--- ray/src/util/dctimestep.c 2014/06/01 03:20:29 2.33 +++ ray/src/util/dctimestep.c 2014/09/17 22:40:49 2.34 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: dctimestep.c,v 2.33 2014/06/01 03:20:29 greg Exp $"; +static const char RCSid[] = "$Id: dctimestep.c,v 2.34 2014/09/17 22:40:49 greg Exp $"; #endif /* * Compute time-step result using Daylight Coefficient method. @@ -119,9 +119,10 @@ hasNumberFormat(const char *s) int main(int argc, char *argv[]) { - int skyfmt = DTascii; + int skyfmt = DTfromHeader; int outfmt = DTascii; - int nsteps = 1; + int headout = 1; + int nsteps = 0; char *ofspec = NULL; FILE *ofp = stdout; CMATRIX *cmtx; /* component vector/matrix result */ @@ -136,7 +137,11 @@ main(int argc, char *argv[]) nsteps = atoi(argv[++a]); if (nsteps < 0) goto userr; + skyfmt = nsteps ? DTascii : DTfromHeader; break; + case 'h': + headout = !headout; + break; case 'i': switch (argv[a][2]) { case 'f': @@ -148,9 +153,6 @@ main(int argc, char *argv[]) case 'a': skyfmt = DTascii; break; - case 'h': - skyfmt = DTfromHeader; - break; default: goto userr; } @@ -266,6 +268,16 @@ main(int argc, char *argv[]) #ifdef getc_unlocked flockfile(ofp); #endif + if (headout) { /* header output */ + newheader("RADIANCE", ofp); + printargs(argc, argv, ofp); + fputnow(ofp); + fprintf(ofp, "FRAME=%d\n", i+1); + fprintf(ofp, "NROWS=%d\n", rvec->nrows); + fputs("NCOLS=1\nNCOMP=3\n", ofp); + fputformat((char *)cm_fmt_id[outfmt], ofp); + fputc('\n', ofp); + } cm_write(rvec, outfmt, ofp); if (fclose(ofp) == EOF) { fprintf(stderr, @@ -282,7 +294,7 @@ main(int argc, char *argv[]) #endif if (outfmt != DTascii) SET_FILE_BINARY(ofp); - if (rmtx->ncols > 1) { /* header if actual matrix */ + if (headout) { /* header output */ newheader("RADIANCE", ofp); printargs(argc, argv, ofp); fputnow(ofp);
