| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.2 2014/02/09 22:19:30 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Add User View Factors to EnergyPlus Input Data File
| 6 |
| 7 |
* G.Ward for LBNL
| 8 |
| 9 |
| 10 |
#include <stdlib.h>
| 11 |
#include "rtio.h"
| 12 |
#include "rtmath.h"
| 13 |
#include "random.h"
| 14 |
#include "eplus_idf.h"
| 15 |
#include "triangulate.h"
| 16 |
#include "rtprocess.h"
| 17 |
| 18 |
#ifndef NSAMPLES
| 19 |
#define NSAMPLES 100000 /* number of samples to use */
| 20 |
#endif
| 21 |
| 22 |
char *progname; /* global argv[0] */
| 23 |
| 24 |
char temp_octree[128]; /* temporary octree */
| 25 |
| 26 |
const char UVF_PNAME[] =
| 27 |
"ZoneProperty:UserViewFactor:bySurfaceName";
| 28 |
| 29 |
const char ADD_HEADER[] =
| 30 |
"!+++ User View Factors computed by Radiance +++!\n";
| 31 |
| 32 |
#define NAME_FLD 1 /* name field always first? */
| 33 |
| 34 |
typedef struct {
| 35 |
const char *pname; /* parameter type name */
| 36 |
short zone_fld; /* zone field index */
| 37 |
short vert_fld; /* vertex field index */
| 38 |
} SURF_PTYPE; /* surface type we're interested in */
| 39 |
| 40 |
const SURF_PTYPE surf_type[] = {
| 41 |
{"BuildingSurface:Detailed", 4, 10},
| 42 |
{NULL}
| 43 |
| 44 |
| 45 |
typedef struct s_zone {
| 46 |
const char *zname; /* zone name */
| 47 |
struct s_zone *next; /* next zone in list */
| 48 |
int nsurf; /* surface count */
| 49 |
IDF_PARAMETER *pfirst; /* first matching parameter */
| 50 |
IDF_PARAMETER *plast; /* last matching parameter */
| 51 |
} ZONE; /* a list of collected zone surfaces */
| 52 |
| 53 |
ZONE *zone_list = NULL; /* our list of zones */
| 54 |
| 55 |
IDF_LOADED *our_idf = NULL; /* loaded/modified IDF */
| 56 |
| 57 |
/* Create a new zone and push to top of our list */
| 58 |
static ZONE *
| 59 |
new_zone(const char *zname, IDF_PARAMETER *param)
| 60 |
| 61 |
ZONE *znew = (ZONE *)malloc(sizeof(ZONE));
| 62 |
| 63 |
if (znew == NULL)
| 64 |
return(NULL);
| 65 |
znew->zname = zname; /* assumes static */
| 66 |
znew->next = zone_list;
| 67 |
znew->pfirst = znew->plast = param;
| 68 |
znew->nsurf = 1;
| 69 |
return(zone_list = znew);
| 70 |
| 71 |
| 72 |
/* Add the detailed surface (polygon) to the named zone */
| 73 |
static ZONE *
| 74 |
add2zone(IDF_PARAMETER *param, const char *zname)
| 75 |
| 76 |
ZONE *zptr;
| 77 |
| 78 |
for (zptr = zone_list; zptr != NULL; zptr = zptr->next)
| 79 |
if (!strcmp(zptr->zname, zname))
| 80 |
break;
| 81 |
if (zptr == NULL)
| 82 |
return(new_zone(zname, param));
| 83 |
/* keep surfaces together */
| 84 |
if (!idf_movparam(our_idf, param, zptr->plast))
| 85 |
return(NULL);
| 86 |
zptr->plast = param;
| 87 |
zptr->nsurf++;
| 88 |
return(zptr);
| 89 |
| 90 |
| 91 |
/* Return field for vertices in the given parameter */
| 92 |
static IDF_FIELD *
| 93 |
get_vlist(IDF_PARAMETER *param, const char *zname)
| 94 |
| 95 |
int i = 0;
| 96 |
IDF_FIELD *fptr;
| 97 |
/* check for surface type */
| 98 |
while (strcmp(surf_type[i].pname, param->pname))
| 99 |
if (surf_type[++i].pname == NULL)
| 100 |
return(NULL);
| 101 |
| 102 |
if (zname != NULL) { /* matches specified zone? */
| 103 |
fptr = idf_getfield(param, surf_type[i].zone_fld);
| 104 |
if (fptr == NULL || strcmp(fptr->val, zname))
| 105 |
return(NULL);
| 106 |
| 107 |
/* return field for #verts */
| 108 |
return(idf_getfield(param, surf_type[i].vert_fld));
| 109 |
| 110 |
| 111 |
/* Convert surface to Radiance with modifier based on unique name */
| 112 |
static int
| 113 |
rad_surface(IDF_PARAMETER *param, FILE *ofp)
| 114 |
| 115 |
const char *sname = idf_getfield(param,NAME_FLD)->val;
| 116 |
IDF_FIELD *fptr = get_vlist(param, NULL);
| 117 |
int nvert, i;
| 118 |
| 119 |
if (fptr == NULL || (nvert = atoi(fptr->val)) < 3) {
| 120 |
fprintf(stderr, "%s: bad surface '%s'\n", progname, sname);
| 121 |
return(0);
| 122 |
| 123 |
fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname);
| 124 |
fprintf(ofp, "\n'%s' polygon 's_%s'\n0\n0\n%d\n", sname, sname, 3*nvert);
| 125 |
while (nvert--) {
| 126 |
for (i = 3; i--; ) {
| 127 |
fptr = fptr->next;
| 128 |
if (fptr == NULL || !isflt(fptr->val)) {
| 129 |
fprintf(stderr,
| 130 |
"%s: missing/bad vertex for %s '%s'\n",
| 131 |
progname, param->pname, sname);
| 132 |
return(0);
| 133 |
| 134 |
fputc('\t', ofp);
| 135 |
fputs(fptr->val, ofp);
| 136 |
| 137 |
fputc('\n', ofp);
| 138 |
| 139 |
return(!ferror(ofp));
| 140 |
| 141 |
| 142 |
/* Start rcontrib process */
| 143 |
static int
| 144 |
start_rcontrib(SUBPROC *pd, ZONE *zp)
| 145 |
| 146 |
#define BASE_AC 3
| 147 |
static char *base_av[BASE_AC] = {
| 148 |
"rcontrib", "-ff", "-h"
| 149 |
| 150 |
char cbuf[300];
| 151 |
char **av;
| 152 |
FILE *ofp;
| 153 |
IDF_PARAMETER *pptr;
| 154 |
int i, n;
| 155 |
/* start oconv command */
| 156 |
sprintf(cbuf, "oconv - > '%s'", temp_octree);
| 157 |
if ((ofp = popen(cbuf, "w")) == NULL) {
| 158 |
fputs(progname, stderr);
| 159 |
fputs(": cannot open oconv process\n", stderr);
| 160 |
return(0);
| 161 |
| 162 |
/* allocate argument list */
| 163 |
av = (char **)malloc(sizeof(char *)*(BASE_AC+4+2*zp->nsurf));
| 164 |
if (av == NULL)
| 165 |
return(0);
| 166 |
for (i = 0; i < BASE_AC; i++)
| 167 |
av[i] = base_av[i];
| 168 |
sprintf(cbuf, "%d", NSAMPLES);
| 169 |
av[i++] = "-c";
| 170 |
av[i++] = cbuf; /* add modifier arguments */
| 171 |
for (n = zp->nsurf, pptr = zp->pfirst; n--; pptr = pptr->dnext) {
| 172 |
IDF_FIELD *fptr = idf_getfield(pptr,NAME_FLD);
| 173 |
if (fptr == NULL || !fptr->val[0]) {
| 174 |
| 175 |
fputs(": missing name for surface parameter\n", stderr);
| 176 |
return(0);
| 177 |
| 178 |
if (!rad_surface(pptr, ofp)) /* add surface to octree */
| 179 |
return(0);
| 180 |
av[i++] = "-m";
| 181 |
av[i++] = fptr->val;
| 182 |
| 183 |
if (pclose(ofp) != 0) { /* finish oconv */
| 184 |
| 185 |
fputs(": error running oconv process\n", stderr);
| 186 |
return(0);
| 187 |
| 188 |
av[i++] = temp_octree; /* add final octree argument */
| 189 |
av[i] = NULL;
| 190 |
if (!open_process(pd, av)) { /* start process */
| 191 |
| 192 |
fputs(": cannot start rcontrib process\n", stderr);
| 193 |
return(0);
| 194 |
| 195 |
free(av); /* all done -- clean up */
| 196 |
return(1);
| 197 |
#undef BASE_AC
| 198 |
| 199 |
| 200 |
typedef struct {
| 201 |
FVECT sdir[3]; /* XYZ unit sampling vectors */
| 202 |
double poff; /* Z-offset for plane of polygon */
| 203 |
double area_left; /* area left to sample */
| 204 |
int samp_left; /* remaining samples */
| 205 |
int wd; /* output file descriptor */
| 206 |
} POLYSAMP; /* structure for polygon sampling */
| 207 |
| 208 |
/* Initialize polygon sampling */
| 209 |
static Vert2_list *
| 210 |
init_poly(POLYSAMP *ps, IDF_FIELD *f0, int nv)
| 211 |
| 212 |
IDF_FIELD *fptr = f0;
| 213 |
int i, j;
| 214 |
FVECT *vl3, e1, e2, vc;
| 215 |
Vert2_list *vl2 = polyAlloc(nv);
| 216 |
| 217 |
if (vl2 == NULL)
| 218 |
return(NULL);
| 219 |
vl2->p = ps;
| 220 |
/* get 3-D vertices */
| 221 |
vl3 = (FVECT *)malloc(sizeof(FVECT)*nv);
| 222 |
if (vl3 == NULL)
| 223 |
return(NULL);
| 224 |
for (i = 0; i < nv; i++)
| 225 |
for (j = 0; j < 3; j++) {
| 226 |
if (fptr == NULL) {
| 227 |
| 228 |
fputs(": bad vertex in init_poly()\n", stderr);
| 229 |
return(NULL);
| 230 |
| 231 |
vl3[i][j] = atof(fptr->val);
| 232 |
| 233 |
/* compute area and normal */
| 234 |
ps->sdir[2][0] = ps->sdir[2][1] = ps->sdir[2][2] = 0;
| 235 |
VSUB(e1, vl3[1], vl3[0]);
| 236 |
for (i = 2; i < nv; i++) {
| 237 |
VSUB(e2, vl3[i], vl3[0]);
| 238 |
fcross(vc, e1, e2);
| 239 |
ps->sdir[2][0] += vc[0];
| 240 |
ps->sdir[2][1] += vc[1];
| 241 |
ps->sdir[2][2] += vc[2];
| 242 |
VCOPY(e1, e2);
| 243 |
| 244 |
ps->area_left = .5 * normalize(ps->sdir[2]);
| 245 |
if (ps->area_left == .0) {
| 246 |
| 247 |
fputs(": degenerate polygon in init_poly()\n", stderr);
| 248 |
return(0);
| 249 |
| 250 |
/* create X & Y axes */
| 251 |
VCOPY(ps->sdir[0], e1);
| 252 |
normalize(ps->sdir[0]);
| 253 |
fcross(ps->sdir[1], ps->sdir[2], ps->sdir[0]);
| 254 |
/* compute plane offset */
| 255 |
ps->poff = DOT(vl3[0], ps->sdir[2]) + FTINY;
| 256 |
/* assign 2-D vertices */
| 257 |
for (i = 0; i < nv; i++) {
| 258 |
vl2->v[i].mX = DOT(vl3[i], ps->sdir[0]);
| 259 |
vl2->v[i].mY = DOT(vl3[i], ps->sdir[1]);
| 260 |
| 261 |
free(vl3); /* it's ready! */
| 262 |
return(vl2);
| 263 |
| 264 |
| 265 |
/* Generate samples on 2-D triangle */
| 266 |
static int
| 267 |
sample_triangle(const Vert2_list *vl2, int a, int b, int c)
| 268 |
| 269 |
POLYSAMP *ps = (POLYSAMP *)vl2->p;
| 270 |
float *samp;
| 271 |
FVECT orig;
| 272 |
FVECT ab, ac;
| 273 |
double area;
| 274 |
int i, j, ns;
| 275 |
/* compute sampling axes */
| 276 |
| 277 |
orig[i] = vl2->v[a].mX*ps->sdir[0][i] +
| 278 |
vl2->v[a].mY*ps->sdir[1][i] +
| 279 |
ps->poff*ps->sdir[2][i];
| 280 |
ab[i] = (vl2->v[b].mX - vl2->v[a].mX)*ps->sdir[0][i] +
| 281 |
(vl2->v[b].mY - vl2->v[a].mY)*ps->sdir[1][i];
| 282 |
ac[i] = (vl2->v[c].mX - vl2->v[a].mX)*ps->sdir[0][i] +
| 283 |
(vl2->v[c].mY - vl2->v[a].mY)*ps->sdir[1][i];
| 284 |
| 285 |
/* compute number of samples to take */
| 286 |
area = .5*(vl2->v[a].mX*vl2->v[b].mY - vl2->v[b].mX*vl2->v[a].mY +
| 287 |
vl2->v[b].mX*vl2->v[c].mY - vl2->v[c].mX*vl2->v[b].mY +
| 288 |
vl2->v[c].mX*vl2->v[a].mY - vl2->v[a].mX*vl2->v[c].mY);
| 289 |
if (area < .0) {
| 290 |
| 291 |
fputs(": negative triangle area in sample_triangle()\n", stderr);
| 292 |
return(0);
| 293 |
| 294 |
if (area >= ps->area_left) {
| 295 |
ns = ps->samp_left;
| 296 |
ps->area_left = 0;
| 297 |
} else {
| 298 |
ns = (ps->samp_left*area/ps->area_left + .5);
| 299 |
ps->samp_left -= ns;
| 300 |
ps->area_left -= area;
| 301 |
| 302 |
if (ns <= 0) /* XXX should be error? */
| 303 |
return(1);
| 304 |
/* buffer sample rays */
| 305 |
samp = (float *)malloc(sizeof(float)*6*ns);
| 306 |
if (samp == NULL)
| 307 |
return(0);
| 308 |
for (i = ns; i--; ) {
| 309 |
double sv[4];
| 310 |
multisamp(sv, 4, (i+frandom())/(double)ns);
| 311 |
sv[0] *= sv[1] = sqrt(sv[1]);
| 312 |
sv[1] = 1. - sv[1];
| 313 |
for (j = 3; j--; )
| 314 |
samp[ns*6 + j] = orig[j] + sv[0]*ab[j] + sv[1]*ac[j];
| 315 |
sv[3] = sqrt(sv[3]);
| 316 |
sv[4] *= 2.*PI;
| 317 |
samp[ns*6 + 3] = tcos(sv[4]) * sv[3];
| 318 |
samp[ns*6 + 4] = tsin(sv[4]) * sv[3];
| 319 |
samp[ns*6 + 5] = sqrt(1. - sv[3]*sv[3]);
| 320 |
| 321 |
/* send to our process */
| 322 |
writebuf(ps->wd, (char *)samp, sizeof(float)*6*ns);
| 323 |
free(samp); /* that's it! */
| 324 |
return(1);
| 325 |
| 326 |
| 327 |
/* Sample the given surface */
| 328 |
static int
| 329 |
sample_surface(IDF_PARAMETER *param, int wd)
| 330 |
| 331 |
| 332 |
POLYSAMP psamp;
| 333 |
int nv;
| 334 |
Vert2_list *vlist2;
| 335 |
/* set up our polygon sampler */
| 336 |
if (fptr == NULL || (nv = atoi(fptr->val)) < 3) {
| 337 |
fprintf(stderr, "%s: error in %s '%s'\n",
| 338 |
| 339 |
idf_getfield(param,NAME_FLD)->val);
| 340 |
return(0);
| 341 |
| 342 |
vlist2 = init_poly(&psamp, fptr->next, nv);
| 343 |
if (vlist2 == NULL)
| 344 |
return(0);
| 345 |
psamp.samp_left = NSAMPLES; /* assign samples & destination */
| 346 |
psamp.wd = wd;
| 347 |
/* sample each subtriangle */
| 348 |
if (!polyTriangulate(vlist2, &sample_triangle))
| 349 |
return(0);
| 350 |
polyFree(vlist2); /* clean up and return */
| 351 |
return(1);
| 352 |
| 353 |
| 354 |
/* Compute User View Factors using open rcontrib process */
| 355 |
static int
| 356 |
compute_uvfs(SUBPROC *pd, ZONE *zp)
| 357 |
| 358 |
IDF_PARAMETER *pptr, *pout, *pptr1;
| 359 |
float *uvfa;
| 360 |
char uvfbuf[24];
| 361 |
int n, m;
| 362 |
/* create output parameter */
| 363 |
pout = idf_newparam(our_idf, UVF_PNAME,
| 364 |
" ! computed by Radiance\n ", zp->plast);
| 365 |
if (pout == NULL) {
| 366 |
| 367 |
fputs(": cannot create new IDF parameter\n", stderr);
| 368 |
return(0);
| 369 |
| 370 |
if (!idf_addfield(pout, zp->zname,
| 371 |
" !- Zone Name\n ")) {
| 372 |
| 373 |
fputs(": cannot add zone name field\n", stderr);
| 374 |
return(0);
| 375 |
| 376 |
/* allocate read buffer */
| 377 |
uvfa = (float *)malloc(sizeof(float)*3*zp->nsurf);
| 378 |
if (uvfa == NULL)
| 379 |
return(0);
| 380 |
/* UVFs from each surface */
| 381 |
| 382 |
/* send samples to rcontrib */
| 383 |
if (!sample_surface(pptr, pd->w))
| 384 |
return(0);
| 385 |
/* read results */
| 386 |
if (readbuf(pd->r, (char *)uvfa, sizeof(float)*3*zp->nsurf) !=
| 387 |
sizeof(float)*3*zp->nsurf) {
| 388 |
| 389 |
fputs(": read error from rcontrib process\n", stderr);
| 390 |
return(0);
| 391 |
| 392 |
/* append UVF fields */
| 393 |
for (m = 0, pptr1 = zp->pfirst;
| 394 |
m < zp->nsurf; m++, pptr1 = pptr1->dnext) {
| 395 |
if (pptr1 == pptr) {
| 396 |
if (uvfa[3*m + 1] > .001)
| 397 |
fprintf(stderr,
| 398 |
"%s: warning - non-zero self-VF (%.3e) for surface '%s'\n",
| 399 |
progname, uvfa[3*m + 1],
| 400 |
idf_getfield(pptr,NAME_FLD)->val);
| 401 |
continue; /* don't record self-factor */
| 402 |
| 403 |
sprintf(uvfbuf, "%.6f", uvfa[3*m + 1]);
| 404 |
| 405 |
idf_getfield(pptr,NAME_FLD)->val, NULL) ||
| 406 |
!idf_addfield(pout,
| 407 |
idf_getfield(pptr1,NAME_FLD)->val, NULL) ||
| 408 |
!idf_addfield(pout, uvfbuf,
| 409 |
(n || m < zp->nsurf-2) ?
| 410 |
"\n " : "\n\n")) {
| 411 |
| 412 |
fputs(": error adding UVF fields\n", stderr);
| 413 |
return(0);
| 414 |
| 415 |
| 416 |
| 417 |
free(uvfa); /* clean up and return */
| 418 |
return(1);
| 419 |
| 420 |
| 421 |
/* Compute zone User View Factors */
| 422 |
static int
| 423 |
compute_zones(void)
| 424 |
| 425 |
ZONE *zptr;
| 426 |
/* temporary octree name */
| 427 |
if (temp_filename(temp_octree, sizeof(temp_octree), TEMPLATE) == NULL) {
| 428 |
| 429 |
fputs(": cannot create temporary octree\n", stderr);
| 430 |
return(0);
| 431 |
| 432 |
/* compute each zone */
| 433 |
for (zptr = zone_list; zptr != NULL; zptr = zptr->next) {
| 434 |
SUBPROC rcproc;
| 435 |
/* start rcontrib process */
| 436 |
if (!start_rcontrib(&rcproc, zptr))
| 437 |
return(0);
| 438 |
/* compute+add view factors */
| 439 |
if (!compute_uvfs(&rcproc, zptr))
| 440 |
return(0);
| 441 |
if (close_process(&rcproc) != 0) {
| 442 |
| 443 |
fputs(": bad return status from rcontrib\n", stderr);
| 444 |
return(0);
| 445 |
| 446 |
| 447 |
unlink(temp_octree); /* remove octree file */
| 448 |
return(1);
| 449 |
| 450 |
| 451 |
/* Load IDF and compute User View Factors */
| 452 |
int
| 453 |
main(int argc, char *argv[])
| 454 |
| 455 |
int incl_comments = 1;
| 456 |
char *origIDF, *revIDF;
| 457 |
| 458 |
int i;
| 459 |
| 460 |
progname = argv[0];
| 461 |
if (argc > 2 && !strcmp(argv[1], "-c")) {
| 462 |
incl_comments = -1; /* output header only */
| 463 |
++argv; --argc;
| 464 |
| 465 |
if ((argc < 2) | (argc > 3)) {
| 466 |
fputs("Usage: ", stderr);
| 467 |
| 468 |
fputs(" [-c] Model.idf [Revised.idf]\n", stderr);
| 469 |
return(1);
| 470 |
| 471 |
origIDF = argv[1];
| 472 |
revIDF = (argc == 2) ? argv[1] : argv[2];
| 473 |
/* load Input Data File */
| 474 |
our_idf = idf_load(origIDF);
| 475 |
if (our_idf == NULL) {
| 476 |
| 477 |
fputs(": cannot load IDF '", stderr);
| 478 |
fputs(origIDF, stderr);
| 479 |
fputs("'\n", stderr);
| 480 |
return(1);
| 481 |
| 482 |
/* remove existing UVFs */
| 483 |
if ((pptr = idf_getparam(our_idf, UVF_PNAME)) != NULL) {
| 484 |
IDF_PARAMETER *pnext;
| 485 |
| 486 |
fputs(": removing previous User View Factors\n", stderr);
| 487 |
do {
| 488 |
pnext = pptr->pnext;
| 489 |
idf_delparam(our_idf, pptr);
| 490 |
} while (pnext != NULL);
| 491 |
| 492 |
/* add to header */
| 493 |
if (our_idf->hrem == NULL ||
| 494 |
(i = strlen(our_idf->hrem)-strlen(ADD_HEADER)) < 0 ||
| 495 |
strcmp(our_idf->hrem+i, ADD_HEADER))
| 496 |
idf_add2hdr(our_idf, ADD_HEADER);
| 497 |
/* gather zone surfaces */
| 498 |
for (i = 0; surf_type[i].pname != NULL; i++)
| 499 |
for (pptr = idf_getparam(our_idf, surf_type[i].pname);
| 500 |
pptr != NULL; pptr = pptr->pnext) {
| 501 |
| 502 |
| 503 |
if (fptr == NULL) {
| 504 |
| 505 |
fputs(": warning - missing zone field\n", stderr);
| 506 |
continue;
| 507 |
| 508 |
if (add2zone(pptr, fptr->val) == NULL)
| 509 |
return(1);
| 510 |
| 511 |
/* run rcontrib on each zone */
| 512 |
if (!compute_zones())
| 513 |
return(1);
| 514 |
/* write out modified IDF */
| 515 |
if (!idf_write(our_idf, revIDF, incl_comments)) {
| 516 |
| 517 |
fputs(": error writing IDF '", stderr);
| 518 |
fputs(revIDF, stderr);
| 519 |
| 520 |
return(1);
| 521 |
| 522 |
return(0); /* finito! */
| 523 |
