root/radiance/ray/src/util/depthcodec.c
Revision: 2.4
Committed: Fri Jul 26 16:18:07 2019 UTC (5 years, 10 months ago) by greg
State: FILE REMOVED
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.4 static const char RCSid[] = "$Id: depthcodec.c,v 2.3 2019/07/19 01:24:33 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Routines to encode/decoded 16-bit depths
6     */
7
8     #include "copyright.h"
9
10     #include <stdlib.h>
11     #include <string.h>
12     #include <math.h>
13     #include <ctype.h>
14     #include "rtio.h"
15     #include "fvect.h"
16     #include "depthcodec.h"
17
18
19 greg 2.2 #if 0 /* defined as macro in depthcodec.h */
20 greg 2.1 /* Encode depth as 16-bit signed integer */
21 greg 2.2 int
22 greg 2.1 depth2code(double d, double dref)
23     {
24     if (d <= .0)
25     return -32768;
26
27     if (d > dref)
28 greg 2.2 return (int)(32768 - 32768*dref/d) - 1;
29 greg 2.1
30 greg 2.2 return (int)(32767*d/dref - 32768);
31 greg 2.1 }
32 greg 2.2 #endif
33 greg 2.1
34
35     /* Decode depth from 16-bit signed integer */
36     double
37 greg 2.2 code2depth(int c, double dref)
38 greg 2.1 {
39 greg 2.2 if (c <= -32768)
40     return .0;
41
42     if (c >= 32767)
43     return FHUGE;
44
45 greg 2.1 if (c < 0)
46 greg 2.2 return dref*(32767.5 + c)*(1./32767.);
47 greg 2.1
48 greg 2.2 return dref*32768./(32766.5 - c);
49 greg 2.1 }
50
51
52     /* Set codec defaults */
53     void
54     set_dc_defaults(DEPTHCODEC *dcp)
55     {
56     memset(dcp, 0, sizeof(DEPTHCODEC));
57     dcp->finp = stdin;
58     dcp->inpname = "<stdin>";
59     dcp->format = 'a';
60     dcp->refdepth = 1.;
61     dcp->depth_unit[0] = '1';
62     dcp->vw = stdview;
63     dcp->res.rt = PIXSTANDARD;
64 greg 2.3 if (!progname) progname = "depth_codec";
65 greg 2.1 }
66
67
68     /* process header line */
69     static int
70     headline(char *s, void *p)
71     {
72     DEPTHCODEC *dcp = (DEPTHCODEC *)p;
73
74     if (formatval(dcp->inpfmt, s)) /* don't pass format */
75     return 0;
76     /* check for reference depth */
77     if (!strncmp(s, DEPTHSTR, LDEPTHSTR)) {
78     char *cp;
79     strlcpy(dcp->depth_unit, s+LDEPTHSTR, sizeof(dcp->depth_unit));
80     cp = dcp->depth_unit;
81     while (*cp) cp++;
82     while (cp > dcp->depth_unit && isspace(cp[-1])) cp--;
83     *cp = '\0';
84     dcp->refdepth = atof(dcp->depth_unit);
85     if (dcp->refdepth <= .0) {
86     fputs(dcp->inpname, stderr);
87     fputs(": bad reference depth in input header\n", stderr);
88     return -1;
89     }
90     } else if (isview(s)) /* get view params */
91     dcp->gotview += (sscanview(&dcp->vw, s) > 0);
92     if (dcp->hdrflags & HF_HEADOUT)
93     fputs(s, stdout); /* copy to standard output */
94     return 1;
95     }
96
97
98     /* Load/copy header */
99     int
100     process_dc_header(DEPTHCODEC *dcp, int ac, char *av[])
101     {
102     if (dcp->hdrflags & HF_HEADIN &&
103     getheader(dcp->finp, headline, dcp) < 0) {
104     fputs(dcp->inpname, stderr);
105     fputs(": bad header\n", stderr);
106     return 1;
107     }
108     if (dcp->hdrflags & HF_HEADOUT) { /* finish header */
109     if (!(dcp->hdrflags & HF_HEADIN))
110     newheader("RADIANCE", stdout);
111     if (ac > 0)
112     printargs(ac, av, stdout);
113     if (dcp->hdrflags & HF_ENCODE) {
114     fputs(DEPTHSTR, stdout);
115     fputs(dcp->depth_unit, stdout);
116     fputc('\n', stdout);
117     fputformat(DEPTH16FMT, stdout);
118     } else
119     switch (dcp->format) {
120     case 'a':
121     fputformat("ascii", stdout);
122     break;
123     case 'f':
124     fputformat("float", stdout);
125     break;
126     case 'd':
127     fputformat("double", stdout);
128     break;
129     }
130     fputc('\n', stdout);
131     }
132     /* get/put resolution string */
133     if (dcp->hdrflags & HF_RESIN && !fgetsresolu(&dcp->res, dcp->finp)) {
134     fputs(dcp->inpname, stderr);
135     fputs(": bad resolution string\n", stderr);
136     return 1;
137     }
138     if (dcp->hdrflags & HF_RESOUT)
139     fputsresolu(&dcp->res, stdout);
140
141     dcp->dstart = dcp->curpos = ftell(dcp->finp);
142     return 1;
143     }
144
145
146     /* Check that we have what we need to decode depths */
147     int
148     check_decode_depths(DEPTHCODEC *dcp)
149     {
150     if (dcp->hdrflags & HF_ENCODE) {
151     fputs(progname, stderr);
152     fputs(": wrong header mode for decode\n", stderr);
153     return 0;
154     }
155     if (dcp->inpfmt[0] && strcmp(dcp->inpfmt, DEPTH16FMT)) {
156     fputs(dcp->inpname, stderr);
157     fputs(": unexpected input format: ", stderr);
158     fputs(dcp->inpfmt, stderr);
159     fputc('\n', stderr);
160     return 0;
161     }
162     return 1;
163     }
164
165
166     /* Check that we have what we need to decode world positions */
167     int
168     check_decode_worldpos(DEPTHCODEC *dcp)
169     {
170     char *err;
171
172     if (!check_decode_depths(dcp))
173     return 0;
174     if ((dcp->res.xr <= 0) | (dcp->res.yr <= 0)) {
175     fputs(progname, stderr);
176 greg 2.3 fputs(": missing map resolution\n", stderr);
177 greg 2.1 return 0;
178     }
179     if (!dcp->gotview) {
180     fputs(dcp->inpname, stderr);
181     fputs(": missing view\n", stderr);
182     return 0;
183     }
184     if ((err = setview(&dcp->vw)) != NULL) {
185     fputs(dcp->inpname, stderr);
186     fputs(": input view error: ", stderr);
187     fputs(err, stderr);
188     fputc('\n', stderr);
189     return 0;
190     }
191     return 1;
192     }
193
194
195     /* Decode next depth pixel */
196     double
197     decode_depth_next(DEPTHCODEC *dcp)
198     {
199     int c = getint(2, dcp->finp);
200
201     if (c == EOF && feof(dcp->finp))
202     return -1.;
203
204     dcp->curpos += 2;
205
206     return code2depth(c, dcp->refdepth);
207     }
208
209
210     /* Compute world position from depth */
211     int
212     compute_worldpos(FVECT wpos, DEPTHCODEC *dcp, int x, int y, double d)
213     {
214     RREAL loc[2];
215     FVECT rdir;
216
217     pix2loc(loc, &dcp->res, x, y);
218
219     if (viewray(wpos, rdir, &dcp->vw, loc[0], loc[1]) < -FTINY) {
220     VCOPY(wpos, dcp->vw.vp);
221     return 0;
222     }
223     VSUM(wpos, wpos, rdir, d);
224     return 1;
225     }
226
227
228     /* Decode the next world position */
229     int
230     decode_worldpos_next(FVECT wpos, DEPTHCODEC *dcp)
231     {
232     const long n = (dcp->curpos - dcp->dstart)>>1;
233     int x, y;
234     double d;
235
236     d = decode_depth_next(dcp);
237     if (d < -FTINY)
238     return -1;
239
240     x = scanlen(&dcp->res);
241     y = n / x;
242     x = n - (long)y*x;
243
244     return compute_worldpos(wpos, dcp, x, y, d);
245     }
246
247
248     /* Seek to the indicated pixel position */
249     int
250     seek_dc_pix(DEPTHCODEC *dcp, int x, int y)
251     {
252     long seekpos;
253
254     if ((dcp->res.xr <= 0) | (dcp->res.yr <= 0)) {
255     fputs(progname, stderr);
256 greg 2.3 fputs(": need map resolution to seek\n", stderr);
257 greg 2.1 return -1;
258     }
259     if ((x < 0) | (y < 0) ||
260     (x >= scanlen(&dcp->res)) | (y >= numscans(&dcp->res))) {
261     fputs(dcp->inpname, stderr);
262 greg 2.3 fputs(": warning - pixel index off map\n", stderr);
263 greg 2.1 return 0;
264     }
265     seekpos = dcp->dstart + 2*((long)y*scanlen(&dcp->res) + x);
266 greg 2.3
267 greg 2.1 if (seekpos != dcp->curpos &&
268     fseek(dcp->finp, seekpos, SEEK_SET) == EOF) {
269     fputs(dcp->inpname, stderr);
270     fputs(": seek error\n", stderr);
271     return -1;
272     }
273     dcp->curpos = seekpos;
274     return 1;
275     }
276
277
278     /* Read and decode depth for the given pixel */
279     double
280     decode_depth_pix(DEPTHCODEC *dcp, int x, int y)
281     {
282     int rval = seek_dc_pix(dcp, x, y);
283
284     if (rval < 0)
285     return -1.;
286     if (!rval)
287     return .0;
288
289     return decode_depth_next(dcp);
290     }
291
292
293     /* Read and decode the world position at the given pixel */
294     int
295     get_worldpos_pix(FVECT wpos, DEPTHCODEC *dcp, int x, int y)
296     {
297     double d = decode_depth_pix(dcp, x, y);
298
299     if (d < -FTINY)
300     return -1;
301
302     return compute_worldpos(wpos, dcp, x, y, d);
303     }
