root/radiance/ray/src/util/eplus_adduvf.c
Revision: 2.11
Committed: Sat Feb 15 01:31:36 2014 UTC (11 years, 2 months ago) by greg
Changes since 2.10: +242 -84 lines
Trial implementation of subsurface sampling -- needs work
2 static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.10 2014/02/13 17:33:37 greg Exp $";
5 * Add User View Factors to EnergyPlus Input Data File
6 *
7 * G.Ward for LBNL
8 */
9
10 #include <stdlib.h>
11 #include "rtio.h"
12 #include "rtmath.h"
13 #include "random.h"
14 #include "eplus_idf.h"
15 #include "triangulate.h"
16 #include "rtprocess.h"
17
18 #ifndef NSAMPLES
19 #define NSAMPLES 80000 /* default number of samples */
20 #endif
21
22 #define SURF_EPS 0.0005 /* surface testing epsilon */
23
24 char *progname; /* global argv[0] */
25
26 int nsamps = NSAMPLES; /* number of samples to use */
27
28 char temp_octree[128]; /* temporary octree */
29
30 const char UVF_PNAME[] =
31 "ZoneProperty:UserViewFactors:bySurfaceName";
32
33 const char SUBSURF_PNAME[] =
34 "FenestrationSurface:Detailed";
35
36 const char ADD_HEADER[] =
37 "\n!+++ User View Factors computed by Radiance +++!\n\n";
38
39 #define NAME_FLD 1 /* name field always first? */
40
41 #define SS_BASE_FLD 4 /* subsurface base surface */
42 #define SS_VERT_FLD 10 /* subsurface vertex count */
43
44 typedef struct {
45 const char *pname; /* object type name */
46 short zone_fld; /* zone field index */
47 short vert_fld; /* vertex field index */
48 } SURF_PTYPE; /* surface type we're interested in */
49
50 const SURF_PTYPE surf_type[] = {
51 {"BuildingSurface:Detailed", 4, 10},
52 {"Floor:Detailed", 3, 9},
53 {"RoofCeiling:Detailed", 3, 9},
54 {"Wall:Detailed", 3, 9},
55 {NULL}
56 }; /* IDF surface types */
57
58 typedef struct s_zone {
59 const char *zname; /* zone name */
60 struct s_zone *next; /* next zone in list */
61 int nsurf; /* surface count */
62 int ntotal; /* surfaces+subsurfaces */
63 IDF_OBJECT *pfirst; /* first matching object */
64 IDF_OBJECT *plast; /* last before subsurfaces */
65 } ZONE; /* a list of collected zone surfaces */
66
67 ZONE *zone_list = NULL; /* our list of zones */
68
69 LUTAB zonesurf_lut = /* zone surface lookup table */
70 LU_SINIT(NULL,NULL);
71
72 IDF_LOADED *our_idf = NULL; /* loaded/modified IDF */
73
74 typedef struct {
75 FVECT norm; /* surface normal */
76 double area; /* surface area */
77 int nv; /* number of vertices */
78 FVECT vl[3]; /* vertex list (extends struct) */
79 } SURFACE; /* a polygonal surface */
80
81 typedef struct {
82 FVECT sdir[3]; /* UVW unit sampling vectors */
83 double poff; /* W-offset for plane of polygon */
84 double area_left; /* area left to sample */
85 int samp_left; /* remaining samples */
86 int wd; /* output file descriptor */
87 } POLYSAMP; /* structure for polygon sampling */
88
89 /* Create a new zone and push to top of our list */
90 static ZONE *
91 new_zone(const char *zname, IDF_OBJECT *param)
92 {
93 ZONE *znew = (ZONE *)malloc(sizeof(ZONE));
94
95 if (znew == NULL)
96 return(NULL);
97 znew->zname = zname; /* assumes static */
98 znew->next = zone_list;
99 znew->pfirst = znew->plast = param;
100 znew->ntotal = znew->nsurf = 1;
101 return(zone_list = znew);
102 }
103
104 /* Add the detailed surface (polygon) to the named zone */
105 static ZONE *
106 add2zone(IDF_OBJECT *param, const char *zname)
107 {
108 IDF_FIELD *nfp = idf_getfield(param, NAME_FLD);
109 ZONE *zptr;
110 LUENT *lep;
111
112 if (nfp == NULL) {
113 fputs(progname, stderr);
114 fputs(": surface missing name field!\n", stderr);
115 return(NULL);
116 }
117 for (zptr = zone_list; zptr != NULL; zptr = zptr->next)
118 if (!strcmp(zptr->zname, zname))
119 break;
120 if (zptr == NULL) {
121 zptr = new_zone(zname, param);
122 } else { /* keep surfaces together */
123 if (!idf_movobject(our_idf, param, zptr->plast))
124 return(NULL);
125 zptr->plast = param;
126 zptr->nsurf++;
127 zptr->ntotal++;
128 }
129 /* add to lookup table */
130 lep = lu_find(&zonesurf_lut, nfp->val);
131 if (lep == NULL)
132 return(NULL);
133 if (lep->data != NULL) {
134 fputs(progname, stderr);
135 fputs(": duplicate surface name '", stderr);
136 fputs(nfp->val, stderr);
137 fputs("'\n", stderr);
138 return(NULL);
139 }
140 lep->key = nfp->val;
141 lep->data = (char *)zptr;
142 return(zptr);
143 }
144
145 /* Add a subsurface by finding its base surface and the corresponding zone */
146 static ZONE *
147 add_subsurf(IDF_OBJECT *param)
148 {
149 IDF_FIELD *bfp = idf_getfield(param, SS_BASE_FLD);
150 ZONE *zptr;
151 LUENT *lep;
152
153 if (bfp == NULL) {
154 fputs(progname, stderr);
155 fputs(": missing base field name in subsurface!\n", stderr);
156 return(NULL);
157 }
158 lep = lu_find(&zonesurf_lut, bfp->val); /* find base zone */
159 if (lep == NULL || lep->data == NULL) {
160 fputs(progname, stderr);
161 fputs(": cannot find referenced base surface '", stderr);
162 fputs(bfp->val, stderr);
163 fputs("'\n", stderr);
164 return(NULL);
165 }
166 zptr = (ZONE *)lep->data; /* add this subsurface */
167 if (!idf_movobject(our_idf, param, zptr->plast))
168 return(NULL);
169 zptr->ntotal++;
170 return(zptr);
171 }
172
173 /* Return field for vertices in the given object */
174 static IDF_FIELD *
175 get_vlist(IDF_OBJECT *param, const char *zname)
176 {
177 int i = 0;
178 /* check if subsurface */
179 if (!strcmp(param->pname, SUBSURF_PNAME)) {
180 if (zname != NULL) {
181 LUENT *lep = lu_find(&zonesurf_lut,
182 idf_getfield(param,SS_BASE_FLD)->val);
183 if (strcmp((*(ZONE *)lep->data).zname, zname))
184 return(NULL);
185 }
186 return(idf_getfield(param, SS_VERT_FLD));
187 }
188 /* check for surface type */
189 while (strcmp(surf_type[i].pname, param->pname))
190 if (surf_type[++i].pname == NULL)
191 return(NULL);
192
193 if (zname != NULL) { /* matches specified zone? */
194 IDF_FIELD *fptr = idf_getfield(param, surf_type[i].zone_fld);
195 if (fptr == NULL || strcmp(fptr->val, zname))
196 return(NULL);
197 }
198 /* return field for #verts */
199 return(idf_getfield(param, surf_type[i].vert_fld));
200 }
201
202 /* Get/allocate surface polygon */
203 static SURFACE *
204 get_surface(IDF_FIELD *fptr)
205 {
206 SURFACE *surf;
207 int nv;
208 FVECT e1, e2, vc;
209 int i, j;
210 /* get number of vertices */
211 if (fptr == NULL || (nv = atoi(fptr->val)) < 3) {
212 fputs(progname, stderr);
213 fputs(": bad vertex count for surface!\n", stderr);
214 return(NULL);
215 }
216 surf = (SURFACE *)malloc(sizeof(SURFACE)+sizeof(FVECT)*(nv-3));
217 if (surf == NULL)
218 return(NULL);
219 surf->nv = nv;
220 for (i = nv; i--; ) /* reverse vertex order/orientation */
221 for (j = 0; j < 3; j++) {
222 fptr = fptr->next;
223 if (fptr == NULL) {
224 fputs(progname, stderr);
225 fputs(": missing vertex in get_surface()\n", stderr);
226 free(surf);
227 return(NULL);
228 }
229 if ((surf->vl[i][j] = atof(fptr->val)) == 0 &&
230 !isflt(fptr->val)) {
231 fputs(progname, stderr);
232 fputs(": bad vertex in get_surface()\n", stderr);
233 free(surf);
234 return(NULL);
235 }
236 }
237 /* compute area and normal */
238 surf->norm[0] = surf->norm[1] = surf->norm[2] = 0;
239 VSUB(e1, surf->vl[1], surf->vl[0]);
240 for (i = 2; i < nv; i++) {
241 VSUB(e2, surf->vl[i], surf->vl[0]);
242 fcross(vc, e1, e2);
243 surf->norm[0] += vc[0];
244 surf->norm[1] += vc[1];
245 surf->norm[2] += vc[2];
246 VCOPY(e1, e2);
247 }
248 surf->area = .5 * normalize(surf->norm);
249 if (surf->area == 0) {
250 fputs(progname, stderr);
251 fputs(": degenerate polygon in get_surface()\n", stderr);
252 free(surf);
253 return(NULL);
254 }
255 return(surf);
256 }
257
258 /* Convert surface to Radiance with modifier based on unique name */
259 static int
260 rad_surface(IDF_OBJECT *param, FILE *ofp)
261 {
262 const char *sname = idf_getfield(param,NAME_FLD)->val;
263 IDF_FIELD *fptr = get_vlist(param, NULL);
264 const char **fargs;
265 int nvert, i, j;
266
267 if (fptr == NULL || (nvert = atoi(fptr->val)) < 3) {
268 fprintf(stderr, "%s: bad surface '%s'\n", progname, sname);
269 return(0);
270 }
271 fargs = (const char **)malloc(sizeof(const char *)*3*nvert);
272 if (fargs == NULL)
273 return(0);
274 fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname);
275 fprintf(ofp, "\n'%s' polygon 's_%s'\n0\n0\n%d\n", sname, sname, 3*nvert);
276 for (j = nvert; j--; ) { /* get arguments in reverse */
277 for (i = 0; i < 3; i++) {
278 fptr = fptr->next;
279 if (fptr == NULL || !isflt(fptr->val)) {
280 fprintf(stderr,
281 "%s: missing/bad vertex for %s '%s'\n",
282 progname, param->pname, sname);
283 return(0);
284 }
285 fargs[3*j + i] = fptr->val;
286 }
287 }
288 for (j = 0; j < nvert; j++) { /* output reversed verts */
289 for (i = 0; i < 3; i++) {
290 fputc('\t', ofp);
291 fputs(fargs[3*j + i], ofp);
292 }
293 fputc('\n', ofp);
294 }
295 free(fargs);
296 return(!ferror(ofp));
297 }
298
299 /* Convert subsurface to Radiance with modifier based on unique name */
300 static int
301 rad_subsurface(IDF_OBJECT *param, FILE *ofp)
302 {
303 const char *sname = idf_getfield(param,NAME_FLD)->val;
304 SURFACE *surf = get_surface(idf_getfield(param,SS_VERT_FLD));
305 int i;
306
307 if (surf == NULL) {
308 fprintf(stderr, "%s: bad subsurface '%s'\n", progname, sname);
309 return(0);
310 }
311 fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname);
312 fprintf(ofp, "\n'%s' polygon 'ss_%s'\n0\n0\n%d\n",
313 sname, sname, 3*surf->nv);
314 for (i = 0; i < surf->nv; i++) { /* offset vertices */
315 FVECT vert;
316 VSUM(vert, surf->vl[i], surf->norm, 2.*SURF_EPS);
317 fprintf(ofp, "\t%.12f %.12f %.12f\n", vert[0], vert[1], vert[2]);
318 }
319 free(surf);
320 return(!ferror(ofp));
321 }
322
323 /* Start rcontrib process */
324 static int
325 start_rcontrib(SUBPROC *pd, ZONE *zp)
326 {
327 #define BASE_AC 6
328 static char *base_av[BASE_AC] = {
329 "rcontrib", "-V+", "-fff", "-h", "-x", "1"
330 };
331 char cbuf[300];
332 char **av;
333 FILE *ofp;
334 IDF_OBJECT *pptr;
335 IDF_FIELD *fptr;
336 int i, n;
337 /* start oconv command */
338 sprintf(cbuf, "oconv - > '%s'", temp_octree);
339 if ((ofp = popen(cbuf, "w")) == NULL) {
340 fputs(progname, stderr);
341 fputs(": cannot open oconv process\n", stderr);
342 return(0);
343 }
344 /* allocate argument list */
345 av = (char **)malloc(sizeof(char *)*(BASE_AC+4+2*(zp->ntotal)));
346 if (av == NULL)
347 return(0);
348 for (i = 0; i < BASE_AC; i++)
349 av[i] = base_av[i];
350 sprintf(cbuf, "%d", nsamps);
351 av[i++] = "-c";
352 av[i++] = cbuf; /* add modifiers & surfaces */
353 for (n = 0, pptr = zp->pfirst; n < zp->nsurf; n++, pptr = pptr->dnext) {
354 fptr = idf_getfield(pptr,NAME_FLD);
355 if (fptr == NULL || !fptr->val[0]) {
356 fputs(progname, stderr);
357 fputs(": missing name for surface object\n", stderr);
358 return(0);
359 }
360 if (!rad_surface(pptr, ofp)) /* add surface to octree */
361 return(0);
362 av[i++] = "-m";
363 av[i++] = fptr->val;
364 }
365 /* now subsurfaces */
366 for ( ; n < zp->ntotal; n++, pptr = pptr->dnext) {
367 fptr = idf_getfield(pptr,NAME_FLD);
368 if (fptr == NULL || !fptr->val[0]) {
369 fputs(progname, stderr);
370 fputs(": missing name for subsurface object\n", stderr);
371 return(0);
372 }
373 if (!rad_subsurface(pptr, ofp)) /* add surface to octree */
374 return(0);
375 av[i++] = "-m";
376 av[i++] = fptr->val;
377 }
378 if (pclose(ofp) != 0) { /* finish oconv */
379 fputs(progname, stderr);
380 fputs(": error running oconv process\n", stderr);
381 return(0);
382 }
383 av[i++] = temp_octree; /* add final octree argument */
384 av[i] = NULL;
385 if (open_process(pd, av) <= 0) { /* start process */
386 fputs(progname, stderr);
387 fputs(": cannot start rcontrib process\n", stderr);
388 return(0);
389 }
390 free(av); /* all done -- clean up */
391 return(1);
392 #undef BASE_AC
393 }
394
395 /* Initialize polygon sampling */
396 static Vert2_list *
397 init_poly(POLYSAMP *ps, IDF_FIELD *f0)
398 {
399 SURFACE *surf;
400 Vert2_list *vl2;
401 int i;
402 /* get 3-D polygon vertices */
403 if ((surf = get_surface(f0)) == NULL)
404 return(NULL);
405 vl2 = polyAlloc(surf->nv);
406 if (vl2 == NULL)
407 return(NULL);
408 /* create X & Y axes */
409 VCOPY(ps->sdir[2], surf->norm);
410 VSUB(ps->sdir[0], surf->vl[1], surf->vl[0]);
411 if (normalize(ps->sdir[0]) == 0)
412 return(NULL);
413 fcross(ps->sdir[1], ps->sdir[2], ps->sdir[0]);
414 /* compute plane offset */
415 ps->poff = DOT(surf->vl[0], ps->sdir[2]);
416 /* assign 2-D vertices */
417 for (i = 0; i < surf->nv; i++) {
418 vl2->v[i].mX = DOT(surf->vl[i], ps->sdir[0]);
419 vl2->v[i].mY = DOT(surf->vl[i], ps->sdir[1]);
420 }
421 ps->area_left = surf->area;
422 free(surf); /* it's ready! */
423 vl2->p = (void *)ps;
424 return(vl2);
425 }
426
427 /* Generate samples on 2-D triangle */
428 static int
429 sample_triangle(const Vert2_list *vl2, int a, int b, int c)
430 {
431 POLYSAMP *ps = (POLYSAMP *)vl2->p;
432 float *samp;
433 FVECT orig;
434 FVECT ab, ac;
435 double area;
436 int i, j, ns;
437 /* compute sampling axes */
438 for (i = 3; i--; ) {
439 orig[i] = vl2->v[a].mX*ps->sdir[0][i] +
440 vl2->v[a].mY*ps->sdir[1][i] +
441 (ps->poff+SURF_EPS)*ps->sdir[2][i];
442 ab[i] = (vl2->v[b].mX - vl2->v[a].mX)*ps->sdir[0][i] +
443 (vl2->v[b].mY - vl2->v[a].mY)*ps->sdir[1][i];
444 ac[i] = (vl2->v[c].mX - vl2->v[a].mX)*ps->sdir[0][i] +
445 (vl2->v[c].mY - vl2->v[a].mY)*ps->sdir[1][i];
446 }
447 /* compute number of samples to take */
448 area = .5*(vl2->v[a].mX*vl2->v[b].mY - vl2->v[b].mX*vl2->v[a].mY +
449 vl2->v[b].mX*vl2->v[c].mY - vl2->v[c].mX*vl2->v[b].mY +
450 vl2->v[c].mX*vl2->v[a].mY - vl2->v[a].mX*vl2->v[c].mY);
451 if (area < .0) {
452 fputs(progname, stderr);
453 fputs(": negative triangle area in sample_triangle()\n", stderr);
454 return(0);
455 }
456 if (area >= ps->area_left) {
457 ns = ps->samp_left;
458 ps->area_left = 0;
459 } else {
460 ns = (ps->samp_left*area/ps->area_left + .5);
461 ps->samp_left -= ns;
462 ps->area_left -= area;
463 }
464 if (ns <= 0) /* XXX should be error? */
465 return(1);
466 /* buffer sample rays */
467 samp = (float *)malloc(sizeof(float)*6*ns);
468 if (samp == NULL)
469 return(0);
470 for (i = ns; i--; ) { /* stratified Monte Carlo sampling */
471 double sv[4];
472 FVECT dv;
473 multisamp(sv, 4, (i+frandom())/(double)ns);
474 sv[0] *= sv[1] = sqrt(sv[1]);
475 sv[1] = 1. - sv[1];
476 for (j = 3; j--; )
477 samp[i*6 + j] = orig[j] + sv[0]*ab[j] + sv[1]*ac[j];
478 sv[2] = sqrt(sv[2]);
479 sv[3] *= 2.*PI;
480 dv[0] = tcos(sv[3]) * sv[2];
481 dv[1] = tsin(sv[3]) * sv[2];
482 dv[2] = sqrt(1. - sv[2]*sv[2]);
483 for (j = 3; j--; )
484 samp[i*6 + 3 + j] = dv[0]*ps->sdir[0][j] +
485 dv[1]*ps->sdir[1][j] +
486 dv[2]*ps->sdir[2][j] ;
487 }
488 /* send to our process */
489 writebuf(ps->wd, (char *)samp, sizeof(float)*6*ns);
490 free(samp); /* that's it! */
491 return(1);
492 }
493
494 /* Sample the given surface */
495 static int
496 sample_surface(IDF_OBJECT *param, int wd)
497 {
498 POLYSAMP psamp;
499 int nv;
500 Vert2_list *vlist2;
501 /* set up our polygon sampler */
502 if ((vlist2 = init_poly(&psamp, get_vlist(param, NULL))) == NULL) {
503 fprintf(stderr, "%s: bad polygon %s '%s'\n",
504 progname, param->pname,
505 idf_getfield(param,NAME_FLD)->val);
506 return(0);
507 }
508 psamp.samp_left = nsamps; /* assign samples & destination */
509 psamp.wd = wd;
510 /* hack for subsurface sampling */
511 psamp.poff += 2.*SURF_EPS * !strcmp(param->pname, SUBSURF_PNAME);
512 /* sample each subtriangle */
513 if (!polyTriangulate(vlist2, &sample_triangle))
514 return(0);
515 polyFree(vlist2); /* clean up and return */
516 return(1);
517 }
518
519 /* Compute User View Factors using open rcontrib process */
520 static int
521 compute_uvfs(SUBPROC *pd, ZONE *zp)
522 {
523 IDF_OBJECT *pptr, *pout, *pptr1;
524 float *uvfa;
525 char uvfbuf[24];
526 int n, m;
527 /* create output object */
528 pout = idf_newobject(our_idf, UVF_PNAME,
529 " ! computed by Radiance\n ", our_idf->plast);
530 if (pout == NULL) {
531 fputs(progname, stderr);
532 fputs(": cannot create new IDF object\n", stderr);
533 return(0);
534 }
535 if (!idf_addfield(pout, zp->zname,
536 " !- Zone Name\n ")) {
537 fputs(progname, stderr);
538 fputs(": cannot add zone name field\n", stderr);
539 return(0);
540 }
541 /* allocate read buffer */
542 uvfa = (float *)malloc(sizeof(float)*3*zp->ntotal);
543 if (uvfa == NULL)
544 return(0);
545 /* UVFs from each surface */
546 for (n = 0, pptr = zp->pfirst; n < zp->ntotal; n++, pptr = pptr->dnext) {
547 double vfsum = 0;
548 /* send samples to rcontrib */
549 if (!sample_surface(pptr, pd->w))
550 return(0);
551 /* read results */
552 if (readbuf(pd->r, (char *)uvfa, sizeof(float)*3*zp->ntotal) !=
553 sizeof(float)*3*zp->ntotal) {
554 fputs(progname, stderr);
555 fputs(": read error from rcontrib process\n", stderr);
556 return(0);
557 }
558 /* append UVF fields */
559 for (m = 0, pptr1 = zp->pfirst;
560 m < zp->ntotal; m++, pptr1 = pptr1->dnext) {
561 vfsum += uvfa[3*m + 1];
562 if (pptr1 == pptr && uvfa[3*m + 1] > .001)
563 fprintf(stderr,
564 "%s: warning - non-zero self-VF (%.1f%%) for surface '%s'\n",
565 progname, 100.*uvfa[3*m + 1],
566 idf_getfield(pptr,NAME_FLD)->val);
567 sprintf(uvfbuf, "%.4f", uvfa[3*m + 1]);
568 if (!idf_addfield(pout,
569 idf_getfield(pptr,NAME_FLD)->val, NULL) ||
570 !idf_addfield(pout,
571 idf_getfield(pptr1,NAME_FLD)->val, NULL) ||
572 !idf_addfield(pout, uvfbuf,
573 (n+m < 2*zp->ntotal-2) ?
574 "\n " : "\n\n")) {
575 fputs(progname, stderr);
576 fputs(": error adding UVF fields\n", stderr);
577 return(0);
578 }
579 }
580 if (vfsum < 0.95)
581 fprintf(stderr,
582 "%s: warning - missing %.1f%% of energy from surface '%s'\n",
583 progname, 100.*(1.-vfsum),
584 idf_getfield(pptr,NAME_FLD)->val);
585 }
586 free(uvfa); /* clean up and return */
587 return(1);
588 }
589
590 /* Compute zone User View Factors */
591 static int
592 compute_zones(void)
593 {
594 ZONE *zptr;
595 /* temporary octree name */
596 mktemp(strcpy(temp_octree, TEMPLATE));
597 /* compute each zone */
598 for (zptr = zone_list; zptr != NULL; zptr = zptr->next) {
599 SUBPROC rcproc;
600 /* start rcontrib process */
601 if (!start_rcontrib(&rcproc, zptr))
602 return(0);
603 /* compute+add view factors */
604 if (!compute_uvfs(&rcproc, zptr))
605 return(0);
606 if (close_process(&rcproc) != 0) {
607 fputs(progname, stderr);
608 fputs(": bad return status from rcontrib\n", stderr);
609 return(0);
610 }
611 }
612 unlink(temp_octree); /* remove octree file */
613 return(1);
614 }
615
616 /* Load IDF and compute User View Factors */
617 int
618 main(int argc, char *argv[])
619 {
620 int incl_comments = 1;
621 char *origIDF, *revIDF;
622 IDF_OBJECT *pptr;
623 int i;
624
625 progname = *argv++; argc--; /* get options if any */
626 while (argc > 1 && argv[0][0] == '-')
627 switch (argv[0][1]) {
628 case 'c': /* elide comments */
629 incl_comments = -1; /* header only */
630 argv++; argc--;
631 continue;
632 case 's': /* samples */
633 nsamps = 1000*atoi(*++argv);
634 argv++; argc -= 2;
635 continue;
636 default:
637 fputs(progname, stderr);
638 fputs(": unknown option '", stderr);
639 fputs(argv[0], stderr);
640 fputs("'\n", stderr);
641 goto userr;
642 }
643 if ((argc < 1) | (argc > 2))
644 goto userr;
645 origIDF = argv[0];
646 revIDF = (argc == 1) ? argv[0] : argv[1];
647 /* load Input Data File */
648 our_idf = idf_load(origIDF);
649 if (our_idf == NULL) {
650 fputs(progname, stderr);
651 fputs(": cannot load IDF '", stderr);
652 fputs(origIDF, stderr);
653 fputs("'\n", stderr);
654 return(1);
655 }
656 /* remove existing UVFs */
657 if ((pptr = idf_getobject(our_idf, UVF_PNAME)) != NULL) {
658 IDF_OBJECT *pnext;
659 fputs(progname, stderr);
660 fputs(": removing previous User View Factors\n", stderr);
661 do {
662 pnext = pptr->pnext;
663 idf_delobject(our_idf, pptr);
664 } while (pnext != NULL);
665 }
666 /* add to header */
667 if (our_idf->hrem == NULL ||
668 (i = strlen(our_idf->hrem)-strlen(ADD_HEADER)) < 0 ||
669 strcmp(our_idf->hrem+i, ADD_HEADER))
670 idf_add2hdr(our_idf, ADD_HEADER);
671 /* gather zone surfaces */
672 for (i = 0; surf_type[i].pname != NULL; i++)
673 for (pptr = idf_getobject(our_idf, surf_type[i].pname);
674 pptr != NULL; pptr = pptr->pnext) {
675 IDF_FIELD *fptr = idf_getfield(pptr,
676 surf_type[i].zone_fld);
677 if (fptr == NULL) {
678 fputs(progname, stderr);
679 fputs(": warning - missing zone field\n", stderr);
680 continue;
681 }
682 if (add2zone(pptr, fptr->val) == NULL)
683 return(1);
684 }
685 /* add subsurfaces */
686 for (pptr = idf_getobject(our_idf, SUBSURF_PNAME);
687 pptr != NULL; pptr = pptr->pnext)
688 if (add_subsurf(pptr) == NULL)
689 return(1);
690 /* run rcontrib on each zone */
691 if (!compute_zones())
692 return(1);
693 /* write out modified IDF */
694 if (!idf_write(our_idf, revIDF, incl_comments)) {
695 fputs(progname, stderr);
696 fputs(": error writing IDF '", stderr);
697 fputs(revIDF, stderr);
698 fputs("'\n", stderr);
699 return(1);
700 }
701 return(0); /* finito! */
702 userr:
703 fputs("Usage: ", stderr);
704 fputs(progname, stderr);
705 fputs(" [-c][-s Ksamps] Model.idf [Revised.idf]\n", stderr);
706 return(1);
707 }
