root/Development/ray/src/util/eplus_adduvf.c
Tue Jun 3 21:31:51 2025 UTC (6 months ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.23: +2 -4 lines
Diff to previous 2.23 , to selected 2.18
Mon Jun 3 18:55:51 2024 UTC (18 months ago) by greg
Diff to previous 2.22 , to selected 2.18
refactor: Changed buffer types in process(), readbuf(), writebuf()
Fri Feb 28 05:18:49 2020 UTC (5 years, 9 months ago) by greg
CVS Tags: rad5R3, rad5R4
Diff to previous 2.21 , to selected 2.18
Mon Jan 20 17:53:40 2020 UTC (5 years, 10 months ago) by greg
Changes since 2.20: +6 -5 lines
Diff to previous 2.20 , to selected 2.18
Updated eplus_adduvf to work with version 9.x
Fri Jan 17 17:33:48 2020 UTC (5 years, 10 months ago) by greg
Changes since 2.19: +10 -1 lines
Diff to previous 2.19 , to selected 2.18
Added warning about incompatible input versions
Fri Dec 13 16:00:33 2019 UTC (5 years, 11 months ago) by greg
Diff to previous 2.18
Fixed potential bug when deleting previous UVFs
Revision 2.18 - (view) (download) (annotate) - [selected]
Sun Mar 6 01:13:18 2016 UTC (9 years, 9 months ago) by schorsch
CVS Tags: rad5R1, rad5R2
Diff to previous 2.17
Fri Apr 4 17:56:45 2014 UTC (11 years, 8 months ago) by greg
Diff to previous 2.16 , to selected 2.18
Fixed major bug in subsurface calculation
Mon Mar 3 17:51:50 2014 UTC (11 years, 9 months ago) by greg
Diff to previous 2.15 , to selected 2.18
Changed single-quotes to double-quotes for Windows command handler
Fri Feb 28 19:14:10 2014 UTC (11 years, 9 months ago) by greg
Changes since 2.14: +3 -2 lines
Diff to previous 2.14 , to selected 2.18
Changed const int to #define for Windoze
Thu Feb 27 22:42:53 2014 UTC (11 years, 9 months ago) by greg
Changes since 2.13: +7 -7 lines
Diff to previous 2.13 , to selected 2.18
Bug fix in last change for subsurfaces
Thu Feb 27 20:39:04 2014 UTC (11 years, 9 months ago) by greg
Changes since 2.12: +33 -13 lines
Diff to previous 2.12 , to selected 2.18
Added hack for missing number of vertices
Fri Feb 21 13:17:45 2014 UTC (11 years, 9 months ago) by greg
Changes since 2.11: +49 -15 lines
Diff to previous 2.11 , to selected 2.18
Added adjustments for area reduction due to subsurfaces
Sat Feb 15 01:31:36 2014 UTC (11 years, 9 months ago) by greg
Changes since 2.10: +242 -84 lines
Diff to previous 2.10 , to selected 2.18
Trial implementation of subsurface sampling -- needs work
Thu Feb 13 17:33:37 2014 UTC (11 years, 9 months ago) by greg
Diff to previous 2.9 , to selected 2.18
Increased allowed comment length and corrected name of view factors object
Wed Feb 12 17:40:07 2014 UTC (11 years, 9 months ago) by greg
Changes since 2.8: +22 -22 lines
Diff to previous 2.8 , to selected 2.18
Changed all "parameter" references to "object"
Wed Feb 12 00:12:38 2014 UTC (11 years, 9 months ago) by greg
Diff to previous 2.7 , to selected 2.18
Fixed error-checking
Tue Feb 11 23:44:11 2014 UTC (11 years, 9 months ago) by greg
Changes since 2.6: +42 -26 lines
Diff to previous 2.6 , to selected 2.18
Added -s option to change number of samples (in 1000's)
Tue Feb 11 22:01:44 2014 UTC (11 years, 9 months ago) by greg
Diff to previous 2.5 , to selected 2.18
Tue Feb 11 21:17:29 2014 UTC (11 years, 9 months ago) by greg
Changes since 2.4: +31 -28 lines
Diff to previous 2.4 , to selected 2.18
Initial working version -- needs man page and accuracy testing
Mon Feb 10 17:50:02 2014 UTC (11 years, 9 months ago) by greg
Diff to previous 2.3 , to selected 2.18
Rob updated cmake for eplus_adduvf and I added check for missing energy
Mon Feb 10 04:51:26 2014 UTC (11 years, 9 months ago) by greg
Changes since 2.2: +246 -32 lines
Diff to previous 2.2 , to selected 2.18
Complete but untested implmentation of eplus_adduvf
Sun Feb 9 22:19:30 2014 UTC (11 years, 9 months ago) by greg
Changes since 2.1: +175 -18 lines
Diff to previous 2.1 , to selected 2.18
Partial implementation of eplus_adduvf
Sun Feb 9 05:49:21 2014 UTC (11 years, 10 months ago) by greg
Diff to selected 2.18
Unfinished implementation of EnergyPlus User View Factors calculation
