--- ray/src/util/eplus_adduvf.c 2014/02/10 04:51:26 2.3 +++ ray/src/util/eplus_adduvf.c 2014/02/11 22:01:44 2.6 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.3 2014/02/10 04:51:26 greg Exp $"; +static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.6 2014/02/11 22:01:44 greg Exp $"; #endif /* * Add User View Factors to EnergyPlus Input Data File @@ -16,18 +16,18 @@ static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.3 #include "rtprocess.h" #ifndef NSAMPLES -#define NSAMPLES 100000 /* number of samples to use */ +#define NSAMPLES 80000 /* number of samples to use */ #endif char *progname; /* global argv[0] */ -char temp_octree[128]; /* temporary octree */ +char temp_octree[128]; /* temporary octree */ const char UVF_PNAME[] = "ZoneProperty:UserViewFactor:bySurfaceName"; const char ADD_HEADER[] = - "!+++ User View Factors computed by Radiance +++!\n"; + "\n!+++ User View Factors computed by Radiance +++!\n\n"; #define NAME_FLD 1 /* name field always first? */ @@ -39,6 +39,9 @@ typedef struct { const SURF_PTYPE surf_type[] = { {"BuildingSurface:Detailed", 4, 10}, + {"Floor:Detailed", 3, 9}, + {"RoofCeiling:Detailed", 3, 9}, + {"Wall:Detailed", 3, 9}, {NULL} }; @@ -143,9 +146,9 @@ rad_surface(IDF_PARAMETER *param, FILE *ofp) static int start_rcontrib(SUBPROC *pd, ZONE *zp) { -#define BASE_AC 3 +#define BASE_AC 5 static char *base_av[BASE_AC] = { - "rcontrib", "-ff", "-h" + "rcontrib", "-ff", "-h", "-x", "1" }; char cbuf[300]; char **av; @@ -221,14 +224,15 @@ init_poly(POLYSAMP *ps, IDF_FIELD *f0, int nv) vl3 = (FVECT *)malloc(sizeof(FVECT)*nv); if (vl3 == NULL) return(NULL); - for (i = 0; i < nv; i++) + for (i = nv; i--; ) /* reverse vertex ordering */ for (j = 0; j < 3; j++) { if (fptr == NULL) { fputs(progname, stderr); - fputs(": bad vertex in init_poly()\n", stderr); + fputs(": missing vertex in init_poly()\n", stderr); return(NULL); } vl3[i][j] = atof(fptr->val); + fptr = fptr->next; } /* compute area and normal */ ps->sdir[2][0] = ps->sdir[2][1] = ps->sdir[2][2] = 0; @@ -252,7 +256,7 @@ init_poly(POLYSAMP *ps, IDF_FIELD *f0, int nv) normalize(ps->sdir[0]); fcross(ps->sdir[1], ps->sdir[2], ps->sdir[0]); /* compute plane offset */ - ps->poff = DOT(vl3[0], ps->sdir[2]) + FTINY; + ps->poff = DOT(vl3[0], ps->sdir[2]); /* assign 2-D vertices */ for (i = 0; i < nv; i++) { vl2->v[i].mX = DOT(vl3[i], ps->sdir[0]); @@ -276,7 +280,7 @@ sample_triangle(const Vert2_list *vl2, int a, int b, i for (i = 3; i--; ) { orig[i] = vl2->v[a].mX*ps->sdir[0][i] + vl2->v[a].mY*ps->sdir[1][i] + - ps->poff*ps->sdir[2][i]; + (ps->poff+.001)*ps->sdir[2][i]; ab[i] = (vl2->v[b].mX - vl2->v[a].mX)*ps->sdir[0][i] + (vl2->v[b].mY - vl2->v[a].mY)*ps->sdir[1][i]; ac[i] = (vl2->v[c].mX - vl2->v[a].mX)*ps->sdir[0][i] + @@ -305,18 +309,23 @@ sample_triangle(const Vert2_list *vl2, int a, int b, i samp = (float *)malloc(sizeof(float)*6*ns); if (samp == NULL) return(0); - for (i = ns; i--; ) { + for (i = ns; i--; ) { /* stratified Monte Carlo sampling */ double sv[4]; + FVECT dv; multisamp(sv, 4, (i+frandom())/(double)ns); sv[0] *= sv[1] = sqrt(sv[1]); sv[1] = 1. - sv[1]; for (j = 3; j--; ) - samp[ns*6 + j] = orig[j] + sv[0]*ab[j] + sv[1]*ac[j]; - sv[3] = sqrt(sv[3]); - sv[4] *= 2.*PI; - samp[ns*6 + 3] = tcos(sv[4]) * sv[3]; - samp[ns*6 + 4] = tsin(sv[4]) * sv[3]; - samp[ns*6 + 5] = sqrt(1. - sv[3]*sv[3]); + samp[i*6 + j] = orig[j] + sv[0]*ab[j] + sv[1]*ac[j]; + sv[2] = sqrt(sv[2]); + sv[3] *= 2.*PI; + dv[0] = tcos(sv[3]) * sv[2]; + dv[1] = tsin(sv[3]) * sv[2]; + dv[2] = sqrt(1. - sv[2]*sv[2]); + for (j = 3; j--; ) + samp[i*6 + 3 + j] = dv[0]*ps->sdir[0][j] + + dv[1]*ps->sdir[1][j] + + dv[2]*ps->sdir[2][j] ; } /* send to our process */ writebuf(ps->wd, (char *)samp, sizeof(float)*6*ns); @@ -333,15 +342,13 @@ sample_surface(IDF_PARAMETER *param, int wd) int nv; Vert2_list *vlist2; /* set up our polygon sampler */ - if (fptr == NULL || (nv = atoi(fptr->val)) < 3) { - fprintf(stderr, "%s: error in %s '%s'\n", + if (fptr == NULL || (nv = atoi(fptr->val)) < 3 || + (vlist2 = init_poly(&psamp, fptr->next, nv)) == NULL) { + fprintf(stderr, "%s: bad polygon %s '%s'\n", progname, param->pname, idf_getfield(param,NAME_FLD)->val); return(0); } - vlist2 = init_poly(&psamp, fptr->next, nv); - if (vlist2 == NULL) - return(0); psamp.samp_left = NSAMPLES; /* assign samples & destination */ psamp.wd = wd; /* sample each subtriangle */ @@ -379,6 +386,7 @@ compute_uvfs(SUBPROC *pd, ZONE *zp) return(0); /* UVFs from each surface */ for (n = zp->nsurf, pptr = zp->pfirst; n--; pptr = pptr->dnext) { + double vfsum = 0; /* send samples to rcontrib */ if (!sample_surface(pptr, pd->w)) return(0); @@ -392,15 +400,16 @@ compute_uvfs(SUBPROC *pd, ZONE *zp) /* append UVF fields */ for (m = 0, pptr1 = zp->pfirst; m < zp->nsurf; m++, pptr1 = pptr1->dnext) { + vfsum += uvfa[3*m + 1]; if (pptr1 == pptr) { if (uvfa[3*m + 1] > .001) fprintf(stderr, - "%s: warning - non-zero self-VF (%.3e) for surface '%s'\n", - progname, uvfa[3*m + 1], + "%s: warning - non-zero self-VF (%.1f%%) for surface '%s'\n", + progname, 100.*uvfa[3*m + 1], idf_getfield(pptr,NAME_FLD)->val); continue; /* don't record self-factor */ } - sprintf(uvfbuf, "%.6f", uvfa[3*m + 1]); + sprintf(uvfbuf, "%.4f", uvfa[3*m + 1]); if (!idf_addfield(pout, idf_getfield(pptr,NAME_FLD)->val, NULL) || !idf_addfield(pout, @@ -413,6 +422,11 @@ compute_uvfs(SUBPROC *pd, ZONE *zp) return(0); } } + if (vfsum < 0.95) + fprintf(stderr, + "%s: warning - missing %.1f%% of energy from surface '%s'\n", + progname, 100.*(1.-vfsum), + idf_getfield(pptr,NAME_FLD)->val); } free(uvfa); /* clean up and return */ return(1); @@ -424,11 +438,7 @@ compute_zones(void) { ZONE *zptr; /* temporary octree name */ - if (temp_filename(temp_octree, sizeof(temp_octree), TEMPLATE) == NULL) { - fputs(progname, stderr); - fputs(": cannot create temporary octree\n", stderr); - return(0); - } + mktemp(strcpy(temp_octree, TEMPLATE)); /* compute each zone */ for (zptr = zone_list; zptr != NULL; zptr = zptr->next) { SUBPROC rcproc;
