--- ray/src/util/dctimestep.c 2009/06/17 20:41:47 2.1 +++ ray/src/util/dctimestep.c 2009/06/20 04:27:18 2.5 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: dctimestep.c,v 2.1 2009/06/17 20:41:47 greg Exp $"; +static const char RCSid[] = "$Id: dctimestep.c,v 2.5 2009/06/20 04:27:18 greg Exp $"; #endif /* * Compute time-step result using Daylight Coefficient method. @@ -16,7 +16,7 @@ static const char RCSid[] = "$Id: dctimestep.c,v 2.1 2 char *progname; /* global argv[0] */ -/* Data types for matrix loading */ +/* Data types for file loading */ enum {DTfromHeader, DTascii, DTfloat, DTdouble, DTrgbe, DTxyze}; /* A color coefficient matrix -- vectors have ncols==1 */ @@ -125,7 +125,6 @@ cm_load(const char *fname, int nrows, int ncols, int d break; default: error(USER, "unexpected data type in cm_load()"); - return(NULL); } if (nrows <= 0) { /* don't know length? */ int guessrows = 147; /* usually big enough */ @@ -135,15 +134,21 @@ cm_load(const char *fname, int nrows, int ncols, int d long endpos = ftell(fp); long elemsiz = 3*(dtype==DTfloat ? sizeof(float) : sizeof(double)); - guessrows = (endpos - startpos)/elemsiz; + + if ((endpos - startpos) % (ncols*elemsiz)) { + sprintf(errmsg, + "improper length for binary file '%s'", + fname); + error(USER, errmsg); + } + guessrows = (endpos - startpos)/(ncols*elemsiz); if (fseek(fp, startpos, SEEK_SET) < 0) { sprintf(errmsg, "fseek() error on file '%s'", fname); error(SYSTEM, errmsg); } - if ((endpos - startpos) % elemsiz == 0) - nrows = guessrows; /* confident */ + nrows = guessrows; /* we're confident */ } } cm = cm_alloc(guessrows, ncols); @@ -210,7 +215,6 @@ cm_load(const char *fname, int nrows, int ncols, int d copycolor(cvp, dc); cvp += 3; } - } else /* dtype == DTfloat */ { float fc[3]; /* load from float */ COLORV *cvp = cm->cmem; @@ -291,11 +295,35 @@ cm_bsdf(const struct BSDF_data *bsdf) { CMATRIX *cm = cm_alloc(bsdf->nout, bsdf->ninc); COLORV *mp = cm->cmem; + int nbadohm = 0; + int nneg = 0; int r, c; for (r = 0; r < cm->nrows; r++) - for (c = 0; c < cm->ncols; c++, mp += 3) - mp[0] = mp[1] = mp[2] = BSDF_value(bsdf,c,r); + for (c = 0; c < cm->ncols; c++, mp += 3) { + float f = BSDF_value(bsdf,c,r); + float dom = getBSDF_incohm(bsdf,c); + FVECT v; + + if (f <= .0) { + nneg += (f < -FTINY); + continue; + } + if (dom <= .0) { + nbadohm++; + continue; + } + if (!getBSDF_incvec(v,bsdf,c) || v[2] > FTINY) + error(USER, "illegal incoming BTDF direction"); + + mp[0] = mp[1] = mp[2] = f * dom * -v[2]; + } + if (nneg || nbadohm) { + sprintf(errmsg, + "BTDF has %d negatives and %d bad incoming solid angles", + nneg, nbadohm); + error(WARNING, errmsg); + } return(cm); } @@ -338,6 +366,11 @@ sum_images(const char *fspec, const CMATRIX *cv) error(SYSTEM, "out of memory in sum_images()"); pmat = cm_alloc(myYR, myXR); memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR); + /* finish header */ + fputformat(myDT==DTrgbe ? COLRFMT : CIEFMT, stdout); + fputc('\n', stdout); + fprtresolu(myXR, myYR, stdout); + fflush(stdout); } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) { sprintf(errmsg, "picture '%s' format/size mismatch", fname); @@ -360,10 +393,6 @@ sum_images(const char *fspec, const CMATRIX *cv) fclose(fp); /* done this picture */ } free(scanline); - /* finish header */ - fputformat(myDT==DTrgbe ? COLRFMT : CIEFMT, stdout); - fputc('\n', stdout); - fprtresolu(myXR, myYR, stdout); /* write scanlines */ for (y = 0; y < myYR; y++) if (fwritescan((COLOR *)cm_lval(pmat, y, 0), myXR, stdout) < 0) @@ -390,7 +419,7 @@ hasDecimalSpec(const char *s) int main(int argc, char *argv[]) { - CMATRIX *tvec, *Dmat, *Tmat, *vtmp, *cvec; + CMATRIX *tvec, *Dmat, *Tmat, *ivec, *cvec; struct BSDF_data *btdf; progname = argv[0]; @@ -400,23 +429,21 @@ main(int argc, char *argv[]) progname); return(1); } + /* load Tregenza vector */ tvec = cm_load(argv[4], 0, 1, DTascii); /* argv[4]==NULL iff argc==4 */ - Dmat = cm_load(argv[3], 0, tvec->nrows, DTfromHeader); + /* load BTDF */ btdf = load_BSDF(argv[2]); if (btdf == NULL) return(1); - if (btdf->ninc != Dmat->nrows) { - sprintf(errmsg, "Incoming BTDF dir (%d) mismatch to D (%d)", - btdf->ninc, Dmat->nrows); - error(USER, errmsg); - } + /* load Daylight matrix */ + Dmat = cm_load(argv[3], btdf->ninc, tvec->nrows, DTfromHeader); /* multiply vector through */ - vtmp = cm_multiply(Dmat, tvec); + ivec = cm_multiply(Dmat, tvec); cm_free(Dmat); cm_free(tvec); Tmat = cm_bsdf(btdf); /* convert BTDF to matrix */ free_BSDF(btdf); - cvec = cm_multiply(Tmat, vtmp); /* cvec = component vector */ - cm_free(Tmat); cm_free(vtmp); + cvec = cm_multiply(Tmat, ivec); /* cvec = component vector */ + cm_free(Tmat); cm_free(ivec); if (hasDecimalSpec(argv[1])) { /* generating image */ SET_FILE_BINARY(stdout); newheader("RADIANCE", stdout);
