--- ray/src/util/eplus_adduvf.c 2014/02/13 17:33:37 2.10 +++ ray/src/util/eplus_adduvf.c 2016/03/06 01:13:18 2.18 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.10 2014/02/13 17:33:37 greg Exp $"; +static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.18 2016/03/06 01:13:18 schorsch Exp $"; #endif /* * Add User View Factors to EnergyPlus Input Data File @@ -8,6 +8,7 @@ static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.1 */ #include +#include "platform.h" #include "rtio.h" #include "rtmath.h" #include "random.h" @@ -19,6 +20,8 @@ static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.1 #define NSAMPLES 80000 /* default number of samples */ #endif +#define SURF_EPS 0.0005 /* surface testing epsilon */ + char *progname; /* global argv[0] */ int nsamps = NSAMPLES; /* number of samples to use */ @@ -28,11 +31,17 @@ char temp_octree[128]; /* temporary octree */ const char UVF_PNAME[] = "ZoneProperty:UserViewFactors:bySurfaceName"; +const char SUBSURF_PNAME[] = + "FenestrationSurface:Detailed"; + const char ADD_HEADER[] = "\n!+++ User View Factors computed by Radiance +++!\n\n"; #define NAME_FLD 1 /* name field always first? */ +#define SS_BASE_FLD 4 /* subsurface base surface */ +#define SS_VERT_FLD 10 /* subsurface vertex count */ + typedef struct { const char *pname; /* object type name */ short zone_fld; /* zone field index */ @@ -51,15 +60,27 @@ typedef struct s_zone { const char *zname; /* zone name */ struct s_zone *next; /* next zone in list */ int nsurf; /* surface count */ + int ntotal; /* surfaces+subsurfaces */ IDF_OBJECT *pfirst; /* first matching object */ - IDF_OBJECT *plast; /* last matching object */ + IDF_OBJECT *plast; /* last before subsurfaces */ + float *area_redu; /* subsurface area per surf. */ } ZONE; /* a list of collected zone surfaces */ ZONE *zone_list = NULL; /* our list of zones */ +LUTAB zonesurf_lut = /* zone surface lookup table */ + LU_SINIT(NULL,NULL); + IDF_LOADED *our_idf = NULL; /* loaded/modified IDF */ typedef struct { + FVECT norm; /* surface normal */ + double area; /* surface area */ + int nv; /* number of vertices */ + FVECT vl[3]; /* vertex list (extends struct) */ +} SURFACE; /* a polygonal surface */ + +typedef struct { FVECT sdir[3]; /* UVW unit sampling vectors */ double poff; /* W-offset for plane of polygon */ double area_left; /* area left to sample */ @@ -78,7 +99,8 @@ new_zone(const char *zname, IDF_OBJECT *param) znew->zname = zname; /* assumes static */ znew->next = zone_list; znew->pfirst = znew->plast = param; - znew->nsurf = 1; + znew->ntotal = znew->nsurf = 1; + znew->area_redu = NULL; return(zone_list = znew); } @@ -86,18 +108,68 @@ new_zone(const char *zname, IDF_OBJECT *param) static ZONE * add2zone(IDF_OBJECT *param, const char *zname) { - ZONE *zptr; + IDF_FIELD *nfp = idf_getfield(param, NAME_FLD); + ZONE *zptr; + LUENT *lep; + if (nfp == NULL) { + fputs(progname, stderr); + fputs(": surface missing name field!\n", stderr); + return(NULL); + } for (zptr = zone_list; zptr != NULL; zptr = zptr->next) if (!strcmp(zptr->zname, zname)) break; - if (zptr == NULL) - return(new_zone(zname, param)); - /* keep surfaces together */ + if (zptr == NULL) { + zptr = new_zone(zname, param); + } else { /* keep surfaces together */ + if (!idf_movobject(our_idf, param, zptr->plast)) + return(NULL); + zptr->plast = param; + zptr->nsurf++; + zptr->ntotal++; + } + /* add to lookup table */ + lep = lu_find(&zonesurf_lut, nfp->val); + if (lep == NULL) + return(NULL); + if (lep->data != NULL) { + fputs(progname, stderr); + fputs(": duplicate surface name '", stderr); + fputs(nfp->val, stderr); + fputs("'\n", stderr); + return(NULL); + } + lep->key = nfp->val; + lep->data = (char *)zptr; + return(zptr); +} + +/* Add a subsurface by finding its base surface and the corresponding zone */ +static ZONE * +add_subsurf(IDF_OBJECT *param) +{ + IDF_FIELD *bfp = idf_getfield(param, SS_BASE_FLD); + ZONE *zptr; + LUENT *lep; + + if (bfp == NULL) { + fputs(progname, stderr); + fputs(": missing base field name in subsurface!\n", stderr); + return(NULL); + } + lep = lu_find(&zonesurf_lut, bfp->val); /* find base zone */ + if (lep == NULL || lep->data == NULL) { + fputs(progname, stderr); + fputs(": cannot find referenced base surface '", stderr); + fputs(bfp->val, stderr); + fputs("'\n", stderr); + return(NULL); + } + zptr = (ZONE *)lep->data; /* add this subsurface */ if (!idf_movobject(our_idf, param, zptr->plast)) return(NULL); - zptr->plast = param; - zptr->nsurf++; + zptr->ntotal++; return(zptr); } @@ -105,38 +177,128 @@ add2zone(IDF_OBJECT *param, const char *zname) static IDF_FIELD * get_vlist(IDF_OBJECT *param, const char *zname) { - int i = 0; - IDF_FIELD *fptr; - /* check for surface type */ - while (strcmp(surf_type[i].pname, param->pname)) - if (surf_type[++i].pname == NULL) - return(NULL); +#define itm_len (sizeof(IDF_FIELD)+6) + static char fld_buf[4*itm_len]; + static char *next_fbp = fld_buf; + int i; + IDF_FIELD *res; + /* check if subsurface */ + if (!strcmp(param->pname, SUBSURF_PNAME)) { + if (zname != NULL) { + LUENT *lep = lu_find(&zonesurf_lut, + idf_getfield(param,SS_BASE_FLD)->val); + if (strcmp((*(ZONE *)lep->data).zname, zname)) + return(NULL); + } + res = idf_getfield(param, SS_VERT_FLD); + } else { + i = 0; /* check for surface type */ + while (strcmp(surf_type[i].pname, param->pname)) + if (surf_type[++i].pname == NULL) + return(NULL); - if (zname != NULL) { /* matches specified zone? */ - fptr = idf_getfield(param, surf_type[i].zone_fld); - if (fptr == NULL || strcmp(fptr->val, zname)) + if (zname != NULL) { /* matches specified zone? */ + IDF_FIELD *fptr = idf_getfield(param, surf_type[i].zone_fld); + if (fptr == NULL || strcmp(fptr->val, zname)) + return(NULL); + } + res = idf_getfield(param, surf_type[i].vert_fld); + } + if (!res->val[0]) { /* hack for missing #vert */ + IDF_FIELD *fptr; + if (next_fbp >= fld_buf+sizeof(fld_buf)) + next_fbp = fld_buf; + i = 0; /* count vertices */ + for (fptr = res->next; fptr != NULL; fptr = fptr->next) + ++i; + if (i % 3) return(NULL); + fptr = res->next; + res = (IDF_FIELD *)next_fbp; next_fbp += itm_len; + res->next = fptr; + res->rem = ""; + sprintf(res->val, "%d", i/3); } - /* return field for #verts */ - return(idf_getfield(param, surf_type[i].vert_fld)); + return(res); +#undef itm_len } +/* Get/allocate surface polygon */ +static SURFACE * +get_surface(IDF_FIELD *fptr) +{ + SURFACE *surf; + int nv; + FVECT e1, e2, vc; + int i, j; + /* get number of vertices */ + if (fptr == NULL || (nv = atoi(fptr->val)) < 3) { + fputs(progname, stderr); + fputs(": bad vertex count for surface!\n", stderr); + return(NULL); + } + surf = (SURFACE *)malloc(sizeof(SURFACE)+sizeof(FVECT)*(nv-3)); + if (surf == NULL) + return(NULL); + surf->nv = nv; + for (i = nv; i--; ) /* reverse vertex order/orientation */ + for (j = 0; j < 3; j++) { + fptr = fptr->next; + if (fptr == NULL) { + fputs(progname, stderr); + fputs(": missing vertex in get_surface()\n", stderr); + free(surf); + return(NULL); + } + if ((surf->vl[i][j] = atof(fptr->val)) == 0 && + !isflt(fptr->val)) { + fputs(progname, stderr); + fputs(": bad vertex in get_surface()\n", stderr); + free(surf); + return(NULL); + } + } + /* compute area and normal */ + surf->norm[0] = surf->norm[1] = surf->norm[2] = 0; + VSUB(e1, surf->vl[1], surf->vl[0]); + for (i = 2; i < nv; i++) { + VSUB(e2, surf->vl[i], surf->vl[0]); + fcross(vc, e1, e2); + surf->norm[0] += vc[0]; + surf->norm[1] += vc[1]; + surf->norm[2] += vc[2]; + VCOPY(e1, e2); + } + surf->area = .5 * normalize(surf->norm); + if (surf->area == 0) { + fputs(progname, stderr); + fputs(": degenerate polygon in get_surface()\n", stderr); + free(surf); + return(NULL); + } + return(surf); +} + /* Convert surface to Radiance with modifier based on unique name */ static int rad_surface(IDF_OBJECT *param, FILE *ofp) { const char *sname = idf_getfield(param,NAME_FLD)->val; IDF_FIELD *fptr = get_vlist(param, NULL); - int nvert, i; + const char **fargs; + int nvert, i, j; if (fptr == NULL || (nvert = atoi(fptr->val)) < 3) { fprintf(stderr, "%s: bad surface '%s'\n", progname, sname); return(0); } + fargs = (const char **)malloc(sizeof(const char *)*3*nvert); + if (fargs == NULL) + return(0); fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname); fprintf(ofp, "\n'%s' polygon 's_%s'\n0\n0\n%d\n", sname, sname, 3*nvert); - while (nvert--) { - for (i = 3; i--; ) { + for (j = nvert; j--; ) { /* get arguments in reverse */ + for (i = 0; i < 3; i++) { fptr = fptr->next; if (fptr == NULL || !isflt(fptr->val)) { fprintf(stderr, @@ -144,45 +306,80 @@ rad_surface(IDF_OBJECT *param, FILE *ofp) progname, param->pname, sname); return(0); } + fargs[3*j + i] = fptr->val; + } + } + for (j = 0; j < nvert; j++) { /* output reversed verts */ + for (i = 0; i < 3; i++) { fputc('\t', ofp); - fputs(fptr->val, ofp); + fputs(fargs[3*j + i], ofp); } fputc('\n', ofp); } + free(fargs); return(!ferror(ofp)); } +/* Convert subsurface to Radiance with modifier based on unique name */ +static double +rad_subsurface(IDF_OBJECT *param, FILE *ofp) +{ + const char *sname = idf_getfield(param,NAME_FLD)->val; + SURFACE *surf = get_surface(get_vlist(param, NULL)); + double area; + int i; + + if (surf == NULL) { + fprintf(stderr, "%s: bad subsurface '%s'\n", progname, sname); + return(-1.); + } + fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname); + fprintf(ofp, "\n'%s' polygon 'ss_%s'\n0\n0\n%d\n", + sname, sname, 3*surf->nv); + for (i = 0; i < surf->nv; i++) { /* offset vertices */ + FVECT vert; + VSUM(vert, surf->vl[i], surf->norm, 2.*SURF_EPS); + fprintf(ofp, "\t%.12f %.12f %.12f\n", vert[0], vert[1], vert[2]); + } + area = surf->area; + free(surf); + if (ferror(ofp)) + return(-1.); + return(area); +} + /* Start rcontrib process */ static int start_rcontrib(SUBPROC *pd, ZONE *zp) { -#define BASE_AC 5 +#define BASE_AC 6 static char *base_av[BASE_AC] = { - "rcontrib", "-fff", "-h", "-x", "1" + "rcontrib", "-V+", "-fff", "-h", "-x", "1" }; char cbuf[300]; char **av; FILE *ofp; IDF_OBJECT *pptr; - int i, n; + IDF_FIELD *fptr; + int i, j, n; /* start oconv command */ - sprintf(cbuf, "oconv - > '%s'", temp_octree); + sprintf(cbuf, "oconv - > \"%s\"", temp_octree); if ((ofp = popen(cbuf, "w")) == NULL) { fputs(progname, stderr); fputs(": cannot open oconv process\n", stderr); return(0); } /* allocate argument list */ - av = (char **)malloc(sizeof(char *)*(BASE_AC+4+2*zp->nsurf)); + av = (char **)malloc(sizeof(char *)*(BASE_AC+4+2*(zp->ntotal))); if (av == NULL) return(0); for (i = 0; i < BASE_AC; i++) av[i] = base_av[i]; sprintf(cbuf, "%d", nsamps); av[i++] = "-c"; - av[i++] = cbuf; /* add modifier arguments */ - for (n = zp->nsurf, pptr = zp->pfirst; n--; pptr = pptr->dnext) { - IDF_FIELD *fptr = idf_getfield(pptr,NAME_FLD); + av[i++] = cbuf; /* add modifiers & surfaces */ + for (n = 0, pptr = zp->pfirst; n < zp->nsurf; n++, pptr = pptr->dnext) { + fptr = idf_getfield(pptr,NAME_FLD); if (fptr == NULL || !fptr->val[0]) { fputs(progname, stderr); fputs(": missing name for surface object\n", stderr); @@ -193,6 +390,38 @@ start_rcontrib(SUBPROC *pd, ZONE *zp) av[i++] = "-m"; av[i++] = fptr->val; } + /* now subsurfaces */ + if (zp->ntotal > zp->nsurf) { + if (zp->area_redu != NULL) + memset(zp->area_redu, 0, sizeof(float)*zp->ntotal); + else if ((zp->area_redu = (float *)calloc(zp->ntotal, + sizeof(float))) == NULL) + return(0); + } + for ( ; n < zp->ntotal; n++, pptr = pptr->dnext) { + double ssarea; + const char *bname; + IDF_OBJECT *pptr1; + fptr = idf_getfield(pptr,NAME_FLD); + if (fptr == NULL || !fptr->val[0]) { + fputs(progname, stderr); + fputs(": missing name for subsurface object\n", stderr); + return(0); + } + /* add subsurface to octree */ + if ((ssarea = rad_subsurface(pptr, ofp)) < 0) + return(0); + /* mark area for subtraction */ + bname = idf_getfield(pptr,SS_BASE_FLD)->val; + for (j = 0, pptr1 = zp->pfirst; + j < zp->nsurf; j++, pptr1 = pptr1->dnext) + if (!strcmp(idf_getfield(pptr1,NAME_FLD)->val, bname)) { + zp->area_redu[j] += ssarea; + break; + } + av[i++] = "-m"; + av[i++] = fptr->val; + } if (pclose(ofp) != 0) { /* finish oconv */ fputs(progname, stderr); fputs(": error running oconv process\n", stderr); @@ -212,59 +441,33 @@ start_rcontrib(SUBPROC *pd, ZONE *zp) /* Initialize polygon sampling */ static Vert2_list * -init_poly(POLYSAMP *ps, IDF_FIELD *f0, int nv) +init_poly(POLYSAMP *ps, IDF_FIELD *f0) { - IDF_FIELD *fptr = f0; - int i, j; - FVECT *vl3, e1, e2, vc; - Vert2_list *vl2 = polyAlloc(nv); - + SURFACE *surf; + Vert2_list *vl2; + int i; + /* get 3-D polygon vertices */ + if ((surf = get_surface(f0)) == NULL) + return(NULL); + vl2 = polyAlloc(surf->nv); if (vl2 == NULL) return(NULL); - vl2->p = ps; - /* get 3-D vertices */ - vl3 = (FVECT *)malloc(sizeof(FVECT)*nv); - if (vl3 == NULL) - return(NULL); - for (i = nv; i--; ) /* reverse vertex ordering */ - for (j = 0; j < 3; j++) { - if (fptr == NULL) { - fputs(progname, stderr); - fputs(": missing vertex in init_poly()\n", stderr); - return(NULL); - } - vl3[i][j] = atof(fptr->val); - fptr = fptr->next; - } - /* compute area and normal */ - ps->sdir[2][0] = ps->sdir[2][1] = ps->sdir[2][2] = 0; - VSUB(e1, vl3[1], vl3[0]); - for (i = 2; i < nv; i++) { - VSUB(e2, vl3[i], vl3[0]); - fcross(vc, e1, e2); - ps->sdir[2][0] += vc[0]; - ps->sdir[2][1] += vc[1]; - ps->sdir[2][2] += vc[2]; - VCOPY(e1, e2); - } - ps->area_left = .5 * normalize(ps->sdir[2]); - if (ps->area_left == .0) { - fputs(progname, stderr); - fputs(": degenerate polygon in init_poly()\n", stderr); - return(0); - } /* create X & Y axes */ - VCOPY(ps->sdir[0], e1); - normalize(ps->sdir[0]); + VCOPY(ps->sdir[2], surf->norm); + VSUB(ps->sdir[0], surf->vl[1], surf->vl[0]); + if (normalize(ps->sdir[0]) == 0) + return(NULL); fcross(ps->sdir[1], ps->sdir[2], ps->sdir[0]); /* compute plane offset */ - ps->poff = DOT(vl3[0], ps->sdir[2]); + ps->poff = DOT(surf->vl[0], ps->sdir[2]); /* assign 2-D vertices */ - for (i = 0; i < nv; i++) { - vl2->v[i].mX = DOT(vl3[i], ps->sdir[0]); - vl2->v[i].mY = DOT(vl3[i], ps->sdir[1]); + for (i = 0; i < surf->nv; i++) { + vl2->v[i].mX = DOT(surf->vl[i], ps->sdir[0]); + vl2->v[i].mY = DOT(surf->vl[i], ps->sdir[1]); } - free(vl3); /* it's ready! */ + ps->area_left = surf->area; + free(surf); /* it's ready! */ + vl2->p = (void *)ps; return(vl2); } @@ -282,7 +485,7 @@ sample_triangle(const Vert2_list *vl2, int a, int b, i for (i = 3; i--; ) { orig[i] = vl2->v[a].mX*ps->sdir[0][i] + vl2->v[a].mY*ps->sdir[1][i] + - (ps->poff+.001)*ps->sdir[2][i]; + (ps->poff+SURF_EPS)*ps->sdir[2][i]; ab[i] = (vl2->v[b].mX - vl2->v[a].mX)*ps->sdir[0][i] + (vl2->v[b].mY - vl2->v[a].mY)*ps->sdir[1][i]; ac[i] = (vl2->v[c].mX - vl2->v[a].mX)*ps->sdir[0][i] + @@ -336,28 +539,31 @@ sample_triangle(const Vert2_list *vl2, int a, int b, i } /* Sample the given surface */ -static int +static double sample_surface(IDF_OBJECT *param, int wd) { - IDF_FIELD *fptr = get_vlist(param, NULL); POLYSAMP psamp; + double area; int nv; Vert2_list *vlist2; /* set up our polygon sampler */ - if (fptr == NULL || (nv = atoi(fptr->val)) < 3 || - (vlist2 = init_poly(&psamp, fptr->next, nv)) == NULL) { + if ((vlist2 = init_poly(&psamp, get_vlist(param, NULL))) == NULL) { fprintf(stderr, "%s: bad polygon %s '%s'\n", progname, param->pname, idf_getfield(param,NAME_FLD)->val); - return(0); + return(-1.); } psamp.samp_left = nsamps; /* assign samples & destination */ psamp.wd = wd; + /* hack for subsurface sampling */ + psamp.poff += 2.*SURF_EPS * !strcmp(param->pname, SUBSURF_PNAME); + + area = psamp.area_left; /* remember starting surface area */ /* sample each subtriangle */ if (!polyTriangulate(vlist2, &sample_triangle)) - return(0); + return(-1.); polyFree(vlist2); /* clean up and return */ - return(1); + return(area); } /* Compute User View Factors using open rcontrib process */ @@ -370,7 +576,7 @@ compute_uvfs(SUBPROC *pd, ZONE *zp) int n, m; /* create output object */ pout = idf_newobject(our_idf, UVF_PNAME, - " ! computed by Radiance\n ", zp->plast); + " ! computed by Radiance\n ", our_idf->plast); if (pout == NULL) { fputs(progname, stderr); fputs(": cannot create new IDF object\n", stderr); @@ -383,42 +589,45 @@ compute_uvfs(SUBPROC *pd, ZONE *zp) return(0); } /* allocate read buffer */ - uvfa = (float *)malloc(sizeof(float)*3*zp->nsurf); + uvfa = (float *)malloc(sizeof(float)*3*zp->ntotal); if (uvfa == NULL) return(0); /* UVFs from each surface */ - for (n = zp->nsurf, pptr = zp->pfirst; n--; pptr = pptr->dnext) { + for (n = 0, pptr = zp->pfirst; n < zp->ntotal; n++, pptr = pptr->dnext) { double vfsum = 0; + double adj_factor; /* send samples to rcontrib */ - if (!sample_surface(pptr, pd->w)) + if ((adj_factor = sample_surface(pptr, pd->w)) < 0) return(0); + if (zp->area_redu == NULL) + adj_factor = 1.; + else /* comp. for subsurface area */ + adj_factor /= adj_factor - zp->area_redu[n]; /* read results */ - if (readbuf(pd->r, (char *)uvfa, sizeof(float)*3*zp->nsurf) != - sizeof(float)*3*zp->nsurf) { + if (readbuf(pd->r, (char *)uvfa, sizeof(float)*3*zp->ntotal) != + sizeof(float)*3*zp->ntotal) { fputs(progname, stderr); fputs(": read error from rcontrib process\n", stderr); return(0); } /* append UVF fields */ for (m = 0, pptr1 = zp->pfirst; - m < zp->nsurf; m++, pptr1 = pptr1->dnext) { - vfsum += uvfa[3*m + 1]; - if (pptr1 == pptr) { - if (uvfa[3*m + 1] > .001) - fprintf(stderr, + m < zp->ntotal; m++, pptr1 = pptr1->dnext) { + const double uvf = uvfa[3*m + 1] * adj_factor; + vfsum += uvf; + if (pptr1 == pptr && uvf > .001) + fprintf(stderr, "%s: warning - non-zero self-VF (%.1f%%) for surface '%s'\n", - progname, 100.*uvfa[3*m + 1], + progname, 100.*uvf, idf_getfield(pptr,NAME_FLD)->val); - continue; /* don't record self-factor */ - } - sprintf(uvfbuf, "%.4f", uvfa[3*m + 1]); + sprintf(uvfbuf, "%.4f", uvf); if (!idf_addfield(pout, idf_getfield(pptr,NAME_FLD)->val, NULL) || !idf_addfield(pout, idf_getfield(pptr1,NAME_FLD)->val, NULL) || !idf_addfield(pout, uvfbuf, - (n || m < zp->nsurf-2) ? - "\n " : "\n\n")) { + (n+m < 2*zp->ntotal-2) ? + "\n " : "\n\n")) { fputs(progname, stderr); fputs(": error adding UVF fields\n", stderr); return(0); @@ -529,6 +738,11 @@ main(int argc, char *argv[]) if (add2zone(pptr, fptr->val) == NULL) return(1); } + /* add subsurfaces */ + for (pptr = idf_getobject(our_idf, SUBSURF_PNAME); + pptr != NULL; pptr = pptr->pnext) + if (add_subsurf(pptr) == NULL) + return(1); /* run rcontrib on each zone */ if (!compute_zones()) return(1);
