--- ray/src/util/eplus_adduvf.c 2014/02/11 22:01:44 2.6 +++ ray/src/util/eplus_adduvf.c 2014/02/12 00:12:38 2.8 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.6 2014/02/11 22:01:44 greg Exp $"; +static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.8 2014/02/12 00:12:38 greg Exp $"; #endif /* * Add User View Factors to EnergyPlus Input Data File @@ -16,11 +16,13 @@ static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.6 #include "rtprocess.h" #ifndef NSAMPLES -#define NSAMPLES 80000 /* number of samples to use */ +#define NSAMPLES 80000 /* default number of samples */ #endif char *progname; /* global argv[0] */ +int nsamps = NSAMPLES; /* number of samples to use */ + char temp_octree[128]; /* temporary octree */ const char UVF_PNAME[] = @@ -43,7 +45,7 @@ const SURF_PTYPE surf_type[] = { {"RoofCeiling:Detailed", 3, 9}, {"Wall:Detailed", 3, 9}, {NULL} - }; + }; /* IDF surface types */ typedef struct s_zone { const char *zname; /* zone name */ @@ -57,6 +59,14 @@ ZONE *zone_list = NULL; /* our list of zones */ IDF_LOADED *our_idf = NULL; /* loaded/modified IDF */ +typedef struct { + FVECT sdir[3]; /* UVW unit sampling vectors */ + double poff; /* W-offset for plane of polygon */ + double area_left; /* area left to sample */ + int samp_left; /* remaining samples */ + int wd; /* output file descriptor */ +} POLYSAMP; /* structure for polygon sampling */ + /* Create a new zone and push to top of our list */ static ZONE * new_zone(const char *zname, IDF_PARAMETER *param) @@ -148,7 +158,7 @@ start_rcontrib(SUBPROC *pd, ZONE *zp) { #define BASE_AC 5 static char *base_av[BASE_AC] = { - "rcontrib", "-ff", "-h", "-x", "1" + "rcontrib", "-fff", "-h", "-x", "1" }; char cbuf[300]; char **av; @@ -168,7 +178,7 @@ start_rcontrib(SUBPROC *pd, ZONE *zp) return(0); for (i = 0; i < BASE_AC; i++) av[i] = base_av[i]; - sprintf(cbuf, "%d", NSAMPLES); + sprintf(cbuf, "%d", nsamps); av[i++] = "-c"; av[i++] = cbuf; /* add modifier arguments */ for (n = zp->nsurf, pptr = zp->pfirst; n--; pptr = pptr->dnext) { @@ -190,7 +200,7 @@ start_rcontrib(SUBPROC *pd, ZONE *zp) } av[i++] = temp_octree; /* add final octree argument */ av[i] = NULL; - if (!open_process(pd, av)) { /* start process */ + if (open_process(pd, av) <= 0) { /* start process */ fputs(progname, stderr); fputs(": cannot start rcontrib process\n", stderr); return(0); @@ -200,14 +210,6 @@ start_rcontrib(SUBPROC *pd, ZONE *zp) #undef BASE_AC } -typedef struct { - FVECT sdir[3]; /* XYZ unit sampling vectors */ - double poff; /* Z-offset for plane of polygon */ - double area_left; /* area left to sample */ - int samp_left; /* remaining samples */ - int wd; /* output file descriptor */ -} POLYSAMP; /* structure for polygon sampling */ - /* Initialize polygon sampling */ static Vert2_list * init_poly(POLYSAMP *ps, IDF_FIELD *f0, int nv) @@ -349,7 +351,7 @@ sample_surface(IDF_PARAMETER *param, int wd) idf_getfield(param,NAME_FLD)->val); return(0); } - psamp.samp_left = NSAMPLES; /* assign samples & destination */ + psamp.samp_left = nsamps; /* assign samples & destination */ psamp.wd = wd; /* sample each subtriangle */ if (!polyTriangulate(vlist2, &sample_triangle)) @@ -467,19 +469,28 @@ main(int argc, char *argv[]) IDF_PARAMETER *pptr; int i; - progname = argv[0]; - if (argc > 2 && !strcmp(argv[1], "-c")) { - incl_comments = -1; /* output header only */ - ++argv; --argc; - } - if ((argc < 2) | (argc > 3)) { - fputs("Usage: ", stderr); - fputs(progname, stderr); - fputs(" [-c] Model.idf [Revised.idf]\n", stderr); - return(1); - } - origIDF = argv[1]; - revIDF = (argc == 2) ? argv[1] : argv[2]; + progname = *argv++; argc--; /* get options if any */ + while (argc > 1 && argv[0][0] == '-') + switch (argv[0][1]) { + case 'c': /* elide comments */ + incl_comments = -1; /* header only */ + argv++; argc--; + continue; + case 's': /* samples */ + nsamps = 1000*atoi(*++argv); + argv++; argc -= 2; + continue; + default: + fputs(progname, stderr); + fputs(": unknown option '", stderr); + fputs(argv[0], stderr); + fputs("'\n", stderr); + goto userr; + } + if ((argc < 1) | (argc > 2)) + goto userr; + origIDF = argv[0]; + revIDF = (argc == 1) ? argv[0] : argv[1]; /* load Input Data File */ our_idf = idf_load(origIDF); if (our_idf == NULL) { @@ -530,4 +541,9 @@ main(int argc, char *argv[]) return(1); } return(0); /* finito! */ +userr: + fputs("Usage: ", stderr); + fputs(progname, stderr); + fputs(" [-c][-s Ksamps] Model.idf [Revised.idf]\n", stderr); + return(1); }
