1 |
# SCCSid "$SunId$ LBL" |
2 |
3 |
# Action screen for trad |
4 |
5 |
6 |
set batch_fmt "Process %d on %s started" |
7 |
set hostname [exec hostname] |
8 |
9 |
proc make_script {} { # make run script |
10 |
global scname rpview curmess |
11 |
set rfn /usr/tmp/rf[pid] |
12 |
if {! [save_vars $rfn]} { |
13 |
beep |
14 |
set curmess "Cannot save variables to temporary file!" |
15 |
return |
16 |
17 |
set radcom {rad -n} |
18 |
if {"$rpview" != " ALL"} { |
19 |
lappend radcom -v $rpview |
20 |
21 |
if {"$scname" == {}} { |
22 |
set rof /usr/tmp/ro[pid] |
23 |
} else { |
24 |
set rof $scname |
25 |
26 |
lappend radcom $rfn > $rof |
27 |
set badrun [catch "exec $radcom" curmess] |
28 |
29 |
if {! $badrun} { |
30 |
view_txt $rof |
31 |
32 |
exec rm $rof |
33 |
34 |
exec rm $rfn |
35 |
36 |
37 |
proc make_oct args { # Make octree file ($args is {-t} or {}) |
38 |
global radvar curmess |
39 |
if {"$radvar(scene)" == {} && "$radvar(illum)" == {}} { |
40 |
set fi [open "|make $radvar(OCTREE) $args" r] |
41 |
while {[gets $fi curmess] >= 0} { update ; after 1000 } |
42 |
catch {close $fi} curmess |
43 |
44 |
if {"$args" == {}} { |
45 |
run_rad -v 0 |
46 |
} else { |
47 |
run_rad $args |
48 |
49 |
50 |
51 |
proc run_rad args { # Run rad command with given arguments |
52 |
global curmess |
53 |
54 |
55 |
beep |
56 |
57 |
return |
58 |
59 |
set ot [file mtime $rfn] |
60 |
set fi [open "|rad $args $rfn" r] |
61 |
62 |
if {! [catch {close $fi} curmess] && [file mtime $rfn] > $ot} { |
63 |
load_vars $rfn {view} |
64 |
make_vmenus |
65 |
66 |
exec rm $rfn |
67 |
68 |
69 |
proc run_batch {} { # start rendering in background |
70 |
global rpview bfname batch_pid curmess rifname mywin batch_fmt hostname |
71 |
if {! [chksave]} {return} |
72 |
if [catch {set fo [open $bfname w]} curmess] { |
73 |
return |
74 |
75 |
# Make space for PID to be written later |
76 |
puts $fo " " |
77 |
if {$rpview == " ALL"} { |
78 |
set radcom "rad" |
79 |
} else { |
80 |
set radcom "rad -v $rpview" |
81 |
82 |
lappend radcom "[file tail $rifname]" |
83 |
# Put out command |
84 |
puts $fo $radcom |
85 |
flush $fo |
86 |
# Execute in background |
87 |
set batch_pid [eval exec $radcom >>& $bfname &] |
88 |
# Now, write PID and close file |
89 |
seek $fo 0 |
90 |
puts -nonewline $fo "[format $batch_fmt $batch_pid $hostname]\ |
91 |
[exec date]" |
92 |
close $fo |
93 |
set curmess "Batch rendering process $batch_pid started." |
94 |
# Correct button stati |
95 |
$mywin.rbst configure -state disabled |
96 |
$mywin.rbki configure -state normal |
97 |
$mywin.rbce configure -state normal |
98 |
$mywin.rbvmb configure -state disabled |
99 |
100 |
101 |
proc kill_batch {} { # kill batch rendering |
102 |
global batch_pid env curmess mywin |
103 |
# Kill batch process and children |
104 |
switch -glob [exec uname] { |
105 |
SunOS - |
106 |
ULTRIX {set ps "ps -lg"} |
107 |
default {set ps "ps -lu $env(LOGNAME)"} |
108 |
109 |
set fi [open "|$ps" r] |
110 |
gets $fi li |
111 |
regexp -indices -nocase { *PID} $li pidsec |
112 |
regexp -indices -nocase { *PPID} $li ppidsec |
113 |
while {[gets $fi li] >= 0} { |
114 |
lappend plist "[eval string range {$li} $pidsec]\ |
115 |
[eval string range {$li} $ppidsec]" |
116 |
117 |
if [catch {close $fi} curmess] { |
118 |
return |
119 |
120 |
set plist [lsort $plist] |
121 |
set procs $batch_pid |
122 |
# Two passes required when process id's go into recycling |
123 |
for {set i 0} {$i < 2} {incr i} { |
124 |
foreach pp $plist { |
125 |
if {[lsearch -exact $procs [lindex $pp 1]] >= 0 && |
126 |
($i == 0 || [lsearch -exact $procs \ |
127 |
[lindex $pp 0]] < 0)} { |
128 |
lappend procs [lindex $pp 0] |
129 |
130 |
131 |
132 |
if {! [catch {eval exec kill $procs} curmess]} { |
133 |
set curmess "Batch process $batch_pid and children killed." |
134 |
135 |
# change modes |
136 |
$mywin.rbki configure -state disabled |
137 |
$mywin.rbst configure -state normal |
138 |
$mywin.rbvmb configure -state normal |
139 |
set batch_pid 0 |
140 |
141 |
142 |
proc make_vmenus {} { # make/update view menus |
143 |
global mywin radvar rvview |
144 |
if {"$radvar(view)" == {}} { |
145 |
set rvview X |
146 |
} else { |
147 |
set rvview [lindex [lindex $radvar(view) 0] 0] |
148 |
149 |
catch {destroy $mywin.rivmb.m} |
150 |
catch {destroy $mywin.rbvmb.m} |
151 |
if {[llength $radvar(view)] < 2} { |
152 |
$mywin.rivmb configure -state disabled |
153 |
return |
154 |
155 |
menu $mywin.rivmb.m |
156 |
$mywin.rivmb configure -menu $mywin.rivmb.m -state normal |
157 |
foreach v $radvar(view) { |
158 |
$mywin.rivmb.m add radiobutton -label [lindex $v 0] \ |
159 |
-variable rvview -value [lindex $v 0] |
160 |
161 |
menu $mywin.rbvmb.m |
162 |
$mywin.rbvmb configure -menu $mywin.rbvmb.m |
163 |
$mywin.rbvmb.m add radiobutton -label ALL \ |
164 |
-variable rpview -value " ALL" |
165 |
$mywin.rbvmb.m add separator |
166 |
167 |
$mywin.rbvmb.m add radiobutton -label [lindex $v 0] \ |
168 |
-variable rpview -value [lindex $v 0] |
169 |
170 |
171 |
172 |
proc do_action w { # Action screen |
173 |
global rifname rvview rpview radvar bfname batch_pid \ |
174 |
curmess scname mywin alldone batch_fmt hostname |
175 |
if {"$w" == "done"} { |
176 |
unset rpview bfname batch_pid mywin |
177 |
return |
178 |
179 |
set bfname [file rootname [file tail $rifname]].err |
180 |
frame $w |
181 |
set mywin $w |
182 |
# Generate octree |
183 |
label $w.octl -text {Compile scene only} |
184 |
place $w.octl -relx .1429 -rely .0610 |
185 |
button $w.octb -text oconv -relief raised -command make_oct |
186 |
place $w.octb -relwidth .1071 -relheight .0610 -relx .4643 -rely .0610 |
187 |
helplink $w.octb trad action oconv |
188 |
button $w.octt -text Touch -relief raised -command {make_oct -t} |
189 |
place $w.octt -relwidth .1071 -relheight .0610 -relx .7143 -rely .0610 |
190 |
helplink $w.octt trad action touch |
191 |
button $w.octf -text Force -relief raised -command \ |
192 |
{catch {exec rm -f $radvar(OCTREE)} ; make_oct} |
193 |
place $w.octf -relwidth .1071 -relheight .0610 -relx .5893 -rely .0610 |
194 |
helplink $w.octf trad action force |
195 |
# Render interactively |
196 |
label $w.ril -text {Render interactively} |
197 |
place $w.ril -relx .1429 -rely .2439 |
198 |
button $w.rirv -text rview -relief raised \ |
199 |
-command {run_rad -v $rvview -o x11} |
200 |
place $w.rirv -relwidth .1071 -relheight .0610 -relx .4643 -rely .2439 |
201 |
helplink $w.rirv trad action rview |
202 |
label $w.rivl -text View: |
203 |
place $w.rivl -relx .6072 -rely .2439 |
204 |
menubutton $w.rivmb -textvariable rvview -anchor w -relief raised |
205 |
place $w.rivmb -relwidth .1071 -relheight .0610 -relx .7143 -rely .2439 |
206 |
helplink $w.rivmb trad action view |
207 |
# Render in background |
208 |
label $w.rbl -text {Render in background} |
209 |
place $w.rbl -relx .1429 -rely .4268 |
210 |
button $w.rbst -text Start -relief raised -command run_batch |
211 |
place $w.rbst -relwidth .1071 -relheight .0610 -relx .4643 -rely .4268 |
212 |
helplink $w.rbst trad action start |
213 |
label $w.rbvl -text View: |
214 |
place $w.rbvl -relx .6072 -rely .4268 |
215 |
menubutton $w.rbvmb -textvariable rpview -anchor w -relief raised |
216 |
place $w.rbvmb -relwidth .1071 -relheight .0610 -relx .7143 -rely .4268 |
217 |
helplink $w.rbvmb trad action view |
218 |
button $w.rbki -text Kill -relief raised -command kill_batch |
219 |
place $w.rbki -relwidth .1071 -relheight .0610 -relx .4643 -rely .5488 |
220 |
helplink $w.rbki trad action kill |
221 |
button $w.rbce -text "Check errors" -relief raised \ |
222 |
-command {view_txt $bfname} |
223 |
place $w.rbce -relwidth .1786 -relheight .0610 -relx .6429 -rely .5488 |
224 |
helplink $w.rbce trad action checkerr |
225 |
if [file exists $bfname] { |
226 |
set fi [open $bfname r] |
227 |
scan [gets $fi] $batch_fmt batch_pid batch_host |
228 |
gets $fi radcom |
229 |
close $fi |
230 |
if [string match "rad -v *" $radcom] { |
231 |
set rpview [lindex $radcom 2] |
232 |
} else { |
233 |
set rpview " ALL" |
234 |
235 |
if {"$hostname" != "$batch_host"} { |
236 |
if $alldone { |
237 |
set curmess "Batch rendering finished\ |
238 |
on host $batch_host." |
239 |
} else { |
240 |
set curmess "Unknown batch rendering status\ |
241 |
242 |
$w.rbst configure -state disabled |
243 |
$w.rbvmb configure -state disabled |
244 |
245 |
set batch_pid 0 |
246 |
$w.rbki configure -state disabled |
247 |
} elseif {[catch {exec /bin/kill -0 $batch_pid}]} { |
248 |
if $alldone { |
249 |
set curmess "Batch rendering finished." |
250 |
} else { |
251 |
set curmess "Batch rendering stopped." |
252 |
253 |
set batch_pid 0 |
254 |
set rpview " ALL" |
255 |
256 |
} else { |
257 |
set curmess "Batch rendering process $batch_pid running." |
258 |
259 |
260 |
261 |
} else { |
262 |
set curmess "No batch rendering in progress." |
263 |
set batch_pid 0 |
264 |
set rpview " ALL" |
265 |
266 |
$w.rbce configure -state disabled |
267 |
268 |
make_vmenus |
269 |
# Dry run |
270 |
label $w.drl -text {Dry run} |
271 |
place $w.drl -relx .1429 -rely .7317 |
272 |
button $w.drsc -text Script -relief raised -command make_script |
273 |
place $w.drsc -relwidth .1071 -relheight .0610 -relx .4643 -rely .7317 |
274 |
entry $w.drsf -textvariable scname -relief sunken |
275 |
place $w.drsf -relwidth .2143 -relheight .0610 -relx .6429 -rely .7317 |
276 |
helplink "$w.drsc $w.drsf" trad action script |
277 |
button $w.drvw -text Edit -relief raised -command {view_txt $scname} |
278 |
place $w.drvw -relwidth .1071 -relheight .0610 -relx .4643 -rely .8537 |
279 |
helplink $w.drvw trad action edit |
280 |
button $w.drdel -text Delete -relief raised \ |
281 |
-command {catch {exec rm $scname < /dev/null} curmess} |
282 |
place $w.drdel -relwidth .1071 -relheight .0610 -relx .6429 -rely .8537 |
283 |
helplink $w.drdel trad action delete |
284 |
