root/radiance/ray/src/util/eplus_adduvf.c
Revision: 2.1
Committed: Sun Feb 9 05:49:21 2014 UTC (10 years, 2 months ago) by greg
Unfinished implementation of EnergyPlus User View Factors calculation
5 * Add User View Factors to EnergyPlus Input Data File
6 *
7 * G.Ward for LBNL
8 */
9
10 #include <stdio.h>
11 #include <stdlib.h>
12 #include <string.h>
13 #include "eplus_idf.h"
14 #include "triangulate.h"
15
16 #ifndef NSAMPLES
17 #define NSAMPLES 100000 /* number of samples to use */
18 #endif
19
20 #define UVF_PNAME "ZoneProperty:UserViewFactor:bySurfaceName"
21
22 const char ADD_HEADER[] =
23 "!+++ User View Factors computed by Radiance +++!\n";
24
25 #define NAME_FLD 1 /* name field always first? */
26
27 typedef struct {
28 const char *pname; /* parameter type name */
29 short zone_fld; /* zone field index */
30 short vert_fld; /* vertex field index */
31 } SURF_PTYPE; /* surface type we're interested in */
32
33 const SURF_PTYPE surf_type[] = {
34 {"BuildingSurface:Detailed", 4, 10},
35 {NULL}
36 };
37
38 struct s_zone {
39 const char *zname; /* zone name */
40 struct s_zone *next; /* next zone in list */
41 IDF_PARAMETER *pfirst; /* first matching parameter */
42 IDF_PARAMETER *plast; /* last matching parameter */
43 } *zone_list = NULL;
44
45 IDF_LOADED *our_idf = NULL; /* loaded/modified IDF */
46
47 /* Create a new zone and push to top of our list */
48 static struct s_zone *
49 new_zone(const char *zname, IDF_PARAMETER *param)
50 {
51 struct s_zone *znew = (struct s_zone *)malloc(sizeof(struct s_zone));
52
53 if (znew == NULL)
54 return(NULL);
55 znew->zname = zname; /* assumes static */
56 znew->next = zone_list;
57 znew->pfirst = znew->plast = param;
58 return(zone_list = znew);
59 }
60
61 /* Add the detailed surface (polygon) to the named zone */
62 static struct s_zone *
63 add2zone(IDF_PARAMETER *param, const char *zname)
64 {
65 struct s_zone *zptr;
66
67 for (zptr = zone_list; zptr != NULL; zptr = zptr->next)
68 if (!strcmp(zptr->zname, zname))
69 break;
70 if (zptr == NULL)
71 return(new_zone(zname, param));
72 /* keep surfaces together */
73 if (!idf_movparam(our_idf, param, zptr->plast))
74 return(NULL);
75 zptr->plast = param;
76 return(zptr);
77 }
78
79 /* Compute zone User View Factors */
80 static int
81 compute_zones(void)
82 {
83 fputs("compute_zones() unimplemented\n", stderr);
84 return(0);
85 }
86
87 /* Load IDF and compute User View Factors */
88 int
89 main(int argc, char *argv[])
90 {
91 char *origIDF, *revIDF;
92 IDF_PARAMETER *pptr;
93 int i;
94
95 if ((argc < 2) | (argc > 3)) {
96 fputs("Usage: ", stderr);
97 fputs(argv[0], stderr);
98 fputs(" Model.idf [Revised.idf]\n", stderr);
99 return(1);
100 }
101 origIDF = argv[1];
102 revIDF = (argc == 2) ? argv[1] : argv[2];
103 /* load Input Data File */
104 our_idf = idf_load(origIDF);
105 if (our_idf == NULL) {
106 fputs(argv[0], stderr);
107 fputs(": cannot load IDF '", stderr);
108 fputs(origIDF, stderr);
109 fputs("'\n", stderr);
110 return(1);
111 }
112 /* remove existing UVFs */
113 if ((pptr = idf_getparam(our_idf, UVF_PNAME)) != NULL) {
114 IDF_PARAMETER *pnext;
115 fputs(argv[0], stderr);
116 fputs(": removing previous User View Factors\n", stderr);
117 do {
118 pnext = pptr->pnext;
119 idf_delparam(our_idf, pptr);
120 } while (pnext != NULL);
121 }
122 /* add to header */
123 if (our_idf->hrem == NULL ||
124 (i = strlen(our_idf->hrem)-strlen(ADD_HEADER)) < 0 ||
125 strcmp(our_idf->hrem+i, ADD_HEADER))
126 idf_add2hdr(our_idf, ADD_HEADER);
127 /* gather zone surfaces */
128 for (i = 0; surf_type[i].pname != NULL; i++)
129 for (pptr = idf_getparam(our_idf, surf_type[i].pname);
130 pptr != NULL; pptr = pptr->pnext) {
131 IDF_FIELD *fptr = idf_getfield(pptr,
132 surf_type[i].zone_fld);
133 if (fptr == NULL) {
134 fputs("Warning: missing zone field!\n", stderr);
135 continue;
136 }
137 if (add2zone(pptr, fptr->arg) == NULL)
138 return(1);
139 }
140 /* run rcontrib on each zone */
141 if (!compute_zones())
142 return(1);
143 /* write out modified IDF */
144 if (!idf_write(our_idf, revIDF, 1)) {
145 fputs(argv[0], stderr);
146 fputs(": error writing IDF '", stderr);
147 fputs(revIDF, stderr);
148 fputs("'\n", stderr);
149 return(1);
150 }
151 return(0); /* finito! */
152 }
