--- ray/src/util/eplus_adduvf.c 2014/02/09 05:49:21 2.1 +++ ray/src/util/eplus_adduvf.c 2020/01/20 17:53:40 2.21 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.1 2014/02/09 05:49:21 greg Exp $"; +static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.21 2020/01/20 17:53:40 greg Exp $"; #endif /* * Add User View Factors to EnergyPlus Input Data File @@ -7,117 +7,727 @@ static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.1 * G.Ward for LBNL */ -#include #include -#include +#include +#include "platform.h" +#include "rtio.h" +#include "rtmath.h" +#include "random.h" #include "eplus_idf.h" #include "triangulate.h" +#include "rtprocess.h" #ifndef NSAMPLES -#define NSAMPLES 100000 /* number of samples to use */ +#define NSAMPLES 80000 /* default number of samples */ #endif -#define UVF_PNAME "ZoneProperty:UserViewFactor:bySurfaceName" +#define SURF_EPS 0.0005 /* surface testing epsilon */ +char *progname; /* global argv[0] */ + +int nsamps = NSAMPLES; /* number of samples to use */ + +char temp_octree[128]; /* temporary octree */ + +const char UVF_PNAME[] = + "ZoneProperty:UserViewFactors:bySurfaceName"; + +const char SUBSURF_PNAME[] = + "FenestrationSurface:Detailed"; + const char ADD_HEADER[] = - "!+++ User View Factors computed by Radiance +++!\n"; + "\n!+++ User View Factors computed by Radiance +++!\n\n"; #define NAME_FLD 1 /* name field always first? */ +#define SS_BASE_FLD 4 /* subsurface base surface */ +#define SS_VERT_FLD 9 /* subsurface vertex count */ + typedef struct { - const char *pname; /* parameter type name */ + const char *pname; /* object type name */ short zone_fld; /* zone field index */ short vert_fld; /* vertex field index */ } SURF_PTYPE; /* surface type we're interested in */ const SURF_PTYPE surf_type[] = { {"BuildingSurface:Detailed", 4, 10}, + {"Floor:Detailed", 3, 9}, + {"RoofCeiling:Detailed", 3, 9}, + {"Wall:Detailed", 3, 9}, {NULL} - }; + }; /* IDF surface types */ -struct s_zone { +typedef struct s_zone { const char *zname; /* zone name */ struct s_zone *next; /* next zone in list */ - IDF_PARAMETER *pfirst; /* first matching parameter */ - IDF_PARAMETER *plast; /* last matching parameter */ -} *zone_list = NULL; + int nsurf; /* surface count */ + int ntotal; /* surfaces+subsurfaces */ + IDF_OBJECT *pfirst; /* first matching object */ + IDF_OBJECT *plast; /* last before subsurfaces */ + float *area_redu; /* subsurface area per surf. */ +} ZONE; /* a list of collected zone surfaces */ +ZONE *zone_list = NULL; /* our list of zones */ + +LUTAB zonesurf_lut = /* zone surface lookup table */ + LU_SINIT(NULL,NULL); + IDF_LOADED *our_idf = NULL; /* loaded/modified IDF */ +typedef struct { + FVECT norm; /* surface normal */ + double area; /* surface area */ + int nv; /* number of vertices */ + FVECT vl[3]; /* vertex list (extends struct) */ +} SURFACE; /* a polygonal surface */ + +typedef struct { + FVECT sdir[3]; /* UVW unit sampling vectors */ + double poff; /* W-offset for plane of polygon */ + double area_left; /* area left to sample */ + int samp_left; /* remaining samples */ + int wd; /* output file descriptor */ +} POLYSAMP; /* structure for polygon sampling */ + /* Create a new zone and push to top of our list */ -static struct s_zone * -new_zone(const char *zname, IDF_PARAMETER *param) +static ZONE * +new_zone(const char *zname, IDF_OBJECT *param) { - struct s_zone *znew = (struct s_zone *)malloc(sizeof(struct s_zone)); + ZONE *znew = (ZONE *)malloc(sizeof(ZONE)); if (znew == NULL) return(NULL); znew->zname = zname; /* assumes static */ znew->next = zone_list; znew->pfirst = znew->plast = param; + znew->ntotal = znew->nsurf = 1; + znew->area_redu = NULL; return(zone_list = znew); } /* Add the detailed surface (polygon) to the named zone */ -static struct s_zone * -add2zone(IDF_PARAMETER *param, const char *zname) +static ZONE * +add2zone(IDF_OBJECT *param, const char *zname) { - struct s_zone *zptr; + IDF_FIELD *nfp = idf_getfield(param, NAME_FLD); + ZONE *zptr; + LUENT *lep; + if (nfp == NULL) { + fputs(progname, stderr); + fputs(": surface missing name field!\n", stderr); + return(NULL); + } for (zptr = zone_list; zptr != NULL; zptr = zptr->next) if (!strcmp(zptr->zname, zname)) break; - if (zptr == NULL) - return(new_zone(zname, param)); - /* keep surfaces together */ - if (!idf_movparam(our_idf, param, zptr->plast)) + if (zptr == NULL) { + zptr = new_zone(zname, param); + } else { /* keep surfaces together */ + if (!idf_movobject(our_idf, param, zptr->plast)) + return(NULL); + zptr->plast = param; + zptr->nsurf++; + zptr->ntotal++; + } + /* add to lookup table */ + lep = lu_find(&zonesurf_lut, nfp->val); + if (lep == NULL) return(NULL); - zptr->plast = param; + if (lep->data != NULL) { + fputs(progname, stderr); + fputs(": duplicate surface name '", stderr); + fputs(nfp->val, stderr); + fputs("'\n", stderr); + return(NULL); + } + lep->key = nfp->val; + lep->data = (char *)zptr; return(zptr); } +/* Add a subsurface by finding its base surface and the corresponding zone */ +static ZONE * +add_subsurf(IDF_OBJECT *param) +{ + IDF_FIELD *bfp = idf_getfield(param, SS_BASE_FLD); + ZONE *zptr; + LUENT *lep; + + if (bfp == NULL) { + fputs(progname, stderr); + fputs(": missing base field name in subsurface!\n", stderr); + return(NULL); + } + lep = lu_find(&zonesurf_lut, bfp->val); /* find base zone */ + if (lep == NULL || lep->data == NULL) { + fputs(progname, stderr); + fputs(": cannot find referenced base surface '", stderr); + fputs(bfp->val, stderr); + fputs("'\n", stderr); + return(NULL); + } + zptr = (ZONE *)lep->data; /* add this subsurface */ + if (!idf_movobject(our_idf, param, zptr->plast)) + return(NULL); + zptr->ntotal++; + return(zptr); +} + +/* Return field for vertices in the given object */ +static IDF_FIELD * +get_vlist(IDF_OBJECT *param, const char *zname) +{ +#define itm_len (sizeof(IDF_FIELD)+6) + static char fld_buf[4*itm_len]; + static char *next_fbp = fld_buf; + int i; + IDF_FIELD *res; + /* check if subsurface */ + if (!strcmp(param->pname, SUBSURF_PNAME)) { + if (zname != NULL) { + LUENT *lep = lu_find(&zonesurf_lut, + idf_getfield(param,SS_BASE_FLD)->val); + if (strcmp((*(ZONE *)lep->data).zname, zname)) + return(NULL); + } + res = idf_getfield(param, SS_VERT_FLD); + } else { + i = 0; /* check for surface type */ + while (strcmp(surf_type[i].pname, param->pname)) + if (surf_type[++i].pname == NULL) + return(NULL); + + if (zname != NULL) { /* matches specified zone? */ + IDF_FIELD *fptr = idf_getfield(param, surf_type[i].zone_fld); + if (fptr == NULL || strcmp(fptr->val, zname)) + return(NULL); + } + res = idf_getfield(param, surf_type[i].vert_fld); + } + if (!res->val[0] || tolower(res->val[0]) == 'a') { /* autocalculate */ + IDF_FIELD *fptr; + if (next_fbp >= fld_buf+sizeof(fld_buf)) + next_fbp = fld_buf; + i = 0; /* count vertices */ + for (fptr = res->next; fptr != NULL; fptr = fptr->next) + ++i; + if (i % 3) + return(NULL); + fptr = res->next; + res = (IDF_FIELD *)next_fbp; next_fbp += itm_len; + res->next = fptr; + res->rem = ""; + sprintf(res->val, "%d", i/3); + } + return(res); +#undef itm_len +} + +/* Get/allocate surface polygon */ +static SURFACE * +get_surface(IDF_FIELD *fptr) +{ + SURFACE *surf; + int nv; + FVECT e1, e2, vc; + int i, j; + /* get number of vertices */ + if (fptr == NULL || (nv = atoi(fptr->val)) < 3) { + fputs(progname, stderr); + fputs(": bad vertex count for surface!\n", stderr); + return(NULL); + } + surf = (SURFACE *)malloc(sizeof(SURFACE)+sizeof(FVECT)*(nv-3)); + if (surf == NULL) + return(NULL); + surf->nv = nv; + for (i = nv; i--; ) /* reverse vertex order/orientation */ + for (j = 0; j < 3; j++) { + fptr = fptr->next; + if (fptr == NULL) { + fputs(progname, stderr); + fputs(": missing vertex in get_surface()\n", stderr); + free(surf); + return(NULL); + } + if ((surf->vl[i][j] = atof(fptr->val)) == 0 && + !isflt(fptr->val)) { + fputs(progname, stderr); + fputs(": bad vertex in get_surface()\n", stderr); + free(surf); + return(NULL); + } + } + /* compute area and normal */ + surf->norm[0] = surf->norm[1] = surf->norm[2] = 0; + VSUB(e1, surf->vl[1], surf->vl[0]); + for (i = 2; i < nv; i++) { + VSUB(e2, surf->vl[i], surf->vl[0]); + fcross(vc, e1, e2); + surf->norm[0] += vc[0]; + surf->norm[1] += vc[1]; + surf->norm[2] += vc[2]; + VCOPY(e1, e2); + } + surf->area = .5 * normalize(surf->norm); + if (surf->area == 0) { + fputs(progname, stderr); + fputs(": degenerate polygon in get_surface()\n", stderr); + free(surf); + return(NULL); + } + return(surf); +} + +/* Convert surface to Radiance with modifier based on unique name */ +static int +rad_surface(IDF_OBJECT *param, FILE *ofp) +{ + const char *sname = idf_getfield(param,NAME_FLD)->val; + IDF_FIELD *fptr = get_vlist(param, NULL); + const char **fargs; + int nvert, i, j; + + if (fptr == NULL || (nvert = atoi(fptr->val)) < 3) { + fprintf(stderr, "%s: bad surface '%s'\n", progname, sname); + return(0); + } + fargs = (const char **)malloc(sizeof(const char *)*3*nvert); + if (fargs == NULL) + return(0); + fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname); + fprintf(ofp, "\n'%s' polygon 's_%s'\n0\n0\n%d\n", sname, sname, 3*nvert); + for (j = nvert; j--; ) { /* get arguments in reverse */ + for (i = 0; i < 3; i++) { + fptr = fptr->next; + if (fptr == NULL || !isflt(fptr->val)) { + fprintf(stderr, + "%s: missing/bad vertex for %s '%s'\n", + progname, param->pname, sname); + return(0); + } + fargs[3*j + i] = fptr->val; + } + } + for (j = 0; j < nvert; j++) { /* output reversed verts */ + for (i = 0; i < 3; i++) { + fputc('\t', ofp); + fputs(fargs[3*j + i], ofp); + } + fputc('\n', ofp); + } + free(fargs); + return(!ferror(ofp)); +} + +/* Convert subsurface to Radiance with modifier based on unique name */ +static double +rad_subsurface(IDF_OBJECT *param, FILE *ofp) +{ + const char *sname = idf_getfield(param,NAME_FLD)->val; + SURFACE *surf = get_surface(get_vlist(param, NULL)); + double area; + int i; + + if (surf == NULL) { + fprintf(stderr, "%s: bad subsurface '%s'\n", progname, sname); + return(-1.); + } + fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname); + fprintf(ofp, "\n'%s' polygon 'ss_%s'\n0\n0\n%d\n", + sname, sname, 3*surf->nv); + for (i = 0; i < surf->nv; i++) { /* offset vertices */ + FVECT vert; + VSUM(vert, surf->vl[i], surf->norm, 2.*SURF_EPS); + fprintf(ofp, "\t%.12f %.12f %.12f\n", vert[0], vert[1], vert[2]); + } + area = surf->area; + free(surf); + if (ferror(ofp)) + return(-1.); + return(area); +} + +/* Start rcontrib process */ +static int +start_rcontrib(SUBPROC *pd, ZONE *zp) +{ +#define BASE_AC 6 + static char *base_av[BASE_AC] = { + "rcontrib", "-V+", "-fff", "-h", "-x", "1" + }; + char cbuf[300]; + char **av; + FILE *ofp; + IDF_OBJECT *pptr; + IDF_FIELD *fptr; + int i, j, n; + /* start oconv command */ + sprintf(cbuf, "oconv - > \"%s\"", temp_octree); + if ((ofp = popen(cbuf, "w")) == NULL) { + fputs(progname, stderr); + fputs(": cannot open oconv process\n", stderr); + return(0); + } + /* allocate argument list */ + av = (char **)malloc(sizeof(char *)*(BASE_AC+4+2*(zp->ntotal))); + if (av == NULL) + return(0); + for (i = 0; i < BASE_AC; i++) + av[i] = base_av[i]; + sprintf(cbuf, "%d", nsamps); + av[i++] = "-c"; + av[i++] = cbuf; /* add modifiers & surfaces */ + for (n = 0, pptr = zp->pfirst; n < zp->nsurf; n++, pptr = pptr->dnext) { + fptr = idf_getfield(pptr,NAME_FLD); + if (fptr == NULL || !fptr->val[0]) { + fputs(progname, stderr); + fputs(": missing name for surface object\n", stderr); + return(0); + } + if (!rad_surface(pptr, ofp)) /* add surface to octree */ + return(0); + av[i++] = "-m"; + av[i++] = fptr->val; + } + /* now subsurfaces */ + if (zp->ntotal > zp->nsurf) { + if (zp->area_redu != NULL) + memset(zp->area_redu, 0, sizeof(float)*zp->ntotal); + else if ((zp->area_redu = (float *)calloc(zp->ntotal, + sizeof(float))) == NULL) + return(0); + } + for ( ; n < zp->ntotal; n++, pptr = pptr->dnext) { + double ssarea; + const char *bname; + IDF_OBJECT *pptr1; + fptr = idf_getfield(pptr,NAME_FLD); + if (fptr == NULL || !fptr->val[0]) { + fputs(progname, stderr); + fputs(": missing name for subsurface object\n", stderr); + return(0); + } + /* add subsurface to octree */ + if ((ssarea = rad_subsurface(pptr, ofp)) < 0) + return(0); + /* mark area for subtraction */ + bname = idf_getfield(pptr,SS_BASE_FLD)->val; + for (j = 0, pptr1 = zp->pfirst; + j < zp->nsurf; j++, pptr1 = pptr1->dnext) + if (!strcmp(idf_getfield(pptr1,NAME_FLD)->val, bname)) { + zp->area_redu[j] += ssarea; + break; + } + av[i++] = "-m"; + av[i++] = fptr->val; + } + if (pclose(ofp) != 0) { /* finish oconv */ + fputs(progname, stderr); + fputs(": error running oconv process\n", stderr); + return(0); + } + av[i++] = temp_octree; /* add final octree argument */ + av[i] = NULL; + if (open_process(pd, av) <= 0) { /* start process */ + fputs(progname, stderr); + fputs(": cannot start rcontrib process\n", stderr); + return(0); + } + free(av); /* all done -- clean up */ + return(1); +#undef BASE_AC +} + +/* Initialize polygon sampling */ +static Vert2_list * +init_poly(POLYSAMP *ps, IDF_FIELD *f0) +{ + SURFACE *surf; + Vert2_list *vl2; + int i; + /* get 3-D polygon vertices */ + if ((surf = get_surface(f0)) == NULL) + return(NULL); + vl2 = polyAlloc(surf->nv); + if (vl2 == NULL) + return(NULL); + /* create X & Y axes */ + VCOPY(ps->sdir[2], surf->norm); + VSUB(ps->sdir[0], surf->vl[1], surf->vl[0]); + if (normalize(ps->sdir[0]) == 0) + return(NULL); + fcross(ps->sdir[1], ps->sdir[2], ps->sdir[0]); + /* compute plane offset */ + ps->poff = DOT(surf->vl[0], ps->sdir[2]); + /* assign 2-D vertices */ + for (i = 0; i < surf->nv; i++) { + vl2->v[i].mX = DOT(surf->vl[i], ps->sdir[0]); + vl2->v[i].mY = DOT(surf->vl[i], ps->sdir[1]); + } + ps->area_left = surf->area; + free(surf); /* it's ready! */ + vl2->p = (void *)ps; + return(vl2); +} + +/* Generate samples on 2-D triangle */ +static int +sample_triangle(const Vert2_list *vl2, int a, int b, int c) +{ + POLYSAMP *ps = (POLYSAMP *)vl2->p; + float *samp; + FVECT orig; + FVECT ab, ac; + double area; + int i, j, ns; + /* compute sampling axes */ + for (i = 3; i--; ) { + orig[i] = vl2->v[a].mX*ps->sdir[0][i] + + vl2->v[a].mY*ps->sdir[1][i] + + (ps->poff+SURF_EPS)*ps->sdir[2][i]; + ab[i] = (vl2->v[b].mX - vl2->v[a].mX)*ps->sdir[0][i] + + (vl2->v[b].mY - vl2->v[a].mY)*ps->sdir[1][i]; + ac[i] = (vl2->v[c].mX - vl2->v[a].mX)*ps->sdir[0][i] + + (vl2->v[c].mY - vl2->v[a].mY)*ps->sdir[1][i]; + } + /* compute number of samples to take */ + area = .5*(vl2->v[a].mX*vl2->v[b].mY - vl2->v[b].mX*vl2->v[a].mY + + vl2->v[b].mX*vl2->v[c].mY - vl2->v[c].mX*vl2->v[b].mY + + vl2->v[c].mX*vl2->v[a].mY - vl2->v[a].mX*vl2->v[c].mY); + if (area < .0) { + fputs(progname, stderr); + fputs(": negative triangle area in sample_triangle()\n", stderr); + return(0); + } + if (area >= ps->area_left) { + ns = ps->samp_left; + ps->area_left = 0; + } else { + ns = (ps->samp_left*area/ps->area_left + .5); + ps->samp_left -= ns; + ps->area_left -= area; + } + if (ns <= 0) /* XXX should be error? */ + return(1); + /* buffer sample rays */ + samp = (float *)malloc(sizeof(float)*6*ns); + if (samp == NULL) + return(0); + for (i = ns; i--; ) { /* stratified Monte Carlo sampling */ + double sv[4]; + FVECT dv; + multisamp(sv, 4, (i+frandom())/(double)ns); + sv[0] *= sv[1] = sqrt(sv[1]); + sv[1] = 1. - sv[1]; + for (j = 3; j--; ) + samp[i*6 + j] = orig[j] + sv[0]*ab[j] + sv[1]*ac[j]; + sv[2] = sqrt(sv[2]); + sv[3] *= 2.*PI; + dv[0] = tcos(sv[3]) * sv[2]; + dv[1] = tsin(sv[3]) * sv[2]; + dv[2] = sqrt(1. - sv[2]*sv[2]); + for (j = 3; j--; ) + samp[i*6 + 3 + j] = dv[0]*ps->sdir[0][j] + + dv[1]*ps->sdir[1][j] + + dv[2]*ps->sdir[2][j] ; + } + /* send to our process */ + writebuf(ps->wd, (char *)samp, sizeof(float)*6*ns); + free(samp); /* that's it! */ + return(1); +} + +/* Sample the given surface */ +static double +sample_surface(IDF_OBJECT *param, int wd) +{ + POLYSAMP psamp; + double area; + int nv; + Vert2_list *vlist2; + /* set up our polygon sampler */ + if ((vlist2 = init_poly(&psamp, get_vlist(param, NULL))) == NULL) { + fprintf(stderr, "%s: bad polygon %s '%s'\n", + progname, param->pname, + idf_getfield(param,NAME_FLD)->val); + return(-1.); + } + psamp.samp_left = nsamps; /* assign samples & destination */ + psamp.wd = wd; + /* hack for subsurface sampling */ + psamp.poff += 2.*SURF_EPS * !strcmp(param->pname, SUBSURF_PNAME); + + area = psamp.area_left; /* remember starting surface area */ + /* sample each subtriangle */ + if (!polyTriangulate(vlist2, &sample_triangle)) + return(-1.); + polyFree(vlist2); /* clean up and return */ + return(area); +} + +/* Compute User View Factors using open rcontrib process */ +static int +compute_uvfs(SUBPROC *pd, ZONE *zp) +{ + IDF_OBJECT *pptr, *pout, *pptr1; + float *uvfa; + char uvfbuf[24]; + int n, m; + /* create output object */ + pout = idf_newobject(our_idf, UVF_PNAME, + " ! computed by Radiance\n ", our_idf->plast); + if (pout == NULL) { + fputs(progname, stderr); + fputs(": cannot create new IDF object\n", stderr); + return(0); + } + if (!idf_addfield(pout, zp->zname, + " !- Zone Name\n ")) { + fputs(progname, stderr); + fputs(": cannot add zone name field\n", stderr); + return(0); + } + /* allocate read buffer */ + uvfa = (float *)malloc(sizeof(float)*3*zp->ntotal); + if (uvfa == NULL) + return(0); + /* UVFs from each surface */ + for (n = 0, pptr = zp->pfirst; n < zp->ntotal; n++, pptr = pptr->dnext) { + double vfsum = 0; + double adj_factor; + /* send samples to rcontrib */ + if ((adj_factor = sample_surface(pptr, pd->w)) < 0) + return(0); + if (zp->area_redu == NULL) + adj_factor = 1.; + else /* comp. for subsurface area */ + adj_factor /= adj_factor - zp->area_redu[n]; + /* read results */ + if (readbuf(pd->r, (char *)uvfa, sizeof(float)*3*zp->ntotal) != + sizeof(float)*3*zp->ntotal) { + fputs(progname, stderr); + fputs(": read error from rcontrib process\n", stderr); + return(0); + } + /* append UVF fields */ + for (m = 0, pptr1 = zp->pfirst; + m < zp->ntotal; m++, pptr1 = pptr1->dnext) { + const double uvf = uvfa[3*m + 1] * adj_factor; + vfsum += uvf; + if (pptr1 == pptr && uvf > .001) + fprintf(stderr, + "%s: warning - non-zero self-VF (%.1f%%) for surface '%s'\n", + progname, 100.*uvf, + idf_getfield(pptr,NAME_FLD)->val); + sprintf(uvfbuf, "%.4f", uvf); + if (!idf_addfield(pout, + idf_getfield(pptr,NAME_FLD)->val, NULL) || + !idf_addfield(pout, + idf_getfield(pptr1,NAME_FLD)->val, NULL) || + !idf_addfield(pout, uvfbuf, + (n+m < 2*zp->ntotal-2) ? + "\n " : "\n\n")) { + fputs(progname, stderr); + fputs(": error adding UVF fields\n", stderr); + return(0); + } + } + if (vfsum < 0.95) + fprintf(stderr, + "%s: warning - missing %.1f%% of energy from surface '%s'\n", + progname, 100.*(1.-vfsum), + idf_getfield(pptr,NAME_FLD)->val); + } + free(uvfa); /* clean up and return */ + return(1); +} + /* Compute zone User View Factors */ static int compute_zones(void) { - fputs("compute_zones() unimplemented\n", stderr); - return(0); + ZONE *zptr; + /* temporary octree name */ + mktemp(strcpy(temp_octree, TEMPLATE)); + /* compute each zone */ + for (zptr = zone_list; zptr != NULL; zptr = zptr->next) { + SUBPROC rcproc; + /* start rcontrib process */ + if (!start_rcontrib(&rcproc, zptr)) + return(0); + /* compute+add view factors */ + if (!compute_uvfs(&rcproc, zptr)) + return(0); + if (close_process(&rcproc) != 0) { + fputs(progname, stderr); + fputs(": bad return status from rcontrib\n", stderr); + return(0); + } + } + unlink(temp_octree); /* remove octree file */ + return(1); } /* Load IDF and compute User View Factors */ int main(int argc, char *argv[]) { + int incl_comments = 1; char *origIDF, *revIDF; - IDF_PARAMETER *pptr; + IDF_OBJECT *pptr; int i; - if ((argc < 2) | (argc > 3)) { - fputs("Usage: ", stderr); - fputs(argv[0], stderr); - fputs(" Model.idf [Revised.idf]\n", stderr); - return(1); - } - origIDF = argv[1]; - revIDF = (argc == 2) ? argv[1] : argv[2]; + progname = *argv++; argc--; /* get options if any */ + while (argc > 1 && argv[0][0] == '-') + switch (argv[0][1]) { + case 'c': /* elide comments */ + incl_comments = -1; /* header only */ + argv++; argc--; + continue; + case 's': /* samples */ + nsamps = 1000*atoi(*++argv); + argv++; argc -= 2; + continue; + default: + fputs(progname, stderr); + fputs(": unknown option '", stderr); + fputs(argv[0], stderr); + fputs("'\n", stderr); + goto userr; + } + if ((argc < 1) | (argc > 2)) + goto userr; + origIDF = argv[0]; + revIDF = (argc == 1) ? argv[0] : argv[1]; /* load Input Data File */ our_idf = idf_load(origIDF); if (our_idf == NULL) { - fputs(argv[0], stderr); + fputs(progname, stderr); fputs(": cannot load IDF '", stderr); fputs(origIDF, stderr); fputs("'\n", stderr); return(1); } + /* check version (warning) */ + if ((pptr = idf_getobject(our_idf, "Version")) != NULL && + pptr->flist != NULL && pptr->flist->val[0] != '9') { + fputs(progname, stderr); + fputs(": warning - written for IDF version 9.x, not ", + stderr); + fputs(pptr->flist->val, stderr); + fputc('\n', stderr); + } /* remove existing UVFs */ - if ((pptr = idf_getparam(our_idf, UVF_PNAME)) != NULL) { - IDF_PARAMETER *pnext; - fputs(argv[0], stderr); + if ((pptr = idf_getobject(our_idf, UVF_PNAME)) != NULL) { + IDF_OBJECT *pnext; + fputs(progname, stderr); fputs(": removing previous User View Factors\n", stderr); do { pnext = pptr->pnext; - idf_delparam(our_idf, pptr); - } while (pnext != NULL); + idf_delobject(our_idf, pptr); + } while ((pptr = pnext) != NULL); } /* add to header */ if (our_idf->hrem == NULL || @@ -126,27 +736,38 @@ main(int argc, char *argv[]) idf_add2hdr(our_idf, ADD_HEADER); /* gather zone surfaces */ for (i = 0; surf_type[i].pname != NULL; i++) - for (pptr = idf_getparam(our_idf, surf_type[i].pname); + for (pptr = idf_getobject(our_idf, surf_type[i].pname); pptr != NULL; pptr = pptr->pnext) { IDF_FIELD *fptr = idf_getfield(pptr, surf_type[i].zone_fld); if (fptr == NULL) { - fputs("Warning: missing zone field!\n", stderr); + fputs(progname, stderr); + fputs(": warning - missing zone field\n", stderr); continue; } - if (add2zone(pptr, fptr->arg) == NULL) + if (add2zone(pptr, fptr->val) == NULL) return(1); } + /* add subsurfaces */ + for (pptr = idf_getobject(our_idf, SUBSURF_PNAME); + pptr != NULL; pptr = pptr->pnext) + if (add_subsurf(pptr) == NULL) + return(1); /* run rcontrib on each zone */ if (!compute_zones()) return(1); /* write out modified IDF */ - if (!idf_write(our_idf, revIDF, 1)) { - fputs(argv[0], stderr); + if (!idf_write(our_idf, revIDF, incl_comments)) { + fputs(progname, stderr); fputs(": error writing IDF '", stderr); fputs(revIDF, stderr); fputs("'\n", stderr); return(1); } return(0); /* finito! */ +userr: + fputs("Usage: ", stderr); + fputs(progname, stderr); + fputs(" [-c][-s Ksamps] Model.idf [Revised.idf]\n", stderr); + return(1); }
