--- ray/src/util/dctimestep.c 2022/03/11 02:44:33 2.49 +++ ray/src/util/dctimestep.c 2025/06/06 19:11:21 2.54 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: dctimestep.c,v 2.49 2022/03/11 02:44:33 greg Exp $"; +static const char RCSid[] = "$Id: dctimestep.c,v 2.54 2025/06/06 19:11:21 greg Exp $"; #endif /* * Compute time-step result using Daylight Coefficient method. @@ -8,18 +8,18 @@ static const char RCSid[] = "$Id: dctimestep.c,v 2.49 */ #include +#include "paths.h" #include "platform.h" #include "standard.h" #include "cmatrix.h" #include "platform.h" #include "resolu.h" -char *progname; /* global argv[0] */ - /* Sum together a set of images and write result to fout */ static int sum_images(const char *fspec, const CMATRIX *cv, FILE *fout) { + static int runcnt = 0; int myDT = DTfromHeader; COLR *scanline = NULL; CMATRIX *pmat = NULL; @@ -28,8 +28,9 @@ sum_images(const char *fspec, const CMATRIX *cv, FILE if (cv->ncols != 1) error(INTERNAL, "expected vector in sum_images()"); - for (i = 0; i < cv->nrows; i++) { - const COLORV *scv = cv_lval(cv,i); + for (i = cv->nrows; i-- > 0; ) { + const int r = runcnt&1 ? i : cv->nrows-1 - i; + const COLORV *scv = cv_lval(cv,r); int flat_file = 0; char fname[1024]; FILE *fp; @@ -39,14 +40,17 @@ sum_images(const char *fspec, const CMATRIX *cv, FILE char *err; /* check for zero */ if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) && - (myDT != DTfromHeader) | (i < cv->nrows-1)) + (myDT != DTfromHeader) | (i > 0)) continue; /* open next picture */ - sprintf(fname, fspec, i); + sprintf(fname, fspec, r); if ((fp = fopen(fname, "rb")) == NULL) { sprintf(errmsg, "cannot open picture '%s'", fname); error(SYSTEM, errmsg); } +#ifdef getc_unlocked + flockfile(fp); +#endif dt = DTfromHeader; if ((err = cm_getheader(&dt, NULL, NULL, NULL, NULL, fp)) != NULL) error(USER, err); @@ -74,7 +78,7 @@ sum_images(const char *fspec, const CMATRIX *cv, FILE } /* flat file check */ if ((data_start = ftell(fp)) > 0 && fseek(fp, 0L, SEEK_END) == 0) { - flat_file = (ftell(fp) == data_start + sizeof(COLR)*xr*yr); + flat_file = (ftell(fp) >= data_start + sizeof(COLR)*xr*yr); if (fseek(fp, data_start, SEEK_SET) < 0) { sprintf(errmsg, "cannot seek on picture '%s'", fname); error(SYSTEM, errmsg); @@ -104,6 +108,7 @@ sum_images(const char *fspec, const CMATRIX *cv, FILE free(scanline); i = cm_write(pmat, myDT, fout); /* write picture */ cm_free(pmat); /* free data */ + ++runcnt; /* for zig-zagging */ return(i); } @@ -174,8 +179,8 @@ main(int argc, char *argv[]) CMATRIX *cmtx; /* component vector/matrix result */ char fnbuf[256]; int a, i; - - progname = argv[0]; + /* set global progname */ + fixargv0(argv[0]); /* get options */ for (a = 1; a < argc && argv[a][0] == '-'; a++) switch (argv[a][1]) { @@ -244,7 +249,7 @@ main(int argc, char *argv[]) nsteps = smtx->ncols; /* load BSDF */ if (argv[a+1][0] != '!' && - (ccp = strrchr(argv[a+1], '.')) != NULL && + (ccp = strrchr(argv[a+1], '.')) > argv[a+1] && !strcasecmp(ccp+1, "XML")) Tmat = cm_loadBTDF(argv[a+1]); else @@ -264,7 +269,7 @@ main(int argc, char *argv[]) } /* prepare output stream */ if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) { - sprintf(fnbuf, ofspec, 1); + sprintf(fnbuf, ofspec, 0); ofspec = fnbuf; } if (ofspec != NULL && !hasNumberFormat(ofspec)) { @@ -275,7 +280,7 @@ main(int argc, char *argv[]) } ofspec = NULL; /* only need to open once */ } - if (hasNumberFormat(argv[a])) { /* generating image(s) */ + if (hasNumberFormat(argv[a])) { /* loading image vector(s) */ if (outfmt != DTrgbe) { error(WARNING, "changing output type to -oc"); outfmt = DTrgbe; @@ -317,7 +322,7 @@ main(int argc, char *argv[]) } else if (!sum_images(argv[a], cmtx, ofp)) return(1); - } else { /* generating vector/matrix */ + } else { /* loading view matrix */ CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader); CMATRIX *rmtx = cm_multiply(Vmat, cmtx); cm_free(Vmat); @@ -345,7 +350,7 @@ main(int argc, char *argv[]) if ((outfmt != DTrgbe) & (outfmt != DTxyze)) { fprintf(ofp, "NROWS=%d\n", rvec->nrows); fprintf(ofp, "NCOLS=%d\n", rvec->ncols); - fputs("NCOMP=3\n", ofp); + fputncomp(3, ofp); } if ((outfmt == DTfloat) | (outfmt == DTdouble)) fputendian(ofp); @@ -377,7 +382,7 @@ main(int argc, char *argv[]) if ((outfmt != DTrgbe) & (outfmt != DTxyze)) { fprintf(ofp, "NROWS=%d\n", rmtx->nrows); fprintf(ofp, "NCOLS=%d\n", rmtx->ncols); - fputs("NCOMP=3\n", ofp); + fputncomp(3, ofp); } if ((outfmt == DTfloat) | (outfmt == DTdouble)) fputendian(ofp);
