--- ray/src/util/dctimestep.c 2009/06/19 14:21:42 2.3 +++ ray/src/util/dctimestep.c 2009/06/20 04:37:43 2.6 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: dctimestep.c,v 2.3 2009/06/19 14:21:42 greg Exp $"; +static const char RCSid[] = "$Id: dctimestep.c,v 2.6 2009/06/20 04:37:43 greg Exp $"; #endif /* * Compute time-step result using Daylight Coefficient method. @@ -160,12 +160,12 @@ cm_load(const char *fname, int nrows, int ncols, int d int maxrow = (nrows > 0 ? nrows : 32000); int r, c; for (r = 0; r < maxrow; r++) { - if (r >= cm->nrows) /* need more space? */ + if (r >= cm->nrows) /* need more space? */ cm = cm_resize(cm, 2*cm->nrows); for (c = 0; c < ncols; c++) { COLORV *cv = cm_lval(cm,r,c); if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) - if ((nrows <= 0) & (r > 0) & (c == 0)) { + if ((nrows <= 0) & (r > 0) & !c) { cm = cm_resize(cm, maxrow=r); break; } else @@ -193,7 +193,7 @@ cm_load(const char *fname, int nrows, int ncols, int d if (nread == cm->nrows*cm->ncols) /* need more space? */ cm = cm_resize(cm, 2*cm->nrows); - else if (nread % cm->ncols == 0) + else if (nread && !(nread % cm->ncols)) /* seem to be done */ cm = cm_resize(cm, nread/cm->ncols); else /* ended mid-row */ @@ -318,9 +318,10 @@ cm_bsdf(const struct BSDF_data *bsdf) mp[0] = mp[1] = mp[2] = f * dom * -v[2]; } - if (nbadohm | nneg) { + if (nneg || nbadohm) { sprintf(errmsg, - "BTDF has %d negatives and %d bad incoming solid angles"); + "BTDF has %d negatives and %d bad incoming solid angles", + nneg, nbadohm); error(WARNING, errmsg); } return(cm); @@ -428,16 +429,14 @@ main(int argc, char *argv[]) progname); return(1); } + /* load Tregenza vector */ tvec = cm_load(argv[4], 0, 1, DTascii); /* argv[4]==NULL iff argc==4 */ - Dmat = cm_load(argv[3], 0, tvec->nrows, DTfromHeader); + /* load BTDF */ btdf = load_BSDF(argv[2]); if (btdf == NULL) return(1); - if (btdf->ninc != Dmat->nrows) { - sprintf(errmsg, "Incoming BTDF dir (%d) mismatch to D (%d)", - btdf->ninc, Dmat->nrows); - error(USER, errmsg); - } + /* load Daylight matrix */ + Dmat = cm_load(argv[3], btdf->ninc, tvec->nrows, DTfromHeader); /* multiply vector through */ ivec = cm_multiply(Dmat, tvec); cm_free(Dmat); cm_free(tvec);
