root/radiance/ray/src/util/dctimestep.c
Revision: 2.49
Committed: Fri Mar 11 02:44:33 2022 UTC (2 years, 2 months ago) by greg
CVS Tags: rad5R4, HEAD
Changes since 2.48: +34 -22 lines
feat(dctimestep): Made it so -x and -y also work for single-picture output
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.49 static const char RCSid[] = "$Id: dctimestep.c,v 2.48 2022/03/11 02:28:51 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Compute time-step result using Daylight Coefficient method.
6     *
7     * G. Ward
8     */
9
10     #include <ctype.h>
11 schorsch 2.37 #include "platform.h"
12 greg 2.1 #include "standard.h"
13 greg 2.28 #include "cmatrix.h"
14 greg 2.1 #include "platform.h"
15     #include "resolu.h"
16
17     char *progname; /* global argv[0] */
18
19 greg 2.24 /* Sum together a set of images and write result to fout */
20 greg 2.1 static int
21 greg 2.13 sum_images(const char *fspec, const CMATRIX *cv, FILE *fout)
22 greg 2.1 {
23     int myDT = DTfromHeader;
24 greg 2.38 COLR *scanline = NULL;
25 greg 2.24 CMATRIX *pmat = NULL;
26     int myXR=0, myYR=0;
27 greg 2.1 int i, y;
28
29     if (cv->ncols != 1)
30 greg 2.35 error(INTERNAL, "expected vector in sum_images()");
31 greg 2.1 for (i = 0; i < cv->nrows; i++) {
32     const COLORV *scv = cv_lval(cv,i);
33 greg 2.39 int flat_file = 0;
34 greg 2.1 char fname[1024];
35     FILE *fp;
36 greg 2.39 long data_start;
37 greg 2.1 int dt, xr, yr;
38     COLORV *psp;
39 greg 2.31 char *err;
40 greg 2.14 /* check for zero */
41 greg 2.19 if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) &&
42     (myDT != DTfromHeader) | (i < cv->nrows-1))
43 greg 2.14 continue;
44 greg 2.1 /* open next picture */
45     sprintf(fname, fspec, i);
46 greg 2.31 if ((fp = fopen(fname, "rb")) == NULL) {
47 greg 2.1 sprintf(errmsg, "cannot open picture '%s'", fname);
48     error(SYSTEM, errmsg);
49     }
50 greg 2.31 dt = DTfromHeader;
51 greg 2.45 if ((err = cm_getheader(&dt, NULL, NULL, NULL, NULL, fp)) != NULL)
52 greg 2.31 error(USER, err);
53 greg 2.1 if ((dt != DTrgbe) & (dt != DTxyze) ||
54     !fscnresolu(&xr, &yr, fp)) {
55     sprintf(errmsg, "file '%s' not a picture", fname);
56     error(USER, errmsg);
57     }
58     if (myDT == DTfromHeader) { /* on first one */
59     myDT = dt;
60     myXR = xr; myYR = yr;
61 greg 2.38 scanline = (COLR *)malloc(sizeof(COLR)*myXR);
62 greg 2.1 if (scanline == NULL)
63     error(SYSTEM, "out of memory in sum_images()");
64     pmat = cm_alloc(myYR, myXR);
65     memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR);
66 greg 2.2 /* finish header */
67 greg 2.46 fputformat(cm_fmt_id[myDT], fout);
68 greg 2.13 fputc('\n', fout);
69     fflush(fout);
70 greg 2.1 } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) {
71     sprintf(errmsg, "picture '%s' format/size mismatch",
72     fname);
73     error(USER, errmsg);
74     }
75 greg 2.39 /* flat file check */
76     if ((data_start = ftell(fp)) > 0 && fseek(fp, 0L, SEEK_END) == 0) {
77     flat_file = (ftell(fp) == data_start + sizeof(COLR)*xr*yr);
78     if (fseek(fp, data_start, SEEK_SET) < 0) {
79     sprintf(errmsg, "cannot seek on picture '%s'", fname);
80     error(SYSTEM, errmsg);
81     }
82     }
83 greg 2.1 psp = pmat->cmem;
84     for (y = 0; y < yr; y++) { /* read it in */
85 greg 2.38 COLOR col;
86 greg 2.1 int x;
87 greg 2.39 if (flat_file ? getbinary(scanline, sizeof(COLR), xr, fp) != xr :
88     freadcolrs(scanline, xr, fp) < 0) {
89 greg 2.1 sprintf(errmsg, "error reading picture '%s'",
90     fname);
91     error(SYSTEM, errmsg);
92     }
93     /* sum in scanline */
94     for (x = 0; x < xr; x++, psp += 3) {
95 greg 2.38 if (!scanline[x][EXP])
96     continue; /* skip zeroes */
97     colr_color(col, scanline[x]);
98     multcolor(col, scv);
99     addcolor(psp, col);
100 greg 2.1 }
101     }
102     fclose(fp); /* done this picture */
103     }
104     free(scanline);
105 greg 2.30 i = cm_write(pmat, myDT, fout); /* write picture */
106     cm_free(pmat); /* free data */
107     return(i);
108 greg 2.1 }
109
110 greg 2.49 /* adjust matrix dimensions according to user size(s) */
111     static int
112     alt_dim(CMATRIX *cm, int nr, int nc)
113     {
114     if ((nr <= 0) & (nc <= 0))
115     return(0);
116     if ((nr == cm->nrows) & (nc == cm->ncols))
117     return(0);
118     if (nr > 0) {
119     if (nc <= 0)
120     nc = cm->nrows*cm->ncols/nr;
121     if (nr*nc != cm->nrows*cm->ncols) {
122     fprintf(stderr, "Bad dimensions: %dx%d != %dx%d\n",
123     nr, nc, cm->nrows, cm->ncols);
124     return(-1);
125     }
126     } else /* nc > 0 */ {
127     nr = cm->nrows*cm->ncols/nc;
128     if (nc*nr != cm->nrows*cm->ncols) {
129     fprintf(stderr, "Bad dimensions: %d does not divide %dx%d evenly\n",
130     nc, cm->nrows, cm->ncols);
131     return(-1);
132     }
133     }
134     cm->nrows = nr;
135     cm->ncols = nc;
136     return(1);
137     }
138
139 greg 2.11 /* check to see if a string contains a %d or %o specification */
140     static int
141     hasNumberFormat(const char *s)
142 greg 2.1 {
143 greg 2.24 if (s == NULL)
144     return(0);
145
146 greg 2.18 while (*s) {
147     while (*s != '%')
148     if (!*s++)
149     return(0);
150     if (*++s == '%') { /* ignore "%%" */
151     ++s;
152     continue;
153     }
154     while (isdigit(*s)) /* field length */
155     ++s;
156     /* field we'll use? */
157     if ((*s == 'd') | (*s == 'i') | (*s == 'o') |
158     (*s == 'x') | (*s == 'X'))
159     return(1);
160     }
161     return(0); /* didn't find one */
162 greg 2.1 }
163
164     int
165     main(int argc, char *argv[])
166     {
167 greg 2.34 int skyfmt = DTfromHeader;
168 greg 2.30 int outfmt = DTascii;
169 greg 2.34 int headout = 1;
170     int nsteps = 0;
171 greg 2.24 char *ofspec = NULL;
172     FILE *ofp = stdout;
173 greg 2.47 int xres=0, yres=0;
174 greg 2.24 CMATRIX *cmtx; /* component vector/matrix result */
175     char fnbuf[256];
176     int a, i;
177 greg 2.1
178     progname = argv[0];
179 greg 2.24 /* get options */
180 greg 2.25 for (a = 1; a < argc && argv[a][0] == '-'; a++)
181     switch (argv[a][1]) {
182 greg 2.24 case 'n':
183     nsteps = atoi(argv[++a]);
184 greg 2.31 if (nsteps < 0)
185 greg 2.24 goto userr;
186 greg 2.34 skyfmt = nsteps ? DTascii : DTfromHeader;
187     break;
188     case 'h':
189     headout = !headout;
190 greg 2.24 break;
191 greg 2.25 case 'i':
192     switch (argv[a][2]) {
193     case 'f':
194     skyfmt = DTfloat;
195     break;
196     case 'd':
197     skyfmt = DTdouble;
198     break;
199     case 'a':
200     skyfmt = DTascii;
201     break;
202     default:
203     goto userr;
204     }
205     break;
206 greg 2.30 case 'o':
207     switch (argv[a][2]) {
208     case '\0': /* output specification (not format) */
209     ofspec = argv[++a];
210     break;
211     case 'f':
212     outfmt = DTfloat;
213     break;
214     case 'd':
215     outfmt = DTdouble;
216     break;
217     case 'a':
218     outfmt = DTascii;
219     break;
220 greg 2.43 case 'c':
221     outfmt = DTrgbe;
222     break;
223 greg 2.30 default:
224     goto userr;
225     }
226     break;
227 greg 2.47 case 'x':
228     xres = atoi(argv[++a]);
229     break;
230     case 'y':
231     yres = atoi(argv[++a]);
232     break;
233 greg 2.24 default:
234     goto userr;
235     }
236     if ((argc-a < 1) | (argc-a > 4))
237     goto userr;
238 greg 2.1
239 greg 2.24 if (argc-a > 2) { /* VTDs expression */
240 greg 2.36 CMATRIX *smtx, *Dmat, *Tmat, *imtx;
241     const char *ccp;
242 greg 2.24 /* get sky vector/matrix */
243 greg 2.25 smtx = cm_load(argv[a+3], 0, nsteps, skyfmt);
244 greg 2.35 nsteps = smtx->ncols;
245 greg 2.12 /* load BSDF */
246 greg 2.36 if (argv[a+1][0] != '!' &&
247     (ccp = strrchr(argv[a+1], '.')) != NULL &&
248     !strcasecmp(ccp+1, "XML"))
249     Tmat = cm_loadBTDF(argv[a+1]);
250     else
251     Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader);
252 greg 2.5 /* load Daylight matrix */
253 greg 2.36 Dmat = cm_load(argv[a+2], Tmat->ncols,
254 greg 2.24 smtx->nrows, DTfromHeader);
255 greg 2.1 /* multiply vector through */
256 greg 2.24 imtx = cm_multiply(Dmat, smtx);
257     cm_free(Dmat); cm_free(smtx);
258 greg 2.29 cmtx = cm_multiply(Tmat, imtx);
259     cm_free(Tmat);
260 greg 2.24 cm_free(imtx);
261     } else { /* sky vector/matrix only */
262 greg 2.25 cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt);
263 greg 2.35 nsteps = cmtx->ncols;
264 greg 2.24 }
265     /* prepare output stream */
266     if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) {
267     sprintf(fnbuf, ofspec, 1);
268     ofspec = fnbuf;
269     }
270     if (ofspec != NULL && !hasNumberFormat(ofspec)) {
271     if ((ofp = fopen(ofspec, "w")) == NULL) {
272     fprintf(stderr, "%s: cannot open '%s' for output\n",
273     progname, ofspec);
274     return(1);
275     }
276     ofspec = NULL; /* only need to open once */
277 greg 2.12 }
278 greg 2.24 if (hasNumberFormat(argv[a])) { /* generating image(s) */
279 greg 2.44 if (outfmt != DTrgbe) {
280     error(WARNING, "changing output type to -oc");
281     outfmt = DTrgbe;
282     }
283 greg 2.24 if (ofspec == NULL) {
284     SET_FILE_BINARY(ofp);
285     newheader("RADIANCE", ofp);
286     printargs(argc, argv, ofp);
287     fputnow(ofp);
288     }
289     if (nsteps > 1) /* multiple output frames? */
290     for (i = 0; i < nsteps; i++) {
291     CMATRIX *cvec = cm_column(cmtx, i);
292     if (ofspec != NULL) {
293 greg 2.40 sprintf(fnbuf, ofspec, i);
294 greg 2.24 if ((ofp = fopen(fnbuf, "wb")) == NULL) {
295     fprintf(stderr,
296     "%s: cannot open '%s' for output\n",
297     progname, fnbuf);
298     return(1);
299     }
300     newheader("RADIANCE", ofp);
301     printargs(argc, argv, ofp);
302     fputnow(ofp);
303     }
304 greg 2.40 fprintf(ofp, "FRAME=%d\n", i);
305 greg 2.24 if (!sum_images(argv[a], cvec, ofp))
306     return(1);
307     if (ofspec != NULL) {
308     if (fclose(ofp) == EOF) {
309     fprintf(stderr,
310     "%s: error writing to '%s'\n",
311     progname, fnbuf);
312     return(1);
313     }
314     ofp = stdout;
315     }
316     cm_free(cvec);
317     }
318     else if (!sum_images(argv[a], cmtx, ofp))
319 greg 2.1 return(1);
320 greg 2.24 } else { /* generating vector/matrix */
321     CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader);
322     CMATRIX *rmtx = cm_multiply(Vmat, cmtx);
323 greg 2.1 cm_free(Vmat);
324 greg 2.30 if (ofspec != NULL) { /* multiple vector files? */
325     const char *wtype = (outfmt==DTascii) ? "w" : "wb";
326 greg 2.24 for (i = 0; i < nsteps; i++) {
327     CMATRIX *rvec = cm_column(rmtx, i);
328 greg 2.49 if (alt_dim(rvec, yres, xres) < 0)
329     return(1);
330 greg 2.40 sprintf(fnbuf, ofspec, i);
331 greg 2.30 if ((ofp = fopen(fnbuf, wtype)) == NULL) {
332 greg 2.24 fprintf(stderr,
333     "%s: cannot open '%s' for output\n",
334     progname, fnbuf);
335     return(1);
336     }
337 greg 2.31 #ifdef getc_unlocked
338     flockfile(ofp);
339     #endif
340 greg 2.34 if (headout) { /* header output */
341     newheader("RADIANCE", ofp);
342     printargs(argc, argv, ofp);
343     fputnow(ofp);
344 greg 2.40 fprintf(ofp, "FRAME=%d\n", i);
345 greg 2.47 if ((outfmt != DTrgbe) & (outfmt != DTxyze)) {
346     fprintf(ofp, "NROWS=%d\n", rvec->nrows);
347     fprintf(ofp, "NCOLS=%d\n", rvec->ncols);
348     fputs("NCOMP=3\n", ofp);
349     }
350     if ((outfmt == DTfloat) | (outfmt == DTdouble))
351 greg 2.42 fputendian(ofp);
352 greg 2.46 fputformat(cm_fmt_id[outfmt], ofp);
353 greg 2.34 fputc('\n', ofp);
354     }
355 greg 2.30 cm_write(rvec, outfmt, ofp);
356 greg 2.24 if (fclose(ofp) == EOF) {
357     fprintf(stderr,
358     "%s: error writing to '%s'\n",
359     progname, fnbuf);
360     return(1);
361     }
362     ofp = stdout;
363     cm_free(rvec);
364     }
365 greg 2.30 } else {
366 greg 2.31 #ifdef getc_unlocked
367     flockfile(ofp);
368     #endif
369 greg 2.30 if (outfmt != DTascii)
370     SET_FILE_BINARY(ofp);
371 greg 2.49 if (alt_dim(rmtx, yres, xres) < 0)
372     return(1);
373 greg 2.34 if (headout) { /* header output */
374 greg 2.30 newheader("RADIANCE", ofp);
375     printargs(argc, argv, ofp);
376     fputnow(ofp);
377 greg 2.47 if ((outfmt != DTrgbe) & (outfmt != DTxyze)) {
378     fprintf(ofp, "NROWS=%d\n", rmtx->nrows);
379     fprintf(ofp, "NCOLS=%d\n", rmtx->ncols);
380     fputs("NCOMP=3\n", ofp);
381     }
382     if ((outfmt == DTfloat) | (outfmt == DTdouble))
383 greg 2.42 fputendian(ofp);
384 greg 2.46 fputformat(cm_fmt_id[outfmt], ofp);
385 greg 2.30 fputc('\n', ofp);
386     }
387     cm_write(rmtx, outfmt, ofp);
388     }
389 greg 2.24 cm_free(rmtx);
390     }
391     if (fflush(ofp) == EOF) { /* final clean-up */
392     fprintf(stderr, "%s: write error on output\n", progname);
393     return(1);
394 greg 2.1 }
395 greg 2.24 cm_free(cmtx);
396 greg 2.1 return(0);
397 greg 2.24 userr:
398 greg 2.48 fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] DCspec [skyf]\n",
399 greg 2.24 progname);
400 greg 2.48 fprintf(stderr, " or: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] Vspec Tbsdf Dmat.dat [skyf]\n",
401 greg 2.24 progname);
402     return(1);
403 greg 2.1 }
