root/radiance/ray/src/util/do_views3.6.tcl
Sat Feb 22 02:07:30 2003 UTC (21 years, 11 months ago) by greg
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0
Fri May 17 13:58:40 1996 UTC (28 years, 9 months ago) by greg
moved globbing values to trad.wsh main file
Mon Aug 28 10:12:39 1995 UTC (29 years, 5 months ago) by greg
Changes since 2.5: +17 -10 lines
added ZFILE variable to rad
Thu Jul 6 12:23:44 1995 UTC (29 years, 7 months ago) by greg
Changes since 2.4: +6 -1 lines
Fri Mar 24 12:35:27 1995 UTC (29 years, 10 months ago) by greg
fixed minor bug in view searching for default views
Sat Nov 5 09:31:48 1994 UTC (30 years, 3 months ago) by greg
modified <Return> action in view options window
Fri Oct 28 20:14:39 1994 UTC (30 years, 3 months ago) by greg
Diff to previous 2.1
added local grab to some getfile procedure
Thu Oct 27 15:56:09 1994 UTC (30 years, 3 months ago) by greg
Links to HEAD: (view) (download) (as text) (annotate) Links to rad3R7P1: (view) (download) (as text) (annotate)
