--- ray/src/util/eplus_adduvf.c 2014/02/09 22:19:30 2.2 +++ ray/src/util/eplus_adduvf.c 2014/02/10 04:51:26 2.3 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.2 2014/02/09 22:19:30 greg Exp $"; +static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.3 2014/02/10 04:51:26 greg Exp $"; #endif /* * Add User View Factors to EnergyPlus Input Data File @@ -7,9 +7,10 @@ static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.2 * G.Ward for LBNL */ -#include #include -#include +#include "rtio.h" +#include "rtmath.h" +#include "random.h" #include "eplus_idf.h" #include "triangulate.h" #include "rtprocess.h" @@ -87,36 +88,35 @@ add2zone(IDF_PARAMETER *param, const char *zname) return(zptr); } -/* Determine if a parameter is a surface in the indicated zone */ -static int -in_zone(IDF_PARAMETER *param, const char *zname) +/* Return field for vertices in the given parameter */ +static IDF_FIELD * +get_vlist(IDF_PARAMETER *param, const char *zname) { int i = 0; IDF_FIELD *fptr; /* check for surface type */ while (strcmp(surf_type[i].pname, param->pname)) if (surf_type[++i].pname == NULL) - return(0); - /* get zone field */ - fptr = idf_getfield(param, surf_type[i].zone_fld); - if (fptr == NULL) - return(0); - /* check for match */ - if (strcmp(fptr->arg, zname)) - return(0); + return(NULL); + + if (zname != NULL) { /* matches specified zone? */ + fptr = idf_getfield(param, surf_type[i].zone_fld); + if (fptr == NULL || strcmp(fptr->val, zname)) + return(NULL); + } /* return field for #verts */ - return(surf_type[i].vert_fld); + return(idf_getfield(param, surf_type[i].vert_fld)); } /* Convert surface to Radiance with modifier based on unique name */ static int -rad_surface(const char *zname, IDF_PARAMETER *param, FILE *ofp) +rad_surface(IDF_PARAMETER *param, FILE *ofp) { - const char *sname = idf_getfield(param, NAME_FLD)->arg; - IDF_FIELD *fptr = idf_getfield(param, in_zone(param, zname)); + const char *sname = idf_getfield(param,NAME_FLD)->val; + IDF_FIELD *fptr = get_vlist(param, NULL); int nvert, i; - if (fptr == NULL || (nvert = atoi(fptr->arg)) < 3) { + if (fptr == NULL || (nvert = atoi(fptr->val)) < 3) { fprintf(stderr, "%s: bad surface '%s'\n", progname, sname); return(0); } @@ -125,21 +125,21 @@ rad_surface(const char *zname, IDF_PARAMETER *param, F while (nvert--) { for (i = 3; i--; ) { fptr = fptr->next; - if (fptr == NULL) { + if (fptr == NULL || !isflt(fptr->val)) { fprintf(stderr, - "%s: missing vertex fields in surface '%s'\n", - progname, sname); + "%s: missing/bad vertex for %s '%s'\n", + progname, param->pname, sname); return(0); } fputc('\t', ofp); - fputs(fptr->arg, ofp); + fputs(fptr->val, ofp); } fputc('\n', ofp); } return(!ferror(ofp)); } -/* Strat rcontrib process */ +/* Start rcontrib process */ static int start_rcontrib(SUBPROC *pd, ZONE *zp) { @@ -169,16 +169,16 @@ start_rcontrib(SUBPROC *pd, ZONE *zp) av[i++] = "-c"; av[i++] = cbuf; /* add modifier arguments */ for (n = zp->nsurf, pptr = zp->pfirst; n--; pptr = pptr->dnext) { - IDF_FIELD *fptr = idf_getfield(pptr, NAME_FLD); - if (fptr == NULL) { + IDF_FIELD *fptr = idf_getfield(pptr,NAME_FLD); + if (fptr == NULL || !fptr->val[0]) { fputs(progname, stderr); fputs(": missing name for surface parameter\n", stderr); return(0); } - av[i++] = "-m"; - av[i++] = fptr->arg; - if (!rad_surface(zp->zname, pptr, ofp)) + if (!rad_surface(pptr, ofp)) /* add surface to octree */ return(0); + av[i++] = "-m"; + av[i++] = fptr->val; } if (pclose(ofp) != 0) { /* finish oconv */ fputs(progname, stderr); @@ -197,11 +197,225 @@ start_rcontrib(SUBPROC *pd, ZONE *zp) #undef BASE_AC } +typedef struct { + FVECT sdir[3]; /* XYZ unit sampling vectors */ + double poff; /* Z-offset for plane of polygon */ + double area_left; /* area left to sample */ + int samp_left; /* remaining samples */ + int wd; /* output file descriptor */ +} POLYSAMP; /* structure for polygon sampling */ + +/* Initialize polygon sampling */ +static Vert2_list * +init_poly(POLYSAMP *ps, IDF_FIELD *f0, int nv) +{ + IDF_FIELD *fptr = f0; + int i, j; + FVECT *vl3, e1, e2, vc; + Vert2_list *vl2 = polyAlloc(nv); + + if (vl2 == NULL) + return(NULL); + vl2->p = ps; + /* get 3-D vertices */ + vl3 = (FVECT *)malloc(sizeof(FVECT)*nv); + if (vl3 == NULL) + return(NULL); + for (i = 0; i < nv; i++) + for (j = 0; j < 3; j++) { + if (fptr == NULL) { + fputs(progname, stderr); + fputs(": bad vertex in init_poly()\n", stderr); + return(NULL); + } + vl3[i][j] = atof(fptr->val); + } + /* compute area and normal */ + ps->sdir[2][0] = ps->sdir[2][1] = ps->sdir[2][2] = 0; + VSUB(e1, vl3[1], vl3[0]); + for (i = 2; i < nv; i++) { + VSUB(e2, vl3[i], vl3[0]); + fcross(vc, e1, e2); + ps->sdir[2][0] += vc[0]; + ps->sdir[2][1] += vc[1]; + ps->sdir[2][2] += vc[2]; + VCOPY(e1, e2); + } + ps->area_left = .5 * normalize(ps->sdir[2]); + if (ps->area_left == .0) { + fputs(progname, stderr); + fputs(": degenerate polygon in init_poly()\n", stderr); + return(0); + } + /* create X & Y axes */ + VCOPY(ps->sdir[0], e1); + normalize(ps->sdir[0]); + fcross(ps->sdir[1], ps->sdir[2], ps->sdir[0]); + /* compute plane offset */ + ps->poff = DOT(vl3[0], ps->sdir[2]) + FTINY; + /* assign 2-D vertices */ + for (i = 0; i < nv; i++) { + vl2->v[i].mX = DOT(vl3[i], ps->sdir[0]); + vl2->v[i].mY = DOT(vl3[i], ps->sdir[1]); + } + free(vl3); /* it's ready! */ + return(vl2); +} + +/* Generate samples on 2-D triangle */ +static int +sample_triangle(const Vert2_list *vl2, int a, int b, int c) +{ + POLYSAMP *ps = (POLYSAMP *)vl2->p; + float *samp; + FVECT orig; + FVECT ab, ac; + double area; + int i, j, ns; + /* compute sampling axes */ + for (i = 3; i--; ) { + orig[i] = vl2->v[a].mX*ps->sdir[0][i] + + vl2->v[a].mY*ps->sdir[1][i] + + ps->poff*ps->sdir[2][i]; + ab[i] = (vl2->v[b].mX - vl2->v[a].mX)*ps->sdir[0][i] + + (vl2->v[b].mY - vl2->v[a].mY)*ps->sdir[1][i]; + ac[i] = (vl2->v[c].mX - vl2->v[a].mX)*ps->sdir[0][i] + + (vl2->v[c].mY - vl2->v[a].mY)*ps->sdir[1][i]; + } + /* compute number of samples to take */ + area = .5*(vl2->v[a].mX*vl2->v[b].mY - vl2->v[b].mX*vl2->v[a].mY + + vl2->v[b].mX*vl2->v[c].mY - vl2->v[c].mX*vl2->v[b].mY + + vl2->v[c].mX*vl2->v[a].mY - vl2->v[a].mX*vl2->v[c].mY); + if (area < .0) { + fputs(progname, stderr); + fputs(": negative triangle area in sample_triangle()\n", stderr); + return(0); + } + if (area >= ps->area_left) { + ns = ps->samp_left; + ps->area_left = 0; + } else { + ns = (ps->samp_left*area/ps->area_left + .5); + ps->samp_left -= ns; + ps->area_left -= area; + } + if (ns <= 0) /* XXX should be error? */ + return(1); + /* buffer sample rays */ + samp = (float *)malloc(sizeof(float)*6*ns); + if (samp == NULL) + return(0); + for (i = ns; i--; ) { + double sv[4]; + multisamp(sv, 4, (i+frandom())/(double)ns); + sv[0] *= sv[1] = sqrt(sv[1]); + sv[1] = 1. - sv[1]; + for (j = 3; j--; ) + samp[ns*6 + j] = orig[j] + sv[0]*ab[j] + sv[1]*ac[j]; + sv[3] = sqrt(sv[3]); + sv[4] *= 2.*PI; + samp[ns*6 + 3] = tcos(sv[4]) * sv[3]; + samp[ns*6 + 4] = tsin(sv[4]) * sv[3]; + samp[ns*6 + 5] = sqrt(1. - sv[3]*sv[3]); + } + /* send to our process */ + writebuf(ps->wd, (char *)samp, sizeof(float)*6*ns); + free(samp); /* that's it! */ + return(1); +} + +/* Sample the given surface */ +static int +sample_surface(IDF_PARAMETER *param, int wd) +{ + IDF_FIELD *fptr = get_vlist(param, NULL); + POLYSAMP psamp; + int nv; + Vert2_list *vlist2; + /* set up our polygon sampler */ + if (fptr == NULL || (nv = atoi(fptr->val)) < 3) { + fprintf(stderr, "%s: error in %s '%s'\n", + progname, param->pname, + idf_getfield(param,NAME_FLD)->val); + return(0); + } + vlist2 = init_poly(&psamp, fptr->next, nv); + if (vlist2 == NULL) + return(0); + psamp.samp_left = NSAMPLES; /* assign samples & destination */ + psamp.wd = wd; + /* sample each subtriangle */ + if (!polyTriangulate(vlist2, &sample_triangle)) + return(0); + polyFree(vlist2); /* clean up and return */ + return(1); +} + /* Compute User View Factors using open rcontrib process */ static int -compute_uvfs(SUBPROC *pd, ZONE *sp) +compute_uvfs(SUBPROC *pd, ZONE *zp) { - + IDF_PARAMETER *pptr, *pout, *pptr1; + float *uvfa; + char uvfbuf[24]; + int n, m; + /* create output parameter */ + pout = idf_newparam(our_idf, UVF_PNAME, + " ! computed by Radiance\n ", zp->plast); + if (pout == NULL) { + fputs(progname, stderr); + fputs(": cannot create new IDF parameter\n", stderr); + return(0); + } + if (!idf_addfield(pout, zp->zname, + " !- Zone Name\n ")) { + fputs(progname, stderr); + fputs(": cannot add zone name field\n", stderr); + return(0); + } + /* allocate read buffer */ + uvfa = (float *)malloc(sizeof(float)*3*zp->nsurf); + if (uvfa == NULL) + return(0); + /* UVFs from each surface */ + for (n = zp->nsurf, pptr = zp->pfirst; n--; pptr = pptr->dnext) { + /* send samples to rcontrib */ + if (!sample_surface(pptr, pd->w)) + return(0); + /* read results */ + if (readbuf(pd->r, (char *)uvfa, sizeof(float)*3*zp->nsurf) != + sizeof(float)*3*zp->nsurf) { + fputs(progname, stderr); + fputs(": read error from rcontrib process\n", stderr); + return(0); + } + /* append UVF fields */ + for (m = 0, pptr1 = zp->pfirst; + m < zp->nsurf; m++, pptr1 = pptr1->dnext) { + if (pptr1 == pptr) { + if (uvfa[3*m + 1] > .001) + fprintf(stderr, + "%s: warning - non-zero self-VF (%.3e) for surface '%s'\n", + progname, uvfa[3*m + 1], + idf_getfield(pptr,NAME_FLD)->val); + continue; /* don't record self-factor */ + } + sprintf(uvfbuf, "%.6f", uvfa[3*m + 1]); + if (!idf_addfield(pout, + idf_getfield(pptr,NAME_FLD)->val, NULL) || + !idf_addfield(pout, + idf_getfield(pptr1,NAME_FLD)->val, NULL) || + !idf_addfield(pout, uvfbuf, + (n || m < zp->nsurf-2) ? + "\n " : "\n\n")) { + fputs(progname, stderr); + fputs(": error adding UVF fields\n", stderr); + return(0); + } + } + } + free(uvfa); /* clean up and return */ + return(1); } /* Compute zone User View Factors */ @@ -291,7 +505,7 @@ main(int argc, char *argv[]) fputs(": warning - missing zone field\n", stderr); continue; } - if (add2zone(pptr, fptr->arg) == NULL) + if (add2zone(pptr, fptr->val) == NULL) return(1); } /* run rcontrib on each zone */
