--- ray/src/util/eplus_adduvf.c 2014/02/09 05:49:21 2.1 +++ ray/src/util/eplus_adduvf.c 2014/02/09 22:19:30 2.2 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.1 2014/02/09 05:49:21 greg Exp $"; +static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.2 2014/02/09 22:19:30 greg Exp $"; #endif /* * Add User View Factors to EnergyPlus Input Data File @@ -12,15 +12,21 @@ static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.1 #include #include "eplus_idf.h" #include "triangulate.h" +#include "rtprocess.h" #ifndef NSAMPLES #define NSAMPLES 100000 /* number of samples to use */ #endif -#define UVF_PNAME "ZoneProperty:UserViewFactor:bySurfaceName" +char *progname; /* global argv[0] */ +char temp_octree[128]; /* temporary octree */ + +const char UVF_PNAME[] = + "ZoneProperty:UserViewFactor:bySurfaceName"; + const char ADD_HEADER[] = - "!+++ User View Factors computed by Radiance +++!\n"; + "!+++ User View Factors computed by Radiance +++!\n"; #define NAME_FLD 1 /* name field always first? */ @@ -35,34 +41,38 @@ const SURF_PTYPE surf_type[] = { {NULL} }; -struct s_zone { +typedef struct s_zone { const char *zname; /* zone name */ struct s_zone *next; /* next zone in list */ + int nsurf; /* surface count */ IDF_PARAMETER *pfirst; /* first matching parameter */ IDF_PARAMETER *plast; /* last matching parameter */ -} *zone_list = NULL; +} ZONE; /* a list of collected zone surfaces */ +ZONE *zone_list = NULL; /* our list of zones */ + IDF_LOADED *our_idf = NULL; /* loaded/modified IDF */ /* Create a new zone and push to top of our list */ -static struct s_zone * +static ZONE * new_zone(const char *zname, IDF_PARAMETER *param) { - struct s_zone *znew = (struct s_zone *)malloc(sizeof(struct s_zone)); + ZONE *znew = (ZONE *)malloc(sizeof(ZONE)); if (znew == NULL) return(NULL); znew->zname = zname; /* assumes static */ znew->next = zone_list; znew->pfirst = znew->plast = param; + znew->nsurf = 1; return(zone_list = znew); } /* Add the detailed surface (polygon) to the named zone */ -static struct s_zone * +static ZONE * add2zone(IDF_PARAMETER *param, const char *zname) { - struct s_zone *zptr; + ZONE *zptr; for (zptr = zone_list; zptr != NULL; zptr = zptr->next) if (!strcmp(zptr->zname, zname)) @@ -73,29 +83,175 @@ add2zone(IDF_PARAMETER *param, const char *zname) if (!idf_movparam(our_idf, param, zptr->plast)) return(NULL); zptr->plast = param; + zptr->nsurf++; return(zptr); } +/* Determine if a parameter is a surface in the indicated zone */ +static int +in_zone(IDF_PARAMETER *param, const char *zname) +{ + int i = 0; + IDF_FIELD *fptr; + /* check for surface type */ + while (strcmp(surf_type[i].pname, param->pname)) + if (surf_type[++i].pname == NULL) + return(0); + /* get zone field */ + fptr = idf_getfield(param, surf_type[i].zone_fld); + if (fptr == NULL) + return(0); + /* check for match */ + if (strcmp(fptr->arg, zname)) + return(0); + /* return field for #verts */ + return(surf_type[i].vert_fld); +} + +/* Convert surface to Radiance with modifier based on unique name */ +static int +rad_surface(const char *zname, IDF_PARAMETER *param, FILE *ofp) +{ + const char *sname = idf_getfield(param, NAME_FLD)->arg; + IDF_FIELD *fptr = idf_getfield(param, in_zone(param, zname)); + int nvert, i; + + if (fptr == NULL || (nvert = atoi(fptr->arg)) < 3) { + fprintf(stderr, "%s: bad surface '%s'\n", progname, sname); + return(0); + } + fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname); + fprintf(ofp, "\n'%s' polygon 's_%s'\n0\n0\n%d\n", sname, sname, 3*nvert); + while (nvert--) { + for (i = 3; i--; ) { + fptr = fptr->next; + if (fptr == NULL) { + fprintf(stderr, + "%s: missing vertex fields in surface '%s'\n", + progname, sname); + return(0); + } + fputc('\t', ofp); + fputs(fptr->arg, ofp); + } + fputc('\n', ofp); + } + return(!ferror(ofp)); +} + +/* Strat rcontrib process */ +static int +start_rcontrib(SUBPROC *pd, ZONE *zp) +{ +#define BASE_AC 3 + static char *base_av[BASE_AC] = { + "rcontrib", "-ff", "-h" + }; + char cbuf[300]; + char **av; + FILE *ofp; + IDF_PARAMETER *pptr; + int i, n; + /* start oconv command */ + sprintf(cbuf, "oconv - > '%s'", temp_octree); + if ((ofp = popen(cbuf, "w")) == NULL) { + fputs(progname, stderr); + fputs(": cannot open oconv process\n", stderr); + return(0); + } + /* allocate argument list */ + av = (char **)malloc(sizeof(char *)*(BASE_AC+4+2*zp->nsurf)); + if (av == NULL) + return(0); + for (i = 0; i < BASE_AC; i++) + av[i] = base_av[i]; + sprintf(cbuf, "%d", NSAMPLES); + av[i++] = "-c"; + av[i++] = cbuf; /* add modifier arguments */ + for (n = zp->nsurf, pptr = zp->pfirst; n--; pptr = pptr->dnext) { + IDF_FIELD *fptr = idf_getfield(pptr, NAME_FLD); + if (fptr == NULL) { + fputs(progname, stderr); + fputs(": missing name for surface parameter\n", stderr); + return(0); + } + av[i++] = "-m"; + av[i++] = fptr->arg; + if (!rad_surface(zp->zname, pptr, ofp)) + return(0); + } + if (pclose(ofp) != 0) { /* finish oconv */ + fputs(progname, stderr); + fputs(": error running oconv process\n", stderr); + return(0); + } + av[i++] = temp_octree; /* add final octree argument */ + av[i] = NULL; + if (!open_process(pd, av)) { /* start process */ + fputs(progname, stderr); + fputs(": cannot start rcontrib process\n", stderr); + return(0); + } + free(av); /* all done -- clean up */ + return(1); +#undef BASE_AC +} + +/* Compute User View Factors using open rcontrib process */ +static int +compute_uvfs(SUBPROC *pd, ZONE *sp) +{ + +} + /* Compute zone User View Factors */ static int compute_zones(void) { - fputs("compute_zones() unimplemented\n", stderr); - return(0); + ZONE *zptr; + /* temporary octree name */ + if (temp_filename(temp_octree, sizeof(temp_octree), TEMPLATE) == NULL) { + fputs(progname, stderr); + fputs(": cannot create temporary octree\n", stderr); + return(0); + } + /* compute each zone */ + for (zptr = zone_list; zptr != NULL; zptr = zptr->next) { + SUBPROC rcproc; + /* start rcontrib process */ + if (!start_rcontrib(&rcproc, zptr)) + return(0); + /* compute+add view factors */ + if (!compute_uvfs(&rcproc, zptr)) + return(0); + if (close_process(&rcproc) != 0) { + fputs(progname, stderr); + fputs(": bad return status from rcontrib\n", stderr); + return(0); + } + } + unlink(temp_octree); /* remove octree file */ + return(1); } /* Load IDF and compute User View Factors */ int main(int argc, char *argv[]) { + int incl_comments = 1; char *origIDF, *revIDF; IDF_PARAMETER *pptr; int i; + progname = argv[0]; + if (argc > 2 && !strcmp(argv[1], "-c")) { + incl_comments = -1; /* output header only */ + ++argv; --argc; + } if ((argc < 2) | (argc > 3)) { fputs("Usage: ", stderr); - fputs(argv[0], stderr); - fputs(" Model.idf [Revised.idf]\n", stderr); + fputs(progname, stderr); + fputs(" [-c] Model.idf [Revised.idf]\n", stderr); return(1); } origIDF = argv[1]; @@ -103,7 +259,7 @@ main(int argc, char *argv[]) /* load Input Data File */ our_idf = idf_load(origIDF); if (our_idf == NULL) { - fputs(argv[0], stderr); + fputs(progname, stderr); fputs(": cannot load IDF '", stderr); fputs(origIDF, stderr); fputs("'\n", stderr); @@ -112,7 +268,7 @@ main(int argc, char *argv[]) /* remove existing UVFs */ if ((pptr = idf_getparam(our_idf, UVF_PNAME)) != NULL) { IDF_PARAMETER *pnext; - fputs(argv[0], stderr); + fputs(progname, stderr); fputs(": removing previous User View Factors\n", stderr); do { pnext = pptr->pnext; @@ -131,7 +287,8 @@ main(int argc, char *argv[]) IDF_FIELD *fptr = idf_getfield(pptr, surf_type[i].zone_fld); if (fptr == NULL) { - fputs("Warning: missing zone field!\n", stderr); + fputs(progname, stderr); + fputs(": warning - missing zone field\n", stderr); continue; } if (add2zone(pptr, fptr->arg) == NULL) @@ -141,8 +298,8 @@ main(int argc, char *argv[]) if (!compute_zones()) return(1); /* write out modified IDF */ - if (!idf_write(our_idf, revIDF, 1)) { - fputs(argv[0], stderr); + if (!idf_write(our_idf, revIDF, incl_comments)) { + fputs(progname, stderr); fputs(": error writing IDF '", stderr); fputs(revIDF, stderr); fputs("'\n", stderr);
