Added missing rvu and rpict variables
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added EYESEP variable
fixed problems with understanding tabs in variable assignments
workaround for active box and REVERT command (load_vars)
moved globbing patterns to trad.wsh main file
minor fixes for RAWFILE and ZFILE variables
Changed RAWSAVE to RAWFILE (and changed meaning) added ZFILE variable to rad
changed naming of unnamed views to avoid problems with rad
fixed partial loading of variables.
bug fix from last change
forgot chmod on read-only file!
added directory update when file is saved
changed "update idletasks" to "update"
fixed bug where changing directory in FILE screen was contageous
