--- ray/src/util/eplus_adduvf.c 2014/02/15 01:31:36 2.11 +++ ray/src/util/eplus_adduvf.c 2020/01/17 17:33:48 2.20 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.11 2014/02/15 01:31:36 greg Exp $"; +static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.20 2020/01/17 17:33:48 greg Exp $"; #endif /* * Add User View Factors to EnergyPlus Input Data File @@ -8,6 +8,7 @@ static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.1 */ #include +#include "platform.h" #include "rtio.h" #include "rtmath.h" #include "random.h" @@ -62,6 +63,7 @@ typedef struct s_zone { int ntotal; /* surfaces+subsurfaces */ IDF_OBJECT *pfirst; /* first matching object */ IDF_OBJECT *plast; /* last before subsurfaces */ + float *area_redu; /* subsurface area per surf. */ } ZONE; /* a list of collected zone surfaces */ ZONE *zone_list = NULL; /* our list of zones */ @@ -98,6 +100,7 @@ new_zone(const char *zname, IDF_OBJECT *param) znew->next = zone_list; znew->pfirst = znew->plast = param; znew->ntotal = znew->nsurf = 1; + znew->area_redu = NULL; return(zone_list = znew); } @@ -174,7 +177,11 @@ add_subsurf(IDF_OBJECT *param) static IDF_FIELD * get_vlist(IDF_OBJECT *param, const char *zname) { - int i = 0; +#define itm_len (sizeof(IDF_FIELD)+6) + static char fld_buf[4*itm_len]; + static char *next_fbp = fld_buf; + int i; + IDF_FIELD *res; /* check if subsurface */ if (!strcmp(param->pname, SUBSURF_PNAME)) { if (zname != NULL) { @@ -183,20 +190,37 @@ get_vlist(IDF_OBJECT *param, const char *zname) if (strcmp((*(ZONE *)lep->data).zname, zname)) return(NULL); } - return(idf_getfield(param, SS_VERT_FLD)); + res = idf_getfield(param, SS_VERT_FLD); + } else { + i = 0; /* check for surface type */ + while (strcmp(surf_type[i].pname, param->pname)) + if (surf_type[++i].pname == NULL) + return(NULL); + + if (zname != NULL) { /* matches specified zone? */ + IDF_FIELD *fptr = idf_getfield(param, surf_type[i].zone_fld); + if (fptr == NULL || strcmp(fptr->val, zname)) + return(NULL); + } + res = idf_getfield(param, surf_type[i].vert_fld); } - /* check for surface type */ - while (strcmp(surf_type[i].pname, param->pname)) - if (surf_type[++i].pname == NULL) + if (!res->val[0]) { /* hack for missing #vert */ + IDF_FIELD *fptr; + if (next_fbp >= fld_buf+sizeof(fld_buf)) + next_fbp = fld_buf; + i = 0; /* count vertices */ + for (fptr = res->next; fptr != NULL; fptr = fptr->next) + ++i; + if (i % 3) return(NULL); - - if (zname != NULL) { /* matches specified zone? */ - IDF_FIELD *fptr = idf_getfield(param, surf_type[i].zone_fld); - if (fptr == NULL || strcmp(fptr->val, zname)) - return(NULL); + fptr = res->next; + res = (IDF_FIELD *)next_fbp; next_fbp += itm_len; + res->next = fptr; + res->rem = ""; + sprintf(res->val, "%d", i/3); } - /* return field for #verts */ - return(idf_getfield(param, surf_type[i].vert_fld)); + return(res); +#undef itm_len } /* Get/allocate surface polygon */ @@ -297,16 +321,17 @@ rad_surface(IDF_OBJECT *param, FILE *ofp) } /* Convert subsurface to Radiance with modifier based on unique name */ -static int +static double rad_subsurface(IDF_OBJECT *param, FILE *ofp) { const char *sname = idf_getfield(param,NAME_FLD)->val; - SURFACE *surf = get_surface(idf_getfield(param,SS_VERT_FLD)); + SURFACE *surf = get_surface(get_vlist(param, NULL)); + double area; int i; if (surf == NULL) { fprintf(stderr, "%s: bad subsurface '%s'\n", progname, sname); - return(0); + return(-1.); } fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname); fprintf(ofp, "\n'%s' polygon 'ss_%s'\n0\n0\n%d\n", @@ -316,8 +341,11 @@ rad_subsurface(IDF_OBJECT *param, FILE *ofp) VSUM(vert, surf->vl[i], surf->norm, 2.*SURF_EPS); fprintf(ofp, "\t%.12f %.12f %.12f\n", vert[0], vert[1], vert[2]); } + area = surf->area; free(surf); - return(!ferror(ofp)); + if (ferror(ofp)) + return(-1.); + return(area); } /* Start rcontrib process */ @@ -333,9 +361,9 @@ start_rcontrib(SUBPROC *pd, ZONE *zp) FILE *ofp; IDF_OBJECT *pptr; IDF_FIELD *fptr; - int i, n; + int i, j, n; /* start oconv command */ - sprintf(cbuf, "oconv - > '%s'", temp_octree); + sprintf(cbuf, "oconv - > \"%s\"", temp_octree); if ((ofp = popen(cbuf, "w")) == NULL) { fputs(progname, stderr); fputs(": cannot open oconv process\n", stderr); @@ -363,15 +391,34 @@ start_rcontrib(SUBPROC *pd, ZONE *zp) av[i++] = fptr->val; } /* now subsurfaces */ + if (zp->ntotal > zp->nsurf) { + if (zp->area_redu != NULL) + memset(zp->area_redu, 0, sizeof(float)*zp->ntotal); + else if ((zp->area_redu = (float *)calloc(zp->ntotal, + sizeof(float))) == NULL) + return(0); + } for ( ; n < zp->ntotal; n++, pptr = pptr->dnext) { + double ssarea; + const char *bname; + IDF_OBJECT *pptr1; fptr = idf_getfield(pptr,NAME_FLD); if (fptr == NULL || !fptr->val[0]) { fputs(progname, stderr); fputs(": missing name for subsurface object\n", stderr); return(0); } - if (!rad_subsurface(pptr, ofp)) /* add surface to octree */ + /* add subsurface to octree */ + if ((ssarea = rad_subsurface(pptr, ofp)) < 0) return(0); + /* mark area for subtraction */ + bname = idf_getfield(pptr,SS_BASE_FLD)->val; + for (j = 0, pptr1 = zp->pfirst; + j < zp->nsurf; j++, pptr1 = pptr1->dnext) + if (!strcmp(idf_getfield(pptr1,NAME_FLD)->val, bname)) { + zp->area_redu[j] += ssarea; + break; + } av[i++] = "-m"; av[i++] = fptr->val; } @@ -492,10 +539,11 @@ sample_triangle(const Vert2_list *vl2, int a, int b, i } /* Sample the given surface */ -static int +static double sample_surface(IDF_OBJECT *param, int wd) { POLYSAMP psamp; + double area; int nv; Vert2_list *vlist2; /* set up our polygon sampler */ @@ -503,17 +551,19 @@ sample_surface(IDF_OBJECT *param, int wd) fprintf(stderr, "%s: bad polygon %s '%s'\n", progname, param->pname, idf_getfield(param,NAME_FLD)->val); - return(0); + return(-1.); } psamp.samp_left = nsamps; /* assign samples & destination */ psamp.wd = wd; /* hack for subsurface sampling */ psamp.poff += 2.*SURF_EPS * !strcmp(param->pname, SUBSURF_PNAME); + + area = psamp.area_left; /* remember starting surface area */ /* sample each subtriangle */ if (!polyTriangulate(vlist2, &sample_triangle)) - return(0); + return(-1.); polyFree(vlist2); /* clean up and return */ - return(1); + return(area); } /* Compute User View Factors using open rcontrib process */ @@ -545,9 +595,14 @@ compute_uvfs(SUBPROC *pd, ZONE *zp) /* UVFs from each surface */ for (n = 0, pptr = zp->pfirst; n < zp->ntotal; n++, pptr = pptr->dnext) { double vfsum = 0; + double adj_factor; /* send samples to rcontrib */ - if (!sample_surface(pptr, pd->w)) + if ((adj_factor = sample_surface(pptr, pd->w)) < 0) return(0); + if (zp->area_redu == NULL) + adj_factor = 1.; + else /* comp. for subsurface area */ + adj_factor /= adj_factor - zp->area_redu[n]; /* read results */ if (readbuf(pd->r, (char *)uvfa, sizeof(float)*3*zp->ntotal) != sizeof(float)*3*zp->ntotal) { @@ -558,13 +613,14 @@ compute_uvfs(SUBPROC *pd, ZONE *zp) /* append UVF fields */ for (m = 0, pptr1 = zp->pfirst; m < zp->ntotal; m++, pptr1 = pptr1->dnext) { - vfsum += uvfa[3*m + 1]; - if (pptr1 == pptr && uvfa[3*m + 1] > .001) + const double uvf = uvfa[3*m + 1] * adj_factor; + vfsum += uvf; + if (pptr1 == pptr && uvf > .001) fprintf(stderr, "%s: warning - non-zero self-VF (%.1f%%) for surface '%s'\n", - progname, 100.*uvfa[3*m + 1], + progname, 100.*uvf, idf_getfield(pptr,NAME_FLD)->val); - sprintf(uvfbuf, "%.4f", uvfa[3*m + 1]); + sprintf(uvfbuf, "%.4f", uvf); if (!idf_addfield(pout, idf_getfield(pptr,NAME_FLD)->val, NULL) || !idf_addfield(pout, @@ -653,6 +709,15 @@ main(int argc, char *argv[]) fputs("'\n", stderr); return(1); } + /* check version (warning) */ + if ((pptr = idf_getobject(our_idf, "Version")) != NULL && + pptr->flist != NULL && atoi(pptr->flist->val) != 7) { + fputs(progname, stderr); + fputs(": warning - written for IDF version 7.x, not ", + stderr); + fputs(pptr->flist->val, stderr); + fputc('\n', stderr); + } /* remove existing UVFs */ if ((pptr = idf_getobject(our_idf, UVF_PNAME)) != NULL) { IDF_OBJECT *pnext; @@ -661,7 +726,7 @@ main(int argc, char *argv[]) do { pnext = pptr->pnext; idf_delobject(our_idf, pptr); - } while (pnext != NULL); + } while ((pptr = pnext) != NULL); } /* add to header */ if (our_idf->hrem == NULL ||
