root/radiance/ray/src/util/depthcodec.h
Revision 2.5
Fri Jul 26 16:18:07 2019 UTC (4 years, 9 months ago) by greg
FILE REMOVED
Tue Jul 23 05:03:07 2019 UTC (4 years, 9 months ago) by greg
Fixed issue with assigning infinity
Fri Jul 19 00:01:49 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.2: +7 -7 lines
Changed constants to real to avoid conversion costs (if any)
Thu Jul 18 22:33:34 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.1: +5 -3 lines
Diff to previous 2.1
Improved accuracy + made depth2code() a macro so module not needed for encoding
Thu Jul 18 18:51:56 2019 UTC (4 years, 9 months ago) by greg
