--- ray/src/util/eplus_adduvf.c 2014/02/11 23:44:11 2.7 +++ ray/src/util/eplus_adduvf.c 2014/02/12 17:40:07 2.9 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.7 2014/02/11 23:44:11 greg Exp $"; +static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.9 2014/02/12 17:40:07 greg Exp $"; #endif /* * Add User View Factors to EnergyPlus Input Data File @@ -34,7 +34,7 @@ const char ADD_HEADER[] = #define NAME_FLD 1 /* name field always first? */ typedef struct { - const char *pname; /* parameter type name */ + const char *pname; /* object type name */ short zone_fld; /* zone field index */ short vert_fld; /* vertex field index */ } SURF_PTYPE; /* surface type we're interested in */ @@ -51,8 +51,8 @@ typedef struct s_zone { const char *zname; /* zone name */ struct s_zone *next; /* next zone in list */ int nsurf; /* surface count */ - IDF_PARAMETER *pfirst; /* first matching parameter */ - IDF_PARAMETER *plast; /* last matching parameter */ + IDF_OBJECT *pfirst; /* first matching object */ + IDF_OBJECT *plast; /* last matching object */ } ZONE; /* a list of collected zone surfaces */ ZONE *zone_list = NULL; /* our list of zones */ @@ -69,7 +69,7 @@ typedef struct { /* Create a new zone and push to top of our list */ static ZONE * -new_zone(const char *zname, IDF_PARAMETER *param) +new_zone(const char *zname, IDF_OBJECT *param) { ZONE *znew = (ZONE *)malloc(sizeof(ZONE)); @@ -84,7 +84,7 @@ new_zone(const char *zname, IDF_PARAMETER *param) /* Add the detailed surface (polygon) to the named zone */ static ZONE * -add2zone(IDF_PARAMETER *param, const char *zname) +add2zone(IDF_OBJECT *param, const char *zname) { ZONE *zptr; @@ -94,16 +94,16 @@ add2zone(IDF_PARAMETER *param, const char *zname) if (zptr == NULL) return(new_zone(zname, param)); /* keep surfaces together */ - if (!idf_movparam(our_idf, param, zptr->plast)) + if (!idf_movobject(our_idf, param, zptr->plast)) return(NULL); zptr->plast = param; zptr->nsurf++; return(zptr); } -/* Return field for vertices in the given parameter */ +/* Return field for vertices in the given object */ static IDF_FIELD * -get_vlist(IDF_PARAMETER *param, const char *zname) +get_vlist(IDF_OBJECT *param, const char *zname) { int i = 0; IDF_FIELD *fptr; @@ -123,7 +123,7 @@ get_vlist(IDF_PARAMETER *param, const char *zname) /* Convert surface to Radiance with modifier based on unique name */ static int -rad_surface(IDF_PARAMETER *param, FILE *ofp) +rad_surface(IDF_OBJECT *param, FILE *ofp) { const char *sname = idf_getfield(param,NAME_FLD)->val; IDF_FIELD *fptr = get_vlist(param, NULL); @@ -158,12 +158,12 @@ start_rcontrib(SUBPROC *pd, ZONE *zp) { #define BASE_AC 5 static char *base_av[BASE_AC] = { - "rcontrib", "-ff", "-h", "-x", "1" + "rcontrib", "-fff", "-h", "-x", "1" }; char cbuf[300]; char **av; FILE *ofp; - IDF_PARAMETER *pptr; + IDF_OBJECT *pptr; int i, n; /* start oconv command */ sprintf(cbuf, "oconv - > '%s'", temp_octree); @@ -185,7 +185,7 @@ start_rcontrib(SUBPROC *pd, ZONE *zp) IDF_FIELD *fptr = idf_getfield(pptr,NAME_FLD); if (fptr == NULL || !fptr->val[0]) { fputs(progname, stderr); - fputs(": missing name for surface parameter\n", stderr); + fputs(": missing name for surface object\n", stderr); return(0); } if (!rad_surface(pptr, ofp)) /* add surface to octree */ @@ -200,7 +200,7 @@ start_rcontrib(SUBPROC *pd, ZONE *zp) } av[i++] = temp_octree; /* add final octree argument */ av[i] = NULL; - if (!open_process(pd, av)) { /* start process */ + if (open_process(pd, av) <= 0) { /* start process */ fputs(progname, stderr); fputs(": cannot start rcontrib process\n", stderr); return(0); @@ -337,7 +337,7 @@ sample_triangle(const Vert2_list *vl2, int a, int b, i /* Sample the given surface */ static int -sample_surface(IDF_PARAMETER *param, int wd) +sample_surface(IDF_OBJECT *param, int wd) { IDF_FIELD *fptr = get_vlist(param, NULL); POLYSAMP psamp; @@ -364,16 +364,16 @@ sample_surface(IDF_PARAMETER *param, int wd) static int compute_uvfs(SUBPROC *pd, ZONE *zp) { - IDF_PARAMETER *pptr, *pout, *pptr1; + IDF_OBJECT *pptr, *pout, *pptr1; float *uvfa; char uvfbuf[24]; int n, m; - /* create output parameter */ - pout = idf_newparam(our_idf, UVF_PNAME, + /* create output object */ + pout = idf_newobject(our_idf, UVF_PNAME, " ! computed by Radiance\n ", zp->plast); if (pout == NULL) { fputs(progname, stderr); - fputs(": cannot create new IDF parameter\n", stderr); + fputs(": cannot create new IDF object\n", stderr); return(0); } if (!idf_addfield(pout, zp->zname, @@ -466,7 +466,7 @@ main(int argc, char *argv[]) { int incl_comments = 1; char *origIDF, *revIDF; - IDF_PARAMETER *pptr; + IDF_OBJECT *pptr; int i; progname = *argv++; argc--; /* get options if any */ @@ -501,13 +501,13 @@ main(int argc, char *argv[]) return(1); } /* remove existing UVFs */ - if ((pptr = idf_getparam(our_idf, UVF_PNAME)) != NULL) { - IDF_PARAMETER *pnext; + if ((pptr = idf_getobject(our_idf, UVF_PNAME)) != NULL) { + IDF_OBJECT *pnext; fputs(progname, stderr); fputs(": removing previous User View Factors\n", stderr); do { pnext = pptr->pnext; - idf_delparam(our_idf, pptr); + idf_delobject(our_idf, pptr); } while (pnext != NULL); } /* add to header */ @@ -517,7 +517,7 @@ main(int argc, char *argv[]) idf_add2hdr(our_idf, ADD_HEADER); /* gather zone surfaces */ for (i = 0; surf_type[i].pname != NULL; i++) - for (pptr = idf_getparam(our_idf, surf_type[i].pname); + for (pptr = idf_getobject(our_idf, surf_type[i].pname); pptr != NULL; pptr = pptr->pnext) { IDF_FIELD *fptr = idf_getfield(pptr, surf_type[i].zone_fld);
