--- ray/src/util/eplus_adduvf.c 2014/02/09 05:49:21 2.1 +++ ray/src/util/eplus_adduvf.c 2014/02/13 17:33:37 2.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.1 2014/02/09 05:49:21 greg Exp $"; +static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.10 2014/02/13 17:33:37 greg Exp $"; #endif /* * Add User View Factors to EnergyPlus Input Data File @@ -7,62 +7,86 @@ static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.1 * G.Ward for LBNL */ -#include #include -#include +#include "rtio.h" +#include "rtmath.h" +#include "random.h" #include "eplus_idf.h" #include "triangulate.h" +#include "rtprocess.h" #ifndef NSAMPLES -#define NSAMPLES 100000 /* number of samples to use */ +#define NSAMPLES 80000 /* default number of samples */ #endif -#define UVF_PNAME "ZoneProperty:UserViewFactor:bySurfaceName" +char *progname; /* global argv[0] */ +int nsamps = NSAMPLES; /* number of samples to use */ + +char temp_octree[128]; /* temporary octree */ + +const char UVF_PNAME[] = + "ZoneProperty:UserViewFactors:bySurfaceName"; + const char ADD_HEADER[] = - "!+++ User View Factors computed by Radiance +++!\n"; + "\n!+++ User View Factors computed by Radiance +++!\n\n"; #define NAME_FLD 1 /* name field always first? */ typedef struct { - const char *pname; /* parameter type name */ + const char *pname; /* object type name */ short zone_fld; /* zone field index */ short vert_fld; /* vertex field index */ } SURF_PTYPE; /* surface type we're interested in */ const SURF_PTYPE surf_type[] = { {"BuildingSurface:Detailed", 4, 10}, + {"Floor:Detailed", 3, 9}, + {"RoofCeiling:Detailed", 3, 9}, + {"Wall:Detailed", 3, 9}, {NULL} - }; + }; /* IDF surface types */ -struct s_zone { +typedef struct s_zone { const char *zname; /* zone name */ struct s_zone *next; /* next zone in list */ - IDF_PARAMETER *pfirst; /* first matching parameter */ - IDF_PARAMETER *plast; /* last matching parameter */ -} *zone_list = NULL; + int nsurf; /* surface count */ + IDF_OBJECT *pfirst; /* first matching object */ + IDF_OBJECT *plast; /* last matching object */ +} ZONE; /* a list of collected zone surfaces */ +ZONE *zone_list = NULL; /* our list of zones */ + IDF_LOADED *our_idf = NULL; /* loaded/modified IDF */ +typedef struct { + FVECT sdir[3]; /* UVW unit sampling vectors */ + double poff; /* W-offset for plane of polygon */ + double area_left; /* area left to sample */ + int samp_left; /* remaining samples */ + int wd; /* output file descriptor */ +} POLYSAMP; /* structure for polygon sampling */ + /* Create a new zone and push to top of our list */ -static struct s_zone * -new_zone(const char *zname, IDF_PARAMETER *param) +static ZONE * +new_zone(const char *zname, IDF_OBJECT *param) { - struct s_zone *znew = (struct s_zone *)malloc(sizeof(struct s_zone)); + ZONE *znew = (ZONE *)malloc(sizeof(ZONE)); if (znew == NULL) return(NULL); znew->zname = zname; /* assumes static */ znew->next = zone_list; znew->pfirst = znew->plast = param; + znew->nsurf = 1; return(zone_list = znew); } /* Add the detailed surface (polygon) to the named zone */ -static struct s_zone * -add2zone(IDF_PARAMETER *param, const char *zname) +static ZONE * +add2zone(IDF_OBJECT *param, const char *zname) { - struct s_zone *zptr; + ZONE *zptr; for (zptr = zone_list; zptr != NULL; zptr = zptr->next) if (!strcmp(zptr->zname, zname)) @@ -70,53 +94,420 @@ add2zone(IDF_PARAMETER *param, const char *zname) if (zptr == NULL) return(new_zone(zname, param)); /* keep surfaces together */ - if (!idf_movparam(our_idf, param, zptr->plast)) + if (!idf_movobject(our_idf, param, zptr->plast)) return(NULL); zptr->plast = param; + zptr->nsurf++; return(zptr); } +/* Return field for vertices in the given object */ +static IDF_FIELD * +get_vlist(IDF_OBJECT *param, const char *zname) +{ + int i = 0; + IDF_FIELD *fptr; + /* check for surface type */ + while (strcmp(surf_type[i].pname, param->pname)) + if (surf_type[++i].pname == NULL) + return(NULL); + + if (zname != NULL) { /* matches specified zone? */ + fptr = idf_getfield(param, surf_type[i].zone_fld); + if (fptr == NULL || strcmp(fptr->val, zname)) + return(NULL); + } + /* return field for #verts */ + return(idf_getfield(param, surf_type[i].vert_fld)); +} + +/* Convert surface to Radiance with modifier based on unique name */ +static int +rad_surface(IDF_OBJECT *param, FILE *ofp) +{ + const char *sname = idf_getfield(param,NAME_FLD)->val; + IDF_FIELD *fptr = get_vlist(param, NULL); + int nvert, i; + + if (fptr == NULL || (nvert = atoi(fptr->val)) < 3) { + fprintf(stderr, "%s: bad surface '%s'\n", progname, sname); + return(0); + } + fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname); + fprintf(ofp, "\n'%s' polygon 's_%s'\n0\n0\n%d\n", sname, sname, 3*nvert); + while (nvert--) { + for (i = 3; i--; ) { + fptr = fptr->next; + if (fptr == NULL || !isflt(fptr->val)) { + fprintf(stderr, + "%s: missing/bad vertex for %s '%s'\n", + progname, param->pname, sname); + return(0); + } + fputc('\t', ofp); + fputs(fptr->val, ofp); + } + fputc('\n', ofp); + } + return(!ferror(ofp)); +} + +/* Start rcontrib process */ +static int +start_rcontrib(SUBPROC *pd, ZONE *zp) +{ +#define BASE_AC 5 + static char *base_av[BASE_AC] = { + "rcontrib", "-fff", "-h", "-x", "1" + }; + char cbuf[300]; + char **av; + FILE *ofp; + IDF_OBJECT *pptr; + int i, n; + /* start oconv command */ + sprintf(cbuf, "oconv - > '%s'", temp_octree); + if ((ofp = popen(cbuf, "w")) == NULL) { + fputs(progname, stderr); + fputs(": cannot open oconv process\n", stderr); + return(0); + } + /* allocate argument list */ + av = (char **)malloc(sizeof(char *)*(BASE_AC+4+2*zp->nsurf)); + if (av == NULL) + return(0); + for (i = 0; i < BASE_AC; i++) + av[i] = base_av[i]; + sprintf(cbuf, "%d", nsamps); + av[i++] = "-c"; + av[i++] = cbuf; /* add modifier arguments */ + for (n = zp->nsurf, pptr = zp->pfirst; n--; pptr = pptr->dnext) { + IDF_FIELD *fptr = idf_getfield(pptr,NAME_FLD); + if (fptr == NULL || !fptr->val[0]) { + fputs(progname, stderr); + fputs(": missing name for surface object\n", stderr); + return(0); + } + if (!rad_surface(pptr, ofp)) /* add surface to octree */ + return(0); + av[i++] = "-m"; + av[i++] = fptr->val; + } + if (pclose(ofp) != 0) { /* finish oconv */ + fputs(progname, stderr); + fputs(": error running oconv process\n", stderr); + return(0); + } + av[i++] = temp_octree; /* add final octree argument */ + av[i] = NULL; + if (open_process(pd, av) <= 0) { /* start process */ + fputs(progname, stderr); + fputs(": cannot start rcontrib process\n", stderr); + return(0); + } + free(av); /* all done -- clean up */ + return(1); +#undef BASE_AC +} + +/* Initialize polygon sampling */ +static Vert2_list * +init_poly(POLYSAMP *ps, IDF_FIELD *f0, int nv) +{ + IDF_FIELD *fptr = f0; + int i, j; + FVECT *vl3, e1, e2, vc; + Vert2_list *vl2 = polyAlloc(nv); + + if (vl2 == NULL) + return(NULL); + vl2->p = ps; + /* get 3-D vertices */ + vl3 = (FVECT *)malloc(sizeof(FVECT)*nv); + if (vl3 == NULL) + return(NULL); + for (i = nv; i--; ) /* reverse vertex ordering */ + for (j = 0; j < 3; j++) { + if (fptr == NULL) { + fputs(progname, stderr); + fputs(": missing vertex in init_poly()\n", stderr); + return(NULL); + } + vl3[i][j] = atof(fptr->val); + fptr = fptr->next; + } + /* compute area and normal */ + ps->sdir[2][0] = ps->sdir[2][1] = ps->sdir[2][2] = 0; + VSUB(e1, vl3[1], vl3[0]); + for (i = 2; i < nv; i++) { + VSUB(e2, vl3[i], vl3[0]); + fcross(vc, e1, e2); + ps->sdir[2][0] += vc[0]; + ps->sdir[2][1] += vc[1]; + ps->sdir[2][2] += vc[2]; + VCOPY(e1, e2); + } + ps->area_left = .5 * normalize(ps->sdir[2]); + if (ps->area_left == .0) { + fputs(progname, stderr); + fputs(": degenerate polygon in init_poly()\n", stderr); + return(0); + } + /* create X & Y axes */ + VCOPY(ps->sdir[0], e1); + normalize(ps->sdir[0]); + fcross(ps->sdir[1], ps->sdir[2], ps->sdir[0]); + /* compute plane offset */ + ps->poff = DOT(vl3[0], ps->sdir[2]); + /* assign 2-D vertices */ + for (i = 0; i < nv; i++) { + vl2->v[i].mX = DOT(vl3[i], ps->sdir[0]); + vl2->v[i].mY = DOT(vl3[i], ps->sdir[1]); + } + free(vl3); /* it's ready! */ + return(vl2); +} + +/* Generate samples on 2-D triangle */ +static int +sample_triangle(const Vert2_list *vl2, int a, int b, int c) +{ + POLYSAMP *ps = (POLYSAMP *)vl2->p; + float *samp; + FVECT orig; + FVECT ab, ac; + double area; + int i, j, ns; + /* compute sampling axes */ + for (i = 3; i--; ) { + orig[i] = vl2->v[a].mX*ps->sdir[0][i] + + vl2->v[a].mY*ps->sdir[1][i] + + (ps->poff+.001)*ps->sdir[2][i]; + ab[i] = (vl2->v[b].mX - vl2->v[a].mX)*ps->sdir[0][i] + + (vl2->v[b].mY - vl2->v[a].mY)*ps->sdir[1][i]; + ac[i] = (vl2->v[c].mX - vl2->v[a].mX)*ps->sdir[0][i] + + (vl2->v[c].mY - vl2->v[a].mY)*ps->sdir[1][i]; + } + /* compute number of samples to take */ + area = .5*(vl2->v[a].mX*vl2->v[b].mY - vl2->v[b].mX*vl2->v[a].mY + + vl2->v[b].mX*vl2->v[c].mY - vl2->v[c].mX*vl2->v[b].mY + + vl2->v[c].mX*vl2->v[a].mY - vl2->v[a].mX*vl2->v[c].mY); + if (area < .0) { + fputs(progname, stderr); + fputs(": negative triangle area in sample_triangle()\n", stderr); + return(0); + } + if (area >= ps->area_left) { + ns = ps->samp_left; + ps->area_left = 0; + } else { + ns = (ps->samp_left*area/ps->area_left + .5); + ps->samp_left -= ns; + ps->area_left -= area; + } + if (ns <= 0) /* XXX should be error? */ + return(1); + /* buffer sample rays */ + samp = (float *)malloc(sizeof(float)*6*ns); + if (samp == NULL) + return(0); + for (i = ns; i--; ) { /* stratified Monte Carlo sampling */ + double sv[4]; + FVECT dv; + multisamp(sv, 4, (i+frandom())/(double)ns); + sv[0] *= sv[1] = sqrt(sv[1]); + sv[1] = 1. - sv[1]; + for (j = 3; j--; ) + samp[i*6 + j] = orig[j] + sv[0]*ab[j] + sv[1]*ac[j]; + sv[2] = sqrt(sv[2]); + sv[3] *= 2.*PI; + dv[0] = tcos(sv[3]) * sv[2]; + dv[1] = tsin(sv[3]) * sv[2]; + dv[2] = sqrt(1. - sv[2]*sv[2]); + for (j = 3; j--; ) + samp[i*6 + 3 + j] = dv[0]*ps->sdir[0][j] + + dv[1]*ps->sdir[1][j] + + dv[2]*ps->sdir[2][j] ; + } + /* send to our process */ + writebuf(ps->wd, (char *)samp, sizeof(float)*6*ns); + free(samp); /* that's it! */ + return(1); +} + +/* Sample the given surface */ +static int +sample_surface(IDF_OBJECT *param, int wd) +{ + IDF_FIELD *fptr = get_vlist(param, NULL); + POLYSAMP psamp; + int nv; + Vert2_list *vlist2; + /* set up our polygon sampler */ + if (fptr == NULL || (nv = atoi(fptr->val)) < 3 || + (vlist2 = init_poly(&psamp, fptr->next, nv)) == NULL) { + fprintf(stderr, "%s: bad polygon %s '%s'\n", + progname, param->pname, + idf_getfield(param,NAME_FLD)->val); + return(0); + } + psamp.samp_left = nsamps; /* assign samples & destination */ + psamp.wd = wd; + /* sample each subtriangle */ + if (!polyTriangulate(vlist2, &sample_triangle)) + return(0); + polyFree(vlist2); /* clean up and return */ + return(1); +} + +/* Compute User View Factors using open rcontrib process */ +static int +compute_uvfs(SUBPROC *pd, ZONE *zp) +{ + IDF_OBJECT *pptr, *pout, *pptr1; + float *uvfa; + char uvfbuf[24]; + int n, m; + /* create output object */ + pout = idf_newobject(our_idf, UVF_PNAME, + " ! computed by Radiance\n ", zp->plast); + if (pout == NULL) { + fputs(progname, stderr); + fputs(": cannot create new IDF object\n", stderr); + return(0); + } + if (!idf_addfield(pout, zp->zname, + " !- Zone Name\n ")) { + fputs(progname, stderr); + fputs(": cannot add zone name field\n", stderr); + return(0); + } + /* allocate read buffer */ + uvfa = (float *)malloc(sizeof(float)*3*zp->nsurf); + if (uvfa == NULL) + return(0); + /* UVFs from each surface */ + for (n = zp->nsurf, pptr = zp->pfirst; n--; pptr = pptr->dnext) { + double vfsum = 0; + /* send samples to rcontrib */ + if (!sample_surface(pptr, pd->w)) + return(0); + /* read results */ + if (readbuf(pd->r, (char *)uvfa, sizeof(float)*3*zp->nsurf) != + sizeof(float)*3*zp->nsurf) { + fputs(progname, stderr); + fputs(": read error from rcontrib process\n", stderr); + return(0); + } + /* append UVF fields */ + for (m = 0, pptr1 = zp->pfirst; + m < zp->nsurf; m++, pptr1 = pptr1->dnext) { + vfsum += uvfa[3*m + 1]; + if (pptr1 == pptr) { + if (uvfa[3*m + 1] > .001) + fprintf(stderr, + "%s: warning - non-zero self-VF (%.1f%%) for surface '%s'\n", + progname, 100.*uvfa[3*m + 1], + idf_getfield(pptr,NAME_FLD)->val); + continue; /* don't record self-factor */ + } + sprintf(uvfbuf, "%.4f", uvfa[3*m + 1]); + if (!idf_addfield(pout, + idf_getfield(pptr,NAME_FLD)->val, NULL) || + !idf_addfield(pout, + idf_getfield(pptr1,NAME_FLD)->val, NULL) || + !idf_addfield(pout, uvfbuf, + (n || m < zp->nsurf-2) ? + "\n " : "\n\n")) { + fputs(progname, stderr); + fputs(": error adding UVF fields\n", stderr); + return(0); + } + } + if (vfsum < 0.95) + fprintf(stderr, + "%s: warning - missing %.1f%% of energy from surface '%s'\n", + progname, 100.*(1.-vfsum), + idf_getfield(pptr,NAME_FLD)->val); + } + free(uvfa); /* clean up and return */ + return(1); +} + /* Compute zone User View Factors */ static int compute_zones(void) { - fputs("compute_zones() unimplemented\n", stderr); - return(0); + ZONE *zptr; + /* temporary octree name */ + mktemp(strcpy(temp_octree, TEMPLATE)); + /* compute each zone */ + for (zptr = zone_list; zptr != NULL; zptr = zptr->next) { + SUBPROC rcproc; + /* start rcontrib process */ + if (!start_rcontrib(&rcproc, zptr)) + return(0); + /* compute+add view factors */ + if (!compute_uvfs(&rcproc, zptr)) + return(0); + if (close_process(&rcproc) != 0) { + fputs(progname, stderr); + fputs(": bad return status from rcontrib\n", stderr); + return(0); + } + } + unlink(temp_octree); /* remove octree file */ + return(1); } /* Load IDF and compute User View Factors */ int main(int argc, char *argv[]) { + int incl_comments = 1; char *origIDF, *revIDF; - IDF_PARAMETER *pptr; + IDF_OBJECT *pptr; int i; - if ((argc < 2) | (argc > 3)) { - fputs("Usage: ", stderr); - fputs(argv[0], stderr); - fputs(" Model.idf [Revised.idf]\n", stderr); - return(1); - } - origIDF = argv[1]; - revIDF = (argc == 2) ? argv[1] : argv[2]; + progname = *argv++; argc--; /* get options if any */ + while (argc > 1 && argv[0][0] == '-') + switch (argv[0][1]) { + case 'c': /* elide comments */ + incl_comments = -1; /* header only */ + argv++; argc--; + continue; + case 's': /* samples */ + nsamps = 1000*atoi(*++argv); + argv++; argc -= 2; + continue; + default: + fputs(progname, stderr); + fputs(": unknown option '", stderr); + fputs(argv[0], stderr); + fputs("'\n", stderr); + goto userr; + } + if ((argc < 1) | (argc > 2)) + goto userr; + origIDF = argv[0]; + revIDF = (argc == 1) ? argv[0] : argv[1]; /* load Input Data File */ our_idf = idf_load(origIDF); if (our_idf == NULL) { - fputs(argv[0], stderr); + fputs(progname, stderr); fputs(": cannot load IDF '", stderr); fputs(origIDF, stderr); fputs("'\n", stderr); return(1); } /* remove existing UVFs */ - if ((pptr = idf_getparam(our_idf, UVF_PNAME)) != NULL) { - IDF_PARAMETER *pnext; - fputs(argv[0], stderr); + if ((pptr = idf_getobject(our_idf, UVF_PNAME)) != NULL) { + IDF_OBJECT *pnext; + fputs(progname, stderr); fputs(": removing previous User View Factors\n", stderr); do { pnext = pptr->pnext; - idf_delparam(our_idf, pptr); + idf_delobject(our_idf, pptr); } while (pnext != NULL); } /* add to header */ @@ -126,27 +517,33 @@ main(int argc, char *argv[]) idf_add2hdr(our_idf, ADD_HEADER); /* gather zone surfaces */ for (i = 0; surf_type[i].pname != NULL; i++) - for (pptr = idf_getparam(our_idf, surf_type[i].pname); + for (pptr = idf_getobject(our_idf, surf_type[i].pname); pptr != NULL; pptr = pptr->pnext) { IDF_FIELD *fptr = idf_getfield(pptr, surf_type[i].zone_fld); if (fptr == NULL) { - fputs("Warning: missing zone field!\n", stderr); + fputs(progname, stderr); + fputs(": warning - missing zone field\n", stderr); continue; } - if (add2zone(pptr, fptr->arg) == NULL) + if (add2zone(pptr, fptr->val) == NULL) return(1); } /* run rcontrib on each zone */ if (!compute_zones()) return(1); /* write out modified IDF */ - if (!idf_write(our_idf, revIDF, 1)) { - fputs(argv[0], stderr); + if (!idf_write(our_idf, revIDF, incl_comments)) { + fputs(progname, stderr); fputs(": error writing IDF '", stderr); fputs(revIDF, stderr); fputs("'\n", stderr); return(1); } return(0); /* finito! */ +userr: + fputs("Usage: ", stderr); + fputs(progname, stderr); + fputs(" [-c][-s Ksamps] Model.idf [Revised.idf]\n", stderr); + return(1); }
