root/radiance/ray/src/util/do_options.tcl
Revision: 2.10
Committed: Tue May 26 12:39:25 2015 UTC (9 years, 11 months ago) by greg
Content type: application/x-tcl
CVS Tags: rad5R4, rad5R2, rad5R0, rad5R1, rad5R3, HEAD
Changes since 2.9: +92 -26 lines
Error occurred while calculating annotation data.
Added photon map support to trad
1 # RCSid: $Id: do_options.tcl,v 2.9 2014/08/01 02:18:42 greg Exp $
2 #
3 # Options screen for trad
4 #
5
6 proc amb_delete {} { # delete ambient file
7 global radvar curmess
8 if {"$radvar(AMBFILE)" == {} || ! [file isfile $radvar(AMBFILE)]} {
9 set curmess {No ambient file.}
10 return
11 }
12 set hl [string length [exec getinfo < $radvar(AMBFILE)]]
13 set fl [file size $radvar(AMBFILE)]
14 set nv [expr ($fl - $hl - 2) / 67]
15 if {$nv > 1000 && [tk_dialog .dlg {Verification} \
16 "Really delete ambient file $radvar(AMBFILE)\
17 with $nv indirect irradiance values?" \
18 questhead 0 {Delete} {Cancel}]} {
19 return 0
20 }
21 if [catch {exec rm $radvar(AMBFILE) < /dev/null} curmess] {return 0}
22 set curmess {Ambient file deleted.}
23 return 1
24 }
25
26 proc pgm_delete {} { # delete global photon map file
27 global radvar curmess
28 set pm [lindex $radvar(PGMAP) 0]
29 if {"$pm" == {} || ! [file isfile $pm]} {
30 set curmess {No global photon file.}
31 return
32 }
33 set hd [exec getinfo < $pm]
34 set nv [lindex $hd [expr [lsearch $hd photons] - 1]]
35 if {$nv > 10000 && [tk_dialog .dlg {Verification} \
36 "Really delete global photon map $pm\
37 with $nv photons?" \
38 questhead 0 {Delete} {Cancel}]} {
39 return 0
40 }
41 if [catch {exec rm $pm < /dev/null} curmess] {return 0}
42 set curmess {Global photon file deleted.}
43 return 1
44 }
45
46 proc pcm_delete {} { # delete caustic photon map file
47 global radvar curmess
48 set pm [lindex $radvar(PCMAP) 0]
49 if {"$pm" == {} || ! [file isfile $pm]} {
50 set curmess {No caustic photon file.}
51 return
52 }
53 set hd [exec getinfo < $pm]
54 set nv [lindex $hd [expr [lsearch $hd photons] - 1]]
55 if {$nv > 10000 && [tk_dialog .dlg {Verification} \
56 "Really delete caustic photon map $pm\
57 with $nv photons?" \
58 questhead 0 {Delete} {Cancel}]} {
59 return 0
60 }
61 if [catch {exec rm $pm < /dev/null} curmess] {return 0}
62 set curmess {Caustic photon file deleted.}
63 return 1
64 }
65
66 proc copyopts rf { # copy option settings from another RIF
67 load_vars [file tail $rf] {QUALITY PENUMBRAS AMBFILE PGMAP PCMAP OPTFILE REPORT \
68 oconv mkillum mkpmap render pfilt}
69 }
70
71 proc do_options w { # Set up options screen
72 global radvar rifname
73 if {"$w" == "done"} {
74 return
75 }
76 frame $w
77 # Quality
78 label $w.qual -text Quality:
79 place $w.qual -relx .0714 -rely .0510
80 radiobutton $w.quaH -text High -anchor w -relief flat \
81 -variable radvar(QUALITY) -value High
82 place $w.quaH -relx .2857 -rely .0510
83 radiobutton $w.quaM -text Medium -anchor w -relief flat \
84 -variable radvar(QUALITY) -value Medium
85 place $w.quaM -relx .5357 -rely .0510
86 radiobutton $w.quaL -text Low -anchor w -relief flat \
87 -variable radvar(QUALITY) -value Low
88 place $w.quaL -relx .7857 -rely .0510
89 helplink "$w.quaH $w.quaM $w.quaL" trad options quality
90 # Penumbras
91 label $w.penl -text Penumbras:
92 place $w.penl -relx .0714 -rely .1485
93 radiobutton $w.penT -text On -anchor w -relief flat \
94 -variable radvar(PENUMBRAS) -value True
95 place $w.penT -relx .2857 -rely .1485
96 radiobutton $w.penF -text Off -anchor w -relief flat \
97 -variable radvar(PENUMBRAS) -value False
98 place $w.penF -relx .5357 -rely .1485
99 helplink "$w.penT $w.penF" trad options penumbras
100 # Global photon map
101 label $w.pgml -text Pgmap:
102 place $w.pgml -relx .0714 -rely .2460
103 entry $w.pgme -textvariable radvar(PGMAP) -relief sunken
104 place $w.pgme -relwidth .5714 -relheight .0610 -relx .2857 -rely .2460
105 helplink $w.pgme trad options pgmap
106 button $w.pgmd -text Delete -relief raised -command pgm_delete
107 place $w.pgmd -relwidth .1071 -relheight .0610 -relx .98 -rely .2460 \
108 -anchor ne
109 helplink $w.pgmd trad options pgmdelete
110 # Caustic photon map
111 label $w.pcml -text Pcmap:
112 place $w.pcml -relx .0714 -rely .3341
113 entry $w.pcme -textvariable radvar(PCMAP) -relief sunken
114 place $w.pcme -relwidth .5714 -relheight .0610 -relx .2857 -rely .3341
115 helplink $w.pcme trad options pcmap
116 button $w.pcmd -text Delete -relief raised -command pcm_delete
117 place $w.pcmd -relwidth .1071 -relheight .0610 -relx .98 -rely .3341 \
118 -anchor ne
119 helplink $w.pcmd trad options pcmdelete
120 # Ambfile
121 label $w.ambl -text Ambfile:
122 place $w.ambl -relx .0714 -rely .4222
123 entry $w.ambe -textvariable radvar(AMBFILE) -relief sunken
124 place $w.ambe -relwidth .5714 -relheight .0610 -relx .2857 -rely .4222
125 helplink $w.ambe trad options ambfile
126 button $w.ambd -text Delete -relief raised -command amb_delete
127 place $w.ambd -relwidth .1071 -relheight .0610 -relx .98 -rely .4222 \
128 -anchor ne
129 helplink $w.ambd trad options ambdelete
130 # Optfile
131 label $w.optl -text Optfile:
132 place $w.optl -relx .0714 -rely .5103
133 entry $w.opte -textvariable radvar(OPTFILE) -relief sunken
134 place $w.opte -relwidth .5714 -relheight .0610 -relx .2857 -rely .5103
135 helplink $w.opte trad options optfile
136 # Report
137 label $w.repl -text Report:
138 place $w.repl -relx .0714 -rely .5984
139 entry $w.repe -textvariable radvar(REPORT) -relief sunken
140 place $w.repe -relwidth .5714 -relheight .0610 -relx .2857 -rely .5984
141 helplink $w.repe trad options report
142 # Oconv options
143 label $w.ocol -text "oconv opts:"
144 place $w.ocol -relx .0714 -rely .6863
145 entry $w.ocoe -textvariable radvar(oconv) -relief sunken
146 place $w.ocoe -relwidth .5714 -relheight .0600 -relx .2857 -rely .6863
147 helplink $w.ocoe trad options oconv
148 # Mkillum options
149 label $w.mkil -text "mkillum opts:"
150 place $w.mkil -relx .0714 -rely .7473
151 entry $w.mkie -textvariable radvar(mkillum) -relief sunken
152 place $w.mkie -relwidth .5714 -relheight .0600 -relx .2857 -rely .7473
153 helplink $w.mkie trad options mkillum
154 # Mkpmap options
155 label $w.mkpl -text "mkpmap opts:"
156 place $w.mkpl -relx .0714 -rely .8083
157 entry $w.mkpe -textvariable radvar(mkpmap) -relief sunken
158 place $w.mkpe -relwidth .5714 -relheight .0600 -relx .2857 -rely .8083
159 helplink $w.mkpe trad options mkpmap
160 # Render options
161 label $w.renl -text "render opts:"
162 place $w.renl -relx .0714 -rely .8693
163 entry $w.rene -textvariable radvar(render) -relief sunken
164 place $w.rene -relwidth .5714 -relheight .0600 -relx .2857 -rely .8693
165 helplink $w.rene trad options render
166 # Pfilt options
167 label $w.pfil -text "pfilt opts:"
168 place $w.pfil -relx .0714 -rely .9339
169 entry $w.pfie -textvariable radvar(pfilt) -relief sunken
170 place $w.pfie -relwidth .5714 -relheight .0600 -relx .2857 -rely .9339
171 helplink $w.pfie trad options pfilt
172 # Revert and Copy buttons
173 button $w.revert -text Revert -relief raised \
174 -command "copyopts $rifname"
175 place $w.revert -relwidth .1071 -relheight .0610 -relx .98 -rely .98 \
176 -anchor se
177 helplink $w.revert trad options revert
178 button $w.copy -text Copy -relief raised -command {getfile -grab \
179 -send copyopts -view view_txt -glob $myglob(rif)}
180 place $w.copy -relwidth .1071 -relheight .0610 -relx .98 -rely .90 \
181 -anchor se
182 helplink $w.copy trad options copy
183 # Set focus
184 focus $w.ambe
185 bind $w.ambe <Return> "focus $w.opte"
186 bind $w.opte <Return> "focus $w.repe"
187 bind $w.repe <Return> "focus $w.ocoe"
188 bind $w.ocoe <Return> "focus $w.mkie"
189 bind $w.mkie <Return> "focus $w.rene"
190 bind $w.rene <Return> "focus $w.pfie"
191 bind $w.pfie <Return> {}
192 }
