root/radiance/ray/src/util/dctimestep.c
Revision: 2.54
Committed: Fri Jun 6 19:11:21 2025 UTC (7 weeks, 6 days ago) by greg
Changes since 2.53: +4 -5 lines
refactor: Making use of printargs() more consistent with fixargv0()
2 static const char RCSid[] = "$Id: dctimestep.c,v 2.53 2025/03/27 16:34:23 greg Exp $";
5 * Compute time-step result using Daylight Coefficient method.
6 *
7 * G. Ward
8 */
9
10 #include <ctype.h>
11 #include "paths.h"
12 #include "platform.h"
13 #include "standard.h"
14 #include "cmatrix.h"
15 #include "platform.h"
16 #include "resolu.h"
17
18 /* Sum together a set of images and write result to fout */
19 static int
20 sum_images(const char *fspec, const CMATRIX *cv, FILE *fout)
21 {
22 static int runcnt = 0;
23 int myDT = DTfromHeader;
24 COLR *scanline = NULL;
25 CMATRIX *pmat = NULL;
26 int myXR=0, myYR=0;
27 int i, y;
28
29 if (cv->ncols != 1)
30 error(INTERNAL, "expected vector in sum_images()");
31 for (i = cv->nrows; i-- > 0; ) {
32 const int r = runcnt&1 ? i : cv->nrows-1 - i;
33 const COLORV *scv = cv_lval(cv,r);
34 int flat_file = 0;
35 char fname[1024];
36 FILE *fp;
37 long data_start;
38 int dt, xr, yr;
39 COLORV *psp;
40 char *err;
41 /* check for zero */
42 if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) &&
43 (myDT != DTfromHeader) | (i > 0))
44 continue;
45 /* open next picture */
46 sprintf(fname, fspec, r);
47 if ((fp = fopen(fname, "rb")) == NULL) {
48 sprintf(errmsg, "cannot open picture '%s'", fname);
49 error(SYSTEM, errmsg);
50 }
51 #ifdef getc_unlocked
52 flockfile(fp);
53 #endif
54 dt = DTfromHeader;
55 if ((err = cm_getheader(&dt, NULL, NULL, NULL, NULL, fp)) != NULL)
56 error(USER, err);
57 if ((dt != DTrgbe) & (dt != DTxyze) ||
58 !fscnresolu(&xr, &yr, fp)) {
59 sprintf(errmsg, "file '%s' not a picture", fname);
60 error(USER, errmsg);
61 }
62 if (myDT == DTfromHeader) { /* on first one */
63 myDT = dt;
64 myXR = xr; myYR = yr;
65 scanline = (COLR *)malloc(sizeof(COLR)*myXR);
66 if (scanline == NULL)
67 error(SYSTEM, "out of memory in sum_images()");
68 pmat = cm_alloc(myYR, myXR);
69 memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR);
70 /* finish header */
71 fputformat(cm_fmt_id[myDT], fout);
72 fputc('\n', fout);
73 fflush(fout);
74 } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) {
75 sprintf(errmsg, "picture '%s' format/size mismatch",
76 fname);
77 error(USER, errmsg);
78 }
79 /* flat file check */
80 if ((data_start = ftell(fp)) > 0 && fseek(fp, 0L, SEEK_END) == 0) {
81 flat_file = (ftell(fp) >= data_start + sizeof(COLR)*xr*yr);
82 if (fseek(fp, data_start, SEEK_SET) < 0) {
83 sprintf(errmsg, "cannot seek on picture '%s'", fname);
84 error(SYSTEM, errmsg);
85 }
86 }
87 psp = pmat->cmem;
88 for (y = 0; y < yr; y++) { /* read it in */
89 COLOR col;
90 int x;
91 if (flat_file ? getbinary(scanline, sizeof(COLR), xr, fp) != xr :
92 freadcolrs(scanline, xr, fp) < 0) {
93 sprintf(errmsg, "error reading picture '%s'",
94 fname);
95 error(SYSTEM, errmsg);
96 }
97 /* sum in scanline */
98 for (x = 0; x < xr; x++, psp += 3) {
99 if (!scanline[x][EXP])
100 continue; /* skip zeroes */
101 colr_color(col, scanline[x]);
102 multcolor(col, scv);
103 addcolor(psp, col);
104 }
105 }
106 fclose(fp); /* done this picture */
107 }
108 free(scanline);
109 i = cm_write(pmat, myDT, fout); /* write picture */
110 cm_free(pmat); /* free data */
111 ++runcnt; /* for zig-zagging */
112 return(i);
113 }
114
115 /* adjust matrix dimensions according to user size(s) */
116 static int
117 alt_dim(CMATRIX *cm, int nr, int nc)
118 {
119 if ((nr <= 0) & (nc <= 0))
120 return(0);
121 if ((nr == cm->nrows) & (nc == cm->ncols))
122 return(0);
123 if (nr > 0) {
124 if (nc <= 0)
125 nc = cm->nrows*cm->ncols/nr;
126 if (nr*nc != cm->nrows*cm->ncols) {
127 fprintf(stderr, "Bad dimensions: %dx%d != %dx%d\n",
128 nr, nc, cm->nrows, cm->ncols);
129 return(-1);
130 }
131 } else /* nc > 0 */ {
132 nr = cm->nrows*cm->ncols/nc;
133 if (nc*nr != cm->nrows*cm->ncols) {
134 fprintf(stderr, "Bad dimensions: %d does not divide %dx%d evenly\n",
135 nc, cm->nrows, cm->ncols);
136 return(-1);
137 }
138 }
139 cm->nrows = nr;
140 cm->ncols = nc;
141 return(1);
142 }
143
144 /* check to see if a string contains a %d or %o specification */
145 static int
146 hasNumberFormat(const char *s)
147 {
148 if (s == NULL)
149 return(0);
150
151 while (*s) {
152 while (*s != '%')
153 if (!*s++)
154 return(0);
155 if (*++s == '%') { /* ignore "%%" */
156 ++s;
157 continue;
158 }
159 while (isdigit(*s)) /* field length */
160 ++s;
161 /* field we'll use? */
162 if ((*s == 'd') | (*s == 'i') | (*s == 'o') |
163 (*s == 'x') | (*s == 'X'))
164 return(1);
165 }
166 return(0); /* didn't find one */
167 }
168
169 int
170 main(int argc, char *argv[])
171 {
172 int skyfmt = DTfromHeader;
173 int outfmt = DTascii;
174 int headout = 1;
175 int nsteps = 0;
176 char *ofspec = NULL;
177 FILE *ofp = stdout;
178 int xres=0, yres=0;
179 CMATRIX *cmtx; /* component vector/matrix result */
180 char fnbuf[256];
181 int a, i;
182 /* set global progname */
183 fixargv0(argv[0]);
184 /* get options */
185 for (a = 1; a < argc && argv[a][0] == '-'; a++)
186 switch (argv[a][1]) {
187 case 'n':
188 nsteps = atoi(argv[++a]);
189 if (nsteps < 0)
190 goto userr;
191 skyfmt = nsteps ? DTascii : DTfromHeader;
192 break;
193 case 'h':
194 headout = !headout;
195 break;
196 case 'i':
197 switch (argv[a][2]) {
198 case 'f':
199 skyfmt = DTfloat;
200 break;
201 case 'd':
202 skyfmt = DTdouble;
203 break;
204 case 'a':
205 skyfmt = DTascii;
206 break;
207 default:
208 goto userr;
209 }
210 break;
211 case 'o':
212 switch (argv[a][2]) {
213 case '\0': /* output specification (not format) */
214 ofspec = argv[++a];
215 break;
216 case 'f':
217 outfmt = DTfloat;
218 break;
219 case 'd':
220 outfmt = DTdouble;
221 break;
222 case 'a':
223 outfmt = DTascii;
224 break;
225 case 'c':
226 outfmt = DTrgbe;
227 break;
228 default:
229 goto userr;
230 }
231 break;
232 case 'x':
233 xres = atoi(argv[++a]);
234 break;
235 case 'y':
236 yres = atoi(argv[++a]);
237 break;
238 default:
239 goto userr;
240 }
241 if ((argc-a < 1) | (argc-a > 4))
242 goto userr;
243
244 if (argc-a > 2) { /* VTDs expression */
245 CMATRIX *smtx, *Dmat, *Tmat, *imtx;
246 const char *ccp;
247 /* get sky vector/matrix */
248 smtx = cm_load(argv[a+3], 0, nsteps, skyfmt);
249 nsteps = smtx->ncols;
250 /* load BSDF */
251 if (argv[a+1][0] != '!' &&
252 (ccp = strrchr(argv[a+1], '.')) > argv[a+1] &&
253 !strcasecmp(ccp+1, "XML"))
254 Tmat = cm_loadBTDF(argv[a+1]);
255 else
256 Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader);
257 /* load Daylight matrix */
258 Dmat = cm_load(argv[a+2], Tmat->ncols,
259 smtx->nrows, DTfromHeader);
260 /* multiply vector through */
261 imtx = cm_multiply(Dmat, smtx);
262 cm_free(Dmat); cm_free(smtx);
263 cmtx = cm_multiply(Tmat, imtx);
264 cm_free(Tmat);
265 cm_free(imtx);
266 } else { /* sky vector/matrix only */
267 cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt);
268 nsteps = cmtx->ncols;
269 }
270 /* prepare output stream */
271 if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) {
272 sprintf(fnbuf, ofspec, 0);
273 ofspec = fnbuf;
274 }
275 if (ofspec != NULL && !hasNumberFormat(ofspec)) {
276 if ((ofp = fopen(ofspec, "w")) == NULL) {
277 fprintf(stderr, "%s: cannot open '%s' for output\n",
278 progname, ofspec);
279 return(1);
280 }
281 ofspec = NULL; /* only need to open once */
282 }
283 if (hasNumberFormat(argv[a])) { /* loading image vector(s) */
284 if (outfmt != DTrgbe) {
285 error(WARNING, "changing output type to -oc");
286 outfmt = DTrgbe;
287 }
288 if (ofspec == NULL) {
289 SET_FILE_BINARY(ofp);
290 newheader("RADIANCE", ofp);
291 printargs(argc, argv, ofp);
292 fputnow(ofp);
293 }
294 if (nsteps > 1) /* multiple output frames? */
295 for (i = 0; i < nsteps; i++) {
296 CMATRIX *cvec = cm_column(cmtx, i);
297 if (ofspec != NULL) {
298 sprintf(fnbuf, ofspec, i);
299 if ((ofp = fopen(fnbuf, "wb")) == NULL) {
300 fprintf(stderr,
301 "%s: cannot open '%s' for output\n",
302 progname, fnbuf);
303 return(1);
304 }
305 newheader("RADIANCE", ofp);
306 printargs(argc, argv, ofp);
307 fputnow(ofp);
308 }
309 fprintf(ofp, "FRAME=%d\n", i);
310 if (!sum_images(argv[a], cvec, ofp))
311 return(1);
312 if (ofspec != NULL) {
313 if (fclose(ofp) == EOF) {
314 fprintf(stderr,
315 "%s: error writing to '%s'\n",
316 progname, fnbuf);
317 return(1);
318 }
319 ofp = stdout;
320 }
321 cm_free(cvec);
322 }
323 else if (!sum_images(argv[a], cmtx, ofp))
324 return(1);
325 } else { /* loading view matrix */
326 CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader);
327 CMATRIX *rmtx = cm_multiply(Vmat, cmtx);
328 cm_free(Vmat);
329 if (ofspec != NULL) { /* multiple vector files? */
330 const char *wtype = (outfmt==DTascii) ? "w" : "wb";
331 for (i = 0; i < nsteps; i++) {
332 CMATRIX *rvec = cm_column(rmtx, i);
333 if (alt_dim(rvec, yres, xres) < 0)
334 return(1);
335 sprintf(fnbuf, ofspec, i);
336 if ((ofp = fopen(fnbuf, wtype)) == NULL) {
337 fprintf(stderr,
338 "%s: cannot open '%s' for output\n",
339 progname, fnbuf);
340 return(1);
341 }
342 #ifdef getc_unlocked
343 flockfile(ofp);
344 #endif
345 if (headout) { /* header output */
346 newheader("RADIANCE", ofp);
347 printargs(argc, argv, ofp);
348 fputnow(ofp);
349 fprintf(ofp, "FRAME=%d\n", i);
350 if ((outfmt != DTrgbe) & (outfmt != DTxyze)) {
351 fprintf(ofp, "NROWS=%d\n", rvec->nrows);
352 fprintf(ofp, "NCOLS=%d\n", rvec->ncols);
353 fputncomp(3, ofp);
354 }
355 if ((outfmt == DTfloat) | (outfmt == DTdouble))
356 fputendian(ofp);
357 fputformat(cm_fmt_id[outfmt], ofp);
358 fputc('\n', ofp);
359 }
360 cm_write(rvec, outfmt, ofp);
361 if (fclose(ofp) == EOF) {
362 fprintf(stderr,
363 "%s: error writing to '%s'\n",
364 progname, fnbuf);
365 return(1);
366 }
367 ofp = stdout;
368 cm_free(rvec);
369 }
370 } else {
371 #ifdef getc_unlocked
372 flockfile(ofp);
373 #endif
374 if (outfmt != DTascii)
375 SET_FILE_BINARY(ofp);
376 if (alt_dim(rmtx, yres, xres) < 0)
377 return(1);
378 if (headout) { /* header output */
379 newheader("RADIANCE", ofp);
380 printargs(argc, argv, ofp);
381 fputnow(ofp);
382 if ((outfmt != DTrgbe) & (outfmt != DTxyze)) {
383 fprintf(ofp, "NROWS=%d\n", rmtx->nrows);
384 fprintf(ofp, "NCOLS=%d\n", rmtx->ncols);
385 fputncomp(3, ofp);
386 }
387 if ((outfmt == DTfloat) | (outfmt == DTdouble))
388 fputendian(ofp);
389 fputformat(cm_fmt_id[outfmt], ofp);
390 fputc('\n', ofp);
391 }
392 cm_write(rmtx, outfmt, ofp);
393 }
394 cm_free(rmtx);
395 }
396 if (fflush(ofp) == EOF) { /* final clean-up */
397 fprintf(stderr, "%s: write error on output\n", progname);
398 return(1);
399 }
400 cm_free(cmtx);
401 return(0);
402 userr:
403 fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] DCspec [skyf]\n",
404 progname);
405 fprintf(stderr, " or: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] Vspec Tbsdf Dmat.dat [skyf]\n",
406 progname);
407 return(1);
408 }
