--- ray/src/util/dctimestep.c 2014/01/20 22:18:29 2.29 +++ ray/src/util/dctimestep.c 2022/03/03 03:55:13 2.46 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: dctimestep.c,v 2.29 2014/01/20 22:18:29 greg Exp $"; +static const char RCSid[] = "$Id: dctimestep.c,v 2.46 2022/03/03 03:55:13 greg Exp $"; #endif /* * Compute time-step result using Daylight Coefficient method. @@ -8,6 +8,7 @@ static const char RCSid[] = "$Id: dctimestep.c,v 2.29 */ #include +#include "platform.h" #include "standard.h" #include "cmatrix.h" #include "platform.h" @@ -20,7 +21,7 @@ static int sum_images(const char *fspec, const CMATRIX *cv, FILE *fout) { int myDT = DTfromHeader; - COLOR *scanline = NULL; + COLR *scanline = NULL; CMATRIX *pmat = NULL; int myXR=0, myYR=0; int i, y; @@ -29,22 +30,26 @@ sum_images(const char *fspec, const CMATRIX *cv, FILE error(INTERNAL, "expected vector in sum_images()"); for (i = 0; i < cv->nrows; i++) { const COLORV *scv = cv_lval(cv,i); + int flat_file = 0; char fname[1024]; FILE *fp; + long data_start; int dt, xr, yr; COLORV *psp; + char *err; /* check for zero */ if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) && (myDT != DTfromHeader) | (i < cv->nrows-1)) continue; /* open next picture */ sprintf(fname, fspec, i); - if ((fp = fopen(fname, "r")) == NULL) { + if ((fp = fopen(fname, "rb")) == NULL) { sprintf(errmsg, "cannot open picture '%s'", fname); error(SYSTEM, errmsg); } - SET_FILE_BINARY(fp); - dt = getDTfromHeader(fp); + dt = DTfromHeader; + if ((err = cm_getheader(&dt, NULL, NULL, NULL, NULL, fp)) != NULL) + error(USER, err); if ((dt != DTrgbe) & (dt != DTxyze) || !fscnresolu(&xr, &yr, fp)) { sprintf(errmsg, "file '%s' not a picture", fname); @@ -53,44 +58,53 @@ sum_images(const char *fspec, const CMATRIX *cv, FILE if (myDT == DTfromHeader) { /* on first one */ myDT = dt; myXR = xr; myYR = yr; - scanline = (COLOR *)malloc(sizeof(COLOR)*myXR); + scanline = (COLR *)malloc(sizeof(COLR)*myXR); if (scanline == NULL) error(SYSTEM, "out of memory in sum_images()"); pmat = cm_alloc(myYR, myXR); memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR); /* finish header */ - fputformat(myDT==DTrgbe ? COLRFMT : CIEFMT, fout); + fputformat(cm_fmt_id[myDT], fout); fputc('\n', fout); - fprtresolu(myXR, myYR, fout); fflush(fout); } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) { sprintf(errmsg, "picture '%s' format/size mismatch", fname); error(USER, errmsg); } + /* flat file check */ + if ((data_start = ftell(fp)) > 0 && fseek(fp, 0L, SEEK_END) == 0) { + flat_file = (ftell(fp) == data_start + sizeof(COLR)*xr*yr); + if (fseek(fp, data_start, SEEK_SET) < 0) { + sprintf(errmsg, "cannot seek on picture '%s'", fname); + error(SYSTEM, errmsg); + } + } psp = pmat->cmem; for (y = 0; y < yr; y++) { /* read it in */ + COLOR col; int x; - if (freadscan(scanline, xr, fp) < 0) { + if (flat_file ? getbinary(scanline, sizeof(COLR), xr, fp) != xr : + freadcolrs(scanline, xr, fp) < 0) { sprintf(errmsg, "error reading picture '%s'", fname); error(SYSTEM, errmsg); } /* sum in scanline */ for (x = 0; x < xr; x++, psp += 3) { - multcolor(scanline[x], scv); - addcolor(psp, scanline[x]); + if (!scanline[x][EXP]) + continue; /* skip zeroes */ + colr_color(col, scanline[x]); + multcolor(col, scv); + addcolor(psp, col); } } fclose(fp); /* done this picture */ } free(scanline); - /* write scanlines */ - for (y = 0; y < myYR; y++) - if (fwritescan((COLOR *)cm_lval(pmat, y, 0), myXR, fout) < 0) - return(0); - cm_free(pmat); /* all done */ - return(fflush(fout) == 0); + i = cm_write(pmat, myDT, fout); /* write picture */ + cm_free(pmat); /* free data */ + return(i); } /* check to see if a string contains a %d or %o specification */ @@ -121,8 +135,10 @@ hasNumberFormat(const char *s) int main(int argc, char *argv[]) { - int skyfmt = DTascii; - int nsteps = 1; + int skyfmt = DTfromHeader; + int outfmt = DTascii; + int headout = 1; + int nsteps = 0; char *ofspec = NULL; FILE *ofp = stdout; CMATRIX *cmtx; /* component vector/matrix result */ @@ -135,11 +151,12 @@ main(int argc, char *argv[]) switch (argv[a][1]) { case 'n': nsteps = atoi(argv[++a]); - if (nsteps <= 0) + if (nsteps < 0) goto userr; + skyfmt = nsteps ? DTascii : DTfromHeader; break; - case 'o': - ofspec = argv[++a]; + case 'h': + headout = !headout; break; case 'i': switch (argv[a][2]) { @@ -156,6 +173,27 @@ main(int argc, char *argv[]) goto userr; } break; + case 'o': + switch (argv[a][2]) { + case '\0': /* output specification (not format) */ + ofspec = argv[++a]; + break; + case 'f': + outfmt = DTfloat; + break; + case 'd': + outfmt = DTdouble; + break; + case 'a': + outfmt = DTascii; + break; + case 'c': + outfmt = DTrgbe; + break; + default: + goto userr; + } + break; default: goto userr; } @@ -163,13 +201,20 @@ main(int argc, char *argv[]) goto userr; if (argc-a > 2) { /* VTDs expression */ - CMATRIX *smtx, *Dmat, *Tmat, *imtx; + CMATRIX *smtx, *Dmat, *Tmat, *imtx; + const char *ccp; /* get sky vector/matrix */ smtx = cm_load(argv[a+3], 0, nsteps, skyfmt); + nsteps = smtx->ncols; /* load BSDF */ - Tmat = cm_loadBTDF(argv[a+1]); + if (argv[a+1][0] != '!' && + (ccp = strrchr(argv[a+1], '.')) != NULL && + !strcasecmp(ccp+1, "XML")) + Tmat = cm_loadBTDF(argv[a+1]); + else + Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader); /* load Daylight matrix */ - Dmat = cm_load(argv[a+2], Tmat==NULL ? 0 : Tmat->ncols, + Dmat = cm_load(argv[a+2], Tmat->ncols, smtx->nrows, DTfromHeader); /* multiply vector through */ imtx = cm_multiply(Dmat, smtx); @@ -179,6 +224,7 @@ main(int argc, char *argv[]) cm_free(imtx); } else { /* sky vector/matrix only */ cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt); + nsteps = cmtx->ncols; } /* prepare output stream */ if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) { @@ -194,6 +240,10 @@ main(int argc, char *argv[]) ofspec = NULL; /* only need to open once */ } if (hasNumberFormat(argv[a])) { /* generating image(s) */ + if (outfmt != DTrgbe) { + error(WARNING, "changing output type to -oc"); + outfmt = DTrgbe; + } if (ofspec == NULL) { SET_FILE_BINARY(ofp); newheader("RADIANCE", ofp); @@ -204,7 +254,7 @@ main(int argc, char *argv[]) for (i = 0; i < nsteps; i++) { CMATRIX *cvec = cm_column(cmtx, i); if (ofspec != NULL) { - sprintf(fnbuf, ofspec, i+1); + sprintf(fnbuf, ofspec, i); if ((ofp = fopen(fnbuf, "wb")) == NULL) { fprintf(stderr, "%s: cannot open '%s' for output\n", @@ -215,7 +265,7 @@ main(int argc, char *argv[]) printargs(argc, argv, ofp); fputnow(ofp); } - fprintf(ofp, "FRAME=%d\n", i+1); + fprintf(ofp, "FRAME=%d\n", i); if (!sum_images(argv[a], cvec, ofp)) return(1); if (ofspec != NULL) { @@ -235,17 +285,33 @@ main(int argc, char *argv[]) CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader); CMATRIX *rmtx = cm_multiply(Vmat, cmtx); cm_free(Vmat); - if (ofspec != NULL) /* multiple vector files? */ + if (ofspec != NULL) { /* multiple vector files? */ + const char *wtype = (outfmt==DTascii) ? "w" : "wb"; for (i = 0; i < nsteps; i++) { CMATRIX *rvec = cm_column(rmtx, i); - sprintf(fnbuf, ofspec, i+1); - if ((ofp = fopen(fnbuf, "w")) == NULL) { + sprintf(fnbuf, ofspec, i); + if ((ofp = fopen(fnbuf, wtype)) == NULL) { fprintf(stderr, "%s: cannot open '%s' for output\n", progname, fnbuf); return(1); } - cm_print(rvec, ofp); +#ifdef getc_unlocked + flockfile(ofp); +#endif + if (headout) { /* header output */ + newheader("RADIANCE", ofp); + printargs(argc, argv, ofp); + fputnow(ofp); + fprintf(ofp, "FRAME=%d\n", i); + fprintf(ofp, "NROWS=%d\n", rvec->nrows); + fputs("NCOLS=1\nNCOMP=3\n", ofp); + if ((outfmt == 'f') | (outfmt == 'd')) + fputendian(ofp); + fputformat(cm_fmt_id[outfmt], ofp); + fputc('\n', ofp); + } + cm_write(rvec, outfmt, ofp); if (fclose(ofp) == EOF) { fprintf(stderr, "%s: error writing to '%s'\n", @@ -255,8 +321,26 @@ main(int argc, char *argv[]) ofp = stdout; cm_free(rvec); } - else - cm_print(rmtx, ofp); + } else { +#ifdef getc_unlocked + flockfile(ofp); +#endif + if (outfmt != DTascii) + SET_FILE_BINARY(ofp); + if (headout) { /* header output */ + newheader("RADIANCE", ofp); + printargs(argc, argv, ofp); + fputnow(ofp); + fprintf(ofp, "NROWS=%d\n", rmtx->nrows); + fprintf(ofp, "NCOLS=%d\n", rmtx->ncols); + fputs("NCOMP=3\n", ofp); + if ((outfmt == 'f') | (outfmt == 'd')) + fputendian(ofp); + fputformat(cm_fmt_id[outfmt], ofp); + fputc('\n', ofp); + } + cm_write(rmtx, outfmt, ofp); + } cm_free(rmtx); } if (fflush(ofp) == EOF) { /* final clean-up */ @@ -266,9 +350,9 @@ main(int argc, char *argv[]) cm_free(cmtx); return(0); userr: - fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-i{f|d}] DCspec [skyf]\n", + fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d|c}] DCspec [skyf]\n", progname); - fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d}] Vspec Tbsdf.xml Dmat.dat [skyf]\n", + fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d|c}] Vspec Tbsdf Dmat.dat [skyf]\n", progname); return(1); }
