root/radiance/ray/src/util/do_options.tcl
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2
Fri May 17 13:58:35 1996 UTC (27 years, 11 months ago) by greg
moved globbing values to trad.wsh main file
Revision 2.6 - (view) (download) (as text) (annotate) - [selected]
Tue Oct 17 21:28:09 1995 UTC (28 years, 6 months ago) by greg
Wed Feb 22 20:48:49 1995 UTC (29 years, 2 months ago) by greg
changed default of dialog box to affirmative
Tue Feb 7 12:01:17 1995 UTC (29 years, 3 months ago) by greg
made amb_delete slightly less sensitive to small ambient files
Mon Dec 5 14:29:46 1994 UTC (29 years, 5 months ago) by greg
minor spelling fix in dialog box
Fri Oct 28 20:14:36 1994 UTC (29 years, 6 months ago) by greg
added local grab to some getfile procedure
Thu Oct 27 15:56:07 1994 UTC (29 years, 6 months ago) by greg
Diff to selected 2.6
Links to HEAD: (view) (download) (as text) (annotate) Links to rad3R6P1: (view) (download) (as text) (annotate)
