--- ray/src/util/dctimestep.c 2013/01/11 17:54:17 2.26 +++ ray/src/util/dctimestep.c 2019/08/14 18:20:02 2.41 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: dctimestep.c,v 2.26 2013/01/11 17:54:17 greg Exp $"; +static const char RCSid[] = "$Id: dctimestep.c,v 2.41 2019/08/14 18:20:02 greg Exp $"; #endif /* * Compute time-step result using Daylight Coefficient method. @@ -8,491 +8,20 @@ static const char RCSid[] = "$Id: dctimestep.c,v 2.26 */ #include +#include "platform.h" #include "standard.h" +#include "cmatrix.h" #include "platform.h" -#include "paths.h" -#include "color.h" #include "resolu.h" -#include "bsdf.h" -#include "bsdf_m.h" char *progname; /* global argv[0] */ -/* Data types for file loading */ -enum {DTfromHeader, DTascii, DTfloat, DTdouble, DTrgbe, DTxyze}; - -/* A color coefficient matrix -- vectors have ncols==1 */ -typedef struct { - int nrows, ncols; - COLORV cmem[3]; /* extends struct */ -} CMATRIX; - -#define COLSPEC (sizeof(COLORV)==sizeof(float) ? "%f %f %f" : "%lf %lf %lf") - -#define cm_lval(cm,r,c) ((cm)->cmem + 3*((r)*(cm)->ncols + (c))) - -#define cv_lval(cm,i) ((cm)->cmem + 3*(i)) - -/* Allocate a color coefficient matrix */ -static CMATRIX * -cm_alloc(int nrows, int ncols) -{ - CMATRIX *cm; - - if ((nrows <= 0) | (ncols <= 0)) - error(USER, "attempt to create empty matrix"); - cm = (CMATRIX *)malloc(sizeof(CMATRIX) + - 3*sizeof(COLORV)*(nrows*ncols - 1)); - if (cm == NULL) - error(SYSTEM, "out of memory in cm_alloc()"); - cm->nrows = nrows; - cm->ncols = ncols; - return(cm); -} - -#define cm_free(cm) free(cm) - -/* Resize color coefficient matrix */ -static CMATRIX * -cm_resize(CMATRIX *cm, int nrows) -{ - if (nrows == cm->nrows) - return(cm); - if (nrows <= 0) { - cm_free(cm); - return(NULL); - } - cm = (CMATRIX *)realloc(cm, sizeof(CMATRIX) + - 3*sizeof(COLORV)*(nrows*cm->ncols - 1)); - if (cm == NULL) - error(SYSTEM, "out of memory in cm_resize()"); - cm->nrows = nrows; - return(cm); -} - -/* Load header to obtain data type */ -static int -getDT(char *s, void *p) -{ - char fmt[32]; - - if (formatval(fmt, s)) { - if (!strcmp(fmt, "ascii")) - *((int *)p) = DTascii; - else if (!strcmp(fmt, "float")) - *((int *)p) = DTfloat; - else if (!strcmp(fmt, "double")) - *((int *)p) = DTdouble; - else if (!strcmp(fmt, COLRFMT)) - *((int *)p) = DTrgbe; - else if (!strcmp(fmt, CIEFMT)) - *((int *)p) = DTxyze; - } - return(0); -} - -static int -getDTfromHeader(FILE *fp) -{ - int dt = DTfromHeader; - - if (getheader(fp, getDT, &dt) < 0) - error(SYSTEM, "header read error"); - if (dt == DTfromHeader) - error(USER, "missing data format in header"); - return(dt); -} - -/* Allocate and load a matrix from the given file (or stdin if NULL) */ -static CMATRIX * -cm_load(const char *fname, int nrows, int ncols, int dtype) -{ - FILE *fp = stdin; - CMATRIX *cm; - - if (ncols <= 0) - error(USER, "Non-positive number of columns"); - if (fname == NULL) - fname = ""; - else if ((fp = fopen(fname, "r")) == NULL) { - sprintf(errmsg, "cannot open file '%s'", fname); - error(SYSTEM, errmsg); - } -#ifdef getc_unlocked - flockfile(fp); -#endif - if (dtype != DTascii) - SET_FILE_BINARY(fp); /* doesn't really work */ - if (dtype == DTfromHeader) - dtype = getDTfromHeader(fp); - switch (dtype) { - case DTascii: - case DTfloat: - case DTdouble: - break; - default: - error(USER, "unexpected data type in cm_load()"); - } - if (nrows <= 0) { /* don't know length? */ - int guessrows = 147; /* usually big enough */ - if ((dtype != DTascii) & (fp != stdin)) { - long startpos = ftell(fp); - if (fseek(fp, 0L, SEEK_END) == 0) { - long endpos = ftell(fp); - long elemsiz = 3*(dtype==DTfloat ? - sizeof(float) : sizeof(double)); - - if ((endpos - startpos) % (ncols*elemsiz)) { - sprintf(errmsg, - "improper length for binary file '%s'", - fname); - error(USER, errmsg); - } - guessrows = (endpos - startpos)/(ncols*elemsiz); - if (fseek(fp, startpos, SEEK_SET) < 0) { - sprintf(errmsg, - "fseek() error on file '%s'", - fname); - error(SYSTEM, errmsg); - } - nrows = guessrows; /* we're confident */ - } - } - cm = cm_alloc(guessrows, ncols); - } else - cm = cm_alloc(nrows, ncols); - if (cm == NULL) /* XXX never happens */ - return(NULL); - if (dtype == DTascii) { /* read text file */ - int maxrow = (nrows > 0 ? nrows : 32000); - int r, c; - for (r = 0; r < maxrow; r++) { - if (r >= cm->nrows) /* need more space? */ - cm = cm_resize(cm, 2*cm->nrows); - for (c = 0; c < ncols; c++) { - COLORV *cv = cm_lval(cm,r,c); - if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) - if ((nrows <= 0) & (r > 0) & !c) { - cm = cm_resize(cm, maxrow=r); - break; - } else - goto EOFerror; - } - } - while ((c = getc(fp)) != EOF) - if (!isspace(c)) { - sprintf(errmsg, - "unexpected data at end of ascii file %s", - fname); - error(WARNING, errmsg); - break; - } - } else { /* read binary file */ - if (sizeof(COLORV) == (dtype==DTfloat ? sizeof(float) : - sizeof(double))) { - int nread = 0; - do { /* read all we can */ - nread += fread(cm->cmem + 3*nread, - 3*sizeof(COLORV), - cm->nrows*cm->ncols - nread, - fp); - if (nrows <= 0) { /* unknown length */ - if (nread == cm->nrows*cm->ncols) - /* need more space? */ - cm = cm_resize(cm, 2*cm->nrows); - else if (nread && !(nread % cm->ncols)) - /* seem to be done */ - cm = cm_resize(cm, nread/cm->ncols); - else /* ended mid-row */ - goto EOFerror; - } else if (nread < cm->nrows*cm->ncols) - goto EOFerror; - } while (nread < cm->nrows*cm->ncols); - - } else if (dtype == DTdouble) { - double dc[3]; /* load from double */ - COLORV *cvp = cm->cmem; - int n = nrows*ncols; - - if (n <= 0) - goto not_handled; - while (n--) { - if (fread(dc, sizeof(double), 3, fp) != 3) - goto EOFerror; - copycolor(cvp, dc); - cvp += 3; - } - } else /* dtype == DTfloat */ { - float fc[3]; /* load from float */ - COLORV *cvp = cm->cmem; - int n = nrows*ncols; - - if (n <= 0) - goto not_handled; - while (n--) { - if (fread(fc, sizeof(float), 3, fp) != 3) - goto EOFerror; - copycolor(cvp, fc); - cvp += 3; - } - } - if (fgetc(fp) != EOF) { - sprintf(errmsg, - "unexpected data at end of binary file %s", - fname); - error(WARNING, errmsg); - } - } - if (fp != stdin) - fclose(fp); -#ifdef getc_unlocked - else - funlockfile(fp); -#endif - return(cm); -EOFerror: - sprintf(errmsg, "unexpected EOF reading %s", fname); - error(USER, errmsg); -not_handled: - error(INTERNAL, "unhandled data size or length in cm_load()"); - return(NULL); /* gratis return */ -} - -/* Extract a column vector from a matrix */ -static CMATRIX * -cm_column(const CMATRIX *cm, int c) -{ - CMATRIX *cvr; - int dr; - - if ((c < 0) | (c >= cm->ncols)) - error(INTERNAL, "column requested outside matrix"); - cvr = cm_alloc(cm->nrows, 1); - if (cvr == NULL) - return(NULL); - for (dr = 0; dr < cm->nrows; dr++) { - const COLORV *sp = cm_lval(cm,dr,c); - COLORV *dp = cv_lval(cvr,dr); - dp[0] = sp[0]; - dp[1] = sp[1]; - dp[2] = sp[2]; - } - return(cvr); -} - -/* Scale a matrix by a single value */ -static CMATRIX * -cm_scale(const CMATRIX *cm1, const COLOR sca) -{ - CMATRIX *cmr; - int dr, dc; - - cmr = cm_alloc(cm1->nrows, cm1->ncols); - if (cmr == NULL) - return(NULL); - for (dr = 0; dr < cmr->nrows; dr++) - for (dc = 0; dc < cmr->ncols; dc++) { - const COLORV *sp = cm_lval(cm1,dr,dc); - COLORV *dp = cm_lval(cmr,dr,dc); - dp[0] = sp[0] * sca[0]; - dp[1] = sp[1] * sca[1]; - dp[2] = sp[2] * sca[2]; - } - return(cmr); -} - -/* Multiply two matrices (or a matrix and a vector) and allocate the result */ -static CMATRIX * -cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2) -{ - CMATRIX *cmr; - int dr, dc, i; - - if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows)) - error(INTERNAL, "matrix dimension mismatch in cm_multiply()"); - cmr = cm_alloc(cm1->nrows, cm2->ncols); - if (cmr == NULL) - return(NULL); - for (dr = 0; dr < cmr->nrows; dr++) - for (dc = 0; dc < cmr->ncols; dc++) { - COLORV *dp = cm_lval(cmr,dr,dc); - dp[0] = dp[1] = dp[2] = 0; - for (i = 0; i < cm1->ncols; i++) { - const COLORV *cp1 = cm_lval(cm1,dr,i); - const COLORV *cp2 = cm_lval(cm2,i,dc); - dp[0] += cp1[0] * cp2[0]; - dp[1] += cp1[1] * cp2[1]; - dp[2] += cp1[2] * cp2[2]; - } - } - return(cmr); -} - -/* print out matrix as ASCII text -- no header */ -static void -cm_print(const CMATRIX *cm, FILE *fp) -{ - int r, c; - const COLORV *mp = cm->cmem; - - for (r = 0; r < cm->nrows; r++) { - for (c = 0; c < cm->ncols; c++, mp += 3) - fprintf(fp, "\t%.6e %.6e %.6e", mp[0], mp[1], mp[2]); - fputc('\n', fp); - } -} - -/* Convert a BSDF to our matrix representation */ -static CMATRIX * -cm_bsdf(const COLOR bsdfLamb, const COLOR specCol, const SDMat *bsdf) -{ - CMATRIX *cm = cm_alloc(bsdf->nout, bsdf->ninc); - int nbadohm = 0; - int nneg = 0; - int r, c; - /* loop over incident angles */ - for (c = 0; c < cm->ncols; c++) { - const double dom = mBSDF_incohm(bsdf,c); - /* projected solid angle */ - nbadohm += (dom <= 0); - - for (r = 0; r < cm->nrows; r++) { - float f = mBSDF_value(bsdf,c,r); - COLORV *mp = cm_lval(cm,r,c); - /* check BSDF value */ - if ((f <= 0) | (dom <= 0)) { - nneg += (f < -FTINY); - f = .0f; - } - copycolor(mp, specCol); - scalecolor(mp, f); - addcolor(mp, bsdfLamb); - scalecolor(mp, dom); - } - } - if (nneg | nbadohm) { - sprintf(errmsg, - "BTDF has %d negatives and %d bad incoming solid angles", - nneg, nbadohm); - error(WARNING, errmsg); - } - return(cm); -} - -/* Convert between input and output indices for reciprocity */ -static int -recip_out_from_in(const SDMat *bsdf, int in_recip) -{ - FVECT v; - - if (!mBSDF_incvec(v, bsdf, in_recip+.5)) - return(in_recip); /* XXX should be error! */ - v[2] = -v[2]; - return(mBSDF_outndx(bsdf, v)); -} - -/* Convert between output and input indices for reciprocity */ -static int -recip_in_from_out(const SDMat *bsdf, int out_recip) -{ - FVECT v; - - if (!mBSDF_outvec(v, bsdf, out_recip+.5)) - return(out_recip); /* XXX should be error! */ - v[2] = -v[2]; - return(mBSDF_incndx(bsdf, v)); -} - -/* Convert a BSDF to our matrix representation, applying reciprocity */ -static CMATRIX * -cm_bsdf_recip(const COLOR bsdfLamb, const COLOR specCol, const SDMat *bsdf) -{ - CMATRIX *cm = cm_alloc(bsdf->ninc, bsdf->nout); - int nbadohm = 0; - int nneg = 0; - int r, c; - /* loop over incident angles */ - for (c = 0; c < cm->ncols; c++) { - const int ro = recip_out_from_in(bsdf,c); - const double dom = mBSDF_outohm(bsdf,ro); - /* projected solid angle */ - nbadohm += (dom <= 0); - - for (r = 0; r < cm->nrows; r++) { - const int ri = recip_in_from_out(bsdf,r); - float f = mBSDF_value(bsdf,ri,ro); - COLORV *mp = cm_lval(cm,r,c); - /* check BSDF value */ - if ((f <= 0) | (dom <= 0)) { - nneg += (f < -FTINY); - f = .0f; - } - copycolor(mp, specCol); - scalecolor(mp, f); - addcolor(mp, bsdfLamb); - scalecolor(mp, dom); - } - } - if (nneg | nbadohm) { - sprintf(errmsg, - "BTDF has %d negatives and %d bad incoming solid angles", - nneg, nbadohm); - error(WARNING, errmsg); - } - return(cm); -} - -/* Load and convert a matrix BSDF from the given XML file */ -static CMATRIX * -cm_loadBSDF(char *fname, COLOR cLamb) -{ - CMATRIX *Tmat; - char *fpath; - int recip; - SDError ec; - SDData myBSDF; - SDSpectralDF *tdf; - COLOR bsdfLamb, specCol; - /* find path to BSDF file */ - fpath = getpath(fname, getrlibpath(), R_OK); - if (fpath == NULL) { - sprintf(errmsg, "cannot find BSDF file '%s'", fname); - error(USER, errmsg); - } - SDclearBSDF(&myBSDF, fname); /* load XML and check type */ - ec = SDloadFile(&myBSDF, fpath); - if (ec) - error(USER, transSDError(ec)); - ccy2rgb(&myBSDF.tLamb.spec, myBSDF.tLamb.cieY/PI, bsdfLamb); - recip = (myBSDF.tb == NULL); - tdf = recip ? myBSDF.tf : myBSDF.tb; - if (tdf == NULL) { /* no non-Lambertian transmission? */ - if (cLamb != NULL) - copycolor(cLamb, bsdfLamb); - SDfreeBSDF(&myBSDF); - return(NULL); - } - if (tdf->ncomp != 1 || tdf->comp[0].func != &SDhandleMtx) { - sprintf(errmsg, "unsupported BSDF '%s'", fpath); - error(USER, errmsg); - } - /* convert BTDF to matrix */ - ccy2rgb(&tdf->comp[0].cspec[0], 1., specCol); - Tmat = recip ? cm_bsdf_recip(bsdfLamb, specCol, (SDMat *)tdf->comp[0].dist) - : cm_bsdf(bsdfLamb, specCol, (SDMat *)tdf->comp[0].dist); - if (cLamb != NULL) /* Lambertian is included */ - setcolor(cLamb, .0, .0, .0); - /* free BSDF and return */ - SDfreeBSDF(&myBSDF); - return(Tmat); -} - /* Sum together a set of images and write result to fout */ static int sum_images(const char *fspec, const CMATRIX *cv, FILE *fout) { int myDT = DTfromHeader; - COLOR *scanline = NULL; + COLR *scanline = NULL; CMATRIX *pmat = NULL; int myXR=0, myYR=0; int i, y; @@ -501,22 +30,26 @@ sum_images(const char *fspec, const CMATRIX *cv, FILE error(INTERNAL, "expected vector in sum_images()"); for (i = 0; i < cv->nrows; i++) { const COLORV *scv = cv_lval(cv,i); + int flat_file = 0; char fname[1024]; FILE *fp; + long data_start; int dt, xr, yr; COLORV *psp; + char *err; /* check for zero */ if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) && (myDT != DTfromHeader) | (i < cv->nrows-1)) continue; /* open next picture */ sprintf(fname, fspec, i); - if ((fp = fopen(fname, "r")) == NULL) { + if ((fp = fopen(fname, "rb")) == NULL) { sprintf(errmsg, "cannot open picture '%s'", fname); error(SYSTEM, errmsg); } - SET_FILE_BINARY(fp); - dt = getDTfromHeader(fp); + dt = DTfromHeader; + if ((err = cm_getheader(&dt, NULL, NULL, NULL, fp)) != NULL) + error(USER, err); if ((dt != DTrgbe) & (dt != DTxyze) || !fscnresolu(&xr, &yr, fp)) { sprintf(errmsg, "file '%s' not a picture", fname); @@ -525,44 +58,53 @@ sum_images(const char *fspec, const CMATRIX *cv, FILE if (myDT == DTfromHeader) { /* on first one */ myDT = dt; myXR = xr; myYR = yr; - scanline = (COLOR *)malloc(sizeof(COLOR)*myXR); + scanline = (COLR *)malloc(sizeof(COLR)*myXR); if (scanline == NULL) error(SYSTEM, "out of memory in sum_images()"); pmat = cm_alloc(myYR, myXR); memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR); /* finish header */ - fputformat(myDT==DTrgbe ? COLRFMT : CIEFMT, fout); + fputformat((char *)cm_fmt_id[myDT], fout); fputc('\n', fout); - fprtresolu(myXR, myYR, fout); fflush(fout); } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) { sprintf(errmsg, "picture '%s' format/size mismatch", fname); error(USER, errmsg); } + /* flat file check */ + if ((data_start = ftell(fp)) > 0 && fseek(fp, 0L, SEEK_END) == 0) { + flat_file = (ftell(fp) == data_start + sizeof(COLR)*xr*yr); + if (fseek(fp, data_start, SEEK_SET) < 0) { + sprintf(errmsg, "cannot seek on picture '%s'", fname); + error(SYSTEM, errmsg); + } + } psp = pmat->cmem; for (y = 0; y < yr; y++) { /* read it in */ + COLOR col; int x; - if (freadscan(scanline, xr, fp) < 0) { + if (flat_file ? getbinary(scanline, sizeof(COLR), xr, fp) != xr : + freadcolrs(scanline, xr, fp) < 0) { sprintf(errmsg, "error reading picture '%s'", fname); error(SYSTEM, errmsg); } /* sum in scanline */ for (x = 0; x < xr; x++, psp += 3) { - multcolor(scanline[x], scv); - addcolor(psp, scanline[x]); + if (!scanline[x][EXP]) + continue; /* skip zeroes */ + colr_color(col, scanline[x]); + multcolor(col, scv); + addcolor(psp, col); } } fclose(fp); /* done this picture */ } free(scanline); - /* write scanlines */ - for (y = 0; y < myYR; y++) - if (fwritescan((COLOR *)cm_lval(pmat, y, 0), myXR, fout) < 0) - return(0); - cm_free(pmat); /* all done */ - return(fflush(fout) == 0); + i = cm_write(pmat, myDT, fout); /* write picture */ + cm_free(pmat); /* free data */ + return(i); } /* check to see if a string contains a %d or %o specification */ @@ -593,8 +135,10 @@ hasNumberFormat(const char *s) int main(int argc, char *argv[]) { - int skyfmt = DTascii; - int nsteps = 1; + int skyfmt = DTfromHeader; + int outfmt = DTascii; + int headout = 1; + int nsteps = 0; char *ofspec = NULL; FILE *ofp = stdout; CMATRIX *cmtx; /* component vector/matrix result */ @@ -607,11 +151,12 @@ main(int argc, char *argv[]) switch (argv[a][1]) { case 'n': nsteps = atoi(argv[++a]); - if (nsteps <= 0) + if (nsteps < 0) goto userr; + skyfmt = nsteps ? DTascii : DTfromHeader; break; - case 'o': - ofspec = argv[++a]; + case 'h': + headout = !headout; break; case 'i': switch (argv[a][2]) { @@ -628,6 +173,24 @@ main(int argc, char *argv[]) goto userr; } break; + case 'o': + switch (argv[a][2]) { + case '\0': /* output specification (not format) */ + ofspec = argv[++a]; + break; + case 'f': + outfmt = DTfloat; + break; + case 'd': + outfmt = DTdouble; + break; + case 'a': + outfmt = DTascii; + break; + default: + goto userr; + } + break; default: goto userr; } @@ -635,27 +198,30 @@ main(int argc, char *argv[]) goto userr; if (argc-a > 2) { /* VTDs expression */ - CMATRIX *smtx, *Dmat, *Tmat, *imtx; - COLOR tLamb; + CMATRIX *smtx, *Dmat, *Tmat, *imtx; + const char *ccp; /* get sky vector/matrix */ smtx = cm_load(argv[a+3], 0, nsteps, skyfmt); + nsteps = smtx->ncols; /* load BSDF */ - Tmat = cm_loadBSDF(argv[a+1], tLamb); + if (argv[a+1][0] != '!' && + (ccp = strrchr(argv[a+1], '.')) != NULL && + !strcasecmp(ccp+1, "XML")) + Tmat = cm_loadBTDF(argv[a+1]); + else + Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader); /* load Daylight matrix */ - Dmat = cm_load(argv[a+2], Tmat==NULL ? 0 : Tmat->ncols, + Dmat = cm_load(argv[a+2], Tmat->ncols, smtx->nrows, DTfromHeader); /* multiply vector through */ imtx = cm_multiply(Dmat, smtx); cm_free(Dmat); cm_free(smtx); - if (Tmat == NULL) { /* diffuse only */ - cmtx = cm_scale(imtx, tLamb); - } else { /* else apply BTDF matrix */ - cmtx = cm_multiply(Tmat, imtx); - cm_free(Tmat); - } + cmtx = cm_multiply(Tmat, imtx); + cm_free(Tmat); cm_free(imtx); } else { /* sky vector/matrix only */ cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt); + nsteps = cmtx->ncols; } /* prepare output stream */ if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) { @@ -681,7 +247,7 @@ main(int argc, char *argv[]) for (i = 0; i < nsteps; i++) { CMATRIX *cvec = cm_column(cmtx, i); if (ofspec != NULL) { - sprintf(fnbuf, ofspec, i+1); + sprintf(fnbuf, ofspec, i); if ((ofp = fopen(fnbuf, "wb")) == NULL) { fprintf(stderr, "%s: cannot open '%s' for output\n", @@ -692,7 +258,7 @@ main(int argc, char *argv[]) printargs(argc, argv, ofp); fputnow(ofp); } - fprintf(ofp, "FRAME=%d\n", i+1); + fprintf(ofp, "FRAME=%d\n", i); if (!sum_images(argv[a], cvec, ofp)) return(1); if (ofspec != NULL) { @@ -712,17 +278,31 @@ main(int argc, char *argv[]) CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader); CMATRIX *rmtx = cm_multiply(Vmat, cmtx); cm_free(Vmat); - if (ofspec != NULL) /* multiple vector files? */ + if (ofspec != NULL) { /* multiple vector files? */ + const char *wtype = (outfmt==DTascii) ? "w" : "wb"; for (i = 0; i < nsteps; i++) { CMATRIX *rvec = cm_column(rmtx, i); - sprintf(fnbuf, ofspec, i+1); - if ((ofp = fopen(fnbuf, "w")) == NULL) { + sprintf(fnbuf, ofspec, i); + if ((ofp = fopen(fnbuf, wtype)) == NULL) { fprintf(stderr, "%s: cannot open '%s' for output\n", progname, fnbuf); return(1); } - cm_print(rvec, ofp); +#ifdef getc_unlocked + flockfile(ofp); +#endif + if (headout) { /* header output */ + newheader("RADIANCE", ofp); + printargs(argc, argv, ofp); + fputnow(ofp); + fprintf(ofp, "FRAME=%d\n", i); + fprintf(ofp, "NROWS=%d\n", rvec->nrows); + fputs("NCOLS=1\nNCOMP=3\n", ofp); + fputformat((char *)cm_fmt_id[outfmt], ofp); + fputc('\n', ofp); + } + cm_write(rvec, outfmt, ofp); if (fclose(ofp) == EOF) { fprintf(stderr, "%s: error writing to '%s'\n", @@ -732,8 +312,24 @@ main(int argc, char *argv[]) ofp = stdout; cm_free(rvec); } - else - cm_print(rmtx, ofp); + } else { +#ifdef getc_unlocked + flockfile(ofp); +#endif + if (outfmt != DTascii) + SET_FILE_BINARY(ofp); + if (headout) { /* header output */ + newheader("RADIANCE", ofp); + printargs(argc, argv, ofp); + fputnow(ofp); + fprintf(ofp, "NROWS=%d\n", rmtx->nrows); + fprintf(ofp, "NCOLS=%d\n", rmtx->ncols); + fputs("NCOMP=3\n", ofp); + fputformat((char *)cm_fmt_id[outfmt], ofp); + fputc('\n', ofp); + } + cm_write(rmtx, outfmt, ofp); + } cm_free(rmtx); } if (fflush(ofp) == EOF) { /* final clean-up */ @@ -743,9 +339,9 @@ main(int argc, char *argv[]) cm_free(cmtx); return(0); userr: - fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-i{f|d}] DCspec [skyf]\n", + fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] DCspec [skyf]\n", progname); - fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d}] Vspec Tbsdf.xml Dmat.dat [skyf]\n", + fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d|h}][-o{f|d}] Vspec Tbsdf Dmat.dat [skyf]\n", progname); return(1); }
