--- ray/src/util/dctimestep.c 2022/03/11 02:27:02 2.47 +++ ray/src/util/dctimestep.c 2022/03/11 02:44:33 2.49 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: dctimestep.c,v 2.47 2022/03/11 02:27:02 greg Exp $"; +static const char RCSid[] = "$Id: dctimestep.c,v 2.49 2022/03/11 02:44:33 greg Exp $"; #endif /* * Compute time-step result using Daylight Coefficient method. @@ -107,6 +107,35 @@ sum_images(const char *fspec, const CMATRIX *cv, FILE return(i); } +/* adjust matrix dimensions according to user size(s) */ +static int +alt_dim(CMATRIX *cm, int nr, int nc) +{ + if ((nr <= 0) & (nc <= 0)) + return(0); + if ((nr == cm->nrows) & (nc == cm->ncols)) + return(0); + if (nr > 0) { + if (nc <= 0) + nc = cm->nrows*cm->ncols/nr; + if (nr*nc != cm->nrows*cm->ncols) { + fprintf(stderr, "Bad dimensions: %dx%d != %dx%d\n", + nr, nc, cm->nrows, cm->ncols); + return(-1); + } + } else /* nc > 0 */ { + nr = cm->nrows*cm->ncols/nc; + if (nc*nr != cm->nrows*cm->ncols) { + fprintf(stderr, "Bad dimensions: %d does not divide %dx%d evenly\n", + nc, cm->nrows, cm->ncols); + return(-1); + } + } + cm->nrows = nr; + cm->ncols = nc; + return(1); +} + /* check to see if a string contains a %d or %o specification */ static int hasNumberFormat(const char *s) @@ -296,27 +325,8 @@ main(int argc, char *argv[]) const char *wtype = (outfmt==DTascii) ? "w" : "wb"; for (i = 0; i < nsteps; i++) { CMATRIX *rvec = cm_column(rmtx, i); - if (yres > 0) { - if (xres <= 0) - xres = rvec->nrows/yres; - if (xres*yres != rvec->nrows) { - fprintf(stderr, "Bad resolution: %d != %dx%d\n", - rvec->nrows, xres, yres); - return(1); - } - rvec->nrows = yres; - rvec->ncols = xres; - } else if (xres > 0) { - yres = rvec->nrows/xres; - if (xres*yres != rvec->nrows) { - fprintf(stderr, - "Bad resolution: %d does not divide %d evenly\n", - xres, rvec->nrows); - return(1); - } - rvec->nrows = yres; - rvec->ncols = xres; - } + if (alt_dim(rvec, yres, xres) < 0) + return(1); sprintf(fnbuf, ofspec, i); if ((ofp = fopen(fnbuf, wtype)) == NULL) { fprintf(stderr, @@ -358,6 +368,8 @@ main(int argc, char *argv[]) #endif if (outfmt != DTascii) SET_FILE_BINARY(ofp); + if (alt_dim(rmtx, yres, xres) < 0) + return(1); if (headout) { /* header output */ newheader("RADIANCE", ofp); printargs(argc, argv, ofp); @@ -383,9 +395,9 @@ main(int argc, char *argv[]) cm_free(cmtx); return(0); userr: - fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d|c}] DCspec [skyf]\n", + fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] DCspec [skyf]\n", progname); - fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d|c}] Vspec Tbsdf Dmat.dat [skyf]\n", + fprintf(stderr, " or: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] Vspec Tbsdf Dmat.dat [skyf]\n", progname); return(1); }
