--- ray/src/util/do_action.tcl 1994/12/06 19:36:21 2.7 +++ ray/src/util/do_action.tcl 2012/06/01 22:55:14 2.13 @@ -1,14 +1,15 @@ -# SCCSid "$SunId$ LBL" +# RCSid: $Id: do_action.tcl,v 2.13 2012/06/01 22:55:14 greg Exp $ # # Action screen for trad # set batch_fmt "Process %d on %s started" set hostname [exec hostname] +set nproc 1 proc make_script {} { # make run script global scname rpview curmess - set rfn /usr/tmp/rf[pid] + set rfn /tmp/rf[pid] if {! [save_vars $rfn]} { beep set curmess "Cannot save variables to temporary file!" @@ -19,7 +20,7 @@ proc make_script {} { # make run script lappend radcom -v $rpview } if {"$scname" == {}} { - set rof /usr/tmp/ro[pid] + set rof /tmp/ro[pid] } else { set rof $scname } @@ -48,9 +49,14 @@ proc make_oct args { # Make octree file ($args is {-t } } +proc set_nproc v { # set number of processes + global nproc + set nproc $v +} + proc run_rad args { # Run rad command with given arguments global curmess - set rfn /usr/tmp/rf[pid] + set rfn /tmp/rf[pid] if {! [save_vars $rfn]} { beep set curmess "Cannot save variables to temporary file!" @@ -67,7 +73,7 @@ proc run_rad args { # Run rad command with given argu } proc run_batch {} { # start rendering in background - global rpview bfname batch_pid curmess rifname mywin batch_fmt hostname + global rpview bfname batch_pid curmess rifname mywin batch_fmt hostname nproc if {! [chksave]} {return} if [catch {set fo [open $bfname w]} curmess] { return @@ -76,9 +82,9 @@ proc run_batch {} { # start rendering in background puts $fo \ " " if {$rpview == " ALL"} { - set radcom "rad" + set radcom "rad -N $nproc" } else { - set radcom "rad -v $rpview" + set radcom "rad -v $rpview -N $nproc" } lappend radcom "[file tail $rifname]" # Put out command @@ -171,10 +177,10 @@ proc make_vmenus {} { # make/update view menus } proc do_action w { # Action screen - global rifname rvview rpview radvar bfname batch_pid \ + global rifname rvview rpview radvar bfname batch_pid nproc \ curmess scname mywin alldone batch_fmt hostname if {"$w" == "done"} { - unset rpview bfname batch_pid mywin + unset rvview rpview bfname batch_pid mywin return } set bfname [file rootname [file tail $rifname]].err @@ -195,38 +201,50 @@ proc do_action w { # Action screen helplink $w.octf trad action force # Render interactively label $w.ril -text {Render interactively} - place $w.ril -relx .1429 -rely .2439 - button $w.rirv -text rview -relief raised \ - -command {run_rad -v $rvview -o x11} - place $w.rirv -relwidth .1071 -relheight .0610 -relx .4643 -rely .2439 - helplink $w.rirv trad action rview + place $w.ril -relx .1429 -rely .2329 + button $w.rirv -text rvu -relief raised \ + -command {run_rad -v $rvview -o x11 -N $nproc} + place $w.rirv -relwidth .1071 -relheight .0610 -relx .4643 -rely .2329 + helplink $w.rirv trad action rvu label $w.rivl -text View: - place $w.rivl -relx .6072 -rely .2439 + place $w.rivl -relx .6072 -rely .2329 menubutton $w.rivmb -textvariable rvview -anchor w -relief raised - place $w.rivmb -relwidth .1071 -relheight .0610 -relx .7143 -rely .2439 + place $w.rivmb -relwidth .1071 -relheight .0610 -relx .7143 -rely .2329 helplink $w.rivmb trad action view + # Number of processes + label $w.rnpl -text {Number of processes:} + place $w.rnpl -relx .1429 -rely .3394 + scale $w.rnps -showvalue yes -from 1 -to 64 \ + -orient horizontal -command set_nproc + $w.rnps set $nproc + place $w.rnps -relwidth .5550 -relheight .1200 -relx .3683 -rely .3000 + helplink $w.rnps trad action processes # Render in background label $w.rbl -text {Render in background} - place $w.rbl -relx .1429 -rely .4268 + place $w.rbl -relx .1429 -rely .4458 button $w.rbst -text Start -relief raised -command run_batch - place $w.rbst -relwidth .1071 -relheight .0610 -relx .4643 -rely .4268 + place $w.rbst -relwidth .1071 -relheight .0610 -relx .4643 -rely .4458 helplink $w.rbst trad action start label $w.rbvl -text View: - place $w.rbvl -relx .6072 -rely .4268 + place $w.rbvl -relx .6072 -rely .4458 menubutton $w.rbvmb -textvariable rpview -anchor w -relief raised - place $w.rbvmb -relwidth .1071 -relheight .0610 -relx .7143 -rely .4268 + place $w.rbvmb -relwidth .1071 -relheight .0610 -relx .7143 -rely .4458 helplink $w.rbvmb trad action view button $w.rbki -text Kill -relief raised -command kill_batch - place $w.rbki -relwidth .1071 -relheight .0610 -relx .4643 -rely .5488 + place $w.rbki -relwidth .1071 -relheight .0610 -relx .4643 -rely .5668 helplink $w.rbki trad action kill button $w.rbce -text "Check errors" -relief raised \ -command {view_txt $bfname} - place $w.rbce -relwidth .1786 -relheight .0610 -relx .6429 -rely .5488 + place $w.rbce -relwidth .1786 -relheight .0610 -relx .6429 -rely .5668 helplink $w.rbce trad action checkerr - if [file exists $bfname] { + if [file isfile $bfname] { set fi [open $bfname r] - scan [gets $fi] $batch_fmt batch_pid batch_host - gets $fi radcom + if {[scan [gets $fi] $batch_fmt batch_pid batch_host] != 2} { + set batch_host unknown + set radcom {} + } else { + gets $fi radcom + } close $fi if [string match "rad -v *" $radcom] { set rpview [lindex $radcom 2] @@ -269,17 +287,17 @@ proc do_action w { # Action screen make_vmenus # Dry run label $w.drl -text {Dry run} - place $w.drl -relx .1429 -rely .7317 + place $w.drl -relx .1429 -rely .7357 button $w.drsc -text Script -relief raised -command make_script - place $w.drsc -relwidth .1071 -relheight .0610 -relx .4643 -rely .7317 + place $w.drsc -relwidth .1071 -relheight .0610 -relx .4643 -rely .7357 entry $w.drsf -textvariable scname -relief sunken - place $w.drsf -relwidth .2143 -relheight .0610 -relx .6429 -rely .7317 + place $w.drsf -relwidth .2143 -relheight .0610 -relx .6429 -rely .7357 helplink "$w.drsc $w.drsf" trad action script button $w.drvw -text Edit -relief raised -command {view_txt $scname} - place $w.drvw -relwidth .1071 -relheight .0610 -relx .4643 -rely .8537 + place $w.drvw -relwidth .1071 -relheight .0610 -relx .4643 -rely .8577 helplink $w.drvw trad action edit button $w.drdel -text Delete -relief raised \ -command {catch {exec rm $scname < /dev/null} curmess} - place $w.drdel -relwidth .1071 -relheight .0610 -relx .6429 -rely .8537 + place $w.drdel -relwidth .1071 -relheight .0610 -relx .6429 -rely .8577 helplink $w.drdel trad action delete }
