root/Development/ray/src/util/depthcodec.h
Revision: 2.5
Committed: Fri Jul 26 16:18:07 2019 UTC (6 years, 5 months ago) by greg
State: FILE REMOVED
Error occurred while calculating annotation data.
1 /* RCSid $Id: depthcodec.h,v 2.4 2019/07/23 05:03:07 greg Exp $ */
2 /*
3 * Definitions and declarations for 16-bit depth encode/decode
4 *
5 * Include after stdio.h and fvect.h
6 * Includes view.h
7 */
8
9 #ifndef _RAD_DEPTHCODEC_H_
10 #define _RAD_DEPTHCODEC_H_
11
12 #include "view.h"
13
14 #ifdef __cplusplus
15 extern "C" {
16 #endif
17
18 #define DEPTHSTR "REFDEPTH="
19 #define LDEPTHSTR 9
20 #define DEPTH16FMT "16-bit_encoded_depth"
21
22 #define HF_HEADIN 0x1
23 #define HF_HEADOUT 0x2
24 #define HF_RESIN 0x4
25 #define HF_RESOUT 0x8
26 #define HF_ALL 0xf
27 #define HF_ENCODE 0x10
28
29 /* Structure for encoding/decoding depths and world points */
30 typedef struct {
31 FILE *finp; /* input stream */
32 const char *inpname; /* input name */
33 int format; /* decoded format */
34 long dstart; /* start of data */
35 long curpos; /* current input position */
36 double refdepth; /* reference depth */
37 char depth_unit[32]; /* string including units */
38 int hdrflags; /* header i/o flags */
39 char inpfmt[MAXFMTLEN]; /* format from header */
40 VIEW vw; /* input view parameters */
41 int gotview; /* got input view? */
42 RESOLU res; /* input resolution */
43 } DEPTHCODEC;
44
45 /* Encode depth as 16-bit signed integer */
46 #define depth2code(d, dref) \
47 ( (d) > (dref) ? (int)(32768.001 - 32768.*(dref)/(d))-1 : \
48 (d) > .0 ? (int)(32767.*(d)/(dref) - 32768.) : -32768 )
49
50 /* Decode depth from 16-bit signed integer */
51 extern double code2depth(int c, double dref);
52
53 /* Set codec defaults */
54 extern void set_dc_defaults(DEPTHCODEC *dcp);
55
56 /* Load/copy header */
57 extern int process_dc_header(DEPTHCODEC *dcp, int ac, char *av[]);
58
59 /* Check that we have what we need to decode depths */
60 extern int check_decode_depths(DEPTHCODEC *dcp);
61
62 /* Decode next depth pixel from input */
63 extern double decode_depth_next(DEPTHCODEC *dcp);
64
65 /* Seek to the indicated pixel position */
66 extern int seek_dc_pix(DEPTHCODEC *dcp, int x, int y);
67
68 /* Read and decode depth for the given pixel */
69 extern double decode_depth_pix(DEPTHCODEC *dcp, int x, int y);
70
71 /* Check that we have what we need to decode world positions */
72 extern int check_decode_worldpos(DEPTHCODEC *dcp);
73
74 /* Compute world position from pixel position and depth */
75 extern int compute_worldpos(FVECT wpos, DEPTHCODEC *dcp,
76 int x, int y, double d);
77
78 /* Decode the next world position from input */
79 int decode_worldpos_next(FVECT wpos, DEPTHCODEC *dcp);
80
81 /* Decode depth and compute world position for the given pixel */
82 extern int get_worldpos_pix(FVECT wpos, DEPTHCODEC *dcp, int x, int y);
83
84 extern char *progname; /* global argv[0] (set by main) */
85
86 #ifdef __cplusplus
87 }
88 #endif
89 #endif /* _RAD_DEPTHCODEC_H_ */
