root/radiance/ray/src/util/do_scene3.6.tcl
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0
Fri May 17 13:53:04 1996 UTC (27 years, 11 months ago) by greg
Changes since 2.8: +0 -5 lines
moved globbing patterns to trad.wsh main file
Tue Oct 17 21:28:15 1995 UTC (28 years, 6 months ago) by greg
Wed Feb 22 20:48:52 1995 UTC (29 years, 2 months ago) by greg
changed default of dialog box to affirmative
Tue Dec 6 15:54:43 1994 UTC (29 years, 5 months ago) by greg
changed "update idletasks" to "update"
Revision 2.5 - (view) (download) (as text) (annotate) - [selected]
Sat Oct 29 10:20:50 1994 UTC (29 years, 6 months ago) by greg
changed glob for objects from *.rad to *
Fri Oct 28 20:14:38 1994 UTC (29 years, 6 months ago) by greg
added local grab to some getfile procedure
Fri Oct 28 11:10:16 1994 UTC (29 years, 6 months ago) by greg
changed position of octree delete button
Fri Oct 28 10:43:32 1994 UTC (29 years, 6 months ago) by greg
Changes since 2.1: +5 -5 lines
fixed size defaults for smaller dispaly
Thu Oct 27 15:56:08 1994 UTC (29 years, 6 months ago) by greg
Diff to selected 2.5
Links to HEAD: (view) (download) (as text) (annotate) Links to rad3R7P2: (view) (download) (as text) (annotate)
