1 |
greg |
2.1 |
#ifndef lint |
2 |
greg |
2.23 |
static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.22 2020/02/28 05:18:49 greg Exp $"; |
3 |
greg |
2.1 |
#endif |
4 |
5 |
* Add User View Factors to EnergyPlus Input Data File |
6 |
7 |
* G.Ward for LBNL |
8 |
9 |
10 |
#include <stdlib.h> |
11 |
greg |
2.21 |
#include <ctype.h> |
12 |
schorsch |
2.18 |
#include "platform.h" |
13 |
greg |
2.3 |
#include "rtio.h" |
14 |
#include "rtmath.h" |
15 |
#include "random.h" |
16 |
greg |
2.1 |
#include "eplus_idf.h" |
17 |
#include "triangulate.h" |
18 |
greg |
2.2 |
#include "rtprocess.h" |
19 |
greg |
2.1 |
20 |
#ifndef NSAMPLES |
21 |
greg |
2.7 |
#define NSAMPLES 80000 /* default number of samples */ |
22 |
greg |
2.1 |
#endif |
23 |
24 |
greg |
2.11 |
#define SURF_EPS 0.0005 /* surface testing epsilon */ |
25 |
26 |
greg |
2.2 |
char *progname; /* global argv[0] */ |
27 |
28 |
greg |
2.7 |
int nsamps = NSAMPLES; /* number of samples to use */ |
29 |
30 |
greg |
2.5 |
char temp_octree[128]; /* temporary octree */ |
31 |
greg |
2.2 |
32 |
const char UVF_PNAME[] = |
33 |
greg |
2.10 |
"ZoneProperty:UserViewFactors:bySurfaceName"; |
34 |
greg |
2.1 |
35 |
greg |
2.11 |
const char SUBSURF_PNAME[] = |
36 |
"FenestrationSurface:Detailed"; |
37 |
38 |
greg |
2.1 |
const char ADD_HEADER[] = |
39 |
greg |
2.5 |
"\n!+++ User View Factors computed by Radiance +++!\n\n"; |
40 |
greg |
2.1 |
41 |
#define NAME_FLD 1 /* name field always first? */ |
42 |
43 |
greg |
2.11 |
#define SS_BASE_FLD 4 /* subsurface base surface */ |
44 |
greg |
2.21 |
#define SS_VERT_FLD 9 /* subsurface vertex count */ |
45 |
greg |
2.11 |
46 |
greg |
2.1 |
typedef struct { |
47 |
greg |
2.9 |
const char *pname; /* object type name */ |
48 |
greg |
2.1 |
short zone_fld; /* zone field index */ |
49 |
short vert_fld; /* vertex field index */ |
50 |
} SURF_PTYPE; /* surface type we're interested in */ |
51 |
52 |
const SURF_PTYPE surf_type[] = { |
53 |
{"BuildingSurface:Detailed", 4, 10}, |
54 |
greg |
2.5 |
{"Floor:Detailed", 3, 9}, |
55 |
{"RoofCeiling:Detailed", 3, 9}, |
56 |
{"Wall:Detailed", 3, 9}, |
57 |
greg |
2.1 |
{NULL} |
58 |
greg |
2.7 |
}; /* IDF surface types */ |
59 |
greg |
2.1 |
60 |
greg |
2.2 |
typedef struct s_zone { |
61 |
greg |
2.1 |
const char *zname; /* zone name */ |
62 |
struct s_zone *next; /* next zone in list */ |
63 |
greg |
2.2 |
int nsurf; /* surface count */ |
64 |
greg |
2.11 |
int ntotal; /* surfaces+subsurfaces */ |
65 |
greg |
2.9 |
IDF_OBJECT *pfirst; /* first matching object */ |
66 |
greg |
2.11 |
IDF_OBJECT *plast; /* last before subsurfaces */ |
67 |
greg |
2.12 |
float *area_redu; /* subsurface area per surf. */ |
68 |
greg |
2.2 |
} ZONE; /* a list of collected zone surfaces */ |
69 |
70 |
ZONE *zone_list = NULL; /* our list of zones */ |
71 |
greg |
2.1 |
72 |
greg |
2.11 |
LUTAB zonesurf_lut = /* zone surface lookup table */ |
73 |
LU_SINIT(NULL,NULL); |
74 |
75 |
greg |
2.1 |
IDF_LOADED *our_idf = NULL; /* loaded/modified IDF */ |
76 |
77 |
greg |
2.7 |
typedef struct { |
78 |
greg |
2.11 |
FVECT norm; /* surface normal */ |
79 |
double area; /* surface area */ |
80 |
int nv; /* number of vertices */ |
81 |
FVECT vl[3]; /* vertex list (extends struct) */ |
82 |
} SURFACE; /* a polygonal surface */ |
83 |
84 |
typedef struct { |
85 |
greg |
2.7 |
FVECT sdir[3]; /* UVW unit sampling vectors */ |
86 |
double poff; /* W-offset for plane of polygon */ |
87 |
double area_left; /* area left to sample */ |
88 |
int samp_left; /* remaining samples */ |
89 |
int wd; /* output file descriptor */ |
90 |
} POLYSAMP; /* structure for polygon sampling */ |
91 |
92 |
greg |
2.1 |
/* Create a new zone and push to top of our list */ |
93 |
greg |
2.2 |
static ZONE * |
94 |
greg |
2.9 |
new_zone(const char *zname, IDF_OBJECT *param) |
95 |
greg |
2.1 |
96 |
greg |
2.2 |
ZONE *znew = (ZONE *)malloc(sizeof(ZONE)); |
97 |
greg |
2.1 |
98 |
if (znew == NULL) |
99 |
return(NULL); |
100 |
znew->zname = zname; /* assumes static */ |
101 |
znew->next = zone_list; |
102 |
znew->pfirst = znew->plast = param; |
103 |
greg |
2.11 |
znew->ntotal = znew->nsurf = 1; |
104 |
greg |
2.12 |
znew->area_redu = NULL; |
105 |
greg |
2.1 |
return(zone_list = znew); |
106 |
107 |
108 |
/* Add the detailed surface (polygon) to the named zone */ |
109 |
greg |
2.2 |
static ZONE * |
110 |
greg |
2.9 |
add2zone(IDF_OBJECT *param, const char *zname) |
111 |
greg |
2.1 |
112 |
greg |
2.11 |
IDF_FIELD *nfp = idf_getfield(param, NAME_FLD); |
113 |
ZONE *zptr; |
114 |
LUENT *lep; |
115 |
greg |
2.1 |
116 |
greg |
2.11 |
if (nfp == NULL) { |
117 |
fputs(progname, stderr); |
118 |
fputs(": surface missing name field!\n", stderr); |
119 |
return(NULL); |
120 |
121 |
greg |
2.1 |
for (zptr = zone_list; zptr != NULL; zptr = zptr->next) |
122 |
if (!strcmp(zptr->zname, zname)) |
123 |
break; |
124 |
greg |
2.11 |
if (zptr == NULL) { |
125 |
zptr = new_zone(zname, param); |
126 |
} else { /* keep surfaces together */ |
127 |
if (!idf_movobject(our_idf, param, zptr->plast)) |
128 |
return(NULL); |
129 |
zptr->plast = param; |
130 |
zptr->nsurf++; |
131 |
zptr->ntotal++; |
132 |
133 |
/* add to lookup table */ |
134 |
lep = lu_find(&zonesurf_lut, nfp->val); |
135 |
if (lep == NULL) |
136 |
return(NULL); |
137 |
if (lep->data != NULL) { |
138 |
139 |
fputs(": duplicate surface name '", stderr); |
140 |
fputs(nfp->val, stderr); |
141 |
fputs("'\n", stderr); |
142 |
return(NULL); |
143 |
144 |
lep->key = nfp->val; |
145 |
lep->data = (char *)zptr; |
146 |
return(zptr); |
147 |
148 |
149 |
/* Add a subsurface by finding its base surface and the corresponding zone */ |
150 |
static ZONE * |
151 |
add_subsurf(IDF_OBJECT *param) |
152 |
153 |
IDF_FIELD *bfp = idf_getfield(param, SS_BASE_FLD); |
154 |
ZONE *zptr; |
155 |
LUENT *lep; |
156 |
157 |
if (bfp == NULL) { |
158 |
159 |
fputs(": missing base field name in subsurface!\n", stderr); |
160 |
return(NULL); |
161 |
162 |
lep = lu_find(&zonesurf_lut, bfp->val); /* find base zone */ |
163 |
if (lep == NULL || lep->data == NULL) { |
164 |
165 |
fputs(": cannot find referenced base surface '", stderr); |
166 |
fputs(bfp->val, stderr); |
167 |
168 |
return(NULL); |
169 |
170 |
zptr = (ZONE *)lep->data; /* add this subsurface */ |
171 |
greg |
2.9 |
172 |
greg |
2.1 |
return(NULL); |
173 |
greg |
2.11 |
zptr->ntotal++; |
174 |
greg |
2.1 |
return(zptr); |
175 |
176 |
177 |
greg |
2.9 |
/* Return field for vertices in the given object */ |
178 |
greg |
2.3 |
static IDF_FIELD * |
179 |
greg |
2.9 |
get_vlist(IDF_OBJECT *param, const char *zname) |
180 |
greg |
2.2 |
181 |
greg |
2.15 |
#define itm_len (sizeof(IDF_FIELD)+6) |
182 |
greg |
2.14 |
static char fld_buf[4*itm_len]; |
183 |
static char *next_fbp = fld_buf; |
184 |
int i; |
185 |
IDF_FIELD *res; |
186 |
greg |
2.11 |
/* check if subsurface */ |
187 |
if (!strcmp(param->pname, SUBSURF_PNAME)) { |
188 |
if (zname != NULL) { |
189 |
LUENT *lep = lu_find(&zonesurf_lut, |
190 |
idf_getfield(param,SS_BASE_FLD)->val); |
191 |
if (strcmp((*(ZONE *)lep->data).zname, zname)) |
192 |
return(NULL); |
193 |
194 |
greg |
2.13 |
res = idf_getfield(param, SS_VERT_FLD); |
195 |
} else { |
196 |
i = 0; /* check for surface type */ |
197 |
while (strcmp(surf_type[i].pname, param->pname)) |
198 |
if (surf_type[++i].pname == NULL) |
199 |
return(NULL); |
200 |
201 |
if (zname != NULL) { /* matches specified zone? */ |
202 |
IDF_FIELD *fptr = idf_getfield(param, surf_type[i].zone_fld); |
203 |
if (fptr == NULL || strcmp(fptr->val, zname)) |
204 |
return(NULL); |
205 |
206 |
res = idf_getfield(param, surf_type[i].vert_fld); |
207 |
greg |
2.11 |
208 |
greg |
2.21 |
if (!res->val[0] || tolower(res->val[0]) == 'a') { /* autocalculate */ |
209 |
greg |
2.13 |
IDF_FIELD *fptr; |
210 |
if (next_fbp >= fld_buf+sizeof(fld_buf)) |
211 |
212 |
i = 0; /* count vertices */ |
213 |
for (fptr = res->next; fptr != NULL; fptr = fptr->next) |
214 |
++i; |
215 |
if (i % 3) |
216 |
greg |
2.3 |
return(NULL); |
217 |
greg |
2.13 |
fptr = res->next; |
218 |
res = (IDF_FIELD *)next_fbp; next_fbp += itm_len; |
219 |
res->next = fptr; |
220 |
res->rem = ""; |
221 |
sprintf(res->val, "%d", i/3); |
222 |
greg |
2.3 |
223 |
greg |
2.13 |
return(res); |
224 |
greg |
2.15 |
#undef itm_len |
225 |
greg |
2.2 |
226 |
227 |
greg |
2.11 |
/* Get/allocate surface polygon */ |
228 |
static SURFACE * |
229 |
get_surface(IDF_FIELD *fptr) |
230 |
231 |
SURFACE *surf; |
232 |
int nv; |
233 |
FVECT e1, e2, vc; |
234 |
int i, j; |
235 |
/* get number of vertices */ |
236 |
if (fptr == NULL || (nv = atoi(fptr->val)) < 3) { |
237 |
238 |
fputs(": bad vertex count for surface!\n", stderr); |
239 |
return(NULL); |
240 |
241 |
surf = (SURFACE *)malloc(sizeof(SURFACE)+sizeof(FVECT)*(nv-3)); |
242 |
if (surf == NULL) |
243 |
return(NULL); |
244 |
surf->nv = nv; |
245 |
for (i = nv; i--; ) /* reverse vertex order/orientation */ |
246 |
for (j = 0; j < 3; j++) { |
247 |
fptr = fptr->next; |
248 |
if (fptr == NULL) { |
249 |
250 |
fputs(": missing vertex in get_surface()\n", stderr); |
251 |
free(surf); |
252 |
return(NULL); |
253 |
254 |
if ((surf->vl[i][j] = atof(fptr->val)) == 0 && |
255 |
!isflt(fptr->val)) { |
256 |
257 |
fputs(": bad vertex in get_surface()\n", stderr); |
258 |
free(surf); |
259 |
return(NULL); |
260 |
261 |
262 |
/* compute area and normal */ |
263 |
surf->norm[0] = surf->norm[1] = surf->norm[2] = 0; |
264 |
VSUB(e1, surf->vl[1], surf->vl[0]); |
265 |
for (i = 2; i < nv; i++) { |
266 |
VSUB(e2, surf->vl[i], surf->vl[0]); |
267 |
fcross(vc, e1, e2); |
268 |
surf->norm[0] += vc[0]; |
269 |
surf->norm[1] += vc[1]; |
270 |
surf->norm[2] += vc[2]; |
271 |
VCOPY(e1, e2); |
272 |
273 |
surf->area = .5 * normalize(surf->norm); |
274 |
if (surf->area == 0) { |
275 |
276 |
fputs(": degenerate polygon in get_surface()\n", stderr); |
277 |
free(surf); |
278 |
return(NULL); |
279 |
280 |
return(surf); |
281 |
282 |
283 |
greg |
2.2 |
/* Convert surface to Radiance with modifier based on unique name */ |
284 |
static int |
285 |
greg |
2.9 |
rad_surface(IDF_OBJECT *param, FILE *ofp) |
286 |
greg |
2.2 |
287 |
greg |
2.3 |
const char *sname = idf_getfield(param,NAME_FLD)->val; |
288 |
IDF_FIELD *fptr = get_vlist(param, NULL); |
289 |
greg |
2.11 |
const char **fargs; |
290 |
int nvert, i, j; |
291 |
greg |
2.2 |
292 |
greg |
2.3 |
if (fptr == NULL || (nvert = atoi(fptr->val)) < 3) { |
293 |
greg |
2.2 |
fprintf(stderr, "%s: bad surface '%s'\n", progname, sname); |
294 |
return(0); |
295 |
296 |
greg |
2.11 |
fargs = (const char **)malloc(sizeof(const char *)*3*nvert); |
297 |
if (fargs == NULL) |
298 |
return(0); |
299 |
greg |
2.2 |
fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname); |
300 |
fprintf(ofp, "\n'%s' polygon 's_%s'\n0\n0\n%d\n", sname, sname, 3*nvert); |
301 |
greg |
2.11 |
for (j = nvert; j--; ) { /* get arguments in reverse */ |
302 |
for (i = 0; i < 3; i++) { |
303 |
greg |
2.2 |
304 |
greg |
2.3 |
if (fptr == NULL || !isflt(fptr->val)) { |
305 |
greg |
2.2 |
fprintf(stderr, |
306 |
greg |
2.3 |
"%s: missing/bad vertex for %s '%s'\n", |
307 |
progname, param->pname, sname); |
308 |
greg |
2.2 |
return(0); |
309 |
310 |
greg |
2.11 |
fargs[3*j + i] = fptr->val; |
311 |
312 |
313 |
for (j = 0; j < nvert; j++) { /* output reversed verts */ |
314 |
315 |
greg |
2.2 |
fputc('\t', ofp); |
316 |
greg |
2.11 |
fputs(fargs[3*j + i], ofp); |
317 |
greg |
2.2 |
318 |
fputc('\n', ofp); |
319 |
320 |
greg |
2.11 |
free(fargs); |
321 |
return(!ferror(ofp)); |
322 |
323 |
324 |
/* Convert subsurface to Radiance with modifier based on unique name */ |
325 |
greg |
2.12 |
static double |
326 |
greg |
2.11 |
rad_subsurface(IDF_OBJECT *param, FILE *ofp) |
327 |
328 |
329 |
greg |
2.14 |
SURFACE *surf = get_surface(get_vlist(param, NULL)); |
330 |
greg |
2.12 |
double area; |
331 |
greg |
2.11 |
int i; |
332 |
333 |
if (surf == NULL) { |
334 |
fprintf(stderr, "%s: bad subsurface '%s'\n", progname, sname); |
335 |
greg |
2.12 |
return(-1.); |
336 |
greg |
2.11 |
337 |
338 |
fprintf(ofp, "\n'%s' polygon 'ss_%s'\n0\n0\n%d\n", |
339 |
sname, sname, 3*surf->nv); |
340 |
for (i = 0; i < surf->nv; i++) { /* offset vertices */ |
341 |
FVECT vert; |
342 |
VSUM(vert, surf->vl[i], surf->norm, 2.*SURF_EPS); |
343 |
fprintf(ofp, "\t%.12f %.12f %.12f\n", vert[0], vert[1], vert[2]); |
344 |
345 |
greg |
2.12 |
area = surf->area; |
346 |
greg |
2.11 |
free(surf); |
347 |
greg |
2.12 |
if (ferror(ofp)) |
348 |
return(-1.); |
349 |
return(area); |
350 |
greg |
2.2 |
351 |
352 |
greg |
2.3 |
/* Start rcontrib process */ |
353 |
greg |
2.2 |
static int |
354 |
start_rcontrib(SUBPROC *pd, ZONE *zp) |
355 |
356 |
greg |
2.11 |
#define BASE_AC 6 |
357 |
greg |
2.2 |
static char *base_av[BASE_AC] = { |
358 |
greg |
2.11 |
"rcontrib", "-V+", "-fff", "-h", "-x", "1" |
359 |
greg |
2.2 |
360 |
char cbuf[300]; |
361 |
char **av; |
362 |
FILE *ofp; |
363 |
greg |
2.9 |
IDF_OBJECT *pptr; |
364 |
greg |
2.11 |
IDF_FIELD *fptr; |
365 |
greg |
2.12 |
int i, j, n; |
366 |
greg |
2.2 |
/* start oconv command */ |
367 |
greg |
2.16 |
sprintf(cbuf, "oconv - > \"%s\"", temp_octree); |
368 |
greg |
2.2 |
if ((ofp = popen(cbuf, "w")) == NULL) { |
369 |
370 |
fputs(": cannot open oconv process\n", stderr); |
371 |
return(0); |
372 |
373 |
/* allocate argument list */ |
374 |
greg |
2.11 |
av = (char **)malloc(sizeof(char *)*(BASE_AC+4+2*(zp->ntotal))); |
375 |
greg |
2.2 |
if (av == NULL) |
376 |
return(0); |
377 |
for (i = 0; i < BASE_AC; i++) |
378 |
av[i] = base_av[i]; |
379 |
greg |
2.7 |
sprintf(cbuf, "%d", nsamps); |
380 |
greg |
2.2 |
av[i++] = "-c"; |
381 |
greg |
2.11 |
av[i++] = cbuf; /* add modifiers & surfaces */ |
382 |
for (n = 0, pptr = zp->pfirst; n < zp->nsurf; n++, pptr = pptr->dnext) { |
383 |
fptr = idf_getfield(pptr,NAME_FLD); |
384 |
greg |
2.3 |
if (fptr == NULL || !fptr->val[0]) { |
385 |
greg |
2.2 |
386 |
greg |
2.9 |
fputs(": missing name for surface object\n", stderr); |
387 |
greg |
2.2 |
return(0); |
388 |
389 |
greg |
2.3 |
if (!rad_surface(pptr, ofp)) /* add surface to octree */ |
390 |
return(0); |
391 |
greg |
2.2 |
av[i++] = "-m"; |
392 |
greg |
2.3 |
av[i++] = fptr->val; |
393 |
greg |
2.2 |
394 |
greg |
2.11 |
/* now subsurfaces */ |
395 |
greg |
2.12 |
if (zp->ntotal > zp->nsurf) { |
396 |
if (zp->area_redu != NULL) |
397 |
greg |
2.17 |
memset(zp->area_redu, 0, sizeof(float)*zp->ntotal); |
398 |
else if ((zp->area_redu = (float *)calloc(zp->ntotal, |
399 |
greg |
2.12 |
sizeof(float))) == NULL) |
400 |
return(0); |
401 |
402 |
greg |
2.11 |
for ( ; n < zp->ntotal; n++, pptr = pptr->dnext) { |
403 |
greg |
2.12 |
double ssarea; |
404 |
const char *bname; |
405 |
IDF_OBJECT *pptr1; |
406 |
greg |
2.11 |
407 |
408 |
409 |
fputs(": missing name for subsurface object\n", stderr); |
410 |
return(0); |
411 |
412 |
greg |
2.12 |
/* add subsurface to octree */ |
413 |
if ((ssarea = rad_subsurface(pptr, ofp)) < 0) |
414 |
greg |
2.11 |
return(0); |
415 |
greg |
2.12 |
/* mark area for subtraction */ |
416 |
bname = idf_getfield(pptr,SS_BASE_FLD)->val; |
417 |
for (j = 0, pptr1 = zp->pfirst; |
418 |
j < zp->nsurf; j++, pptr1 = pptr1->dnext) |
419 |
if (!strcmp(idf_getfield(pptr1,NAME_FLD)->val, bname)) { |
420 |
zp->area_redu[j] += ssarea; |
421 |
break; |
422 |
423 |
greg |
2.11 |
av[i++] = "-m"; |
424 |
425 |
426 |
greg |
2.2 |
if (pclose(ofp) != 0) { /* finish oconv */ |
427 |
428 |
fputs(": error running oconv process\n", stderr); |
429 |
return(0); |
430 |
431 |
av[i++] = temp_octree; /* add final octree argument */ |
432 |
av[i] = NULL; |
433 |
greg |
2.8 |
if (open_process(pd, av) <= 0) { /* start process */ |
434 |
greg |
2.2 |
435 |
fputs(": cannot start rcontrib process\n", stderr); |
436 |
return(0); |
437 |
438 |
free(av); /* all done -- clean up */ |
439 |
return(1); |
440 |
#undef BASE_AC |
441 |
442 |
443 |
greg |
2.3 |
/* Initialize polygon sampling */ |
444 |
static Vert2_list * |
445 |
greg |
2.11 |
init_poly(POLYSAMP *ps, IDF_FIELD *f0) |
446 |
greg |
2.3 |
447 |
greg |
2.11 |
SURFACE *surf; |
448 |
Vert2_list *vl2; |
449 |
int i; |
450 |
/* get 3-D polygon vertices */ |
451 |
if ((surf = get_surface(f0)) == NULL) |
452 |
return(NULL); |
453 |
vl2 = polyAlloc(surf->nv); |
454 |
greg |
2.3 |
if (vl2 == NULL) |
455 |
return(NULL); |
456 |
greg |
2.11 |
/* create X & Y axes */ |
457 |
VCOPY(ps->sdir[2], surf->norm); |
458 |
VSUB(ps->sdir[0], surf->vl[1], surf->vl[0]); |
459 |
if (normalize(ps->sdir[0]) == 0) |
460 |
greg |
2.3 |
return(NULL); |
461 |
fcross(ps->sdir[1], ps->sdir[2], ps->sdir[0]); |
462 |
/* compute plane offset */ |
463 |
greg |
2.11 |
ps->poff = DOT(surf->vl[0], ps->sdir[2]); |
464 |
greg |
2.3 |
/* assign 2-D vertices */ |
465 |
greg |
2.11 |
for (i = 0; i < surf->nv; i++) { |
466 |
vl2->v[i].mX = DOT(surf->vl[i], ps->sdir[0]); |
467 |
vl2->v[i].mY = DOT(surf->vl[i], ps->sdir[1]); |
468 |
469 |
ps->area_left = surf->area; |
470 |
free(surf); /* it's ready! */ |
471 |
vl2->p = (void *)ps; |
472 |
greg |
2.3 |
return(vl2); |
473 |
474 |
475 |
/* Generate samples on 2-D triangle */ |
476 |
static int |
477 |
sample_triangle(const Vert2_list *vl2, int a, int b, int c) |
478 |
479 |
POLYSAMP *ps = (POLYSAMP *)vl2->p; |
480 |
float *samp; |
481 |
FVECT orig; |
482 |
FVECT ab, ac; |
483 |
double area; |
484 |
int i, j, ns; |
485 |
/* compute sampling axes */ |
486 |
for (i = 3; i--; ) { |
487 |
orig[i] = vl2->v[a].mX*ps->sdir[0][i] + |
488 |
vl2->v[a].mY*ps->sdir[1][i] + |
489 |
greg |
2.11 |
(ps->poff+SURF_EPS)*ps->sdir[2][i]; |
490 |
greg |
2.3 |
ab[i] = (vl2->v[b].mX - vl2->v[a].mX)*ps->sdir[0][i] + |
491 |
(vl2->v[b].mY - vl2->v[a].mY)*ps->sdir[1][i]; |
492 |
ac[i] = (vl2->v[c].mX - vl2->v[a].mX)*ps->sdir[0][i] + |
493 |
(vl2->v[c].mY - vl2->v[a].mY)*ps->sdir[1][i]; |
494 |
495 |
/* compute number of samples to take */ |
496 |
area = .5*(vl2->v[a].mX*vl2->v[b].mY - vl2->v[b].mX*vl2->v[a].mY + |
497 |
vl2->v[b].mX*vl2->v[c].mY - vl2->v[c].mX*vl2->v[b].mY + |
498 |
vl2->v[c].mX*vl2->v[a].mY - vl2->v[a].mX*vl2->v[c].mY); |
499 |
if (area < .0) { |
500 |
501 |
fputs(": negative triangle area in sample_triangle()\n", stderr); |
502 |
return(0); |
503 |
504 |
if (area >= ps->area_left) { |
505 |
ns = ps->samp_left; |
506 |
ps->area_left = 0; |
507 |
} else { |
508 |
ns = (ps->samp_left*area/ps->area_left + .5); |
509 |
ps->samp_left -= ns; |
510 |
ps->area_left -= area; |
511 |
512 |
if (ns <= 0) /* XXX should be error? */ |
513 |
return(1); |
514 |
/* buffer sample rays */ |
515 |
samp = (float *)malloc(sizeof(float)*6*ns); |
516 |
if (samp == NULL) |
517 |
return(0); |
518 |
greg |
2.4 |
for (i = ns; i--; ) { /* stratified Monte Carlo sampling */ |
519 |
greg |
2.3 |
double sv[4]; |
520 |
greg |
2.5 |
FVECT dv; |
521 |
greg |
2.3 |
multisamp(sv, 4, (i+frandom())/(double)ns); |
522 |
sv[0] *= sv[1] = sqrt(sv[1]); |
523 |
sv[1] = 1. - sv[1]; |
524 |
for (j = 3; j--; ) |
525 |
greg |
2.5 |
samp[i*6 + j] = orig[j] + sv[0]*ab[j] + sv[1]*ac[j]; |
526 |
sv[2] = sqrt(sv[2]); |
527 |
sv[3] *= 2.*PI; |
528 |
dv[0] = tcos(sv[3]) * sv[2]; |
529 |
dv[1] = tsin(sv[3]) * sv[2]; |
530 |
dv[2] = sqrt(1. - sv[2]*sv[2]); |
531 |
532 |
samp[i*6 + 3 + j] = dv[0]*ps->sdir[0][j] + |
533 |
dv[1]*ps->sdir[1][j] + |
534 |
dv[2]*ps->sdir[2][j] ; |
535 |
greg |
2.3 |
536 |
/* send to our process */ |
537 |
greg |
2.23 |
writebuf(ps->wd, samp, sizeof(float)*6*ns); |
538 |
greg |
2.3 |
free(samp); /* that's it! */ |
539 |
return(1); |
540 |
541 |
542 |
/* Sample the given surface */ |
543 |
greg |
2.12 |
static double |
544 |
greg |
2.9 |
sample_surface(IDF_OBJECT *param, int wd) |
545 |
greg |
2.3 |
546 |
POLYSAMP psamp; |
547 |
greg |
2.12 |
double area; |
548 |
greg |
2.3 |
int nv; |
549 |
Vert2_list *vlist2; |
550 |
/* set up our polygon sampler */ |
551 |
greg |
2.11 |
if ((vlist2 = init_poly(&psamp, get_vlist(param, NULL))) == NULL) { |
552 |
greg |
2.5 |
fprintf(stderr, "%s: bad polygon %s '%s'\n", |
553 |
greg |
2.3 |
progname, param->pname, |
554 |
idf_getfield(param,NAME_FLD)->val); |
555 |
greg |
2.12 |
return(-1.); |
556 |
greg |
2.3 |
557 |
greg |
2.7 |
psamp.samp_left = nsamps; /* assign samples & destination */ |
558 |
greg |
2.3 |
psamp.wd = wd; |
559 |
greg |
2.11 |
/* hack for subsurface sampling */ |
560 |
psamp.poff += 2.*SURF_EPS * !strcmp(param->pname, SUBSURF_PNAME); |
561 |
greg |
2.12 |
562 |
area = psamp.area_left; /* remember starting surface area */ |
563 |
greg |
2.3 |
/* sample each subtriangle */ |
564 |
if (!polyTriangulate(vlist2, &sample_triangle)) |
565 |
greg |
2.12 |
return(-1.); |
566 |
greg |
2.3 |
polyFree(vlist2); /* clean up and return */ |
567 |
greg |
2.12 |
return(area); |
568 |
greg |
2.3 |
569 |
570 |
greg |
2.2 |
/* Compute User View Factors using open rcontrib process */ |
571 |
static int |
572 |
greg |
2.3 |
compute_uvfs(SUBPROC *pd, ZONE *zp) |
573 |
greg |
2.2 |
574 |
greg |
2.9 |
IDF_OBJECT *pptr, *pout, *pptr1; |
575 |
greg |
2.3 |
float *uvfa; |
576 |
char uvfbuf[24]; |
577 |
int n, m; |
578 |
greg |
2.9 |
/* create output object */ |
579 |
pout = idf_newobject(our_idf, UVF_PNAME, |
580 |
greg |
2.11 |
" ! computed by Radiance\n ", our_idf->plast); |
581 |
greg |
2.3 |
if (pout == NULL) { |
582 |
583 |
greg |
2.9 |
fputs(": cannot create new IDF object\n", stderr); |
584 |
greg |
2.3 |
return(0); |
585 |
586 |
if (!idf_addfield(pout, zp->zname, |
587 |
" !- Zone Name\n ")) { |
588 |
589 |
fputs(": cannot add zone name field\n", stderr); |
590 |
return(0); |
591 |
592 |
/* allocate read buffer */ |
593 |
greg |
2.11 |
uvfa = (float *)malloc(sizeof(float)*3*zp->ntotal); |
594 |
greg |
2.3 |
if (uvfa == NULL) |
595 |
return(0); |
596 |
/* UVFs from each surface */ |
597 |
greg |
2.11 |
for (n = 0, pptr = zp->pfirst; n < zp->ntotal; n++, pptr = pptr->dnext) { |
598 |
greg |
2.4 |
double vfsum = 0; |
599 |
greg |
2.12 |
double adj_factor; |
600 |
greg |
2.3 |
/* send samples to rcontrib */ |
601 |
greg |
2.12 |
if ((adj_factor = sample_surface(pptr, pd->w)) < 0) |
602 |
greg |
2.3 |
return(0); |
603 |
greg |
2.12 |
if (zp->area_redu == NULL) |
604 |
adj_factor = 1.; |
605 |
else /* comp. for subsurface area */ |
606 |
adj_factor /= adj_factor - zp->area_redu[n]; |
607 |
greg |
2.3 |
/* read results */ |
608 |
greg |
2.23 |
if (readbuf(pd->r, uvfa, sizeof(float)*3*zp->ntotal) != |
609 |
greg |
2.11 |
sizeof(float)*3*zp->ntotal) { |
610 |
greg |
2.3 |
611 |
fputs(": read error from rcontrib process\n", stderr); |
612 |
return(0); |
613 |
614 |
/* append UVF fields */ |
615 |
for (m = 0, pptr1 = zp->pfirst; |
616 |
greg |
2.11 |
m < zp->ntotal; m++, pptr1 = pptr1->dnext) { |
617 |
greg |
2.12 |
const double uvf = uvfa[3*m + 1] * adj_factor; |
618 |
vfsum += uvf; |
619 |
if (pptr1 == pptr && uvf > .001) |
620 |
greg |
2.11 |
fprintf(stderr, |
621 |
greg |
2.5 |
"%s: warning - non-zero self-VF (%.1f%%) for surface '%s'\n", |
622 |
greg |
2.12 |
progname, 100.*uvf, |
623 |
greg |
2.3 |
idf_getfield(pptr,NAME_FLD)->val); |
624 |
greg |
2.12 |
sprintf(uvfbuf, "%.4f", uvf); |
625 |
greg |
2.3 |
if (!idf_addfield(pout, |
626 |
idf_getfield(pptr,NAME_FLD)->val, NULL) || |
627 |
628 |
idf_getfield(pptr1,NAME_FLD)->val, NULL) || |
629 |
!idf_addfield(pout, uvfbuf, |
630 |
greg |
2.11 |
(n+m < 2*zp->ntotal-2) ? |
631 |
"\n " : "\n\n")) { |
632 |
greg |
2.3 |
633 |
fputs(": error adding UVF fields\n", stderr); |
634 |
return(0); |
635 |
636 |
637 |
greg |
2.4 |
if (vfsum < 0.95) |
638 |
fprintf(stderr, |
639 |
"%s: warning - missing %.1f%% of energy from surface '%s'\n", |
640 |
progname, 100.*(1.-vfsum), |
641 |
642 |
greg |
2.3 |
643 |
free(uvfa); /* clean up and return */ |
644 |
return(1); |
645 |
greg |
2.2 |
646 |
647 |
greg |
2.1 |
/* Compute zone User View Factors */ |
648 |
static int |
649 |
compute_zones(void) |
650 |
651 |
greg |
2.2 |
ZONE *zptr; |
652 |
/* temporary octree name */ |
653 |
greg |
2.5 |
mktemp(strcpy(temp_octree, TEMPLATE)); |
654 |
greg |
2.2 |
/* compute each zone */ |
655 |
for (zptr = zone_list; zptr != NULL; zptr = zptr->next) { |
656 |
SUBPROC rcproc; |
657 |
/* start rcontrib process */ |
658 |
greg |
2.22 |
rcproc = sp_inactive; |
659 |
greg |
2.2 |
if (!start_rcontrib(&rcproc, zptr)) |
660 |
return(0); |
661 |
/* compute+add view factors */ |
662 |
if (!compute_uvfs(&rcproc, zptr)) |
663 |
return(0); |
664 |
if (close_process(&rcproc) != 0) { |
665 |
666 |
fputs(": bad return status from rcontrib\n", stderr); |
667 |
return(0); |
668 |
669 |
670 |
unlink(temp_octree); /* remove octree file */ |
671 |
return(1); |
672 |
greg |
2.1 |
673 |
674 |
/* Load IDF and compute User View Factors */ |
675 |
int |
676 |
main(int argc, char *argv[]) |
677 |
678 |
greg |
2.2 |
int incl_comments = 1; |
679 |
greg |
2.1 |
char *origIDF, *revIDF; |
680 |
greg |
2.9 |
IDF_OBJECT *pptr; |
681 |
greg |
2.1 |
int i; |
682 |
683 |
greg |
2.7 |
progname = *argv++; argc--; /* get options if any */ |
684 |
while (argc > 1 && argv[0][0] == '-') |
685 |
switch (argv[0][1]) { |
686 |
case 'c': /* elide comments */ |
687 |
incl_comments = -1; /* header only */ |
688 |
argv++; argc--; |
689 |
continue; |
690 |
case 's': /* samples */ |
691 |
nsamps = 1000*atoi(*++argv); |
692 |
argv++; argc -= 2; |
693 |
continue; |
694 |
default: |
695 |
696 |
fputs(": unknown option '", stderr); |
697 |
fputs(argv[0], stderr); |
698 |
699 |
goto userr; |
700 |
701 |
if ((argc < 1) | (argc > 2)) |
702 |
goto userr; |
703 |
origIDF = argv[0]; |
704 |
revIDF = (argc == 1) ? argv[0] : argv[1]; |
705 |
greg |
2.1 |
/* load Input Data File */ |
706 |
our_idf = idf_load(origIDF); |
707 |
if (our_idf == NULL) { |
708 |
greg |
2.2 |
709 |
greg |
2.1 |
fputs(": cannot load IDF '", stderr); |
710 |
fputs(origIDF, stderr); |
711 |
712 |
return(1); |
713 |
714 |
greg |
2.20 |
/* check version (warning) */ |
715 |
if ((pptr = idf_getobject(our_idf, "Version")) != NULL && |
716 |
greg |
2.21 |
pptr->flist != NULL && pptr->flist->val[0] != '9') { |
717 |
greg |
2.20 |
718 |
greg |
2.21 |
fputs(": warning - written for IDF version 9.x, not ", |
719 |
greg |
2.20 |
stderr); |
720 |
fputs(pptr->flist->val, stderr); |
721 |
fputc('\n', stderr); |
722 |
723 |
greg |
2.1 |
/* remove existing UVFs */ |
724 |
greg |
2.9 |
if ((pptr = idf_getobject(our_idf, UVF_PNAME)) != NULL) { |
725 |
IDF_OBJECT *pnext; |
726 |
greg |
2.2 |
727 |
greg |
2.1 |
fputs(": removing previous User View Factors\n", stderr); |
728 |
do { |
729 |
pnext = pptr->pnext; |
730 |
greg |
2.9 |
idf_delobject(our_idf, pptr); |
731 |
greg |
2.19 |
} while ((pptr = pnext) != NULL); |
732 |
greg |
2.1 |
733 |
/* add to header */ |
734 |
if (our_idf->hrem == NULL || |
735 |
(i = strlen(our_idf->hrem)-strlen(ADD_HEADER)) < 0 || |
736 |
strcmp(our_idf->hrem+i, ADD_HEADER)) |
737 |
idf_add2hdr(our_idf, ADD_HEADER); |
738 |
/* gather zone surfaces */ |
739 |
for (i = 0; surf_type[i].pname != NULL; i++) |
740 |
greg |
2.9 |
for (pptr = idf_getobject(our_idf, surf_type[i].pname); |
741 |
greg |
2.1 |
pptr != NULL; pptr = pptr->pnext) { |
742 |
IDF_FIELD *fptr = idf_getfield(pptr, |
743 |
744 |
745 |
greg |
2.2 |
746 |
fputs(": warning - missing zone field\n", stderr); |
747 |
greg |
2.1 |
continue; |
748 |
749 |
greg |
2.3 |
if (add2zone(pptr, fptr->val) == NULL) |
750 |
greg |
2.1 |
return(1); |
751 |
752 |
greg |
2.11 |
/* add subsurfaces */ |
753 |
for (pptr = idf_getobject(our_idf, SUBSURF_PNAME); |
754 |
pptr != NULL; pptr = pptr->pnext) |
755 |
if (add_subsurf(pptr) == NULL) |
756 |
return(1); |
757 |
greg |
2.1 |
/* run rcontrib on each zone */ |
758 |
if (!compute_zones()) |
759 |
return(1); |
760 |
/* write out modified IDF */ |
761 |
greg |
2.2 |
if (!idf_write(our_idf, revIDF, incl_comments)) { |
762 |
763 |
greg |
2.1 |
fputs(": error writing IDF '", stderr); |
764 |
fputs(revIDF, stderr); |
765 |
766 |
return(1); |
767 |
768 |
return(0); /* finito! */ |
769 |
greg |
2.7 |
userr: |
770 |
fputs("Usage: ", stderr); |
771 |
772 |
fputs(" [-c][-s Ksamps] Model.idf [Revised.idf]\n", stderr); |
773 |
return(1); |
774 |
greg |
2.1 |
