--- ray/src/util/do_file.tcl 1994/10/27 15:56:06 2.1 +++ ray/src/util/do_file.tcl 2017/09/07 00:02:07 2.24 @@ -1,14 +1,12 @@ -# SCCSid "$SunId$ LBL" +# RCSid: $Id: do_file.tcl,v 2.24 2017/09/07 00:02:07 greg Exp $ # # Choose the Rad Input File to work on. # -set rif_glob *.rif - proc preen {} { # clean up radvar global radvar rifname - foreach n {objects scene materials illum mkillum render oconv pfilt - AMBFILE OPTFILE EXPOSURE ZONE REPORT} { + foreach n {objects scene materials illum mkillum mkpmap render oconv rvu rpict pfilt + RAWFILE ZFILE AMBFILE PGMAP PCMAP OPTFILE EXPOSURE ZONE REPORT} { if {! [info exists radvar($n)]} { set radvar($n) {} } @@ -19,7 +17,7 @@ proc preen {} { # clean up radvar set n 1 foreach v $oldval { if {"[string index $v 0]" == "-"} { - lappend radvar(view) "$n $v" + lappend radvar(view) "u$n $v" } elseif {[lsearch -glob $radvar(view) \ "[lindex $v 0] *"] >= 0} { continue @@ -45,6 +43,9 @@ proc preen {} { # clean up radvar if {! [info exists radvar(RESOLUTION)]} { set radvar(RESOLUTION) 512 } + if {! [info exists radvar(EYESEP)]} { + set radvar(EYESEP) 1 + } if [info exists radvar(QUALITY)] { cardval radvar(QUALITY) {High Medium Low} } else { @@ -75,15 +76,18 @@ proc preen {} { # clean up radvar proc setradvar stmt { # assign a rad variable global radvar - regexp {^([a-zA-Z][a-zA-Z0-9]*) *= *(.*)$} $stmt dummy vnam vval + regexp {^([a-zA-Z][a-zA-Z0-9]*) *=[ ]*(.*)$} $stmt dummy vnam vval switch -glob $vnam { obj* { eval lappend radvar(objects) $vval } sce* { eval lappend radvar(scene) $vval } mat* { eval lappend radvar(materials) $vval } ill* { eval lappend radvar(illum) $vval } mki* { eval lappend radvar(mkillum) $vval } + mkp* { eval lappend radvar(mkpmap) $vval } ren* { eval lappend radvar(render) $vval } oco* { eval lappend radvar(oconv) $vval } + rvu { eval lappend radvar(rvu) $vval } + rpi* { eval lappend radvar(rpict) $vval } pf* { eval lappend radvar(pfilt) $vval } vi* { lappend radvar(view) $vval } ZO* { set radvar(ZONE) $vval } @@ -93,6 +97,7 @@ proc setradvar stmt { # assign a rad variable AMB* { set radvar(AMBFILE) $vval } OPT* { set radvar(OPTFILE) $vval } EXP* { set radvar(EXPOSURE) $vval } + EYE* { set radvar(EYESEP) $vval } RES* { set radvar(RESOLUTION) $vval } UP { set radvar(UP) $vval } IND* { set radvar(INDIRECT) $vval } @@ -100,6 +105,10 @@ proc setradvar stmt { # assign a rad variable PEN* { set radvar(PENUMBRAS) $vval } VAR* { set radvar(VARIABILITY) $vval } REP* { set radvar(REPORT) $vval } + RAW* { set radvar(RAWFILE) $vval } + ZF* {set radvar(ZFILE) $vval } + PGM* {set radvar(PGMAP) $vval } + PCM* {set radvar(PCMAP) $vval } } } @@ -119,7 +128,8 @@ proc putradvar {fi vn} { # print out a rad variable } if {[lsearch -exact {ZONE QUALITY OCTREE PICTURE AMBFILE OPTFILE EXPOSURE RESOLUTION UP INDIRECT DETAIL PENUMBRAS - VARIABILITY REPORT} $vn] >= 0} { + EYESEP RAWFILE ZFILE VARIABILITY REPORT + PGMAP PCMAP} $vn] >= 0} { puts $fi "$vn= $radvar($vn)" return } @@ -141,24 +151,24 @@ proc putradvar {fi vn} { # print out a rad variable proc load_vars {f {vl all}} { # load RIF variables global curmess radvar alldone if {"$f" == ""} {return 0} - if {! [file exists $f]} { + if {! [file isfile $f]} { beep set curmess "$f: no such file." return 0 } if {"$vl" == "all" && ! [chksave]} {return 0} set curmess {Please wait...} - update idletasks - if [catch {exec rad -n -w -e $f >& /usr/tmp/ro[pid]}] { - set curmess [exec cat /usr/tmp/ro[pid]] - exec rm -f /usr/tmp/ro[pid] + update + if [catch {exec rad -n -w -e $f >& /tmp/ro[pid]}] { + set curmess [exec cat /tmp/ro[pid]] + exec rm -f /tmp/ro[pid] return 0 } - set fi [open /usr/tmp/ro[pid] r] + set fi [open /tmp/ro[pid] r] if {"$vl" == "all"} { catch {unset radvar} while {[gets $fi curli] != -1} { - if [regexp {^[a-zA-Z][a-zA-Z0-9]*= } $curli] { + if [regexp {^[a-zA-Z][a-zA-Z0-9]* *=} $curli] { setradvar $curli } else { break @@ -167,7 +177,11 @@ proc load_vars {f {vl all}} { # load RIF variables set curmess {Project loaded.} } else { foreach n $vl { - set radvar($n) {} + if [regexp {[a-z][a-z]*} $n] { + set radvar($n) {} + } else { + catch {unset radvar($n)} + } } while {[gets $fi curli] != -1} { if [regexp {^[a-zA-Z][a-zA-Z0-9]* *=} $curli] { @@ -183,7 +197,7 @@ proc load_vars {f {vl all}} { # load RIF variables } set alldone [eof $fi] close $fi - exec rm -f /usr/tmp/ro[pid] + exec rm -f /tmp/ro[pid] preen return 1 } @@ -236,12 +250,23 @@ proc newsave f { # save a RIF return 0 } } elseif {[file exists $f]} { + set ftyp [file type $f] + if { $ftyp != "file" } { + beep + set curmess "Selected file $f is a $ftyp." + return 0 + } if [tk_dialog .dlg {Verification} \ "Overwrite existing file $f?" \ questhead 1 {Go Ahead} {Cancel}] { return 0 } } + if {[file isfile $f] && ! [file writable $f] && + [catch {exec chmod u+w $f} curmess]} { + beep + return 0 + } if [save_vars $f] { set rifname [pwd]/$f set readonly 0 @@ -254,6 +279,12 @@ proc newsave f { # save a RIF proc newnew f { # create a new RIF global rifname readonly curmess radvar if [file exists $f] { + set ftyp [file type $f] + if { $ftyp != "file" } { + beep + set curmess "Selected file $f is a $ftyp." + return 0 + } if [tk_dialog .dlg {Verification} \ "File $f exists -- disregard it?" \ questhead 1 {Yes} {Cancel}] { @@ -271,9 +302,10 @@ proc newnew f { # create a new RIF } proc do_file w { - global rifname readonly rif_glob curfile curpat + global rifname readonly myglob curfile curpat if {"$w" == "done"} { - set rif_glob $curpat + cd [file dirname $rifname] + set myglob(rif) $curpat return } frame $w @@ -281,8 +313,8 @@ proc do_file w { pack $w.left -side left button $w.left.load -text LOAD -width 5 \ -relief raised -command {newload $curfile} - button $w.left.save -text SAVE -width 5 \ - -relief raised -command {newsave $curfile} + button $w.left.save -text SAVE -width 5 -relief raised \ + -command "newsave \$curfile; update_dir $w.right" button $w.left.new -text NEW -width 5 \ -relief raised -command {newnew $curfile} pack $w.left.load $w.left.save $w.left.new -side top -pady 15 -padx 20 @@ -294,6 +326,6 @@ proc do_file w { helplink $w.left.new trad file new helplink $w.left.ro trad file readonly getfile -view view_txt -perm \ - -win $w.right -glob [file dirname $rifname]/$rif_glob + -win $w.right -glob [file dirname $rifname]/$myglob(rif) set curfile [file tail $rifname] }
