1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.11 2014/02/15 01:31:36 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Add User View Factors to EnergyPlus Input Data File |
6 |
7 |
* G.Ward for LBNL |
8 |
9 |
10 |
#include <stdlib.h> |
11 |
#include "rtio.h" |
12 |
#include "rtmath.h" |
13 |
#include "random.h" |
14 |
#include "eplus_idf.h" |
15 |
#include "triangulate.h" |
16 |
#include "rtprocess.h" |
17 |
18 |
#ifndef NSAMPLES |
19 |
#define NSAMPLES 80000 /* default number of samples */ |
20 |
#endif |
21 |
22 |
#define SURF_EPS 0.0005 /* surface testing epsilon */ |
23 |
24 |
char *progname; /* global argv[0] */ |
25 |
26 |
int nsamps = NSAMPLES; /* number of samples to use */ |
27 |
28 |
char temp_octree[128]; /* temporary octree */ |
29 |
30 |
const char UVF_PNAME[] = |
31 |
"ZoneProperty:UserViewFactors:bySurfaceName"; |
32 |
33 |
const char SUBSURF_PNAME[] = |
34 |
"FenestrationSurface:Detailed"; |
35 |
36 |
const char ADD_HEADER[] = |
37 |
"\n!+++ User View Factors computed by Radiance +++!\n\n"; |
38 |
39 |
#define NAME_FLD 1 /* name field always first? */ |
40 |
41 |
#define SS_BASE_FLD 4 /* subsurface base surface */ |
42 |
#define SS_VERT_FLD 10 /* subsurface vertex count */ |
43 |
44 |
typedef struct { |
45 |
const char *pname; /* object type name */ |
46 |
short zone_fld; /* zone field index */ |
47 |
short vert_fld; /* vertex field index */ |
48 |
} SURF_PTYPE; /* surface type we're interested in */ |
49 |
50 |
const SURF_PTYPE surf_type[] = { |
51 |
{"BuildingSurface:Detailed", 4, 10}, |
52 |
{"Floor:Detailed", 3, 9}, |
53 |
{"RoofCeiling:Detailed", 3, 9}, |
54 |
{"Wall:Detailed", 3, 9}, |
55 |
{NULL} |
56 |
}; /* IDF surface types */ |
57 |
58 |
typedef struct s_zone { |
59 |
const char *zname; /* zone name */ |
60 |
struct s_zone *next; /* next zone in list */ |
61 |
int nsurf; /* surface count */ |
62 |
int ntotal; /* surfaces+subsurfaces */ |
63 |
IDF_OBJECT *pfirst; /* first matching object */ |
64 |
IDF_OBJECT *plast; /* last before subsurfaces */ |
65 |
float *area_redu; /* subsurface area per surf. */ |
66 |
} ZONE; /* a list of collected zone surfaces */ |
67 |
68 |
ZONE *zone_list = NULL; /* our list of zones */ |
69 |
70 |
LUTAB zonesurf_lut = /* zone surface lookup table */ |
71 |
LU_SINIT(NULL,NULL); |
72 |
73 |
IDF_LOADED *our_idf = NULL; /* loaded/modified IDF */ |
74 |
75 |
typedef struct { |
76 |
FVECT norm; /* surface normal */ |
77 |
double area; /* surface area */ |
78 |
int nv; /* number of vertices */ |
79 |
FVECT vl[3]; /* vertex list (extends struct) */ |
80 |
} SURFACE; /* a polygonal surface */ |
81 |
82 |
typedef struct { |
83 |
FVECT sdir[3]; /* UVW unit sampling vectors */ |
84 |
double poff; /* W-offset for plane of polygon */ |
85 |
double area_left; /* area left to sample */ |
86 |
int samp_left; /* remaining samples */ |
87 |
int wd; /* output file descriptor */ |
88 |
} POLYSAMP; /* structure for polygon sampling */ |
89 |
90 |
/* Create a new zone and push to top of our list */ |
91 |
static ZONE * |
92 |
new_zone(const char *zname, IDF_OBJECT *param) |
93 |
94 |
ZONE *znew = (ZONE *)malloc(sizeof(ZONE)); |
95 |
96 |
if (znew == NULL) |
97 |
return(NULL); |
98 |
znew->zname = zname; /* assumes static */ |
99 |
znew->next = zone_list; |
100 |
znew->pfirst = znew->plast = param; |
101 |
znew->ntotal = znew->nsurf = 1; |
102 |
znew->area_redu = NULL; |
103 |
return(zone_list = znew); |
104 |
105 |
106 |
/* Add the detailed surface (polygon) to the named zone */ |
107 |
static ZONE * |
108 |
add2zone(IDF_OBJECT *param, const char *zname) |
109 |
110 |
IDF_FIELD *nfp = idf_getfield(param, NAME_FLD); |
111 |
ZONE *zptr; |
112 |
LUENT *lep; |
113 |
114 |
if (nfp == NULL) { |
115 |
fputs(progname, stderr); |
116 |
fputs(": surface missing name field!\n", stderr); |
117 |
return(NULL); |
118 |
119 |
for (zptr = zone_list; zptr != NULL; zptr = zptr->next) |
120 |
if (!strcmp(zptr->zname, zname)) |
121 |
break; |
122 |
if (zptr == NULL) { |
123 |
zptr = new_zone(zname, param); |
124 |
} else { /* keep surfaces together */ |
125 |
if (!idf_movobject(our_idf, param, zptr->plast)) |
126 |
return(NULL); |
127 |
zptr->plast = param; |
128 |
zptr->nsurf++; |
129 |
zptr->ntotal++; |
130 |
131 |
/* add to lookup table */ |
132 |
lep = lu_find(&zonesurf_lut, nfp->val); |
133 |
if (lep == NULL) |
134 |
return(NULL); |
135 |
if (lep->data != NULL) { |
136 |
137 |
fputs(": duplicate surface name '", stderr); |
138 |
fputs(nfp->val, stderr); |
139 |
fputs("'\n", stderr); |
140 |
return(NULL); |
141 |
142 |
lep->key = nfp->val; |
143 |
lep->data = (char *)zptr; |
144 |
return(zptr); |
145 |
146 |
147 |
/* Add a subsurface by finding its base surface and the corresponding zone */ |
148 |
static ZONE * |
149 |
add_subsurf(IDF_OBJECT *param) |
150 |
151 |
IDF_FIELD *bfp = idf_getfield(param, SS_BASE_FLD); |
152 |
ZONE *zptr; |
153 |
LUENT *lep; |
154 |
155 |
if (bfp == NULL) { |
156 |
157 |
fputs(": missing base field name in subsurface!\n", stderr); |
158 |
return(NULL); |
159 |
160 |
lep = lu_find(&zonesurf_lut, bfp->val); /* find base zone */ |
161 |
if (lep == NULL || lep->data == NULL) { |
162 |
163 |
fputs(": cannot find referenced base surface '", stderr); |
164 |
fputs(bfp->val, stderr); |
165 |
166 |
return(NULL); |
167 |
168 |
zptr = (ZONE *)lep->data; /* add this subsurface */ |
169 |
170 |
return(NULL); |
171 |
zptr->ntotal++; |
172 |
return(zptr); |
173 |
174 |
175 |
/* Return field for vertices in the given object */ |
176 |
static IDF_FIELD * |
177 |
get_vlist(IDF_OBJECT *param, const char *zname) |
178 |
179 |
int i = 0; |
180 |
/* check if subsurface */ |
181 |
if (!strcmp(param->pname, SUBSURF_PNAME)) { |
182 |
if (zname != NULL) { |
183 |
LUENT *lep = lu_find(&zonesurf_lut, |
184 |
idf_getfield(param,SS_BASE_FLD)->val); |
185 |
if (strcmp((*(ZONE *)lep->data).zname, zname)) |
186 |
return(NULL); |
187 |
188 |
return(idf_getfield(param, SS_VERT_FLD)); |
189 |
190 |
/* check for surface type */ |
191 |
while (strcmp(surf_type[i].pname, param->pname)) |
192 |
if (surf_type[++i].pname == NULL) |
193 |
return(NULL); |
194 |
195 |
if (zname != NULL) { /* matches specified zone? */ |
196 |
IDF_FIELD *fptr = idf_getfield(param, surf_type[i].zone_fld); |
197 |
if (fptr == NULL || strcmp(fptr->val, zname)) |
198 |
return(NULL); |
199 |
200 |
/* return field for #verts */ |
201 |
return(idf_getfield(param, surf_type[i].vert_fld)); |
202 |
203 |
204 |
/* Get/allocate surface polygon */ |
205 |
static SURFACE * |
206 |
get_surface(IDF_FIELD *fptr) |
207 |
208 |
SURFACE *surf; |
209 |
int nv; |
210 |
FVECT e1, e2, vc; |
211 |
int i, j; |
212 |
/* get number of vertices */ |
213 |
if (fptr == NULL || (nv = atoi(fptr->val)) < 3) { |
214 |
215 |
fputs(": bad vertex count for surface!\n", stderr); |
216 |
return(NULL); |
217 |
218 |
surf = (SURFACE *)malloc(sizeof(SURFACE)+sizeof(FVECT)*(nv-3)); |
219 |
if (surf == NULL) |
220 |
return(NULL); |
221 |
surf->nv = nv; |
222 |
for (i = nv; i--; ) /* reverse vertex order/orientation */ |
223 |
for (j = 0; j < 3; j++) { |
224 |
fptr = fptr->next; |
225 |
if (fptr == NULL) { |
226 |
227 |
fputs(": missing vertex in get_surface()\n", stderr); |
228 |
free(surf); |
229 |
return(NULL); |
230 |
231 |
if ((surf->vl[i][j] = atof(fptr->val)) == 0 && |
232 |
!isflt(fptr->val)) { |
233 |
234 |
fputs(": bad vertex in get_surface()\n", stderr); |
235 |
free(surf); |
236 |
return(NULL); |
237 |
238 |
239 |
/* compute area and normal */ |
240 |
surf->norm[0] = surf->norm[1] = surf->norm[2] = 0; |
241 |
VSUB(e1, surf->vl[1], surf->vl[0]); |
242 |
for (i = 2; i < nv; i++) { |
243 |
VSUB(e2, surf->vl[i], surf->vl[0]); |
244 |
fcross(vc, e1, e2); |
245 |
surf->norm[0] += vc[0]; |
246 |
surf->norm[1] += vc[1]; |
247 |
surf->norm[2] += vc[2]; |
248 |
VCOPY(e1, e2); |
249 |
250 |
surf->area = .5 * normalize(surf->norm); |
251 |
if (surf->area == 0) { |
252 |
253 |
fputs(": degenerate polygon in get_surface()\n", stderr); |
254 |
free(surf); |
255 |
return(NULL); |
256 |
257 |
return(surf); |
258 |
259 |
260 |
/* Convert surface to Radiance with modifier based on unique name */ |
261 |
static int |
262 |
rad_surface(IDF_OBJECT *param, FILE *ofp) |
263 |
264 |
const char *sname = idf_getfield(param,NAME_FLD)->val; |
265 |
IDF_FIELD *fptr = get_vlist(param, NULL); |
266 |
const char **fargs; |
267 |
int nvert, i, j; |
268 |
269 |
if (fptr == NULL || (nvert = atoi(fptr->val)) < 3) { |
270 |
fprintf(stderr, "%s: bad surface '%s'\n", progname, sname); |
271 |
return(0); |
272 |
273 |
fargs = (const char **)malloc(sizeof(const char *)*3*nvert); |
274 |
if (fargs == NULL) |
275 |
return(0); |
276 |
fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname); |
277 |
fprintf(ofp, "\n'%s' polygon 's_%s'\n0\n0\n%d\n", sname, sname, 3*nvert); |
278 |
for (j = nvert; j--; ) { /* get arguments in reverse */ |
279 |
for (i = 0; i < 3; i++) { |
280 |
281 |
if (fptr == NULL || !isflt(fptr->val)) { |
282 |
fprintf(stderr, |
283 |
"%s: missing/bad vertex for %s '%s'\n", |
284 |
progname, param->pname, sname); |
285 |
return(0); |
286 |
287 |
fargs[3*j + i] = fptr->val; |
288 |
289 |
290 |
for (j = 0; j < nvert; j++) { /* output reversed verts */ |
291 |
292 |
fputc('\t', ofp); |
293 |
fputs(fargs[3*j + i], ofp); |
294 |
295 |
fputc('\n', ofp); |
296 |
297 |
free(fargs); |
298 |
return(!ferror(ofp)); |
299 |
300 |
301 |
/* Convert subsurface to Radiance with modifier based on unique name */ |
302 |
static double |
303 |
rad_subsurface(IDF_OBJECT *param, FILE *ofp) |
304 |
305 |
306 |
SURFACE *surf = get_surface(idf_getfield(param,SS_VERT_FLD)); |
307 |
double area; |
308 |
int i; |
309 |
310 |
if (surf == NULL) { |
311 |
fprintf(stderr, "%s: bad subsurface '%s'\n", progname, sname); |
312 |
return(-1.); |
313 |
314 |
315 |
fprintf(ofp, "\n'%s' polygon 'ss_%s'\n0\n0\n%d\n", |
316 |
sname, sname, 3*surf->nv); |
317 |
for (i = 0; i < surf->nv; i++) { /* offset vertices */ |
318 |
FVECT vert; |
319 |
VSUM(vert, surf->vl[i], surf->norm, 2.*SURF_EPS); |
320 |
fprintf(ofp, "\t%.12f %.12f %.12f\n", vert[0], vert[1], vert[2]); |
321 |
322 |
area = surf->area; |
323 |
free(surf); |
324 |
if (ferror(ofp)) |
325 |
return(-1.); |
326 |
return(area); |
327 |
328 |
329 |
/* Start rcontrib process */ |
330 |
static int |
331 |
start_rcontrib(SUBPROC *pd, ZONE *zp) |
332 |
333 |
#define BASE_AC 6 |
334 |
static char *base_av[BASE_AC] = { |
335 |
"rcontrib", "-V+", "-fff", "-h", "-x", "1" |
336 |
337 |
char cbuf[300]; |
338 |
char **av; |
339 |
FILE *ofp; |
340 |
IDF_OBJECT *pptr; |
341 |
IDF_FIELD *fptr; |
342 |
int i, j, n; |
343 |
/* start oconv command */ |
344 |
sprintf(cbuf, "oconv - > '%s'", temp_octree); |
345 |
if ((ofp = popen(cbuf, "w")) == NULL) { |
346 |
347 |
fputs(": cannot open oconv process\n", stderr); |
348 |
return(0); |
349 |
350 |
/* allocate argument list */ |
351 |
av = (char **)malloc(sizeof(char *)*(BASE_AC+4+2*(zp->ntotal))); |
352 |
if (av == NULL) |
353 |
return(0); |
354 |
for (i = 0; i < BASE_AC; i++) |
355 |
av[i] = base_av[i]; |
356 |
sprintf(cbuf, "%d", nsamps); |
357 |
av[i++] = "-c"; |
358 |
av[i++] = cbuf; /* add modifiers & surfaces */ |
359 |
for (n = 0, pptr = zp->pfirst; n < zp->nsurf; n++, pptr = pptr->dnext) { |
360 |
fptr = idf_getfield(pptr,NAME_FLD); |
361 |
if (fptr == NULL || !fptr->val[0]) { |
362 |
363 |
fputs(": missing name for surface object\n", stderr); |
364 |
return(0); |
365 |
366 |
if (!rad_surface(pptr, ofp)) /* add surface to octree */ |
367 |
return(0); |
368 |
av[i++] = "-m"; |
369 |
av[i++] = fptr->val; |
370 |
371 |
/* now subsurfaces */ |
372 |
if (zp->ntotal > zp->nsurf) { |
373 |
if (zp->area_redu != NULL) |
374 |
memset(zp->area_redu, 0, sizeof(float)*zp->nsurf); |
375 |
else if ((zp->area_redu = (float *)calloc(zp->nsurf, |
376 |
sizeof(float))) == NULL) |
377 |
return(0); |
378 |
379 |
for ( ; n < zp->ntotal; n++, pptr = pptr->dnext) { |
380 |
double ssarea; |
381 |
const char *bname; |
382 |
IDF_OBJECT *pptr1; |
383 |
384 |
385 |
386 |
fputs(": missing name for subsurface object\n", stderr); |
387 |
return(0); |
388 |
389 |
/* add subsurface to octree */ |
390 |
if ((ssarea = rad_subsurface(pptr, ofp)) < 0) |
391 |
return(0); |
392 |
/* mark area for subtraction */ |
393 |
bname = idf_getfield(pptr,SS_BASE_FLD)->val; |
394 |
for (j = 0, pptr1 = zp->pfirst; |
395 |
j < zp->nsurf; j++, pptr1 = pptr1->dnext) |
396 |
if (!strcmp(idf_getfield(pptr1,NAME_FLD)->val, bname)) { |
397 |
zp->area_redu[j] += ssarea; |
398 |
break; |
399 |
400 |
av[i++] = "-m"; |
401 |
402 |
403 |
if (pclose(ofp) != 0) { /* finish oconv */ |
404 |
405 |
fputs(": error running oconv process\n", stderr); |
406 |
return(0); |
407 |
408 |
av[i++] = temp_octree; /* add final octree argument */ |
409 |
av[i] = NULL; |
410 |
if (open_process(pd, av) <= 0) { /* start process */ |
411 |
412 |
fputs(": cannot start rcontrib process\n", stderr); |
413 |
return(0); |
414 |
415 |
free(av); /* all done -- clean up */ |
416 |
return(1); |
417 |
#undef BASE_AC |
418 |
419 |
420 |
/* Initialize polygon sampling */ |
421 |
static Vert2_list * |
422 |
init_poly(POLYSAMP *ps, IDF_FIELD *f0) |
423 |
424 |
SURFACE *surf; |
425 |
Vert2_list *vl2; |
426 |
int i; |
427 |
/* get 3-D polygon vertices */ |
428 |
if ((surf = get_surface(f0)) == NULL) |
429 |
return(NULL); |
430 |
vl2 = polyAlloc(surf->nv); |
431 |
if (vl2 == NULL) |
432 |
return(NULL); |
433 |
/* create X & Y axes */ |
434 |
VCOPY(ps->sdir[2], surf->norm); |
435 |
VSUB(ps->sdir[0], surf->vl[1], surf->vl[0]); |
436 |
if (normalize(ps->sdir[0]) == 0) |
437 |
return(NULL); |
438 |
fcross(ps->sdir[1], ps->sdir[2], ps->sdir[0]); |
439 |
/* compute plane offset */ |
440 |
ps->poff = DOT(surf->vl[0], ps->sdir[2]); |
441 |
/* assign 2-D vertices */ |
442 |
for (i = 0; i < surf->nv; i++) { |
443 |
vl2->v[i].mX = DOT(surf->vl[i], ps->sdir[0]); |
444 |
vl2->v[i].mY = DOT(surf->vl[i], ps->sdir[1]); |
445 |
446 |
ps->area_left = surf->area; |
447 |
free(surf); /* it's ready! */ |
448 |
vl2->p = (void *)ps; |
449 |
return(vl2); |
450 |
451 |
452 |
/* Generate samples on 2-D triangle */ |
453 |
static int |
454 |
sample_triangle(const Vert2_list *vl2, int a, int b, int c) |
455 |
456 |
POLYSAMP *ps = (POLYSAMP *)vl2->p; |
457 |
float *samp; |
458 |
FVECT orig; |
459 |
FVECT ab, ac; |
460 |
double area; |
461 |
int i, j, ns; |
462 |
/* compute sampling axes */ |
463 |
for (i = 3; i--; ) { |
464 |
orig[i] = vl2->v[a].mX*ps->sdir[0][i] + |
465 |
vl2->v[a].mY*ps->sdir[1][i] + |
466 |
(ps->poff+SURF_EPS)*ps->sdir[2][i]; |
467 |
ab[i] = (vl2->v[b].mX - vl2->v[a].mX)*ps->sdir[0][i] + |
468 |
(vl2->v[b].mY - vl2->v[a].mY)*ps->sdir[1][i]; |
469 |
ac[i] = (vl2->v[c].mX - vl2->v[a].mX)*ps->sdir[0][i] + |
470 |
(vl2->v[c].mY - vl2->v[a].mY)*ps->sdir[1][i]; |
471 |
472 |
/* compute number of samples to take */ |
473 |
area = .5*(vl2->v[a].mX*vl2->v[b].mY - vl2->v[b].mX*vl2->v[a].mY + |
474 |
vl2->v[b].mX*vl2->v[c].mY - vl2->v[c].mX*vl2->v[b].mY + |
475 |
vl2->v[c].mX*vl2->v[a].mY - vl2->v[a].mX*vl2->v[c].mY); |
476 |
if (area < .0) { |
477 |
478 |
fputs(": negative triangle area in sample_triangle()\n", stderr); |
479 |
return(0); |
480 |
481 |
if (area >= ps->area_left) { |
482 |
ns = ps->samp_left; |
483 |
ps->area_left = 0; |
484 |
} else { |
485 |
ns = (ps->samp_left*area/ps->area_left + .5); |
486 |
ps->samp_left -= ns; |
487 |
ps->area_left -= area; |
488 |
489 |
if (ns <= 0) /* XXX should be error? */ |
490 |
return(1); |
491 |
/* buffer sample rays */ |
492 |
samp = (float *)malloc(sizeof(float)*6*ns); |
493 |
if (samp == NULL) |
494 |
return(0); |
495 |
for (i = ns; i--; ) { /* stratified Monte Carlo sampling */ |
496 |
double sv[4]; |
497 |
FVECT dv; |
498 |
multisamp(sv, 4, (i+frandom())/(double)ns); |
499 |
sv[0] *= sv[1] = sqrt(sv[1]); |
500 |
sv[1] = 1. - sv[1]; |
501 |
for (j = 3; j--; ) |
502 |
samp[i*6 + j] = orig[j] + sv[0]*ab[j] + sv[1]*ac[j]; |
503 |
sv[2] = sqrt(sv[2]); |
504 |
sv[3] *= 2.*PI; |
505 |
dv[0] = tcos(sv[3]) * sv[2]; |
506 |
dv[1] = tsin(sv[3]) * sv[2]; |
507 |
dv[2] = sqrt(1. - sv[2]*sv[2]); |
508 |
509 |
samp[i*6 + 3 + j] = dv[0]*ps->sdir[0][j] + |
510 |
dv[1]*ps->sdir[1][j] + |
511 |
dv[2]*ps->sdir[2][j] ; |
512 |
513 |
/* send to our process */ |
514 |
writebuf(ps->wd, (char *)samp, sizeof(float)*6*ns); |
515 |
free(samp); /* that's it! */ |
516 |
return(1); |
517 |
518 |
519 |
/* Sample the given surface */ |
520 |
static double |
521 |
sample_surface(IDF_OBJECT *param, int wd) |
522 |
523 |
POLYSAMP psamp; |
524 |
double area; |
525 |
int nv; |
526 |
Vert2_list *vlist2; |
527 |
/* set up our polygon sampler */ |
528 |
if ((vlist2 = init_poly(&psamp, get_vlist(param, NULL))) == NULL) { |
529 |
fprintf(stderr, "%s: bad polygon %s '%s'\n", |
530 |
progname, param->pname, |
531 |
idf_getfield(param,NAME_FLD)->val); |
532 |
return(-1.); |
533 |
534 |
psamp.samp_left = nsamps; /* assign samples & destination */ |
535 |
psamp.wd = wd; |
536 |
/* hack for subsurface sampling */ |
537 |
psamp.poff += 2.*SURF_EPS * !strcmp(param->pname, SUBSURF_PNAME); |
538 |
539 |
area = psamp.area_left; /* remember starting surface area */ |
540 |
/* sample each subtriangle */ |
541 |
if (!polyTriangulate(vlist2, &sample_triangle)) |
542 |
return(-1.); |
543 |
polyFree(vlist2); /* clean up and return */ |
544 |
return(area); |
545 |
546 |
547 |
/* Compute User View Factors using open rcontrib process */ |
548 |
static int |
549 |
compute_uvfs(SUBPROC *pd, ZONE *zp) |
550 |
551 |
IDF_OBJECT *pptr, *pout, *pptr1; |
552 |
float *uvfa; |
553 |
char uvfbuf[24]; |
554 |
int n, m; |
555 |
/* create output object */ |
556 |
pout = idf_newobject(our_idf, UVF_PNAME, |
557 |
" ! computed by Radiance\n ", our_idf->plast); |
558 |
if (pout == NULL) { |
559 |
560 |
fputs(": cannot create new IDF object\n", stderr); |
561 |
return(0); |
562 |
563 |
if (!idf_addfield(pout, zp->zname, |
564 |
" !- Zone Name\n ")) { |
565 |
566 |
fputs(": cannot add zone name field\n", stderr); |
567 |
return(0); |
568 |
569 |
/* allocate read buffer */ |
570 |
uvfa = (float *)malloc(sizeof(float)*3*zp->ntotal); |
571 |
if (uvfa == NULL) |
572 |
return(0); |
573 |
/* UVFs from each surface */ |
574 |
for (n = 0, pptr = zp->pfirst; n < zp->ntotal; n++, pptr = pptr->dnext) { |
575 |
double vfsum = 0; |
576 |
double adj_factor; |
577 |
/* send samples to rcontrib */ |
578 |
if ((adj_factor = sample_surface(pptr, pd->w)) < 0) |
579 |
return(0); |
580 |
if (zp->area_redu == NULL) |
581 |
adj_factor = 1.; |
582 |
else /* comp. for subsurface area */ |
583 |
adj_factor /= adj_factor - zp->area_redu[n]; |
584 |
/* read results */ |
585 |
if (readbuf(pd->r, (char *)uvfa, sizeof(float)*3*zp->ntotal) != |
586 |
sizeof(float)*3*zp->ntotal) { |
587 |
588 |
fputs(": read error from rcontrib process\n", stderr); |
589 |
return(0); |
590 |
591 |
/* append UVF fields */ |
592 |
for (m = 0, pptr1 = zp->pfirst; |
593 |
m < zp->ntotal; m++, pptr1 = pptr1->dnext) { |
594 |
const double uvf = uvfa[3*m + 1] * adj_factor; |
595 |
vfsum += uvf; |
596 |
if (pptr1 == pptr && uvf > .001) |
597 |
fprintf(stderr, |
598 |
"%s: warning - non-zero self-VF (%.1f%%) for surface '%s'\n", |
599 |
progname, 100.*uvf, |
600 |
idf_getfield(pptr,NAME_FLD)->val); |
601 |
sprintf(uvfbuf, "%.4f", uvf); |
602 |
if (!idf_addfield(pout, |
603 |
idf_getfield(pptr,NAME_FLD)->val, NULL) || |
604 |
605 |
idf_getfield(pptr1,NAME_FLD)->val, NULL) || |
606 |
!idf_addfield(pout, uvfbuf, |
607 |
(n+m < 2*zp->ntotal-2) ? |
608 |
"\n " : "\n\n")) { |
609 |
610 |
fputs(": error adding UVF fields\n", stderr); |
611 |
return(0); |
612 |
613 |
614 |
if (vfsum < 0.95) |
615 |
fprintf(stderr, |
616 |
"%s: warning - missing %.1f%% of energy from surface '%s'\n", |
617 |
progname, 100.*(1.-vfsum), |
618 |
619 |
620 |
free(uvfa); /* clean up and return */ |
621 |
return(1); |
622 |
623 |
624 |
/* Compute zone User View Factors */ |
625 |
static int |
626 |
compute_zones(void) |
627 |
628 |
ZONE *zptr; |
629 |
/* temporary octree name */ |
630 |
mktemp(strcpy(temp_octree, TEMPLATE)); |
631 |
/* compute each zone */ |
632 |
for (zptr = zone_list; zptr != NULL; zptr = zptr->next) { |
633 |
SUBPROC rcproc; |
634 |
/* start rcontrib process */ |
635 |
if (!start_rcontrib(&rcproc, zptr)) |
636 |
return(0); |
637 |
/* compute+add view factors */ |
638 |
if (!compute_uvfs(&rcproc, zptr)) |
639 |
return(0); |
640 |
if (close_process(&rcproc) != 0) { |
641 |
642 |
fputs(": bad return status from rcontrib\n", stderr); |
643 |
return(0); |
644 |
645 |
646 |
unlink(temp_octree); /* remove octree file */ |
647 |
return(1); |
648 |
649 |
650 |
/* Load IDF and compute User View Factors */ |
651 |
int |
652 |
main(int argc, char *argv[]) |
653 |
654 |
int incl_comments = 1; |
655 |
char *origIDF, *revIDF; |
656 |
IDF_OBJECT *pptr; |
657 |
int i; |
658 |
659 |
progname = *argv++; argc--; /* get options if any */ |
660 |
while (argc > 1 && argv[0][0] == '-') |
661 |
switch (argv[0][1]) { |
662 |
case 'c': /* elide comments */ |
663 |
incl_comments = -1; /* header only */ |
664 |
argv++; argc--; |
665 |
continue; |
666 |
case 's': /* samples */ |
667 |
nsamps = 1000*atoi(*++argv); |
668 |
argv++; argc -= 2; |
669 |
continue; |
670 |
default: |
671 |
672 |
fputs(": unknown option '", stderr); |
673 |
fputs(argv[0], stderr); |
674 |
675 |
goto userr; |
676 |
677 |
if ((argc < 1) | (argc > 2)) |
678 |
goto userr; |
679 |
origIDF = argv[0]; |
680 |
revIDF = (argc == 1) ? argv[0] : argv[1]; |
681 |
/* load Input Data File */ |
682 |
our_idf = idf_load(origIDF); |
683 |
if (our_idf == NULL) { |
684 |
685 |
fputs(": cannot load IDF '", stderr); |
686 |
fputs(origIDF, stderr); |
687 |
688 |
return(1); |
689 |
690 |
/* remove existing UVFs */ |
691 |
if ((pptr = idf_getobject(our_idf, UVF_PNAME)) != NULL) { |
692 |
IDF_OBJECT *pnext; |
693 |
694 |
fputs(": removing previous User View Factors\n", stderr); |
695 |
do { |
696 |
pnext = pptr->pnext; |
697 |
idf_delobject(our_idf, pptr); |
698 |
} while (pnext != NULL); |
699 |
700 |
/* add to header */ |
701 |
if (our_idf->hrem == NULL || |
702 |
(i = strlen(our_idf->hrem)-strlen(ADD_HEADER)) < 0 || |
703 |
strcmp(our_idf->hrem+i, ADD_HEADER)) |
704 |
idf_add2hdr(our_idf, ADD_HEADER); |
705 |
/* gather zone surfaces */ |
706 |
for (i = 0; surf_type[i].pname != NULL; i++) |
707 |
for (pptr = idf_getobject(our_idf, surf_type[i].pname); |
708 |
pptr != NULL; pptr = pptr->pnext) { |
709 |
IDF_FIELD *fptr = idf_getfield(pptr, |
710 |
711 |
712 |
713 |
fputs(": warning - missing zone field\n", stderr); |
714 |
continue; |
715 |
716 |
if (add2zone(pptr, fptr->val) == NULL) |
717 |
return(1); |
718 |
719 |
/* add subsurfaces */ |
720 |
for (pptr = idf_getobject(our_idf, SUBSURF_PNAME); |
721 |
pptr != NULL; pptr = pptr->pnext) |
722 |
if (add_subsurf(pptr) == NULL) |
723 |
return(1); |
724 |
/* run rcontrib on each zone */ |
725 |
if (!compute_zones()) |
726 |
return(1); |
727 |
/* write out modified IDF */ |
728 |
if (!idf_write(our_idf, revIDF, incl_comments)) { |
729 |
730 |
fputs(": error writing IDF '", stderr); |
731 |
fputs(revIDF, stderr); |
732 |
733 |
return(1); |
734 |
735 |
return(0); /* finito! */ |
736 |
userr: |
737 |
fputs("Usage: ", stderr); |
738 |
739 |
fputs(" [-c][-s Ksamps] Model.idf [Revised.idf]\n", stderr); |
740 |
return(1); |
741 |
