root/radiance/ray/src/util/do_action.tcl
Revision: 2.10
Committed: Sat Feb 22 02:07:30 2003 UTC (22 years, 2 months ago) by greg
Content type: application/x-tcl
1 # RCSid: $Id$
2 #
3 # Action screen for trad
4 #
5
6 set batch_fmt "Process %d on %s started"
7 set hostname [exec hostname]
8
9 proc make_script {} { # make run script
10 global scname rpview curmess
11 set rfn /usr/tmp/rf[pid]
12 if {! [save_vars $rfn]} {
13 beep
14 set curmess "Cannot save variables to temporary file!"
15 return
16 }
17 set radcom {rad -n}
18 if {"$rpview" != " ALL"} {
19 lappend radcom -v $rpview
20 }
21 if {"$scname" == {}} {
22 set rof /usr/tmp/ro[pid]
23 } else {
24 set rof $scname
25 }
26 lappend radcom $rfn > $rof
27 set badrun [catch "exec $radcom" curmess]
28 if {"$scname" == {}} {
29 if {! $badrun} {
30 view_txt $rof
31 }
32 exec rm $rof
33 }
34 exec rm $rfn
35 }
36
37 proc make_oct args { # Make octree file ($args is {-t} or {})
38 global radvar curmess
39 if {"$radvar(scene)" == {} && "$radvar(illum)" == {}} {
40 set fi [open "|make $radvar(OCTREE) $args" r]
41 while {[gets $fi curmess] >= 0} { update ; after 1000 }
42 catch {close $fi} curmess
43 }
44 if {"$args" == {}} {
45 run_rad -v 0
46 } else {
47 run_rad $args
48 }
49 }
50
51 proc run_rad args { # Run rad command with given arguments
52 global curmess
53 set rfn /usr/tmp/rf[pid]
54 if {! [save_vars $rfn]} {
55 beep
56 set curmess "Cannot save variables to temporary file!"
57 return
58 }
59 set ot [file mtime $rfn]
60 set fi [open "|rad $args $rfn" r]
61 while {[gets $fi curmess] >= 0} { update ; after 1000 }
62 if {! [catch {close $fi} curmess] && [file mtime $rfn] > $ot} {
63 load_vars $rfn {view}
64 make_vmenus
65 }
66 exec rm $rfn
67 }
68
69 proc run_batch {} { # start rendering in background
70 global rpview bfname batch_pid curmess rifname mywin batch_fmt hostname
71 if {! [chksave]} {return}
72 if [catch {set fo [open $bfname w]} curmess] {
73 return
74 }
75 # Make space for PID to be written later
76 puts $fo \
77 " "
78 if {$rpview == " ALL"} {
79 set radcom "rad"
80 } else {
81 set radcom "rad -v $rpview"
82 }
83 lappend radcom "[file tail $rifname]"
84 # Put out command
85 puts $fo $radcom
86 flush $fo
87 # Execute in background
88 set batch_pid [eval exec $radcom >>& $bfname &]
89 # Now, write PID and close file
90 seek $fo 0
91 puts -nonewline $fo "[format $batch_fmt $batch_pid $hostname]\
92 [exec date]"
93 close $fo
94 set curmess "Batch rendering process $batch_pid started."
95 # Correct button stati
96 $mywin.rbst configure -state disabled
97 $mywin.rbki configure -state normal
98 $mywin.rbce configure -state normal
99 $mywin.rbvmb configure -state disabled
100 }
101
102 proc kill_batch {} { # kill batch rendering
103 global batch_pid env curmess mywin
104 # Kill batch process and children
105 switch -glob [exec uname] {
106 SunOS -
107 ULTRIX {set ps "ps -lg"}
108 default {set ps "ps -lu $env(LOGNAME)"}
109 }
110 set fi [open "|$ps" r]
111 gets $fi li
112 regexp -indices -nocase { *PID} $li pidsec
113 regexp -indices -nocase { *PPID} $li ppidsec
114 while {[gets $fi li] >= 0} {
115 lappend plist "[eval string range {$li} $pidsec]\
116 [eval string range {$li} $ppidsec]"
117 }
118 if [catch {close $fi} curmess] {
119 return
120 }
121 set plist [lsort $plist]
122 set procs $batch_pid
123 # Two passes required when process id's go into recycling
124 for {set i 0} {$i < 2} {incr i} {
125 foreach pp $plist {
126 if {[lsearch -exact $procs [lindex $pp 1]] >= 0 &&
127 ($i == 0 || [lsearch -exact $procs \
128 [lindex $pp 0]] < 0)} {
129 lappend procs [lindex $pp 0]
130 }
131 }
132 }
133 if {! [catch {eval exec kill $procs} curmess]} {
134 set curmess "Batch process $batch_pid and children killed."
135 }
136 # change modes
137 $mywin.rbki configure -state disabled
138 $mywin.rbst configure -state normal
139 $mywin.rbvmb configure -state normal
140 set batch_pid 0
141 }
142
143 proc make_vmenus {} { # make/update view menus
144 global mywin radvar rvview
145 if {"$radvar(view)" == {}} {
146 set rvview X
147 } else {
148 set rvview [lindex [lindex $radvar(view) 0] 0]
149 }
150 catch {destroy $mywin.rivmb.m}
151 catch {destroy $mywin.rbvmb.m}
152 if {[llength $radvar(view)] < 2} {
153 $mywin.rivmb configure -state disabled
154 return
155 }
156 menu $mywin.rivmb.m
157 $mywin.rivmb configure -menu $mywin.rivmb.m -state normal
158 foreach v $radvar(view) {
159 $mywin.rivmb.m add radiobutton -label [lindex $v 0] \
160 -variable rvview -value [lindex $v 0]
161 }
162 menu $mywin.rbvmb.m
163 $mywin.rbvmb configure -menu $mywin.rbvmb.m
164 $mywin.rbvmb.m add radiobutton -label ALL \
165 -variable rpview -value " ALL"
166 $mywin.rbvmb.m add separator
167 foreach v $radvar(view) {
168 $mywin.rbvmb.m add radiobutton -label [lindex $v 0] \
169 -variable rpview -value [lindex $v 0]
170 }
171 }
172
173 proc do_action w { # Action screen
174 global rifname rvview rpview radvar bfname batch_pid \
175 curmess scname mywin alldone batch_fmt hostname
176 if {"$w" == "done"} {
177 unset rvview rpview bfname batch_pid mywin
178 return
179 }
180 set bfname [file rootname [file tail $rifname]].err
181 frame $w
182 set mywin $w
183 # Generate octree
184 label $w.octl -text {Compile scene only}
185 place $w.octl -relx .1429 -rely .0610
186 button $w.octb -text oconv -relief raised -command make_oct
187 place $w.octb -relwidth .1071 -relheight .0610 -relx .4643 -rely .0610
188 helplink $w.octb trad action oconv
189 button $w.octt -text Touch -relief raised -command {make_oct -t}
190 place $w.octt -relwidth .1071 -relheight .0610 -relx .7143 -rely .0610
191 helplink $w.octt trad action touch
192 button $w.octf -text Force -relief raised -command \
193 {catch {exec rm -f $radvar(OCTREE)} ; make_oct}
194 place $w.octf -relwidth .1071 -relheight .0610 -relx .5893 -rely .0610
195 helplink $w.octf trad action force
196 # Render interactively
197 label $w.ril -text {Render interactively}
198 place $w.ril -relx .1429 -rely .2439
199 button $w.rirv -text rview -relief raised \
200 -command {run_rad -v $rvview -o x11}
201 place $w.rirv -relwidth .1071 -relheight .0610 -relx .4643 -rely .2439
202 helplink $w.rirv trad action rview
203 label $w.rivl -text View:
204 place $w.rivl -relx .6072 -rely .2439
205 menubutton $w.rivmb -textvariable rvview -anchor w -relief raised
206 place $w.rivmb -relwidth .1071 -relheight .0610 -relx .7143 -rely .2439
207 helplink $w.rivmb trad action view
208 # Render in background
209 label $w.rbl -text {Render in background}
210 place $w.rbl -relx .1429 -rely .4268
211 button $w.rbst -text Start -relief raised -command run_batch
212 place $w.rbst -relwidth .1071 -relheight .0610 -relx .4643 -rely .4268
213 helplink $w.rbst trad action start
214 label $w.rbvl -text View:
215 place $w.rbvl -relx .6072 -rely .4268
216 menubutton $w.rbvmb -textvariable rpview -anchor w -relief raised
217 place $w.rbvmb -relwidth .1071 -relheight .0610 -relx .7143 -rely .4268
218 helplink $w.rbvmb trad action view
219 button $w.rbki -text Kill -relief raised -command kill_batch
220 place $w.rbki -relwidth .1071 -relheight .0610 -relx .4643 -rely .5488
221 helplink $w.rbki trad action kill
222 button $w.rbce -text "Check errors" -relief raised \
223 -command {view_txt $bfname}
224 place $w.rbce -relwidth .1786 -relheight .0610 -relx .6429 -rely .5488
225 helplink $w.rbce trad action checkerr
226 if [file isfile $bfname] {
227 set fi [open $bfname r]
228 if {[scan [gets $fi] $batch_fmt batch_pid batch_host] != 2} {
229 set batch_host unknown
230 set radcom {}
231 } else {
232 gets $fi radcom
233 }
234 close $fi
235 if [string match "rad -v *" $radcom] {
236 set rpview [lindex $radcom 2]
237 } else {
238 set rpview " ALL"
239 }
240 if {"$hostname" != "$batch_host"} {
241 if $alldone {
242 set curmess "Batch rendering finished\
243 on $batch_host."
244 } else {
245 set curmess "Batch rendering on\
246 $batch_host -- status UNKNOWN."
247 $w.rbst configure -state disabled
248 $w.rbvmb configure -state disabled
249 }
250 set batch_pid 0
251 $w.rbki configure -state disabled
252 } elseif {[catch {exec /bin/kill -0 $batch_pid}]} {
253 if $alldone {
254 set curmess "Batch rendering finished."
255 } else {
256 set curmess "Batch rendering stopped."
257 }
258 set batch_pid 0
259 set rpview " ALL"
260 $w.rbki configure -state disabled
261 } else {
262 set curmess "Batch rendering process $batch_pid running."
263 $w.rbst configure -state disabled
264 $w.rbvmb configure -state disabled
265 }
266 } else {
267 set curmess "No batch rendering in progress."
268 set batch_pid 0
269 set rpview " ALL"
270 $w.rbki configure -state disabled
271 $w.rbce configure -state disabled
272 }
273 make_vmenus
274 # Dry run
275 label $w.drl -text {Dry run}
276 place $w.drl -relx .1429 -rely .7317
277 button $w.drsc -text Script -relief raised -command make_script
278 place $w.drsc -relwidth .1071 -relheight .0610 -relx .4643 -rely .7317
279 entry $w.drsf -textvariable scname -relief sunken
280 place $w.drsf -relwidth .2143 -relheight .0610 -relx .6429 -rely .7317
281 helplink "$w.drsc $w.drsf" trad action script
282 button $w.drvw -text Edit -relief raised -command {view_txt $scname}
283 place $w.drvw -relwidth .1071 -relheight .0610 -relx .4643 -rely .8537
284 helplink $w.drvw trad action edit
285 button $w.drdel -text Delete -relief raised \
286 -command {catch {exec rm $scname < /dev/null} curmess}
287 place $w.drdel -relwidth .1071 -relheight .0610 -relx .6429 -rely .8537
288 helplink $w.drdel trad action delete
289 }
