--- ray/src/util/dctimestep.c 2014/09/26 23:33:09 2.35 +++ ray/src/util/dctimestep.c 2019/08/14 18:20:02 2.41 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: dctimestep.c,v 2.35 2014/09/26 23:33:09 greg Exp $"; +static const char RCSid[] = "$Id: dctimestep.c,v 2.41 2019/08/14 18:20:02 greg Exp $"; #endif /* * Compute time-step result using Daylight Coefficient method. @@ -8,6 +8,7 @@ static const char RCSid[] = "$Id: dctimestep.c,v 2.35 */ #include +#include "platform.h" #include "standard.h" #include "cmatrix.h" #include "platform.h" @@ -20,7 +21,7 @@ static int sum_images(const char *fspec, const CMATRIX *cv, FILE *fout) { int myDT = DTfromHeader; - COLOR *scanline = NULL; + COLR *scanline = NULL; CMATRIX *pmat = NULL; int myXR=0, myYR=0; int i, y; @@ -29,8 +30,10 @@ sum_images(const char *fspec, const CMATRIX *cv, FILE error(INTERNAL, "expected vector in sum_images()"); for (i = 0; i < cv->nrows; i++) { const COLORV *scv = cv_lval(cv,i); + int flat_file = 0; char fname[1024]; FILE *fp; + long data_start; int dt, xr, yr; COLORV *psp; char *err; @@ -45,7 +48,7 @@ sum_images(const char *fspec, const CMATRIX *cv, FILE error(SYSTEM, errmsg); } dt = DTfromHeader; - if ((err = cm_getheader(&dt, NULL, NULL, fp)) != NULL) + if ((err = cm_getheader(&dt, NULL, NULL, NULL, fp)) != NULL) error(USER, err); if ((dt != DTrgbe) & (dt != DTxyze) || !fscnresolu(&xr, &yr, fp)) { @@ -55,7 +58,7 @@ sum_images(const char *fspec, const CMATRIX *cv, FILE if (myDT == DTfromHeader) { /* on first one */ myDT = dt; myXR = xr; myYR = yr; - scanline = (COLOR *)malloc(sizeof(COLOR)*myXR); + scanline = (COLR *)malloc(sizeof(COLR)*myXR); if (scanline == NULL) error(SYSTEM, "out of memory in sum_images()"); pmat = cm_alloc(myYR, myXR); @@ -69,18 +72,31 @@ sum_images(const char *fspec, const CMATRIX *cv, FILE fname); error(USER, errmsg); } + /* flat file check */ + if ((data_start = ftell(fp)) > 0 && fseek(fp, 0L, SEEK_END) == 0) { + flat_file = (ftell(fp) == data_start + sizeof(COLR)*xr*yr); + if (fseek(fp, data_start, SEEK_SET) < 0) { + sprintf(errmsg, "cannot seek on picture '%s'", fname); + error(SYSTEM, errmsg); + } + } psp = pmat->cmem; for (y = 0; y < yr; y++) { /* read it in */ + COLOR col; int x; - if (freadscan(scanline, xr, fp) < 0) { + if (flat_file ? getbinary(scanline, sizeof(COLR), xr, fp) != xr : + freadcolrs(scanline, xr, fp) < 0) { sprintf(errmsg, "error reading picture '%s'", fname); error(SYSTEM, errmsg); } /* sum in scanline */ for (x = 0; x < xr; x++, psp += 3) { - multcolor(scanline[x], scv); - addcolor(psp, scanline[x]); + if (!scanline[x][EXP]) + continue; /* skip zeroes */ + colr_color(col, scanline[x]); + multcolor(col, scv); + addcolor(psp, col); } } fclose(fp); /* done this picture */ @@ -182,14 +198,20 @@ main(int argc, char *argv[]) goto userr; if (argc-a > 2) { /* VTDs expression */ - CMATRIX *smtx, *Dmat, *Tmat, *imtx; + CMATRIX *smtx, *Dmat, *Tmat, *imtx; + const char *ccp; /* get sky vector/matrix */ smtx = cm_load(argv[a+3], 0, nsteps, skyfmt); nsteps = smtx->ncols; /* load BSDF */ - Tmat = cm_loadBTDF(argv[a+1]); + if (argv[a+1][0] != '!' && + (ccp = strrchr(argv[a+1], '.')) != NULL && + !strcasecmp(ccp+1, "XML")) + Tmat = cm_loadBTDF(argv[a+1]); + else + Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader); /* load Daylight matrix */ - Dmat = cm_load(argv[a+2], Tmat==NULL ? 0 : Tmat->ncols, + Dmat = cm_load(argv[a+2], Tmat->ncols, smtx->nrows, DTfromHeader); /* multiply vector through */ imtx = cm_multiply(Dmat, smtx); @@ -225,7 +247,7 @@ main(int argc, char *argv[]) for (i = 0; i < nsteps; i++) { CMATRIX *cvec = cm_column(cmtx, i); if (ofspec != NULL) { - sprintf(fnbuf, ofspec, i+1); + sprintf(fnbuf, ofspec, i); if ((ofp = fopen(fnbuf, "wb")) == NULL) { fprintf(stderr, "%s: cannot open '%s' for output\n", @@ -236,7 +258,7 @@ main(int argc, char *argv[]) printargs(argc, argv, ofp); fputnow(ofp); } - fprintf(ofp, "FRAME=%d\n", i+1); + fprintf(ofp, "FRAME=%d\n", i); if (!sum_images(argv[a], cvec, ofp)) return(1); if (ofspec != NULL) { @@ -260,7 +282,7 @@ main(int argc, char *argv[]) const char *wtype = (outfmt==DTascii) ? "w" : "wb"; for (i = 0; i < nsteps; i++) { CMATRIX *rvec = cm_column(rmtx, i); - sprintf(fnbuf, ofspec, i+1); + sprintf(fnbuf, ofspec, i); if ((ofp = fopen(fnbuf, wtype)) == NULL) { fprintf(stderr, "%s: cannot open '%s' for output\n", @@ -274,7 +296,7 @@ main(int argc, char *argv[]) newheader("RADIANCE", ofp); printargs(argc, argv, ofp); fputnow(ofp); - fprintf(ofp, "FRAME=%d\n", i+1); + fprintf(ofp, "FRAME=%d\n", i); fprintf(ofp, "NROWS=%d\n", rvec->nrows); fputs("NCOLS=1\nNCOMP=3\n", ofp); fputformat((char *)cm_fmt_id[outfmt], ofp); @@ -319,7 +341,7 @@ main(int argc, char *argv[]) userr: fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] DCspec [skyf]\n", progname); - fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] Vspec Tbsdf.xml Dmat.dat [skyf]\n", + fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] Vspec Tbsdf Dmat.dat [skyf]\n", progname); return(1); }
