| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: dctimestep.c,v 2.50 2025/03/01 04:50:13 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Compute time-step result using Daylight Coefficient method.
| 6 |
| 7 |
* G. Ward
| 8 |
| 9 |
| 10 |
#include <ctype.h>
| 11 |
#include "platform.h"
| 12 |
#include "standard.h"
| 13 |
#include "cmatrix.h"
| 14 |
| 15 |
#include "resolu.h"
| 16 |
| 17 |
char *progname; /* global argv[0] */
| 18 |
| 19 |
/* Sum together a set of images and write result to fout */
| 20 |
static int
| 21 |
sum_images(const char *fspec, const CMATRIX *cv, FILE *fout)
| 22 |
| 23 |
int myDT = DTfromHeader;
| 24 |
COLR *scanline = NULL;
| 25 |
CMATRIX *pmat = NULL;
| 26 |
int myXR=0, myYR=0;
| 27 |
int i, y;
| 28 |
| 29 |
if (cv->ncols != 1)
| 30 |
error(INTERNAL, "expected vector in sum_images()");
| 31 |
for (i = 0; i < cv->nrows; i++) {
| 32 |
const COLORV *scv = cv_lval(cv,i);
| 33 |
int flat_file = 0;
| 34 |
char fname[1024];
| 35 |
FILE *fp;
| 36 |
long data_start;
| 37 |
int dt, xr, yr;
| 38 |
COLORV *psp;
| 39 |
char *err;
| 40 |
/* check for zero */
| 41 |
if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) &&
| 42 |
(myDT != DTfromHeader) | (i < cv->nrows-1))
| 43 |
continue;
| 44 |
/* open next picture */
| 45 |
sprintf(fname, fspec, i);
| 46 |
if ((fp = fopen(fname, "rb")) == NULL) {
| 47 |
sprintf(errmsg, "cannot open picture '%s'", fname);
| 48 |
error(SYSTEM, errmsg);
| 49 |
| 50 |
#ifdef getc_unlocked
| 51 |
flockfile(fp);
| 52 |
#endif
| 53 |
dt = DTfromHeader;
| 54 |
if ((err = cm_getheader(&dt, NULL, NULL, NULL, NULL, fp)) != NULL)
| 55 |
error(USER, err);
| 56 |
if ((dt != DTrgbe) & (dt != DTxyze) ||
| 57 |
!fscnresolu(&xr, &yr, fp)) {
| 58 |
sprintf(errmsg, "file '%s' not a picture", fname);
| 59 |
error(USER, errmsg);
| 60 |
| 61 |
if (myDT == DTfromHeader) { /* on first one */
| 62 |
myDT = dt;
| 63 |
myXR = xr; myYR = yr;
| 64 |
scanline = (COLR *)malloc(sizeof(COLR)*myXR);
| 65 |
if (scanline == NULL)
| 66 |
error(SYSTEM, "out of memory in sum_images()");
| 67 |
pmat = cm_alloc(myYR, myXR);
| 68 |
memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR);
| 69 |
/* finish header */
| 70 |
fputformat(cm_fmt_id[myDT], fout);
| 71 |
fputc('\n', fout);
| 72 |
fflush(fout);
| 73 |
} else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) {
| 74 |
sprintf(errmsg, "picture '%s' format/size mismatch",
| 75 |
fname);
| 76 |
| 77 |
| 78 |
/* flat file check */
| 79 |
if ((data_start = ftell(fp)) > 0 && fseek(fp, 0L, SEEK_END) == 0) {
| 80 |
flat_file = (ftell(fp) >= data_start + sizeof(COLR)*xr*yr);
| 81 |
if (fseek(fp, data_start, SEEK_SET) < 0) {
| 82 |
sprintf(errmsg, "cannot seek on picture '%s'", fname);
| 83 |
| 84 |
| 85 |
| 86 |
psp = pmat->cmem;
| 87 |
for (y = 0; y < yr; y++) { /* read it in */
| 88 |
COLOR col;
| 89 |
int x;
| 90 |
if (flat_file ? getbinary(scanline, sizeof(COLR), xr, fp) != xr :
| 91 |
freadcolrs(scanline, xr, fp) < 0) {
| 92 |
sprintf(errmsg, "error reading picture '%s'",
| 93 |
fname);
| 94 |
| 95 |
| 96 |
/* sum in scanline */
| 97 |
for (x = 0; x < xr; x++, psp += 3) {
| 98 |
if (!scanline[x][EXP])
| 99 |
continue; /* skip zeroes */
| 100 |
colr_color(col, scanline[x]);
| 101 |
multcolor(col, scv);
| 102 |
addcolor(psp, col);
| 103 |
| 104 |
| 105 |
fclose(fp); /* done this picture */
| 106 |
| 107 |
free(scanline);
| 108 |
i = cm_write(pmat, myDT, fout); /* write picture */
| 109 |
cm_free(pmat); /* free data */
| 110 |
return(i);
| 111 |
| 112 |
| 113 |
/* adjust matrix dimensions according to user size(s) */
| 114 |
static int
| 115 |
alt_dim(CMATRIX *cm, int nr, int nc)
| 116 |
| 117 |
if ((nr <= 0) & (nc <= 0))
| 118 |
return(0);
| 119 |
if ((nr == cm->nrows) & (nc == cm->ncols))
| 120 |
return(0);
| 121 |
if (nr > 0) {
| 122 |
if (nc <= 0)
| 123 |
nc = cm->nrows*cm->ncols/nr;
| 124 |
if (nr*nc != cm->nrows*cm->ncols) {
| 125 |
fprintf(stderr, "Bad dimensions: %dx%d != %dx%d\n",
| 126 |
nr, nc, cm->nrows, cm->ncols);
| 127 |
return(-1);
| 128 |
| 129 |
} else /* nc > 0 */ {
| 130 |
nr = cm->nrows*cm->ncols/nc;
| 131 |
if (nc*nr != cm->nrows*cm->ncols) {
| 132 |
fprintf(stderr, "Bad dimensions: %d does not divide %dx%d evenly\n",
| 133 |
| 134 |
return(-1);
| 135 |
| 136 |
| 137 |
cm->nrows = nr;
| 138 |
cm->ncols = nc;
| 139 |
return(1);
| 140 |
| 141 |
| 142 |
/* check to see if a string contains a %d or %o specification */
| 143 |
static int
| 144 |
hasNumberFormat(const char *s)
| 145 |
| 146 |
if (s == NULL)
| 147 |
return(0);
| 148 |
| 149 |
while (*s) {
| 150 |
while (*s != '%')
| 151 |
if (!*s++)
| 152 |
return(0);
| 153 |
if (*++s == '%') { /* ignore "%%" */
| 154 |
++s;
| 155 |
continue;
| 156 |
| 157 |
while (isdigit(*s)) /* field length */
| 158 |
++s;
| 159 |
/* field we'll use? */
| 160 |
if ((*s == 'd') | (*s == 'i') | (*s == 'o') |
| 161 |
(*s == 'x') | (*s == 'X'))
| 162 |
return(1);
| 163 |
| 164 |
return(0); /* didn't find one */
| 165 |
| 166 |
| 167 |
int
| 168 |
main(int argc, char *argv[])
| 169 |
| 170 |
int skyfmt = DTfromHeader;
| 171 |
int outfmt = DTascii;
| 172 |
int headout = 1;
| 173 |
int nsteps = 0;
| 174 |
char *ofspec = NULL;
| 175 |
FILE *ofp = stdout;
| 176 |
int xres=0, yres=0;
| 177 |
CMATRIX *cmtx; /* component vector/matrix result */
| 178 |
char fnbuf[256];
| 179 |
int a, i;
| 180 |
| 181 |
progname = argv[0];
| 182 |
/* get options */
| 183 |
for (a = 1; a < argc && argv[a][0] == '-'; a++)
| 184 |
switch (argv[a][1]) {
| 185 |
case 'n':
| 186 |
nsteps = atoi(argv[++a]);
| 187 |
if (nsteps < 0)
| 188 |
goto userr;
| 189 |
skyfmt = nsteps ? DTascii : DTfromHeader;
| 190 |
break;
| 191 |
case 'h':
| 192 |
headout = !headout;
| 193 |
break;
| 194 |
case 'i':
| 195 |
switch (argv[a][2]) {
| 196 |
case 'f':
| 197 |
skyfmt = DTfloat;
| 198 |
break;
| 199 |
case 'd':
| 200 |
skyfmt = DTdouble;
| 201 |
break;
| 202 |
case 'a':
| 203 |
skyfmt = DTascii;
| 204 |
break;
| 205 |
default:
| 206 |
goto userr;
| 207 |
| 208 |
break;
| 209 |
case 'o':
| 210 |
| 211 |
case '\0': /* output specification (not format) */
| 212 |
ofspec = argv[++a];
| 213 |
break;
| 214 |
case 'f':
| 215 |
outfmt = DTfloat;
| 216 |
break;
| 217 |
case 'd':
| 218 |
outfmt = DTdouble;
| 219 |
break;
| 220 |
case 'a':
| 221 |
outfmt = DTascii;
| 222 |
break;
| 223 |
case 'c':
| 224 |
outfmt = DTrgbe;
| 225 |
break;
| 226 |
default:
| 227 |
goto userr;
| 228 |
| 229 |
break;
| 230 |
case 'x':
| 231 |
xres = atoi(argv[++a]);
| 232 |
break;
| 233 |
case 'y':
| 234 |
yres = atoi(argv[++a]);
| 235 |
break;
| 236 |
default:
| 237 |
goto userr;
| 238 |
| 239 |
if ((argc-a < 1) | (argc-a > 4))
| 240 |
goto userr;
| 241 |
| 242 |
if (argc-a > 2) { /* VTDs expression */
| 243 |
CMATRIX *smtx, *Dmat, *Tmat, *imtx;
| 244 |
const char *ccp;
| 245 |
/* get sky vector/matrix */
| 246 |
smtx = cm_load(argv[a+3], 0, nsteps, skyfmt);
| 247 |
nsteps = smtx->ncols;
| 248 |
/* load BSDF */
| 249 |
if (argv[a+1][0] != '!' &&
| 250 |
(ccp = strrchr(argv[a+1], '.')) != NULL &&
| 251 |
!strcasecmp(ccp+1, "XML"))
| 252 |
Tmat = cm_loadBTDF(argv[a+1]);
| 253 |
else
| 254 |
Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader);
| 255 |
/* load Daylight matrix */
| 256 |
Dmat = cm_load(argv[a+2], Tmat->ncols,
| 257 |
smtx->nrows, DTfromHeader);
| 258 |
/* multiply vector through */
| 259 |
imtx = cm_multiply(Dmat, smtx);
| 260 |
cm_free(Dmat); cm_free(smtx);
| 261 |
cmtx = cm_multiply(Tmat, imtx);
| 262 |
cm_free(Tmat);
| 263 |
cm_free(imtx);
| 264 |
} else { /* sky vector/matrix only */
| 265 |
cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt);
| 266 |
nsteps = cmtx->ncols;
| 267 |
| 268 |
/* prepare output stream */
| 269 |
if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) {
| 270 |
sprintf(fnbuf, ofspec, 1);
| 271 |
ofspec = fnbuf;
| 272 |
| 273 |
if (ofspec != NULL && !hasNumberFormat(ofspec)) {
| 274 |
if ((ofp = fopen(ofspec, "w")) == NULL) {
| 275 |
fprintf(stderr, "%s: cannot open '%s' for output\n",
| 276 |
progname, ofspec);
| 277 |
return(1);
| 278 |
| 279 |
ofspec = NULL; /* only need to open once */
| 280 |
| 281 |
if (hasNumberFormat(argv[a])) { /* generating image(s) */
| 282 |
if (outfmt != DTrgbe) {
| 283 |
error(WARNING, "changing output type to -oc");
| 284 |
outfmt = DTrgbe;
| 285 |
| 286 |
if (ofspec == NULL) {
| 287 |
SET_FILE_BINARY(ofp);
| 288 |
newheader("RADIANCE", ofp);
| 289 |
printargs(argc, argv, ofp);
| 290 |
fputnow(ofp);
| 291 |
| 292 |
if (nsteps > 1) /* multiple output frames? */
| 293 |
for (i = 0; i < nsteps; i++) {
| 294 |
CMATRIX *cvec = cm_column(cmtx, i);
| 295 |
if (ofspec != NULL) {
| 296 |
sprintf(fnbuf, ofspec, i);
| 297 |
if ((ofp = fopen(fnbuf, "wb")) == NULL) {
| 298 |
fprintf(stderr,
| 299 |
| 300 |
progname, fnbuf);
| 301 |
return(1);
| 302 |
| 303 |
| 304 |
| 305 |
fputnow(ofp);
| 306 |
| 307 |
fprintf(ofp, "FRAME=%d\n", i);
| 308 |
if (!sum_images(argv[a], cvec, ofp))
| 309 |
return(1);
| 310 |
| 311 |
if (fclose(ofp) == EOF) {
| 312 |
fprintf(stderr,
| 313 |
"%s: error writing to '%s'\n",
| 314 |
progname, fnbuf);
| 315 |
return(1);
| 316 |
| 317 |
ofp = stdout;
| 318 |
| 319 |
cm_free(cvec);
| 320 |
| 321 |
else if (!sum_images(argv[a], cmtx, ofp))
| 322 |
return(1);
| 323 |
} else { /* generating vector/matrix */
| 324 |
CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader);
| 325 |
CMATRIX *rmtx = cm_multiply(Vmat, cmtx);
| 326 |
cm_free(Vmat);
| 327 |
if (ofspec != NULL) { /* multiple vector files? */
| 328 |
const char *wtype = (outfmt==DTascii) ? "w" : "wb";
| 329 |
| 330 |
CMATRIX *rvec = cm_column(rmtx, i);
| 331 |
if (alt_dim(rvec, yres, xres) < 0)
| 332 |
return(1);
| 333 |
| 334 |
if ((ofp = fopen(fnbuf, wtype)) == NULL) {
| 335 |
fprintf(stderr,
| 336 |
| 337 |
progname, fnbuf);
| 338 |
return(1);
| 339 |
| 340 |
| 341 |
flockfile(ofp);
| 342 |
#endif
| 343 |
if (headout) { /* header output */
| 344 |
| 345 |
| 346 |
fputnow(ofp);
| 347 |
| 348 |
if ((outfmt != DTrgbe) & (outfmt != DTxyze)) {
| 349 |
fprintf(ofp, "NROWS=%d\n", rvec->nrows);
| 350 |
fprintf(ofp, "NCOLS=%d\n", rvec->ncols);
| 351 |
fputs("NCOMP=3\n", ofp);
| 352 |
| 353 |
if ((outfmt == DTfloat) | (outfmt == DTdouble))
| 354 |
fputendian(ofp);
| 355 |
fputformat(cm_fmt_id[outfmt], ofp);
| 356 |
fputc('\n', ofp);
| 357 |
| 358 |
cm_write(rvec, outfmt, ofp);
| 359 |
| 360 |
fprintf(stderr,
| 361 |
| 362 |
progname, fnbuf);
| 363 |
return(1);
| 364 |
| 365 |
ofp = stdout;
| 366 |
cm_free(rvec);
| 367 |
| 368 |
} else {
| 369 |
| 370 |
flockfile(ofp);
| 371 |
#endif
| 372 |
if (outfmt != DTascii)
| 373 |
| 374 |
if (alt_dim(rmtx, yres, xres) < 0)
| 375 |
return(1);
| 376 |
| 377 |
| 378 |
| 379 |
fputnow(ofp);
| 380 |
| 381 |
fprintf(ofp, "NROWS=%d\n", rmtx->nrows);
| 382 |
fprintf(ofp, "NCOLS=%d\n", rmtx->ncols);
| 383 |
| 384 |
| 385 |
| 386 |
fputendian(ofp);
| 387 |
| 388 |
fputc('\n', ofp);
| 389 |
| 390 |
cm_write(rmtx, outfmt, ofp);
| 391 |
| 392 |
cm_free(rmtx);
| 393 |
| 394 |
if (fflush(ofp) == EOF) { /* final clean-up */
| 395 |
fprintf(stderr, "%s: write error on output\n", progname);
| 396 |
return(1);
| 397 |
| 398 |
cm_free(cmtx);
| 399 |
return(0);
| 400 |
userr:
| 401 |
fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] DCspec [skyf]\n",
| 402 |
progname);
| 403 |
fprintf(stderr, " or: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] Vspec Tbsdf Dmat.dat [skyf]\n",
| 404 |
progname);
| 405 |
return(1);
| 406 |
