root/radiance/ray/src/util/do_views.tcl
Revision: 2.4
Committed: Sat Feb 22 02:07:30 2003 UTC (22 years, 2 months ago) by greg
Content type: application/x-tcl
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
1 # RCSid: $Id$
2 #
3 # Handle view parameters
4 #
5
6 proc viewchange {nm el op} { # handle changes to radvar(view)
7 global radvar viewbox viewname viewopts
8 if {"$op" == "u"} {
9 set radvar(view) {}
10 trace variable radvar(view) wu viewchange
11 }
12 $viewbox delete 0 end
13 foreach v $radvar(view) {
14 $viewbox insert end [lindex $v 0]
15 }
16 }
17
18 proc vnchange {nm el op} { # handle changes to viewname
19 global viewname vdefbutt radvar
20 if {"$viewname" == {}} {
21 $vdefbutt configure -text "Set Default" -state disabled
22 } elseif {$radvar(view) != {} &&
23 "[lindex [lindex $radvar(view) 0] 0]" == "$viewname"} {
24 $vdefbutt configure -text "Is Default" -state disabled
25 } else {
26 $vdefbutt configure -text "Set Default" -state normal
27 }
28 }
29
30 proc selview {} { # change selected view
31 global radvar viewbox viewname viewopts viewseln
32 set viewseln [$viewbox curselection]
33 set viewname [$viewbox get $viewseln]
34 set viewopts [lrange [lindex $radvar(view) $viewseln] 1 end]
35 }
36
37 proc addview {{pos end}} { # add current view
38 global radvar viewname viewopts curmess viewseln viewbox
39 if {$pos == -1} {return -1}
40 if {[llength $viewname] != 1} {
41 beep
42 set curmess "Illegal view name."
43 return -1
44 }
45 set curmess {}
46 set n [lsearch -exact $radvar(view) $viewname]
47 if {$n < 0} {
48 set n [lsearch -glob $radvar(view) "$viewname *"]
49 }
50 if {$n >= 0} {
51 set radvar(view) [lreplace $radvar(view) $n $n]
52 if {"$pos" != "end" && $pos > $n} {incr pos -1}
53 }
54 if {"$pos" == "end"} {
55 set viewseln [llength $radvar(view)]
56 lappend radvar(view) "$viewname $viewopts"
57 } else {
58 set viewseln $pos
59 set radvar(view) [linsert $radvar(view) $pos \
60 "$viewname $viewopts"]
61 }
62 vnchange viewname {} w
63 $viewbox selection anchor $pos
64 return $pos
65 }
66
67 proc delview {} { # delete current view
68 global radvar viewbox curmess viewseln
69 if {! [info exists viewseln]} {
70 beep
71 set curmess "No view selected for deletion."
72 return -1
73 }
74 set n $viewseln
75 set curmess {}
76 set radvar(view) [lreplace $radvar(view) $n $n]
77 vnchange viewname {} w
78 unset viewseln
79 return $n
80 }
81
82 proc copyviews rf { # copy view settings from another RIF
83 load_vars [file tail $rf] {view UP PICTURE EYESEP RESOLUTION RAWFILE ZFILE}
84 vnchange viewname {} w
85 }
86
87 proc do_views w { # create views screen
88 global radvar viewbox viewseln viewname viewopts vdefbutt rifname
89 if {"$w" == "done"} {
90 trace vdelete radvar(view) wu viewchange
91 trace vdelete viewname w vnchange
92 unset viewbox viewname viewopts vdefbutt
93 return
94 }
95 frame $w
96 # View box
97 label $w.vvl -text Views
98 place $w.vvl -relx .0714 -rely .0610
99 frame $w.vnl
100 scrollbar $w.vnl.sb -relief sunken -command "$w.vnl.lb yview"
101 listbox $w.vnl.lb -relief sunken -yscroll "$w.vnl.sb set" \
102 -selectmode browse
103 set viewbox $w.vnl.lb
104 bind $w.vnl.lb <ButtonRelease-1> +selview
105 pack $w.vnl.sb -side right -fill y
106 pack $w.vnl.lb -side left -expand yes -fill both
107 place $w.vnl -relwidth .1786 -relheight .3049 -relx .07143 -rely .1220
108 helplink $w.vnl.lb trad views list
109 # View name
110 set viewname {}
111 label $w.vnlb -text Name
112 place $w.vnlb -relx .2857 -rely .0610
113 entry $w.vne -textvariable viewname -relief sunken
114 place $w.vne -relwidth .1429 -relheight .0610 -relx .2857 -rely .1220
115 helplink $w.vne trad views name
116 # View options
117 set viewopts {}
118 label $w.vol -text Options
119 place $w.vol -relx .2857 -rely .1829
120 frame $w.vo
121 entry $w.vo.e -textvariable viewopts -relief sunken \
122 -xscroll "$w.vo.s set"
123 scrollbar $w.vo.s -relief sunken -orient horiz \
124 -highlightthickness 0 -command "$w.vo.e xview"
125 pack $w.vo.e $w.vo.s -side top -fill x
126 place $w.vo -relwidth .6429 -relheight .1000 -relx .2857 -rely .2439
127 helplink $w.vo.e trad views options
128 # View change buttons
129 button $w.vclr -text Clear -width 7 -relief raised \
130 -command "set viewname {} ; set viewopts {}
131 focus $w.vne
132 catch {unset viewseln}
133 $w.vnl.lb selection clear 0 end"
134 place $w.vclr -relx .4643 -rely .1220
135 helplink $w.vclr trad views clear
136 button $w.vdef -text "Set Default" -width 12 \
137 -relief raised -state disabled -command {addview 0}
138 place $w.vdef -relx .6429 -rely .1220
139 helplink $w.vdef trad views default
140 set vdefbutt $w.vdef
141 button $w.vadd -text Add -width 7 -relief raised -command addview
142 place $w.vadd -relx .2857 -rely .3659
143 helplink $w.vadd trad views add
144 button $w.vchg -text Change -width 7 -relief raised \
145 -command {addview [delview]}
146 place $w.vchg -relx .4643 -rely .3659
147 helplink $w.vchg trad views change
148 button $w.vdel -text Delete -width 7 -relief raised -command delview
149 place $w.vdel -relx .6429 -rely .3659
150 helplink $w.vdel trad views delete
151 # Up vector
152 label $w.upl -text Up:
153 place $w.upl -relx .0714 -rely .4878
154 radiobutton $w.upxp -text +X -variable radvar(UP) -value X -relief flat
155 place $w.upxp -relx .2857 -rely .4634
156 radiobutton $w.upxn -text -X -variable radvar(UP) -value -X -relief flat
157 place $w.upxn -relx .2857 -rely .5244
158 radiobutton $w.upyp -text +Y -variable radvar(UP) -value Y -relief flat
159 place $w.upyp -relx .4286 -rely .4634
160 radiobutton $w.upyn -text -Y -variable radvar(UP) -value -Y -relief flat
161 place $w.upyn -relx .4286 -rely .5244
162 radiobutton $w.upzp -text +Z -variable radvar(UP) -value Z -relief flat
163 place $w.upzp -relx .5714 -rely .4634
164 radiobutton $w.upzn -text -Z -variable radvar(UP) -value -Z -relief flat
165 place $w.upzn -relx .5714 -rely .5244
166 helplink "$w.upxp $w.upxn $w.upyp $w.upyn $w.upzp $w.upzn" \
167 trad views up
168 # Eye separation distance
169 label $w.eyl -text Eyesep:
170 place $w.eyl -relx .0714 -rely .6000
171 entry $w.eye -textvariable radvar(EYESEP) -relief sunken
172 place $w.eye -relwidth .2857 -relheight .0610 -relx .2857 -rely .6000
173 helplink $w.eye trad views eyesep
174 # Picture file name
175 label $w.pfl -text Picture:
176 place $w.pfl -relx .0714 -rely .6658
177 entry $w.pfe -textvariable radvar(PICTURE) -relief sunken
178 place $w.pfe -relwidth .5714 -relheight .0610 -relx .2857 -rely .6658
179 helplink $w.pfe trad views picture
180 # Resolution
181 label $w.rzl -text Resolution:
182 place $w.rzl -relx .0714 -rely .7316
183 entry $w.rze -textvariable radvar(RESOLUTION) -relief sunken
184 place $w.rze -relwidth .2857 -relheight .0610 -relx .2857 -rely .7316
185 helplink $w.rze trad views resolution
186 # Rawfile
187 label $w.rfl -text Rawfile:
188 place $w.rfl -relx .0714 -rely .7974
189 entry $w.rfe -textvariable radvar(RAWFILE) -relief sunken
190 place $w.rfe -relwidth .5714 -relheight .0610 -relx .2857 -rely .7974
191 helplink $w.rfe trad views rawfile
192 # Zfile
193 label $w.zfl -text Zfile:
194 place $w.zfl -relx .0714 -rely .8632
195 entry $w.zfe -textvariable radvar(ZFILE) -relief sunken
196 place $w.zfe -relwidth .5714 -relheight .0610 -relx .2857 -rely .8632
197 helplink $w.zfe trad views zfile
198 # Revert and Copy buttons
199 button $w.revert -text Revert -relief raised \
200 -command "copyviews $rifname"
201 place $w.revert -relwidth .1071 -relheight .0610 -relx .98 -rely .98 \
202 -anchor se
203 helplink $w.revert trad views revert
204 button $w.copy -text Copy -relief raised -command {getfile -grab \
205 -send copyviews -view view_txt -glob $myglob(rif)}
206 place $w.copy -relwidth .1071 -relheight .0610 -relx .98 -rely .90 \
207 -anchor se
208 helplink $w.copy trad views copy
209 # Assign focus
210 bind $w.vne <Return> "focus $w.vo.e"
211 bind $w.vo.e <Return> "addview ; $w.vclr invoke"
212 bind $w.vo.e <B2-Motion> {}
213 bind $w.vo.e <Button-2> "$w.vo.e insert insert \[selection get\]"
214 $w.vclr invoke
215 # Track variables
216 vnchange viewname {} w
217 trace variable viewname w vnchange
218 if [info exists radvar(view)] {
219 viewchange radvar view w
220 trace variable radvar(view) wu viewchange
221 } else {
222 viewchange radvar view u
223 }
224 }
