| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.14 2014/02/27 22:42:53 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Add User View Factors to EnergyPlus Input Data File
| 6 |
| 7 |
* G.Ward for LBNL
| 8 |
| 9 |
| 10 |
#include <stdlib.h>
| 11 |
#include "rtio.h"
| 12 |
#include "rtmath.h"
| 13 |
#include "random.h"
| 14 |
#include "eplus_idf.h"
| 15 |
#include "triangulate.h"
| 16 |
#include "rtprocess.h"
| 17 |
| 18 |
#ifndef NSAMPLES
| 19 |
#define NSAMPLES 80000 /* default number of samples */
| 20 |
#endif
| 21 |
| 22 |
#define SURF_EPS 0.0005 /* surface testing epsilon */
| 23 |
| 24 |
char *progname; /* global argv[0] */
| 25 |
| 26 |
int nsamps = NSAMPLES; /* number of samples to use */
| 27 |
| 28 |
char temp_octree[128]; /* temporary octree */
| 29 |
| 30 |
const char UVF_PNAME[] =
| 31 |
"ZoneProperty:UserViewFactors:bySurfaceName";
| 32 |
| 33 |
const char SUBSURF_PNAME[] =
| 34 |
"FenestrationSurface:Detailed";
| 35 |
| 36 |
const char ADD_HEADER[] =
| 37 |
"\n!+++ User View Factors computed by Radiance +++!\n\n";
| 38 |
| 39 |
#define NAME_FLD 1 /* name field always first? */
| 40 |
| 41 |
#define SS_BASE_FLD 4 /* subsurface base surface */
| 42 |
#define SS_VERT_FLD 10 /* subsurface vertex count */
| 43 |
| 44 |
typedef struct {
| 45 |
const char *pname; /* object type name */
| 46 |
short zone_fld; /* zone field index */
| 47 |
short vert_fld; /* vertex field index */
| 48 |
} SURF_PTYPE; /* surface type we're interested in */
| 49 |
| 50 |
const SURF_PTYPE surf_type[] = {
| 51 |
{"BuildingSurface:Detailed", 4, 10},
| 52 |
{"Floor:Detailed", 3, 9},
| 53 |
{"RoofCeiling:Detailed", 3, 9},
| 54 |
{"Wall:Detailed", 3, 9},
| 55 |
{NULL}
| 56 |
}; /* IDF surface types */
| 57 |
| 58 |
typedef struct s_zone {
| 59 |
const char *zname; /* zone name */
| 60 |
struct s_zone *next; /* next zone in list */
| 61 |
int nsurf; /* surface count */
| 62 |
int ntotal; /* surfaces+subsurfaces */
| 63 |
IDF_OBJECT *pfirst; /* first matching object */
| 64 |
IDF_OBJECT *plast; /* last before subsurfaces */
| 65 |
float *area_redu; /* subsurface area per surf. */
| 66 |
} ZONE; /* a list of collected zone surfaces */
| 67 |
| 68 |
ZONE *zone_list = NULL; /* our list of zones */
| 69 |
| 70 |
LUTAB zonesurf_lut = /* zone surface lookup table */
| 71 |
LU_SINIT(NULL,NULL);
| 72 |
| 73 |
IDF_LOADED *our_idf = NULL; /* loaded/modified IDF */
| 74 |
| 75 |
typedef struct {
| 76 |
FVECT norm; /* surface normal */
| 77 |
double area; /* surface area */
| 78 |
int nv; /* number of vertices */
| 79 |
FVECT vl[3]; /* vertex list (extends struct) */
| 80 |
} SURFACE; /* a polygonal surface */
| 81 |
| 82 |
typedef struct {
| 83 |
FVECT sdir[3]; /* UVW unit sampling vectors */
| 84 |
double poff; /* W-offset for plane of polygon */
| 85 |
double area_left; /* area left to sample */
| 86 |
int samp_left; /* remaining samples */
| 87 |
int wd; /* output file descriptor */
| 88 |
} POLYSAMP; /* structure for polygon sampling */
| 89 |
| 90 |
/* Create a new zone and push to top of our list */
| 91 |
static ZONE *
| 92 |
new_zone(const char *zname, IDF_OBJECT *param)
| 93 |
| 94 |
ZONE *znew = (ZONE *)malloc(sizeof(ZONE));
| 95 |
| 96 |
if (znew == NULL)
| 97 |
return(NULL);
| 98 |
znew->zname = zname; /* assumes static */
| 99 |
znew->next = zone_list;
| 100 |
znew->pfirst = znew->plast = param;
| 101 |
znew->ntotal = znew->nsurf = 1;
| 102 |
znew->area_redu = NULL;
| 103 |
return(zone_list = znew);
| 104 |
| 105 |
| 106 |
/* Add the detailed surface (polygon) to the named zone */
| 107 |
static ZONE *
| 108 |
add2zone(IDF_OBJECT *param, const char *zname)
| 109 |
| 110 |
IDF_FIELD *nfp = idf_getfield(param, NAME_FLD);
| 111 |
ZONE *zptr;
| 112 |
LUENT *lep;
| 113 |
| 114 |
if (nfp == NULL) {
| 115 |
fputs(progname, stderr);
| 116 |
fputs(": surface missing name field!\n", stderr);
| 117 |
return(NULL);
| 118 |
| 119 |
for (zptr = zone_list; zptr != NULL; zptr = zptr->next)
| 120 |
if (!strcmp(zptr->zname, zname))
| 121 |
break;
| 122 |
if (zptr == NULL) {
| 123 |
zptr = new_zone(zname, param);
| 124 |
} else { /* keep surfaces together */
| 125 |
if (!idf_movobject(our_idf, param, zptr->plast))
| 126 |
return(NULL);
| 127 |
zptr->plast = param;
| 128 |
zptr->nsurf++;
| 129 |
zptr->ntotal++;
| 130 |
| 131 |
/* add to lookup table */
| 132 |
lep = lu_find(&zonesurf_lut, nfp->val);
| 133 |
if (lep == NULL)
| 134 |
return(NULL);
| 135 |
if (lep->data != NULL) {
| 136 |
| 137 |
fputs(": duplicate surface name '", stderr);
| 138 |
fputs(nfp->val, stderr);
| 139 |
fputs("'\n", stderr);
| 140 |
return(NULL);
| 141 |
| 142 |
lep->key = nfp->val;
| 143 |
lep->data = (char *)zptr;
| 144 |
return(zptr);
| 145 |
| 146 |
| 147 |
/* Add a subsurface by finding its base surface and the corresponding zone */
| 148 |
static ZONE *
| 149 |
add_subsurf(IDF_OBJECT *param)
| 150 |
| 151 |
IDF_FIELD *bfp = idf_getfield(param, SS_BASE_FLD);
| 152 |
ZONE *zptr;
| 153 |
LUENT *lep;
| 154 |
| 155 |
if (bfp == NULL) {
| 156 |
| 157 |
fputs(": missing base field name in subsurface!\n", stderr);
| 158 |
return(NULL);
| 159 |
| 160 |
lep = lu_find(&zonesurf_lut, bfp->val); /* find base zone */
| 161 |
if (lep == NULL || lep->data == NULL) {
| 162 |
| 163 |
fputs(": cannot find referenced base surface '", stderr);
| 164 |
fputs(bfp->val, stderr);
| 165 |
| 166 |
return(NULL);
| 167 |
| 168 |
zptr = (ZONE *)lep->data; /* add this subsurface */
| 169 |
| 170 |
return(NULL);
| 171 |
zptr->ntotal++;
| 172 |
return(zptr);
| 173 |
| 174 |
| 175 |
/* Return field for vertices in the given object */
| 176 |
static IDF_FIELD *
| 177 |
get_vlist(IDF_OBJECT *param, const char *zname)
| 178 |
| 179 |
#define itm_len (sizeof(IDF_FIELD)+6)
| 180 |
static char fld_buf[4*itm_len];
| 181 |
static char *next_fbp = fld_buf;
| 182 |
int i;
| 183 |
IDF_FIELD *res;
| 184 |
/* check if subsurface */
| 185 |
if (!strcmp(param->pname, SUBSURF_PNAME)) {
| 186 |
if (zname != NULL) {
| 187 |
LUENT *lep = lu_find(&zonesurf_lut,
| 188 |
idf_getfield(param,SS_BASE_FLD)->val);
| 189 |
if (strcmp((*(ZONE *)lep->data).zname, zname))
| 190 |
return(NULL);
| 191 |
| 192 |
res = idf_getfield(param, SS_VERT_FLD);
| 193 |
} else {
| 194 |
i = 0; /* check for surface type */
| 195 |
while (strcmp(surf_type[i].pname, param->pname))
| 196 |
if (surf_type[++i].pname == NULL)
| 197 |
return(NULL);
| 198 |
| 199 |
if (zname != NULL) { /* matches specified zone? */
| 200 |
IDF_FIELD *fptr = idf_getfield(param, surf_type[i].zone_fld);
| 201 |
if (fptr == NULL || strcmp(fptr->val, zname))
| 202 |
return(NULL);
| 203 |
| 204 |
res = idf_getfield(param, surf_type[i].vert_fld);
| 205 |
| 206 |
if (!res->val[0]) { /* hack for missing #vert */
| 207 |
IDF_FIELD *fptr;
| 208 |
if (next_fbp >= fld_buf+sizeof(fld_buf))
| 209 |
next_fbp = fld_buf;
| 210 |
i = 0; /* count vertices */
| 211 |
for (fptr = res->next; fptr != NULL; fptr = fptr->next)
| 212 |
++i;
| 213 |
if (i % 3)
| 214 |
return(NULL);
| 215 |
fptr = res->next;
| 216 |
res = (IDF_FIELD *)next_fbp; next_fbp += itm_len;
| 217 |
res->next = fptr;
| 218 |
res->rem = "";
| 219 |
sprintf(res->val, "%d", i/3);
| 220 |
| 221 |
return(res);
| 222 |
#undef itm_len
| 223 |
| 224 |
| 225 |
/* Get/allocate surface polygon */
| 226 |
static SURFACE *
| 227 |
get_surface(IDF_FIELD *fptr)
| 228 |
| 229 |
SURFACE *surf;
| 230 |
int nv;
| 231 |
FVECT e1, e2, vc;
| 232 |
int i, j;
| 233 |
/* get number of vertices */
| 234 |
if (fptr == NULL || (nv = atoi(fptr->val)) < 3) {
| 235 |
| 236 |
fputs(": bad vertex count for surface!\n", stderr);
| 237 |
return(NULL);
| 238 |
| 239 |
surf = (SURFACE *)malloc(sizeof(SURFACE)+sizeof(FVECT)*(nv-3));
| 240 |
if (surf == NULL)
| 241 |
return(NULL);
| 242 |
surf->nv = nv;
| 243 |
for (i = nv; i--; ) /* reverse vertex order/orientation */
| 244 |
for (j = 0; j < 3; j++) {
| 245 |
fptr = fptr->next;
| 246 |
if (fptr == NULL) {
| 247 |
| 248 |
fputs(": missing vertex in get_surface()\n", stderr);
| 249 |
free(surf);
| 250 |
return(NULL);
| 251 |
| 252 |
if ((surf->vl[i][j] = atof(fptr->val)) == 0 &&
| 253 |
!isflt(fptr->val)) {
| 254 |
| 255 |
fputs(": bad vertex in get_surface()\n", stderr);
| 256 |
free(surf);
| 257 |
return(NULL);
| 258 |
| 259 |
| 260 |
/* compute area and normal */
| 261 |
surf->norm[0] = surf->norm[1] = surf->norm[2] = 0;
| 262 |
VSUB(e1, surf->vl[1], surf->vl[0]);
| 263 |
for (i = 2; i < nv; i++) {
| 264 |
VSUB(e2, surf->vl[i], surf->vl[0]);
| 265 |
fcross(vc, e1, e2);
| 266 |
surf->norm[0] += vc[0];
| 267 |
surf->norm[1] += vc[1];
| 268 |
surf->norm[2] += vc[2];
| 269 |
VCOPY(e1, e2);
| 270 |
| 271 |
surf->area = .5 * normalize(surf->norm);
| 272 |
if (surf->area == 0) {
| 273 |
| 274 |
fputs(": degenerate polygon in get_surface()\n", stderr);
| 275 |
free(surf);
| 276 |
return(NULL);
| 277 |
| 278 |
return(surf);
| 279 |
| 280 |
| 281 |
/* Convert surface to Radiance with modifier based on unique name */
| 282 |
static int
| 283 |
rad_surface(IDF_OBJECT *param, FILE *ofp)
| 284 |
| 285 |
const char *sname = idf_getfield(param,NAME_FLD)->val;
| 286 |
IDF_FIELD *fptr = get_vlist(param, NULL);
| 287 |
const char **fargs;
| 288 |
int nvert, i, j;
| 289 |
| 290 |
if (fptr == NULL || (nvert = atoi(fptr->val)) < 3) {
| 291 |
fprintf(stderr, "%s: bad surface '%s'\n", progname, sname);
| 292 |
return(0);
| 293 |
| 294 |
fargs = (const char **)malloc(sizeof(const char *)*3*nvert);
| 295 |
if (fargs == NULL)
| 296 |
return(0);
| 297 |
fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname);
| 298 |
fprintf(ofp, "\n'%s' polygon 's_%s'\n0\n0\n%d\n", sname, sname, 3*nvert);
| 299 |
for (j = nvert; j--; ) { /* get arguments in reverse */
| 300 |
for (i = 0; i < 3; i++) {
| 301 |
fptr = fptr->next;
| 302 |
if (fptr == NULL || !isflt(fptr->val)) {
| 303 |
fprintf(stderr,
| 304 |
"%s: missing/bad vertex for %s '%s'\n",
| 305 |
progname, param->pname, sname);
| 306 |
return(0);
| 307 |
| 308 |
fargs[3*j + i] = fptr->val;
| 309 |
| 310 |
| 311 |
for (j = 0; j < nvert; j++) { /* output reversed verts */
| 312 |
| 313 |
fputc('\t', ofp);
| 314 |
fputs(fargs[3*j + i], ofp);
| 315 |
| 316 |
fputc('\n', ofp);
| 317 |
| 318 |
free(fargs);
| 319 |
return(!ferror(ofp));
| 320 |
| 321 |
| 322 |
/* Convert subsurface to Radiance with modifier based on unique name */
| 323 |
static double
| 324 |
rad_subsurface(IDF_OBJECT *param, FILE *ofp)
| 325 |
| 326 |
| 327 |
SURFACE *surf = get_surface(get_vlist(param, NULL));
| 328 |
double area;
| 329 |
int i;
| 330 |
| 331 |
if (surf == NULL) {
| 332 |
fprintf(stderr, "%s: bad subsurface '%s'\n", progname, sname);
| 333 |
return(-1.);
| 334 |
| 335 |
| 336 |
fprintf(ofp, "\n'%s' polygon 'ss_%s'\n0\n0\n%d\n",
| 337 |
sname, sname, 3*surf->nv);
| 338 |
for (i = 0; i < surf->nv; i++) { /* offset vertices */
| 339 |
FVECT vert;
| 340 |
VSUM(vert, surf->vl[i], surf->norm, 2.*SURF_EPS);
| 341 |
fprintf(ofp, "\t%.12f %.12f %.12f\n", vert[0], vert[1], vert[2]);
| 342 |
| 343 |
area = surf->area;
| 344 |
free(surf);
| 345 |
if (ferror(ofp))
| 346 |
return(-1.);
| 347 |
return(area);
| 348 |
| 349 |
| 350 |
/* Start rcontrib process */
| 351 |
static int
| 352 |
start_rcontrib(SUBPROC *pd, ZONE *zp)
| 353 |
| 354 |
#define BASE_AC 6
| 355 |
static char *base_av[BASE_AC] = {
| 356 |
"rcontrib", "-V+", "-fff", "-h", "-x", "1"
| 357 |
| 358 |
char cbuf[300];
| 359 |
char **av;
| 360 |
FILE *ofp;
| 361 |
IDF_OBJECT *pptr;
| 362 |
IDF_FIELD *fptr;
| 363 |
int i, j, n;
| 364 |
/* start oconv command */
| 365 |
sprintf(cbuf, "oconv - > '%s'", temp_octree);
| 366 |
if ((ofp = popen(cbuf, "w")) == NULL) {
| 367 |
| 368 |
fputs(": cannot open oconv process\n", stderr);
| 369 |
return(0);
| 370 |
| 371 |
/* allocate argument list */
| 372 |
av = (char **)malloc(sizeof(char *)*(BASE_AC+4+2*(zp->ntotal)));
| 373 |
if (av == NULL)
| 374 |
return(0);
| 375 |
for (i = 0; i < BASE_AC; i++)
| 376 |
av[i] = base_av[i];
| 377 |
sprintf(cbuf, "%d", nsamps);
| 378 |
av[i++] = "-c";
| 379 |
av[i++] = cbuf; /* add modifiers & surfaces */
| 380 |
for (n = 0, pptr = zp->pfirst; n < zp->nsurf; n++, pptr = pptr->dnext) {
| 381 |
fptr = idf_getfield(pptr,NAME_FLD);
| 382 |
if (fptr == NULL || !fptr->val[0]) {
| 383 |
| 384 |
fputs(": missing name for surface object\n", stderr);
| 385 |
return(0);
| 386 |
| 387 |
if (!rad_surface(pptr, ofp)) /* add surface to octree */
| 388 |
return(0);
| 389 |
av[i++] = "-m";
| 390 |
av[i++] = fptr->val;
| 391 |
| 392 |
/* now subsurfaces */
| 393 |
if (zp->ntotal > zp->nsurf) {
| 394 |
if (zp->area_redu != NULL)
| 395 |
memset(zp->area_redu, 0, sizeof(float)*zp->nsurf);
| 396 |
else if ((zp->area_redu = (float *)calloc(zp->nsurf,
| 397 |
sizeof(float))) == NULL)
| 398 |
return(0);
| 399 |
| 400 |
for ( ; n < zp->ntotal; n++, pptr = pptr->dnext) {
| 401 |
double ssarea;
| 402 |
const char *bname;
| 403 |
IDF_OBJECT *pptr1;
| 404 |
| 405 |
| 406 |
| 407 |
fputs(": missing name for subsurface object\n", stderr);
| 408 |
return(0);
| 409 |
| 410 |
/* add subsurface to octree */
| 411 |
if ((ssarea = rad_subsurface(pptr, ofp)) < 0)
| 412 |
return(0);
| 413 |
/* mark area for subtraction */
| 414 |
bname = idf_getfield(pptr,SS_BASE_FLD)->val;
| 415 |
for (j = 0, pptr1 = zp->pfirst;
| 416 |
j < zp->nsurf; j++, pptr1 = pptr1->dnext)
| 417 |
if (!strcmp(idf_getfield(pptr1,NAME_FLD)->val, bname)) {
| 418 |
zp->area_redu[j] += ssarea;
| 419 |
break;
| 420 |
| 421 |
av[i++] = "-m";
| 422 |
| 423 |
| 424 |
if (pclose(ofp) != 0) { /* finish oconv */
| 425 |
| 426 |
fputs(": error running oconv process\n", stderr);
| 427 |
return(0);
| 428 |
| 429 |
av[i++] = temp_octree; /* add final octree argument */
| 430 |
av[i] = NULL;
| 431 |
if (open_process(pd, av) <= 0) { /* start process */
| 432 |
| 433 |
fputs(": cannot start rcontrib process\n", stderr);
| 434 |
return(0);
| 435 |
| 436 |
free(av); /* all done -- clean up */
| 437 |
return(1);
| 438 |
#undef BASE_AC
| 439 |
| 440 |
| 441 |
/* Initialize polygon sampling */
| 442 |
static Vert2_list *
| 443 |
init_poly(POLYSAMP *ps, IDF_FIELD *f0)
| 444 |
| 445 |
SURFACE *surf;
| 446 |
Vert2_list *vl2;
| 447 |
int i;
| 448 |
/* get 3-D polygon vertices */
| 449 |
if ((surf = get_surface(f0)) == NULL)
| 450 |
return(NULL);
| 451 |
vl2 = polyAlloc(surf->nv);
| 452 |
if (vl2 == NULL)
| 453 |
return(NULL);
| 454 |
/* create X & Y axes */
| 455 |
VCOPY(ps->sdir[2], surf->norm);
| 456 |
VSUB(ps->sdir[0], surf->vl[1], surf->vl[0]);
| 457 |
if (normalize(ps->sdir[0]) == 0)
| 458 |
return(NULL);
| 459 |
fcross(ps->sdir[1], ps->sdir[2], ps->sdir[0]);
| 460 |
/* compute plane offset */
| 461 |
ps->poff = DOT(surf->vl[0], ps->sdir[2]);
| 462 |
/* assign 2-D vertices */
| 463 |
| 464 |
vl2->v[i].mX = DOT(surf->vl[i], ps->sdir[0]);
| 465 |
vl2->v[i].mY = DOT(surf->vl[i], ps->sdir[1]);
| 466 |
| 467 |
ps->area_left = surf->area;
| 468 |
free(surf); /* it's ready! */
| 469 |
vl2->p = (void *)ps;
| 470 |
return(vl2);
| 471 |
| 472 |
| 473 |
/* Generate samples on 2-D triangle */
| 474 |
static int
| 475 |
sample_triangle(const Vert2_list *vl2, int a, int b, int c)
| 476 |
| 477 |
POLYSAMP *ps = (POLYSAMP *)vl2->p;
| 478 |
float *samp;
| 479 |
FVECT orig;
| 480 |
FVECT ab, ac;
| 481 |
double area;
| 482 |
int i, j, ns;
| 483 |
/* compute sampling axes */
| 484 |
for (i = 3; i--; ) {
| 485 |
orig[i] = vl2->v[a].mX*ps->sdir[0][i] +
| 486 |
vl2->v[a].mY*ps->sdir[1][i] +
| 487 |
(ps->poff+SURF_EPS)*ps->sdir[2][i];
| 488 |
ab[i] = (vl2->v[b].mX - vl2->v[a].mX)*ps->sdir[0][i] +
| 489 |
(vl2->v[b].mY - vl2->v[a].mY)*ps->sdir[1][i];
| 490 |
ac[i] = (vl2->v[c].mX - vl2->v[a].mX)*ps->sdir[0][i] +
| 491 |
(vl2->v[c].mY - vl2->v[a].mY)*ps->sdir[1][i];
| 492 |
| 493 |
/* compute number of samples to take */
| 494 |
area = .5*(vl2->v[a].mX*vl2->v[b].mY - vl2->v[b].mX*vl2->v[a].mY +
| 495 |
vl2->v[b].mX*vl2->v[c].mY - vl2->v[c].mX*vl2->v[b].mY +
| 496 |
vl2->v[c].mX*vl2->v[a].mY - vl2->v[a].mX*vl2->v[c].mY);
| 497 |
if (area < .0) {
| 498 |
| 499 |
fputs(": negative triangle area in sample_triangle()\n", stderr);
| 500 |
return(0);
| 501 |
| 502 |
if (area >= ps->area_left) {
| 503 |
ns = ps->samp_left;
| 504 |
ps->area_left = 0;
| 505 |
} else {
| 506 |
ns = (ps->samp_left*area/ps->area_left + .5);
| 507 |
ps->samp_left -= ns;
| 508 |
ps->area_left -= area;
| 509 |
| 510 |
if (ns <= 0) /* XXX should be error? */
| 511 |
return(1);
| 512 |
/* buffer sample rays */
| 513 |
samp = (float *)malloc(sizeof(float)*6*ns);
| 514 |
if (samp == NULL)
| 515 |
return(0);
| 516 |
for (i = ns; i--; ) { /* stratified Monte Carlo sampling */
| 517 |
double sv[4];
| 518 |
FVECT dv;
| 519 |
multisamp(sv, 4, (i+frandom())/(double)ns);
| 520 |
sv[0] *= sv[1] = sqrt(sv[1]);
| 521 |
sv[1] = 1. - sv[1];
| 522 |
for (j = 3; j--; )
| 523 |
samp[i*6 + j] = orig[j] + sv[0]*ab[j] + sv[1]*ac[j];
| 524 |
sv[2] = sqrt(sv[2]);
| 525 |
sv[3] *= 2.*PI;
| 526 |
dv[0] = tcos(sv[3]) * sv[2];
| 527 |
dv[1] = tsin(sv[3]) * sv[2];
| 528 |
dv[2] = sqrt(1. - sv[2]*sv[2]);
| 529 |
for (j = 3; j--; )
| 530 |
samp[i*6 + 3 + j] = dv[0]*ps->sdir[0][j] +
| 531 |
dv[1]*ps->sdir[1][j] +
| 532 |
dv[2]*ps->sdir[2][j] ;
| 533 |
| 534 |
/* send to our process */
| 535 |
writebuf(ps->wd, (char *)samp, sizeof(float)*6*ns);
| 536 |
free(samp); /* that's it! */
| 537 |
return(1);
| 538 |
| 539 |
| 540 |
/* Sample the given surface */
| 541 |
static double
| 542 |
sample_surface(IDF_OBJECT *param, int wd)
| 543 |
| 544 |
POLYSAMP psamp;
| 545 |
double area;
| 546 |
int nv;
| 547 |
Vert2_list *vlist2;
| 548 |
/* set up our polygon sampler */
| 549 |
if ((vlist2 = init_poly(&psamp, get_vlist(param, NULL))) == NULL) {
| 550 |
fprintf(stderr, "%s: bad polygon %s '%s'\n",
| 551 |
| 552 |
idf_getfield(param,NAME_FLD)->val);
| 553 |
return(-1.);
| 554 |
| 555 |
psamp.samp_left = nsamps; /* assign samples & destination */
| 556 |
psamp.wd = wd;
| 557 |
/* hack for subsurface sampling */
| 558 |
psamp.poff += 2.*SURF_EPS * !strcmp(param->pname, SUBSURF_PNAME);
| 559 |
| 560 |
area = psamp.area_left; /* remember starting surface area */
| 561 |
/* sample each subtriangle */
| 562 |
if (!polyTriangulate(vlist2, &sample_triangle))
| 563 |
return(-1.);
| 564 |
polyFree(vlist2); /* clean up and return */
| 565 |
return(area);
| 566 |
| 567 |
| 568 |
/* Compute User View Factors using open rcontrib process */
| 569 |
static int
| 570 |
compute_uvfs(SUBPROC *pd, ZONE *zp)
| 571 |
| 572 |
IDF_OBJECT *pptr, *pout, *pptr1;
| 573 |
float *uvfa;
| 574 |
char uvfbuf[24];
| 575 |
int n, m;
| 576 |
/* create output object */
| 577 |
pout = idf_newobject(our_idf, UVF_PNAME,
| 578 |
" ! computed by Radiance\n ", our_idf->plast);
| 579 |
if (pout == NULL) {
| 580 |
| 581 |
fputs(": cannot create new IDF object\n", stderr);
| 582 |
return(0);
| 583 |
| 584 |
if (!idf_addfield(pout, zp->zname,
| 585 |
" !- Zone Name\n ")) {
| 586 |
| 587 |
fputs(": cannot add zone name field\n", stderr);
| 588 |
return(0);
| 589 |
| 590 |
/* allocate read buffer */
| 591 |
uvfa = (float *)malloc(sizeof(float)*3*zp->ntotal);
| 592 |
if (uvfa == NULL)
| 593 |
return(0);
| 594 |
/* UVFs from each surface */
| 595 |
for (n = 0, pptr = zp->pfirst; n < zp->ntotal; n++, pptr = pptr->dnext) {
| 596 |
double vfsum = 0;
| 597 |
double adj_factor;
| 598 |
/* send samples to rcontrib */
| 599 |
if ((adj_factor = sample_surface(pptr, pd->w)) < 0)
| 600 |
return(0);
| 601 |
if (zp->area_redu == NULL)
| 602 |
adj_factor = 1.;
| 603 |
else /* comp. for subsurface area */
| 604 |
adj_factor /= adj_factor - zp->area_redu[n];
| 605 |
/* read results */
| 606 |
if (readbuf(pd->r, (char *)uvfa, sizeof(float)*3*zp->ntotal) !=
| 607 |
sizeof(float)*3*zp->ntotal) {
| 608 |
| 609 |
fputs(": read error from rcontrib process\n", stderr);
| 610 |
return(0);
| 611 |
| 612 |
/* append UVF fields */
| 613 |
for (m = 0, pptr1 = zp->pfirst;
| 614 |
m < zp->ntotal; m++, pptr1 = pptr1->dnext) {
| 615 |
const double uvf = uvfa[3*m + 1] * adj_factor;
| 616 |
vfsum += uvf;
| 617 |
if (pptr1 == pptr && uvf > .001)
| 618 |
fprintf(stderr,
| 619 |
"%s: warning - non-zero self-VF (%.1f%%) for surface '%s'\n",
| 620 |
progname, 100.*uvf,
| 621 |
idf_getfield(pptr,NAME_FLD)->val);
| 622 |
sprintf(uvfbuf, "%.4f", uvf);
| 623 |
| 624 |
idf_getfield(pptr,NAME_FLD)->val, NULL) ||
| 625 |
!idf_addfield(pout,
| 626 |
idf_getfield(pptr1,NAME_FLD)->val, NULL) ||
| 627 |
!idf_addfield(pout, uvfbuf,
| 628 |
(n+m < 2*zp->ntotal-2) ?
| 629 |
"\n " : "\n\n")) {
| 630 |
| 631 |
fputs(": error adding UVF fields\n", stderr);
| 632 |
return(0);
| 633 |
| 634 |
| 635 |
if (vfsum < 0.95)
| 636 |
fprintf(stderr,
| 637 |
"%s: warning - missing %.1f%% of energy from surface '%s'\n",
| 638 |
progname, 100.*(1.-vfsum),
| 639 |
| 640 |
| 641 |
free(uvfa); /* clean up and return */
| 642 |
return(1);
| 643 |
| 644 |
| 645 |
/* Compute zone User View Factors */
| 646 |
static int
| 647 |
compute_zones(void)
| 648 |
| 649 |
ZONE *zptr;
| 650 |
/* temporary octree name */
| 651 |
mktemp(strcpy(temp_octree, TEMPLATE));
| 652 |
/* compute each zone */
| 653 |
for (zptr = zone_list; zptr != NULL; zptr = zptr->next) {
| 654 |
SUBPROC rcproc;
| 655 |
/* start rcontrib process */
| 656 |
if (!start_rcontrib(&rcproc, zptr))
| 657 |
return(0);
| 658 |
/* compute+add view factors */
| 659 |
if (!compute_uvfs(&rcproc, zptr))
| 660 |
return(0);
| 661 |
if (close_process(&rcproc) != 0) {
| 662 |
| 663 |
fputs(": bad return status from rcontrib\n", stderr);
| 664 |
return(0);
| 665 |
| 666 |
| 667 |
unlink(temp_octree); /* remove octree file */
| 668 |
return(1);
| 669 |
| 670 |
| 671 |
/* Load IDF and compute User View Factors */
| 672 |
int
| 673 |
main(int argc, char *argv[])
| 674 |
| 675 |
int incl_comments = 1;
| 676 |
char *origIDF, *revIDF;
| 677 |
IDF_OBJECT *pptr;
| 678 |
int i;
| 679 |
| 680 |
progname = *argv++; argc--; /* get options if any */
| 681 |
while (argc > 1 && argv[0][0] == '-')
| 682 |
switch (argv[0][1]) {
| 683 |
case 'c': /* elide comments */
| 684 |
incl_comments = -1; /* header only */
| 685 |
argv++; argc--;
| 686 |
continue;
| 687 |
case 's': /* samples */
| 688 |
nsamps = 1000*atoi(*++argv);
| 689 |
argv++; argc -= 2;
| 690 |
continue;
| 691 |
default:
| 692 |
| 693 |
fputs(": unknown option '", stderr);
| 694 |
fputs(argv[0], stderr);
| 695 |
| 696 |
goto userr;
| 697 |
| 698 |
if ((argc < 1) | (argc > 2))
| 699 |
goto userr;
| 700 |
origIDF = argv[0];
| 701 |
revIDF = (argc == 1) ? argv[0] : argv[1];
| 702 |
/* load Input Data File */
| 703 |
our_idf = idf_load(origIDF);
| 704 |
if (our_idf == NULL) {
| 705 |
| 706 |
fputs(": cannot load IDF '", stderr);
| 707 |
fputs(origIDF, stderr);
| 708 |
| 709 |
return(1);
| 710 |
| 711 |
/* remove existing UVFs */
| 712 |
if ((pptr = idf_getobject(our_idf, UVF_PNAME)) != NULL) {
| 713 |
IDF_OBJECT *pnext;
| 714 |
| 715 |
fputs(": removing previous User View Factors\n", stderr);
| 716 |
do {
| 717 |
pnext = pptr->pnext;
| 718 |
idf_delobject(our_idf, pptr);
| 719 |
} while (pnext != NULL);
| 720 |
| 721 |
/* add to header */
| 722 |
if (our_idf->hrem == NULL ||
| 723 |
(i = strlen(our_idf->hrem)-strlen(ADD_HEADER)) < 0 ||
| 724 |
strcmp(our_idf->hrem+i, ADD_HEADER))
| 725 |
idf_add2hdr(our_idf, ADD_HEADER);
| 726 |
/* gather zone surfaces */
| 727 |
for (i = 0; surf_type[i].pname != NULL; i++)
| 728 |
for (pptr = idf_getobject(our_idf, surf_type[i].pname);
| 729 |
pptr != NULL; pptr = pptr->pnext) {
| 730 |
IDF_FIELD *fptr = idf_getfield(pptr,
| 731 |
| 732 |
if (fptr == NULL) {
| 733 |
| 734 |
fputs(": warning - missing zone field\n", stderr);
| 735 |
continue;
| 736 |
| 737 |
if (add2zone(pptr, fptr->val) == NULL)
| 738 |
return(1);
| 739 |
| 740 |
/* add subsurfaces */
| 741 |
for (pptr = idf_getobject(our_idf, SUBSURF_PNAME);
| 742 |
| 743 |
if (add_subsurf(pptr) == NULL)
| 744 |
return(1);
| 745 |
/* run rcontrib on each zone */
| 746 |
if (!compute_zones())
| 747 |
return(1);
| 748 |
/* write out modified IDF */
| 749 |
if (!idf_write(our_idf, revIDF, incl_comments)) {
| 750 |
| 751 |
fputs(": error writing IDF '", stderr);
| 752 |
fputs(revIDF, stderr);
| 753 |
| 754 |
return(1);
| 755 |
| 756 |
return(0); /* finito! */
| 757 |
userr:
| 758 |
fputs("Usage: ", stderr);
| 759 |
| 760 |
fputs(" [-c][-s Ksamps] Model.idf [Revised.idf]\n", stderr);
| 761 |
return(1);
| 762 |
