX)*ps->sdir[0][i] +
489 (vl2->v[b].mY - vl2->v[a].mY)*ps->sdir[1][i];
490 ac[i] = (vl2->v[c].mX - vl2->v[a].mX)*ps->sdir[0][i] +
491 (vl2->v[c].mY - vl2->v[a].mY)*ps->sdir[1][i];
492 }
493 /* compute number of samples to take */
494 area = .5*(vl2->v[a].mX*vl2->v[b].mY - vl2->v[b].mX*vl2->v[a].mY +
495 vl2->v[b].mX*vl2->v[c].mY - vl2->v[c].mX*vl2->v[b].mY +
496 vl2->v[c].mX*vl2->v[a].mY - vl2->v[a].mX*vl2->v[c].mY);
497 if (area < .0) {
498 fputs(progname, stderr);
499 fputs(": negative triangle area in sample_triangle()\n", stderr);
500 return(0);
501 }
502 if (area >= ps->area_left) {
503 ns = ps->samp_left;
504 ps->area_left = 0;
505 } else {
506 ns = (ps->samp_left*area/ps->area_left + .5);
507 ps->samp_left -= ns;
508 ps->area_left -= area;
509 }
510 if (ns <= 0) /* XXX should be error? */
511 return(1);
512 /* buffer sample rays */
513 samp = (float *)malloc(sizeof(float)*6*ns);
514 if (samp == NULL)
515 return(0);
516 for (i = ns; i--; ) { /* stratified Monte Carlo sampling */
517 double sv[4];
518 FVECT dv;
519 multisamp(sv, 4, (i+frandom())/(double)ns);
520 sv[0] *= sv[1] = sqrt(sv[1]);
521 sv[1] = 1. - sv[1];
522 for (j = 3; j--; )
523 samp[i*6 + j] = orig[j] + sv[0]*ab[j] + sv[1]*ac[j];
524 sv[2] = sqrt(sv[2]);
525 sv[3] *= 2.*PI;
526 dv[0] = tcos(sv[3]) * sv[2];
527 dv[1] = tsin(sv[3]) * sv[2];
528 dv[2] = sqrt(1. - sv[2]*sv[2]);
529 for (j = 3; j--; )
530 samp[i*6 + 3 + j] = dv[0]*ps->sdir[0][j] +
531 dv[1]*ps->sdir[1][j] +
532 dv[2]*ps->sdir[2][j] ;
533 }
534 /* send to our process */
535 writebuf(ps->wd, (char *)samp, sizeof(float)*6*ns);
536 free(samp); /* that's it! */
537 return(1);
538 }
539
540 /* Sample the given surface */
541 static double
542 sample_surface(IDF_OBJECT *param, int wd)
543 {
544 POLYSAMP psamp;
545 double area;
546 int nv;
547 Vert2_list *vlist2;
548 /* set up our polygon sampler */
549 if ((vlist2 = init_poly(&psamp, get_vlist(param, NULL))) == NULL) {
550 fprintf(stderr, "%s: bad polygon %s '%s'\n",
551 progname, param->pname,
552 idf_getfield(param,NAME_FLD)->val);
553 return(-1.);
554 }
555 psamp.samp_left = nsamps; /* assign samples & destination */
556 psamp.wd = wd;
557 /* hack for subsurface sampling */
558 psamp.poff += 2.*SURF_EPS * !strcmp(param->pname, SUBSURF_PNAME);
559
560 area = psamp.area_left; /* remember starting surface area */
561 /* sample each subtriangle */
562 if (!polyTriangulate(vlist2, &sample_triangle))
563 return(-1.);
564 polyFree(vlist2); /* clean up and return */
565 return(area);
566 }
567
568 /* Compute User View Factors using open rcontrib process */
569 static int
570 compute_uvfs(SUBPROC *pd, ZONE *zp)
571 {
572 IDF_OBJECT *pptr, *pout, *pptr1;
573 float *uvfa;
574 char uvfbuf[24];
575 int n, m;
576 /* create output object */
577 pout = idf_newobject(our_idf, UVF_PNAME,
578 " ! computed by Radiance\n ", our_idf->plast);
579 if (pout == NULL) {
580 fputs(progname, stderr);
581 fputs(": cannot create new IDF object\n", stderr);
582 return(0);
583 }
584 if (!idf_addfield(pout, zp->zname,
585 " !- Zone Name\n ")) {
586 fputs(progname, stderr);
587 fputs(": cannot add zone name field\n", stderr);
588 return(0);
589 }
590 /* allocate read buffer */
591 uvfa = (float *)malloc(sizeof(float)*3*zp->ntotal);
592 if (uvfa == NULL)
593 return(0);
594 /* UVFs from each surface */
595 for (n = 0, pptr = zp->pfirst; n < zp->ntotal; n++, pptr = pptr->dnext) {
596 double vfsum = 0;
597 double adj_factor;
598 /* send samples to rcontrib */
599 if ((adj_factor = sample_surface(pptr, pd->w)) < 0)
600 return(0);
601 if (zp->area_redu == NULL)
602 adj_factor = 1.;
603 else /* comp. for subsurface area */
604 adj_factor /= adj_factor - zp->area_redu[n];
605 /* read results */
606 if (readbuf(pd->r, (char *)uvfa, sizeof(float)*3*zp->ntotal) !=
607 sizeof(float)*3*zp->ntotal) {
608 fputs(progname, stderr);
609 fputs(": read error from rcontrib process\n", stderr);
610 return(0);
611 }
612 /* append UVF fields */
613 for (m = 0, pptr1 = zp->pfirst;
614 m < zp->ntotal; m++, pptr1 = pptr1->dnext) {
615 const double uvf = uvfa[3*m + 1] * adj_factor;
616 vfsum += uvf;
617 if (pptr1 == pptr && uvf > .001)
618 fprintf(stderr,
619 "%s: warning - non-zero self-VF (%.1f%%) for surface '%s'\n",
620 progname, 100.*uvf,
621 idf_getfield(pptr,NAME_FLD)->val);
622 sprintf(uvfbuf, "%.4f", uvf);
623 if (!idf_addfield(pout,
624 idf_getfield(pptr,NAME_FLD)->val, NULL) ||
625 !idf_addfield(pout,
626 idf_getfield(pptr1,NAME_FLD)->val, NULL) ||
627 !idf_addfield(pout, uvfbuf,
628 (n+m < 2*zp->ntotal-2) ?
629 "\n " : "\n\n")) {
630 fputs(progname, stderr);
631 fputs(": error adding UVF fields\n", stderr);
632 return(0);
633 }
634 }
635 if (vfsum < 0.95)
636 fprintf(stderr,
637 "%s: warning - missing %.1f%% of energy from surface '%s'\n",
638 progname, 100.*(1.-vfsum),
639 idf_getfield(pptr,NAME_FLD)->val);
640 }
641 free(uvfa); /* clean up and return */
642 return(1);
643 }
644
645 /* Compute zone User View Factors */
646 static int
647 compute_zones(void)
648 {
649 ZONE *zptr;
650 /* temporary octree name */
651 mktemp(strcpy(temp_octree, TEMPLATE));
652 /* compute each zone */
653 for (zptr = zone_list; zptr != NULL; zptr = zptr->next) {
654 SUBPROC rcproc;
655 /* start rcontrib process */
656 if (!start_rcontrib(&rcproc, zptr))
657 return(0);
658 /* compute+add view factors */
659 if (!compute_uvfs(&rcproc, zptr))
660 return(0);
661 if (close_process(&rcproc) != 0) {
662 fputs(progname, stderr);
663 fputs(": bad return status from rcontrib\n", stderr);
664 return(0);
665 }
666 }
667 unlink(temp_octree); /* remove octree file */
668 return(1);
669 }
670
671 /* Load IDF and compute User View Factors */
672 int
673 main(int argc, char *argv[])
674 {
675 int incl_comments = 1;
676 char *origIDF, *revIDF;
677 IDF_OBJECT *pptr;
678 int i;
679
680 progname = *argv++; argc--; /* get options if any */
681 while (argc > 1 && argv[0][0] == '-')
682 switch (argv[0][1]) {
683 case 'c': /* elide comments */
684 incl_comments = -1; /* header only */
685 argv++; argc--;
686 continue;
687 case 's': /* samples */
688 nsamps = 1000*atoi(*++argv);
689 argv++; argc -= 2;
690 continue;
691 default:
692 fputs(progname, stderr);
693 fputs(": unknown option '", stderr);
694 fputs(argv[0], stderr);
695 fputs("'\n", stderr);
696 goto userr;
697 }
698 if ((argc < 1) | (argc > 2))
699 goto userr;
700 origIDF = argv[0];
701 revIDF = (argc == 1) ? argv[0] : argv[1];
702 /* load Input Data File */
703 our_idf = idf_load(origIDF);
704 if (our_idf == NULL) {
705 fputs(progname, stderr);
706 fputs(": cannot load IDF '", stderr);
707 fputs(origIDF, stderr);
708 fputs("'\n", stderr);
709 return(1);
710 }
711 /* remove existing UVFs */
712 if ((pptr = idf_getobject(our_idf, UVF_PNAME)) != NULL) {
713 IDF_OBJECT *pnext;
714 fputs(progname, stderr);
715 fputs(": removing previous User View Factors\n", stderr);
716 do {
717 pnext = pptr->pnext;
718 idf_delobject(our_idf, pptr);
719 } while (pnext != NULL);
720 }
721 /* add to header */
722 if (our_idf->hrem == NULL ||
723 (i = strlen(our_idf->hrem)-strlen(ADD_HEADER)) < 0 ||
724 strcmp(our_idf->hrem+i, ADD_HEADER))
725 idf_add2hdr(our_idf, ADD_HEADER);
726 /* gather zone surfaces */
727 for (i = 0; surf_type[i].pname != NULL; i++)
728 for (pptr = idf_getobject(our_idf, surf_type[i].pname);
729 pptr != NULL; pptr = pptr->pnext) {
730 IDF_FIELD *fptr = idf_getfield(pptr,
731 surf_type[i].zone_fld);
732 if (fptr == NULL) {
733 fputs(progname, stderr);
734 fputs(": warning - missing zone field\n", stderr);
735 continue;
736 }
737 if (add2zone(pptr, fptr->val) == NULL)
738 return(1);
739 }
740 /* add subsurfaces */
741 for (pptr = idf_getobject(our_idf, SUBSURF_PNAME);
742 pptr != NULL; pptr = pptr->pnext)
743 if (add_subsurf(pptr) == NULL)
744 return(1);
745 /* run rcontrib on each zone */
746 if (!compute_zones())
747 return(1);
748 /* write out modified IDF */
749 if (!idf_write(our_idf, revIDF, incl_comments)) {
750 fputs(progname, stderr);
751 fputs(": error writing IDF '", stderr);
752 fputs(revIDF, stderr);
753 fputs("'\n", stderr);
754 return(1);
755 }
756 return(0); /* finito! */
757 userr:
758 fputs("Usage: ", stderr);
759 fputs(progname, stderr);
760 fputs(" [-c][-s Ksamps] Model.idf [Revised.idf]\n", stderr);
761 return(1);
762 }
