root/radiance/ray/src/util/do_file.tcl
Revision 2.24 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Sep 7 00:02:07 2017 UTC (7 years, 7 months ago) by greg
Diff to previous 2.23 , to selected 2.19
Added missing variables
Revision 2.23 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Sep 6 23:57:56 2017 UTC (7 years, 7 months ago) by greg
Changes since 2.22: +6 -0 lines
Diff to previous 2.22 , to selected 2.19
Fixed issue with trad introduced in last change
Revision 2.22 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Aug 26 16:07:22 2017 UTC (7 years, 8 months ago) by greg
Changes since 2.21: +1 -7 lines
Diff to previous 2.21 , to selected 2.19
Revision 2.21 - (view) (download) (as text) (annotate) - [select for diffs]
Thu May 28 10:23:06 2015 UTC (9 years, 11 months ago) by greg
CVS Tags: rad5R0, rad5R1
Diff to previous 2.20 , to selected 2.19
Fixed typo that caused mkpmap options to be ignored
Revision 2.20 - (view) (download) (as text) (annotate) - [select for diffs]
Tue May 26 12:39:25 2015 UTC (9 years, 11 months ago) by greg
Changes since 2.19: +6 -3 lines
Diff to previous 2.19
Added photon map support to trad
Revision 2.19 - (view) (download) (as text) (annotate) - [selected]
Sun Jun 3 20:32:49 2012 UTC (12 years, 11 months ago) by greg
Changes since 2.18: +4 -2 lines
Diff to previous 2.18
Added missing rvu and rpict variables
Revision 2.18 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Feb 16 05:40:12 2005 UTC (20 years, 2 months ago) by greg
Diff to previous 2.17 , to selected 2.19
Revision 2.17 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 22 02:07:30 2003 UTC (22 years, 2 months ago) by greg
Diff to previous 2.16 , to selected 2.19
Revision 2.16 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Oct 20 11:52:15 1998 UTC (26 years, 6 months ago) by gwlarson
Diff to previous 2.15 , to selected 2.19
added EYESEP variable
Revision 2.15 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Aug 12 15:19:05 1997 UTC (27 years, 8 months ago) by gregl
Diff to previous 2.14 , to selected 2.19
fixed problems with understanding tabs in variable assignments
Revision 2.14 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jul 10 11:48:58 1996 UTC (28 years, 9 months ago) by greg
Diff to previous 2.13 , to selected 2.19
workaround for active box and REVERT command (load_vars)
Fri May 17 13:53:07 1996 UTC (28 years, 11 months ago) by greg
Changes since 2.12: +3 -5 lines
Diff to previous 2.12 , to selected 2.19
moved globbing patterns to trad.wsh main file
Tue Oct 17 21:28:20 1995 UTC (29 years, 6 months ago) by greg
Changes since 2.11: +14 -2 lines
Diff to previous 2.11 , to selected 2.19
Thu Sep 21 10:29:12 1995 UTC (29 years, 7 months ago) by greg
Diff to previous 2.10 , to selected 2.19
minor fixes for RAWFILE and ZFILE variables
Mon Aug 28 10:12:38 1995 UTC (29 years, 8 months ago) by greg
Changes since 2.9: +3 -7 lines
Diff to previous 2.9 , to selected 2.19
added ZFILE variable to rad
Thu Jul 6 12:15:54 1995 UTC (29 years, 10 months ago) by greg
Diff to previous 2.8 , to selected 2.19
Wed May 17 15:55:06 1995 UTC (29 years, 11 months ago) by greg
Diff to previous 2.7 , to selected 2.19
changed naming of unnamed views to avoid problems with rad
Tue Mar 21 16:19:26 1995 UTC (30 years, 1 month ago) by greg
Diff to previous 2.6 , to selected 2.19
fixed partial loading of variables.
Wed Feb 15 14:12:05 1995 UTC (30 years, 2 months ago) by greg
Diff to previous 2.5 , to selected 2.19
bug fix from last change
Thu Dec 8 17:16:38 1994 UTC (30 years, 5 months ago) by greg
Changes since 2.4: +4 -0 lines
Diff to previous 2.4 , to selected 2.19
forgot chmod on read-only file!
Thu Dec 8 15:53:46 1994 UTC (30 years, 5 months ago) by greg
Diff to previous 2.3 , to selected 2.19
added directory update when file is saved
Tue Dec 6 15:54:45 1994 UTC (30 years, 5 months ago) by greg
Diff to previous 2.2 , to selected 2.19
changed "update idletasks" to "update"
Thu Dec 1 09:53:55 1994 UTC (30 years, 5 months ago) by greg
Diff to previous 2.1 , to selected 2.19
fixed bug where changing directory in FILE screen was contageous
Thu Oct 27 15:56:06 1994 UTC (30 years, 6 months ago) by greg
Diff to selected 2.19
Links to HEAD: (view) (download) (as text) (annotate) Links to MAIN: (view) (download) (as text) (annotate)
