--- ray/src/util/dctimestep.c 2009/06/19 14:21:42 2.3 +++ ray/src/util/dctimestep.c 2025/06/06 19:11:21 2.54 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: dctimestep.c,v 2.3 2009/06/19 14:21:42 greg Exp $"; +static const char RCSid[] = "$Id: dctimestep.c,v 2.54 2025/06/06 19:11:21 greg Exp $"; #endif /* * Compute time-step result using Daylight Coefficient method. @@ -8,350 +8,52 @@ static const char RCSid[] = "$Id: dctimestep.c,v 2.3 2 */ #include +#include "paths.h" +#include "platform.h" #include "standard.h" +#include "cmatrix.h" #include "platform.h" -#include "color.h" #include "resolu.h" -#include "bsdf.h" -char *progname; /* global argv[0] */ - -/* Data types for file loading */ -enum {DTfromHeader, DTascii, DTfloat, DTdouble, DTrgbe, DTxyze}; - -/* A color coefficient matrix -- vectors have ncols==1 */ -typedef struct { - int nrows, ncols; - COLORV cmem[3]; /* extends struct */ -} CMATRIX; - -#define COLSPEC (sizeof(COLORV)==sizeof(float) ? "%f %f %f" : "%lf %lf %lf") - -#define cm_lval(cm,r,c) ((cm)->cmem + 3*((r)*(cm)->ncols + (c))) - -#define cv_lval(cm,i) ((cm)->cmem + 3*(i)) - -/* Allocate a color coefficient matrix */ -static CMATRIX * -cm_alloc(int nrows, int ncols) -{ - CMATRIX *cm; - - if ((nrows <= 0) | (ncols <= 0)) - return(NULL); - cm = (CMATRIX *)malloc(sizeof(CMATRIX) + - 3*sizeof(COLORV)*(nrows*ncols - 1)); - if (cm == NULL) - error(SYSTEM, "out of memory in cm_alloc()"); - cm->nrows = nrows; - cm->ncols = ncols; - return(cm); -} - -#define cm_free(cm) free(cm) - -/* Resize color coefficient matrix */ -static CMATRIX * -cm_resize(CMATRIX *cm, int nrows) -{ - if (nrows == cm->nrows) - return(cm); - if (nrows <= 0) { - cm_free(cm); - return(NULL); - } - cm = (CMATRIX *)realloc(cm, sizeof(CMATRIX) + - 3*sizeof(COLORV)*(nrows*cm->ncols - 1)); - if (cm == NULL) - error(SYSTEM, "out of memory in cm_resize()"); - cm->nrows = nrows; - return(cm); -} - -/* Load header to obtain data type */ +/* Sum together a set of images and write result to fout */ static int -getDT(char *s, void *p) +sum_images(const char *fspec, const CMATRIX *cv, FILE *fout) { - char fmt[32]; - - if (formatval(fmt, s)) { - if (!strcmp(fmt, "ascii")) - *((int *)p) = DTascii; - else if (!strcmp(fmt, "float")) - *((int *)p) = DTfloat; - else if (!strcmp(fmt, "double")) - *((int *)p) = DTdouble; - else if (!strcmp(fmt, COLRFMT)) - *((int *)p) = DTrgbe; - else if (!strcmp(fmt, CIEFMT)) - *((int *)p) = DTxyze; - } - return(0); -} - -static int -getDTfromHeader(FILE *fp) -{ - int dt = DTfromHeader; - - if (getheader(fp, getDT, &dt) < 0) - error(SYSTEM, "header read error"); - if (dt == DTfromHeader) - error(USER, "missing data format in header"); - return(dt); -} - -/* Allocate and load a matrix from the given file (or stdin if NULL) */ -static CMATRIX * -cm_load(const char *fname, int nrows, int ncols, int dtype) -{ - CMATRIX *cm; - FILE *fp = stdin; - - if (fname == NULL) - fname = ""; - else if ((fp = fopen(fname, "r")) == NULL) { - sprintf(errmsg, "cannot open file '%s'", fname); - error(SYSTEM, errmsg); - } - if (dtype != DTascii) - SET_FILE_BINARY(fp); - if (dtype == DTfromHeader) - dtype = getDTfromHeader(fp); - switch (dtype) { - case DTascii: - case DTfloat: - case DTdouble: - break; - default: - error(USER, "unexpected data type in cm_load()"); - } - if (nrows <= 0) { /* don't know length? */ - int guessrows = 147; /* usually big enough */ - if ((dtype != DTascii) & (fp != stdin)) { - long startpos = ftell(fp); - if (fseek(fp, 0L, SEEK_END) == 0) { - long endpos = ftell(fp); - long elemsiz = 3*(dtype==DTfloat ? - sizeof(float) : sizeof(double)); - - if ((endpos - startpos) % (ncols*elemsiz)) { - sprintf(errmsg, - "improper length for binary file '%s'", - fname); - error(USER, errmsg); - } - guessrows = (endpos - startpos)/(ncols*elemsiz); - if (fseek(fp, startpos, SEEK_SET) < 0) { - sprintf(errmsg, - "fseek() error on file '%s'", - fname); - error(SYSTEM, errmsg); - } - nrows = guessrows; /* we're confident */ - } - } - cm = cm_alloc(guessrows, ncols); - } else - cm = cm_alloc(nrows, ncols); - if (cm == NULL) - return(NULL); - if (dtype == DTascii) { /* read text file */ - int maxrow = (nrows > 0 ? nrows : 32000); - int r, c; - for (r = 0; r < maxrow; r++) { - if (r >= cm->nrows) /* need more space? */ - cm = cm_resize(cm, 2*cm->nrows); - for (c = 0; c < ncols; c++) { - COLORV *cv = cm_lval(cm,r,c); - if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) - if ((nrows <= 0) & (r > 0) & (c == 0)) { - cm = cm_resize(cm, maxrow=r); - break; - } else - goto EOFerror; - } - } - while ((c = getc(fp)) != EOF) - if (!isspace(c)) { - sprintf(errmsg, - "unexpected data at end of ascii file %s", - fname); - error(WARNING, errmsg); - break; - } - } else { /* read binary file */ - if (sizeof(COLORV) == (dtype==DTfloat ? sizeof(float) : - sizeof(double))) { - int nread = 0; - do { /* read all we can */ - nread += fread(cm->cmem + 3*nread, - 3*sizeof(COLORV), - cm->nrows*cm->ncols - nread, - fp); - if (nrows <= 0) { /* unknown length */ - if (nread == cm->nrows*cm->ncols) - /* need more space? */ - cm = cm_resize(cm, 2*cm->nrows); - else if (nread % cm->ncols == 0) - /* seem to be done */ - cm = cm_resize(cm, nread/cm->ncols); - else /* ended mid-row */ - goto EOFerror; - } else if (nread < cm->nrows*cm->ncols) - goto EOFerror; - } while (nread < cm->nrows*cm->ncols); - - } else if (dtype == DTdouble) { - double dc[3]; /* load from double */ - COLORV *cvp = cm->cmem; - int n = nrows*ncols; - - if (n <= 0) - goto not_handled; - while (n--) { - if (fread(dc, sizeof(double), 3, fp) != 3) - goto EOFerror; - copycolor(cvp, dc); - cvp += 3; - } - } else /* dtype == DTfloat */ { - float fc[3]; /* load from float */ - COLORV *cvp = cm->cmem; - int n = nrows*ncols; - - if (n <= 0) - goto not_handled; - while (n--) { - if (fread(fc, sizeof(float), 3, fp) != 3) - goto EOFerror; - copycolor(cvp, fc); - cvp += 3; - } - } - if (getc(fp) != EOF) { - sprintf(errmsg, - "unexpected data at end of binary file %s", - fname); - error(WARNING, errmsg); - } - } - if (fp != stdin) - fclose(fp); - return(cm); -EOFerror: - sprintf(errmsg, "unexpected EOF reading %s", - fname); - error(USER, errmsg); -not_handled: - error(INTERNAL, "unhandled data size or length in cm_load()"); - return(NULL); /* gratis return */ -} - -/* Multiply two matrices (or a matrix and a vector) and allocate the result*/ -static CMATRIX * -cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2) -{ - CMATRIX *cmr; - int dr, dc, i; - - if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows)) - error(INTERNAL, "matrix dimension mismatch in cm_multiply()"); - cmr = cm_alloc(cm1->nrows, cm2->ncols); - if (cmr == NULL) - return(NULL); - for (dr = 0; dr < cmr->nrows; dr++) - for (dc = 0; dc < cmr->ncols; dc++) { - COLORV *dp = cm_lval(cmr,dr,dc); - dp[0] = dp[1] = dp[2] = 0; - for (i = 0; i < cm1->ncols; i++) { - const COLORV *cp1 = cm_lval(cm1,dr,i); - const COLORV *cp2 = cm_lval(cm2,i,dc); - dp[0] += cp1[0] * cp2[0]; - dp[1] += cp1[1] * cp2[1]; - dp[2] += cp1[2] * cp2[2]; - } - } - return(cmr); -} - -/* print out matrix as ASCII text -- no header */ -static void -cm_print(const CMATRIX *cm, FILE *fp) -{ - int r, c; - const COLORV *mp = cm->cmem; - - for (r = 0; r < cm->nrows; r++) { - for (c = 0; c < cm->ncols; c++, mp += 3) - fprintf(fp, "\t%.6e %.6e %.6e", mp[0], mp[1], mp[2]); - fputc('\n', fp); - } -} - -/* convert a BSDF to our matrix representation */ -static CMATRIX * -cm_bsdf(const struct BSDF_data *bsdf) -{ - CMATRIX *cm = cm_alloc(bsdf->nout, bsdf->ninc); - COLORV *mp = cm->cmem; - int nbadohm = 0; - int nneg = 0; - int r, c; - - for (r = 0; r < cm->nrows; r++) - for (c = 0; c < cm->ncols; c++, mp += 3) { - float f = BSDF_value(bsdf,c,r); - float dom = getBSDF_incohm(bsdf,c); - FVECT v; - - if (f <= .0) { - nneg += (f < -FTINY); - continue; - } - if (dom <= .0) { - nbadohm++; - continue; - } - if (!getBSDF_incvec(v,bsdf,c) || v[2] > FTINY) - error(USER, "illegal incoming BTDF direction"); - - mp[0] = mp[1] = mp[2] = f * dom * -v[2]; - } - if (nbadohm | nneg) { - sprintf(errmsg, - "BTDF has %d negatives and %d bad incoming solid angles"); - error(WARNING, errmsg); - } - return(cm); -} - -/* Sum together a set of images and write result to stdout */ -static int -sum_images(const char *fspec, const CMATRIX *cv) -{ + static int runcnt = 0; int myDT = DTfromHeader; - CMATRIX *pmat; - COLOR *scanline; - int myXR, myYR; + COLR *scanline = NULL; + CMATRIX *pmat = NULL; + int myXR=0, myYR=0; int i, y; if (cv->ncols != 1) error(INTERNAL, "expected vector in sum_images()"); - for (i = 0; i < cv->nrows; i++) { - const COLORV *scv = cv_lval(cv,i); + for (i = cv->nrows; i-- > 0; ) { + const int r = runcnt&1 ? i : cv->nrows-1 - i; + const COLORV *scv = cv_lval(cv,r); + int flat_file = 0; char fname[1024]; FILE *fp; + long data_start; int dt, xr, yr; COLORV *psp; + char *err; + /* check for zero */ + if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) && + (myDT != DTfromHeader) | (i > 0)) + continue; /* open next picture */ - sprintf(fname, fspec, i); - if ((fp = fopen(fname, "r")) == NULL) { + sprintf(fname, fspec, r); + if ((fp = fopen(fname, "rb")) == NULL) { sprintf(errmsg, "cannot open picture '%s'", fname); error(SYSTEM, errmsg); } - SET_FILE_BINARY(fp); - dt = getDTfromHeader(fp); +#ifdef getc_unlocked + flockfile(fp); +#endif + dt = DTfromHeader; + if ((err = cm_getheader(&dt, NULL, NULL, NULL, NULL, fp)) != NULL) + error(USER, err); if ((dt != DTrgbe) & (dt != DTxyze) || !fscnresolu(&xr, &yr, fp)) { sprintf(errmsg, "file '%s' not a picture", fname); @@ -360,105 +62,347 @@ sum_images(const char *fspec, const CMATRIX *cv) if (myDT == DTfromHeader) { /* on first one */ myDT = dt; myXR = xr; myYR = yr; - scanline = (COLOR *)malloc(sizeof(COLOR)*myXR); + scanline = (COLR *)malloc(sizeof(COLR)*myXR); if (scanline == NULL) error(SYSTEM, "out of memory in sum_images()"); pmat = cm_alloc(myYR, myXR); memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR); /* finish header */ - fputformat(myDT==DTrgbe ? COLRFMT : CIEFMT, stdout); - fputc('\n', stdout); - fprtresolu(myXR, myYR, stdout); - fflush(stdout); + fputformat(cm_fmt_id[myDT], fout); + fputc('\n', fout); + fflush(fout); } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) { sprintf(errmsg, "picture '%s' format/size mismatch", fname); error(USER, errmsg); } + /* flat file check */ + if ((data_start = ftell(fp)) > 0 && fseek(fp, 0L, SEEK_END) == 0) { + flat_file = (ftell(fp) >= data_start + sizeof(COLR)*xr*yr); + if (fseek(fp, data_start, SEEK_SET) < 0) { + sprintf(errmsg, "cannot seek on picture '%s'", fname); + error(SYSTEM, errmsg); + } + } psp = pmat->cmem; for (y = 0; y < yr; y++) { /* read it in */ + COLOR col; int x; - if (freadscan(scanline, xr, fp) < 0) { + if (flat_file ? getbinary(scanline, sizeof(COLR), xr, fp) != xr : + freadcolrs(scanline, xr, fp) < 0) { sprintf(errmsg, "error reading picture '%s'", fname); error(SYSTEM, errmsg); } /* sum in scanline */ for (x = 0; x < xr; x++, psp += 3) { - multcolor(scanline[x], scv); - addcolor(psp, scanline[x]); + if (!scanline[x][EXP]) + continue; /* skip zeroes */ + colr_color(col, scanline[x]); + multcolor(col, scv); + addcolor(psp, col); } } fclose(fp); /* done this picture */ } free(scanline); - /* write scanlines */ - for (y = 0; y < myYR; y++) - if (fwritescan((COLOR *)cm_lval(pmat, y, 0), myXR, stdout) < 0) - return(0); - cm_free(pmat); /* all done */ - return(fflush(stdout) == 0); + i = cm_write(pmat, myDT, fout); /* write picture */ + cm_free(pmat); /* free data */ + ++runcnt; /* for zig-zagging */ + return(i); } -/* check to see if a string contains a %d specification */ -int -hasDecimalSpec(const char *s) +/* adjust matrix dimensions according to user size(s) */ +static int +alt_dim(CMATRIX *cm, int nr, int nc) { - while (*s && *s != '%') - s++; - if (!*s) + if ((nr <= 0) & (nc <= 0)) return(0); - do - ++s; - while (isdigit(*s)); + if ((nr == cm->nrows) & (nc == cm->ncols)) + return(0); + if (nr > 0) { + if (nc <= 0) + nc = cm->nrows*cm->ncols/nr; + if (nr*nc != cm->nrows*cm->ncols) { + fprintf(stderr, "Bad dimensions: %dx%d != %dx%d\n", + nr, nc, cm->nrows, cm->ncols); + return(-1); + } + } else /* nc > 0 */ { + nr = cm->nrows*cm->ncols/nc; + if (nc*nr != cm->nrows*cm->ncols) { + fprintf(stderr, "Bad dimensions: %d does not divide %dx%d evenly\n", + nc, cm->nrows, cm->ncols); + return(-1); + } + } + cm->nrows = nr; + cm->ncols = nc; + return(1); +} - return(*s == 'd'); +/* check to see if a string contains a %d or %o specification */ +static int +hasNumberFormat(const char *s) +{ + if (s == NULL) + return(0); + + while (*s) { + while (*s != '%') + if (!*s++) + return(0); + if (*++s == '%') { /* ignore "%%" */ + ++s; + continue; + } + while (isdigit(*s)) /* field length */ + ++s; + /* field we'll use? */ + if ((*s == 'd') | (*s == 'i') | (*s == 'o') | + (*s == 'x') | (*s == 'X')) + return(1); + } + return(0); /* didn't find one */ } int main(int argc, char *argv[]) { - CMATRIX *tvec, *Dmat, *Tmat, *ivec, *cvec; - struct BSDF_data *btdf; + int skyfmt = DTfromHeader; + int outfmt = DTascii; + int headout = 1; + int nsteps = 0; + char *ofspec = NULL; + FILE *ofp = stdout; + int xres=0, yres=0; + CMATRIX *cmtx; /* component vector/matrix result */ + char fnbuf[256]; + int a, i; + /* set global progname */ + fixargv0(argv[0]); + /* get options */ + for (a = 1; a < argc && argv[a][0] == '-'; a++) + switch (argv[a][1]) { + case 'n': + nsteps = atoi(argv[++a]); + if (nsteps < 0) + goto userr; + skyfmt = nsteps ? DTascii : DTfromHeader; + break; + case 'h': + headout = !headout; + break; + case 'i': + switch (argv[a][2]) { + case 'f': + skyfmt = DTfloat; + break; + case 'd': + skyfmt = DTdouble; + break; + case 'a': + skyfmt = DTascii; + break; + default: + goto userr; + } + break; + case 'o': + switch (argv[a][2]) { + case '\0': /* output specification (not format) */ + ofspec = argv[++a]; + break; + case 'f': + outfmt = DTfloat; + break; + case 'd': + outfmt = DTdouble; + break; + case 'a': + outfmt = DTascii; + break; + case 'c': + outfmt = DTrgbe; + break; + default: + goto userr; + } + break; + case 'x': + xres = atoi(argv[++a]); + break; + case 'y': + yres = atoi(argv[++a]); + break; + default: + goto userr; + } + if ((argc-a < 1) | (argc-a > 4)) + goto userr; - progname = argv[0]; - - if ((argc < 4) | (argc > 5)) { - fprintf(stderr, "Usage: %s Vspec Tbsdf.xml Dmat.dat [tregvec]\n", - progname); - return(1); + if (argc-a > 2) { /* VTDs expression */ + CMATRIX *smtx, *Dmat, *Tmat, *imtx; + const char *ccp; + /* get sky vector/matrix */ + smtx = cm_load(argv[a+3], 0, nsteps, skyfmt); + nsteps = smtx->ncols; + /* load BSDF */ + if (argv[a+1][0] != '!' && + (ccp = strrchr(argv[a+1], '.')) > argv[a+1] && + !strcasecmp(ccp+1, "XML")) + Tmat = cm_loadBTDF(argv[a+1]); + else + Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader); + /* load Daylight matrix */ + Dmat = cm_load(argv[a+2], Tmat->ncols, + smtx->nrows, DTfromHeader); + /* multiply vector through */ + imtx = cm_multiply(Dmat, smtx); + cm_free(Dmat); cm_free(smtx); + cmtx = cm_multiply(Tmat, imtx); + cm_free(Tmat); + cm_free(imtx); + } else { /* sky vector/matrix only */ + cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt); + nsteps = cmtx->ncols; } - tvec = cm_load(argv[4], 0, 1, DTascii); /* argv[4]==NULL iff argc==4 */ - Dmat = cm_load(argv[3], 0, tvec->nrows, DTfromHeader); - btdf = load_BSDF(argv[2]); - if (btdf == NULL) - return(1); - if (btdf->ninc != Dmat->nrows) { - sprintf(errmsg, "Incoming BTDF dir (%d) mismatch to D (%d)", - btdf->ninc, Dmat->nrows); - error(USER, errmsg); + /* prepare output stream */ + if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) { + sprintf(fnbuf, ofspec, 0); + ofspec = fnbuf; } - /* multiply vector through */ - ivec = cm_multiply(Dmat, tvec); - cm_free(Dmat); cm_free(tvec); - Tmat = cm_bsdf(btdf); /* convert BTDF to matrix */ - free_BSDF(btdf); - cvec = cm_multiply(Tmat, ivec); /* cvec = component vector */ - cm_free(Tmat); cm_free(ivec); - if (hasDecimalSpec(argv[1])) { /* generating image */ - SET_FILE_BINARY(stdout); - newheader("RADIANCE", stdout); - printargs(argc, argv, stdout); - fputnow(stdout); - if (!sum_images(argv[1], cvec)) + if (ofspec != NULL && !hasNumberFormat(ofspec)) { + if ((ofp = fopen(ofspec, "w")) == NULL) { + fprintf(stderr, "%s: cannot open '%s' for output\n", + progname, ofspec); return(1); - } else { /* generating vector */ - CMATRIX *Vmat = cm_load(argv[1], 0, cvec->nrows, DTfromHeader); - CMATRIX *rvec = cm_multiply(Vmat, cvec); + } + ofspec = NULL; /* only need to open once */ + } + if (hasNumberFormat(argv[a])) { /* loading image vector(s) */ + if (outfmt != DTrgbe) { + error(WARNING, "changing output type to -oc"); + outfmt = DTrgbe; + } + if (ofspec == NULL) { + SET_FILE_BINARY(ofp); + newheader("RADIANCE", ofp); + printargs(argc, argv, ofp); + fputnow(ofp); + } + if (nsteps > 1) /* multiple output frames? */ + for (i = 0; i < nsteps; i++) { + CMATRIX *cvec = cm_column(cmtx, i); + if (ofspec != NULL) { + sprintf(fnbuf, ofspec, i); + if ((ofp = fopen(fnbuf, "wb")) == NULL) { + fprintf(stderr, + "%s: cannot open '%s' for output\n", + progname, fnbuf); + return(1); + } + newheader("RADIANCE", ofp); + printargs(argc, argv, ofp); + fputnow(ofp); + } + fprintf(ofp, "FRAME=%d\n", i); + if (!sum_images(argv[a], cvec, ofp)) + return(1); + if (ofspec != NULL) { + if (fclose(ofp) == EOF) { + fprintf(stderr, + "%s: error writing to '%s'\n", + progname, fnbuf); + return(1); + } + ofp = stdout; + } + cm_free(cvec); + } + else if (!sum_images(argv[a], cmtx, ofp)) + return(1); + } else { /* loading view matrix */ + CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader); + CMATRIX *rmtx = cm_multiply(Vmat, cmtx); cm_free(Vmat); - cm_print(rvec, stdout); - cm_free(rvec); + if (ofspec != NULL) { /* multiple vector files? */ + const char *wtype = (outfmt==DTascii) ? "w" : "wb"; + for (i = 0; i < nsteps; i++) { + CMATRIX *rvec = cm_column(rmtx, i); + if (alt_dim(rvec, yres, xres) < 0) + return(1); + sprintf(fnbuf, ofspec, i); + if ((ofp = fopen(fnbuf, wtype)) == NULL) { + fprintf(stderr, + "%s: cannot open '%s' for output\n", + progname, fnbuf); + return(1); + } +#ifdef getc_unlocked + flockfile(ofp); +#endif + if (headout) { /* header output */ + newheader("RADIANCE", ofp); + printargs(argc, argv, ofp); + fputnow(ofp); + fprintf(ofp, "FRAME=%d\n", i); + if ((outfmt != DTrgbe) & (outfmt != DTxyze)) { + fprintf(ofp, "NROWS=%d\n", rvec->nrows); + fprintf(ofp, "NCOLS=%d\n", rvec->ncols); + fputncomp(3, ofp); + } + if ((outfmt == DTfloat) | (outfmt == DTdouble)) + fputendian(ofp); + fputformat(cm_fmt_id[outfmt], ofp); + fputc('\n', ofp); + } + cm_write(rvec, outfmt, ofp); + if (fclose(ofp) == EOF) { + fprintf(stderr, + "%s: error writing to '%s'\n", + progname, fnbuf); + return(1); + } + ofp = stdout; + cm_free(rvec); + } + } else { +#ifdef getc_unlocked + flockfile(ofp); +#endif + if (outfmt != DTascii) + SET_FILE_BINARY(ofp); + if (alt_dim(rmtx, yres, xres) < 0) + return(1); + if (headout) { /* header output */ + newheader("RADIANCE", ofp); + printargs(argc, argv, ofp); + fputnow(ofp); + if ((outfmt != DTrgbe) & (outfmt != DTxyze)) { + fprintf(ofp, "NROWS=%d\n", rmtx->nrows); + fprintf(ofp, "NCOLS=%d\n", rmtx->ncols); + fputncomp(3, ofp); + } + if ((outfmt == DTfloat) | (outfmt == DTdouble)) + fputendian(ofp); + fputformat(cm_fmt_id[outfmt], ofp); + fputc('\n', ofp); + } + cm_write(rmtx, outfmt, ofp); + } + cm_free(rmtx); } - cm_free(cvec); /* final clean-up */ + if (fflush(ofp) == EOF) { /* final clean-up */ + fprintf(stderr, "%s: write error on output\n", progname); + return(1); + } + cm_free(cmtx); return(0); +userr: + fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] DCspec [skyf]\n", + progname); + fprintf(stderr, " or: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] Vspec Tbsdf Dmat.dat [skyf]\n", + progname); + return(1); }
