--- ray/src/util/dctimestep.c 2009/06/21 21:49:13 2.8 +++ ray/src/util/dctimestep.c 2011/04/03 03:06:19 2.14 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: dctimestep.c,v 2.8 2009/06/21 21:49:13 greg Exp $"; +static const char RCSid[] = "$Id: dctimestep.c,v 2.14 2011/04/03 03:06:19 greg Exp $"; #endif /* * Compute time-step result using Daylight Coefficient method. @@ -38,7 +38,7 @@ cm_alloc(int nrows, int ncols) CMATRIX *cm; if ((nrows <= 0) | (ncols <= 0)) - return(NULL); + error(USER, "attempt to create empty matrix"); cm = (CMATRIX *)malloc(sizeof(CMATRIX) + 3*sizeof(COLORV)*(nrows*ncols - 1)); if (cm == NULL) @@ -108,6 +108,8 @@ cm_load(const char *fname, int nrows, int ncols, int d CMATRIX *cm; FILE *fp = stdin; + if (ncols <= 0) + error(USER, "Non-positive number of columns"); if (fname == NULL) fname = ""; else if ((fp = fopen(fname, "r")) == NULL) { @@ -294,7 +296,6 @@ static CMATRIX * cm_bsdf(const struct BSDF_data *bsdf) { CMATRIX *cm = cm_alloc(bsdf->nout, bsdf->ninc); - COLORV *mp = cm->cmem; int nbadohm = 0; int nneg = 0; int r, c; @@ -313,12 +314,12 @@ cm_bsdf(const struct BSDF_data *bsdf) for (r = 0; r < cm->nrows; r++) { float f = BSDF_value(bsdf,c,r); + COLORV *mp = cm_lval(cm,r,c); if (f <= .0) { nneg += (f < -FTINY); f = .0f; } - mp = cm_lval(cm,r,c); mp[0] = mp[1] = mp[2] = f * dom; } } @@ -333,7 +334,7 @@ cm_bsdf(const struct BSDF_data *bsdf) /* Sum together a set of images and write result to stdout */ static int -sum_images(const char *fspec, const CMATRIX *cv) +sum_images(const char *fspec, const CMATRIX *cv, FILE *fout) { int myDT = DTfromHeader; CMATRIX *pmat; @@ -349,6 +350,9 @@ sum_images(const char *fspec, const CMATRIX *cv) FILE *fp; int dt, xr, yr; COLORV *psp; + /* check for zero */ + if ((scv[RED] == .0) & (scv[GRN] == .0) & (scv[BLU] == .0)) + continue; /* open next picture */ sprintf(fname, fspec, i); if ((fp = fopen(fname, "r")) == NULL) { @@ -371,10 +375,10 @@ sum_images(const char *fspec, const CMATRIX *cv) pmat = cm_alloc(myYR, myXR); memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR); /* finish header */ - fputformat(myDT==DTrgbe ? COLRFMT : CIEFMT, stdout); - fputc('\n', stdout); - fprtresolu(myXR, myYR, stdout); - fflush(stdout); + fputformat(myDT==DTrgbe ? COLRFMT : CIEFMT, fout); + fputc('\n', fout); + fprtresolu(myXR, myYR, fout); + fflush(fout); } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) { sprintf(errmsg, "picture '%s' format/size mismatch", fname); @@ -399,15 +403,15 @@ sum_images(const char *fspec, const CMATRIX *cv) free(scanline); /* write scanlines */ for (y = 0; y < myYR; y++) - if (fwritescan((COLOR *)cm_lval(pmat, y, 0), myXR, stdout) < 0) + if (fwritescan((COLOR *)cm_lval(pmat, y, 0), myXR, fout) < 0) return(0); cm_free(pmat); /* all done */ - return(fflush(stdout) == 0); + return(fflush(fout) == 0); } -/* check to see if a string contains a %d specification */ -int -hasDecimalSpec(const char *s) +/* check to see if a string contains a %d or %o specification */ +static int +hasNumberFormat(const char *s) { while (*s && *s != '%') s++; @@ -417,43 +421,51 @@ hasDecimalSpec(const char *s) ++s; while (isdigit(*s)); - return(*s == 'd'); + return(*s == 'd' | *s == 'i' | *s == 'o' | *s == 'x' | *s == 'X'); } int main(int argc, char *argv[]) { - CMATRIX *tvec, *Dmat, *Tmat, *ivec, *cvec; - struct BSDF_data *btdf; + CMATRIX *cvec; progname = argv[0]; - if ((argc < 4) | (argc > 5)) { - fprintf(stderr, "Usage: %s Vspec Tbsdf.xml Dmat.dat [tregvec]\n", - progname); + if ((argc < 2) | (argc > 5)) { + fprintf(stderr, "Usage: %s DCspec [tregvec]\n", progname); + fprintf(stderr, " or: %s Vspec Tbsdf.xml Dmat.dat [tregvec]\n", + progname); return(1); } - /* load Tregenza vector */ - tvec = cm_load(argv[4], 0, 1, DTascii); /* argv[4]==NULL iff argc==4 */ - /* load BTDF */ - btdf = load_BSDF(argv[2]); - if (btdf == NULL) - return(1); + + if (argc > 3) { /* VTDs expression */ + CMATRIX *svec, *Dmat, *Tmat, *ivec; + struct BSDF_data *btdf; + /* get sky vector */ + svec = cm_load(argv[4], 0, 1, DTascii); + /* load BSDF */ + btdf = load_BSDF(argv[2]); + if (btdf == NULL) + return(1); /* load Daylight matrix */ - Dmat = cm_load(argv[3], btdf->ninc, tvec->nrows, DTfromHeader); + Dmat = cm_load(argv[3], btdf->ninc, svec->nrows, DTfromHeader); /* multiply vector through */ - ivec = cm_multiply(Dmat, tvec); - cm_free(Dmat); cm_free(tvec); - Tmat = cm_bsdf(btdf); /* convert BTDF to matrix */ - free_BSDF(btdf); - cvec = cm_multiply(Tmat, ivec); /* cvec = component vector */ - cm_free(Tmat); cm_free(ivec); - if (hasDecimalSpec(argv[1])) { /* generating image */ + ivec = cm_multiply(Dmat, svec); + cm_free(Dmat); cm_free(svec); + Tmat = cm_bsdf(btdf); /* convert BTDF to matrix */ + free_BSDF(btdf); + cvec = cm_multiply(Tmat, ivec); /* cvec = component vector */ + cm_free(Tmat); cm_free(ivec); + } else { /* else just use sky vector */ + cvec = cm_load(argv[2], 0, 1, DTascii); + } + + if (hasNumberFormat(argv[1])) { /* generating image */ SET_FILE_BINARY(stdout); newheader("RADIANCE", stdout); printargs(argc, argv, stdout); fputnow(stdout); - if (!sum_images(argv[1], cvec)) + if (!sum_images(argv[1], cvec, stdout)) return(1); } else { /* generating vector */ CMATRIX *Vmat = cm_load(argv[1], 0, cvec->nrows, DTfromHeader);
