root/radiance/ray/src/util/do_action.tcl
Fri Jun 1 22:55:14 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.12: +35 -21 lines
Added number of processes control to trad
Wed Feb 16 05:40:12 2005 UTC (19 years, 2 months ago) by greg
Tue Oct 17 21:28:06 1995 UTC (28 years, 6 months ago) by greg
Thu Oct 5 13:16:39 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.7: +7 -3 lines
added minimal error checking to error file parsing
Tue Dec 6 19:36:21 1994 UTC (29 years, 5 months ago) by greg
Changes since 2.6: +5 -4 lines
slight improvement on last change
Tue Dec 6 13:00:31 1994 UTC (29 years, 5 months ago) by greg
Changes since 2.5: +27 -11 lines
added host name tracking to batch rendering processes
Wed Nov 30 15:23:56 1994 UTC (29 years, 5 months ago) by greg
fixed improper disabling/enabling of rpict view menu button
Revision 2.4 - (view) (download) (as text) (annotate) - [selected]
Mon Oct 31 11:30:44 1994 UTC (29 years, 6 months ago) by greg
changed USER to LOGNAME for better system compatibility
Thu Oct 27 18:08:09 1994 UTC (29 years, 6 months ago) by greg
fixed minor problem where OPTFILE is not updated by make(1)
Thu Oct 27 17:28:19 1994 UTC (29 years, 6 months ago) by greg
Changes since 2.1: +17 -20 lines
fixed problem with reading in new views
Thu Oct 27 15:56:06 1994 UTC (29 years, 6 months ago) by greg
Diff to selected 2.4
Links to HEAD: (view) (download) (as text) (annotate) Links to rad5R3: (view) (download) (as text) (annotate)
