--- ray/src/util/dctimestep.c 2013/01/11 05:07:47 2.24 +++ ray/src/util/dctimestep.c 2014/01/20 21:29:04 2.28 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: dctimestep.c,v 2.24 2013/01/11 05:07:47 greg Exp $"; +static const char RCSid[] = "$Id: dctimestep.c,v 2.28 2014/01/20 21:29:04 greg Exp $"; #endif /* * Compute time-step result using Daylight Coefficient method. @@ -9,478 +9,12 @@ static const char RCSid[] = "$Id: dctimestep.c,v 2.24 #include #include "standard.h" +#include "cmatrix.h" #include "platform.h" -#include "paths.h" -#include "color.h" #include "resolu.h" -#include "bsdf.h" -#include "bsdf_m.h" char *progname; /* global argv[0] */ -/* Data types for file loading */ -enum {DTfromHeader, DTascii, DTfloat, DTdouble, DTrgbe, DTxyze}; - -/* A color coefficient matrix -- vectors have ncols==1 */ -typedef struct { - int nrows, ncols; - COLORV cmem[3]; /* extends struct */ -} CMATRIX; - -#define COLSPEC (sizeof(COLORV)==sizeof(float) ? "%f %f %f" : "%lf %lf %lf") - -#define cm_lval(cm,r,c) ((cm)->cmem + 3*((r)*(cm)->ncols + (c))) - -#define cv_lval(cm,i) ((cm)->cmem + 3*(i)) - -/* Allocate a color coefficient matrix */ -static CMATRIX * -cm_alloc(int nrows, int ncols) -{ - CMATRIX *cm; - - if ((nrows <= 0) | (ncols <= 0)) - error(USER, "attempt to create empty matrix"); - cm = (CMATRIX *)malloc(sizeof(CMATRIX) + - 3*sizeof(COLORV)*(nrows*ncols - 1)); - if (cm == NULL) - error(SYSTEM, "out of memory in cm_alloc()"); - cm->nrows = nrows; - cm->ncols = ncols; - return(cm); -} - -#define cm_free(cm) free(cm) - -/* Resize color coefficient matrix */ -static CMATRIX * -cm_resize(CMATRIX *cm, int nrows) -{ - if (nrows == cm->nrows) - return(cm); - if (nrows <= 0) { - cm_free(cm); - return(NULL); - } - cm = (CMATRIX *)realloc(cm, sizeof(CMATRIX) + - 3*sizeof(COLORV)*(nrows*cm->ncols - 1)); - if (cm == NULL) - error(SYSTEM, "out of memory in cm_resize()"); - cm->nrows = nrows; - return(cm); -} - -/* Load header to obtain data type */ -static int -getDT(char *s, void *p) -{ - char fmt[32]; - - if (formatval(fmt, s)) { - if (!strcmp(fmt, "ascii")) - *((int *)p) = DTascii; - else if (!strcmp(fmt, "float")) - *((int *)p) = DTfloat; - else if (!strcmp(fmt, "double")) - *((int *)p) = DTdouble; - else if (!strcmp(fmt, COLRFMT)) - *((int *)p) = DTrgbe; - else if (!strcmp(fmt, CIEFMT)) - *((int *)p) = DTxyze; - } - return(0); -} - -static int -getDTfromHeader(FILE *fp) -{ - int dt = DTfromHeader; - - if (getheader(fp, getDT, &dt) < 0) - error(SYSTEM, "header read error"); - if (dt == DTfromHeader) - error(USER, "missing data format in header"); - return(dt); -} - -/* Allocate and load a matrix from the given file (or stdin if NULL) */ -static CMATRIX * -cm_load(const char *fname, int nrows, int ncols, int dtype) -{ - CMATRIX *cm; - FILE *fp = stdin; - - if (ncols <= 0) - error(USER, "Non-positive number of columns"); - if (fname == NULL) - fname = ""; - else if ((fp = fopen(fname, "r")) == NULL) { - sprintf(errmsg, "cannot open file '%s'", fname); - error(SYSTEM, errmsg); - } - if (dtype != DTascii) - SET_FILE_BINARY(fp); - if (dtype == DTfromHeader) - dtype = getDTfromHeader(fp); - switch (dtype) { - case DTascii: - case DTfloat: - case DTdouble: - break; - default: - error(USER, "unexpected data type in cm_load()"); - } - if (nrows <= 0) { /* don't know length? */ - int guessrows = 147; /* usually big enough */ - if ((dtype != DTascii) & (fp != stdin)) { - long startpos = ftell(fp); - if (fseek(fp, 0L, SEEK_END) == 0) { - long endpos = ftell(fp); - long elemsiz = 3*(dtype==DTfloat ? - sizeof(float) : sizeof(double)); - - if ((endpos - startpos) % (ncols*elemsiz)) { - sprintf(errmsg, - "improper length for binary file '%s'", - fname); - error(USER, errmsg); - } - guessrows = (endpos - startpos)/(ncols*elemsiz); - if (fseek(fp, startpos, SEEK_SET) < 0) { - sprintf(errmsg, - "fseek() error on file '%s'", - fname); - error(SYSTEM, errmsg); - } - nrows = guessrows; /* we're confident */ - } - } - cm = cm_alloc(guessrows, ncols); - } else - cm = cm_alloc(nrows, ncols); - if (cm == NULL) - return(NULL); - if (dtype == DTascii) { /* read text file */ - int maxrow = (nrows > 0 ? nrows : 32000); - int r, c; - for (r = 0; r < maxrow; r++) { - if (r >= cm->nrows) /* need more space? */ - cm = cm_resize(cm, 2*cm->nrows); - for (c = 0; c < ncols; c++) { - COLORV *cv = cm_lval(cm,r,c); - if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3) - if ((nrows <= 0) & (r > 0) & !c) { - cm = cm_resize(cm, maxrow=r); - break; - } else - goto EOFerror; - } - } - while ((c = getc(fp)) != EOF) - if (!isspace(c)) { - sprintf(errmsg, - "unexpected data at end of ascii file %s", - fname); - error(WARNING, errmsg); - break; - } - } else { /* read binary file */ - if (sizeof(COLORV) == (dtype==DTfloat ? sizeof(float) : - sizeof(double))) { - int nread = 0; - do { /* read all we can */ - nread += fread(cm->cmem + 3*nread, - 3*sizeof(COLORV), - cm->nrows*cm->ncols - nread, - fp); - if (nrows <= 0) { /* unknown length */ - if (nread == cm->nrows*cm->ncols) - /* need more space? */ - cm = cm_resize(cm, 2*cm->nrows); - else if (nread && !(nread % cm->ncols)) - /* seem to be done */ - cm = cm_resize(cm, nread/cm->ncols); - else /* ended mid-row */ - goto EOFerror; - } else if (nread < cm->nrows*cm->ncols) - goto EOFerror; - } while (nread < cm->nrows*cm->ncols); - - } else if (dtype == DTdouble) { - double dc[3]; /* load from double */ - COLORV *cvp = cm->cmem; - int n = nrows*ncols; - - if (n <= 0) - goto not_handled; - while (n--) { - if (fread(dc, sizeof(double), 3, fp) != 3) - goto EOFerror; - copycolor(cvp, dc); - cvp += 3; - } - } else /* dtype == DTfloat */ { - float fc[3]; /* load from float */ - COLORV *cvp = cm->cmem; - int n = nrows*ncols; - - if (n <= 0) - goto not_handled; - while (n--) { - if (fread(fc, sizeof(float), 3, fp) != 3) - goto EOFerror; - copycolor(cvp, fc); - cvp += 3; - } - } - if (getc(fp) != EOF) { - sprintf(errmsg, - "unexpected data at end of binary file %s", - fname); - error(WARNING, errmsg); - } - } - if (fp != stdin) - fclose(fp); - return(cm); -EOFerror: - sprintf(errmsg, "unexpected EOF reading %s", - fname); - error(USER, errmsg); -not_handled: - error(INTERNAL, "unhandled data size or length in cm_load()"); - return(NULL); /* gratis return */ -} - -/* Extract a column vector from a matrix */ -static CMATRIX * -cm_column(const CMATRIX *cm, int c) -{ - CMATRIX *cvr; - int dr; - - if ((c < 0) | (c >= cm->ncols)) - return(NULL); - cvr = cm_alloc(cm->nrows, 1); - if (cvr == NULL) - return(NULL); - for (dr = 0; dr < cm->nrows; dr++) { - const COLORV *sp = cm_lval(cm,dr,c); - COLORV *dp = cv_lval(cvr,dr); - dp[0] = sp[0]; - dp[1] = sp[1]; - dp[2] = sp[2]; - } - return(cvr); -} - -/* Scale a matrix by a single value */ -static CMATRIX * -cm_scale(const CMATRIX *cm1, const COLOR sca) -{ - CMATRIX *cmr; - int dr, dc; - - cmr = cm_alloc(cm1->nrows, cm1->ncols); - if (cmr == NULL) - return(NULL); - for (dr = 0; dr < cmr->nrows; dr++) - for (dc = 0; dc < cmr->ncols; dc++) { - const COLORV *sp = cm_lval(cm1,dr,dc); - COLORV *dp = cm_lval(cmr,dr,dc); - dp[0] = sp[0] * sca[0]; - dp[1] = sp[1] * sca[1]; - dp[2] = sp[2] * sca[2]; - } - return(cmr); -} - -/* Multiply two matrices (or a matrix and a vector) and allocate the result */ -static CMATRIX * -cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2) -{ - CMATRIX *cmr; - int dr, dc, i; - - if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows)) - error(INTERNAL, "matrix dimension mismatch in cm_multiply()"); - cmr = cm_alloc(cm1->nrows, cm2->ncols); - if (cmr == NULL) - return(NULL); - for (dr = 0; dr < cmr->nrows; dr++) - for (dc = 0; dc < cmr->ncols; dc++) { - COLORV *dp = cm_lval(cmr,dr,dc); - dp[0] = dp[1] = dp[2] = 0; - for (i = 0; i < cm1->ncols; i++) { - const COLORV *cp1 = cm_lval(cm1,dr,i); - const COLORV *cp2 = cm_lval(cm2,i,dc); - dp[0] += cp1[0] * cp2[0]; - dp[1] += cp1[1] * cp2[1]; - dp[2] += cp1[2] * cp2[2]; - } - } - return(cmr); -} - -/* print out matrix as ASCII text -- no header */ -static void -cm_print(const CMATRIX *cm, FILE *fp) -{ - int r, c; - const COLORV *mp = cm->cmem; - - for (r = 0; r < cm->nrows; r++) { - for (c = 0; c < cm->ncols; c++, mp += 3) - fprintf(fp, "\t%.6e %.6e %.6e", mp[0], mp[1], mp[2]); - fputc('\n', fp); - } -} - -/* Convert a BSDF to our matrix representation */ -static CMATRIX * -cm_bsdf(const COLOR bsdfLamb, const COLOR specCol, const SDMat *bsdf) -{ - CMATRIX *cm = cm_alloc(bsdf->nout, bsdf->ninc); - int nbadohm = 0; - int nneg = 0; - int r, c; - /* loop over incident angles */ - for (c = 0; c < cm->ncols; c++) { - const double dom = mBSDF_incohm(bsdf,c); - /* projected solid angle */ - nbadohm += (dom <= 0); - - for (r = 0; r < cm->nrows; r++) { - float f = mBSDF_value(bsdf,c,r); - COLORV *mp = cm_lval(cm,r,c); - /* check BSDF value */ - if ((f <= 0) | (dom <= 0)) { - nneg += (f < -FTINY); - f = .0f; - } - copycolor(mp, specCol); - scalecolor(mp, f); - addcolor(mp, bsdfLamb); - scalecolor(mp, dom); - } - } - if (nneg | nbadohm) { - sprintf(errmsg, - "BTDF has %d negatives and %d bad incoming solid angles", - nneg, nbadohm); - error(WARNING, errmsg); - } - return(cm); -} - -/* Convert between input and output indices for reciprocity */ -static int -recip_out_from_in(const SDMat *bsdf, int in_recip) -{ - FVECT v; - - if (!mBSDF_incvec(v, bsdf, in_recip+.5)) - return(in_recip); /* XXX should be error! */ - v[2] = -v[2]; - return(mBSDF_outndx(bsdf, v)); -} - -/* Convert between output and input indices for reciprocity */ -static int -recip_in_from_out(const SDMat *bsdf, int out_recip) -{ - FVECT v; - - if (!mBSDF_outvec(v, bsdf, out_recip+.5)) - return(out_recip); /* XXX should be error! */ - v[2] = -v[2]; - return(mBSDF_incndx(bsdf, v)); -} - -/* Convert a BSDF to our matrix representation, applying reciprocity */ -static CMATRIX * -cm_bsdf_recip(const COLOR bsdfLamb, const COLOR specCol, const SDMat *bsdf) -{ - CMATRIX *cm = cm_alloc(bsdf->ninc, bsdf->nout); - int nbadohm = 0; - int nneg = 0; - int r, c; - /* loop over incident angles */ - for (c = 0; c < cm->ncols; c++) { - const int ro = recip_out_from_in(bsdf,c); - const double dom = mBSDF_outohm(bsdf,ro); - /* projected solid angle */ - nbadohm += (dom <= 0); - - for (r = 0; r < cm->nrows; r++) { - const int ri = recip_in_from_out(bsdf,r); - float f = mBSDF_value(bsdf,ri,ro); - COLORV *mp = cm_lval(cm,r,c); - /* check BSDF value */ - if ((f <= 0) | (dom <= 0)) { - nneg += (f < -FTINY); - f = .0f; - } - copycolor(mp, specCol); - scalecolor(mp, f); - addcolor(mp, bsdfLamb); - scalecolor(mp, dom); - } - } - if (nneg | nbadohm) { - sprintf(errmsg, - "BTDF has %d negatives and %d bad incoming solid angles", - nneg, nbadohm); - error(WARNING, errmsg); - } - return(cm); -} - -/* Load and convert a matrix BSDF from the given XML file */ -static CMATRIX * -cm_loadBSDF(char *fname, COLOR cLamb) -{ - CMATRIX *Tmat; - char *fpath; - int recip; - SDError ec; - SDData myBSDF; - SDSpectralDF *tdf; - COLOR bsdfLamb, specCol; - /* find path to BSDF file */ - fpath = getpath(fname, getrlibpath(), R_OK); - if (fpath == NULL) { - sprintf(errmsg, "cannot find BSDF file '%s'", fname); - error(USER, errmsg); - } - SDclearBSDF(&myBSDF, fname); /* load XML and check type */ - ec = SDloadFile(&myBSDF, fpath); - if (ec) - error(USER, transSDError(ec)); - ccy2rgb(&myBSDF.tLamb.spec, myBSDF.tLamb.cieY/PI, bsdfLamb); - recip = (myBSDF.tb == NULL); - tdf = recip ? myBSDF.tf : myBSDF.tb; - if (tdf == NULL) { /* no non-Lambertian transmission? */ - if (cLamb != NULL) - copycolor(cLamb, bsdfLamb); - SDfreeBSDF(&myBSDF); - return(NULL); - } - if (tdf->ncomp != 1 || tdf->comp[0].func != &SDhandleMtx) { - sprintf(errmsg, "unsupported BSDF '%s'", fpath); - error(USER, errmsg); - } - /* convert BTDF to matrix */ - ccy2rgb(&tdf->comp[0].cspec[0], 1., specCol); - Tmat = recip ? cm_bsdf_recip(bsdfLamb, specCol, (SDMat *)tdf->comp[0].dist) - : cm_bsdf(bsdfLamb, specCol, (SDMat *)tdf->comp[0].dist); - if (cLamb != NULL) /* Lambertian is included */ - setcolor(cLamb, .0, .0, .0); - /* free BSDF and return */ - SDfreeBSDF(&myBSDF); - return(Tmat); -} - /* Sum together a set of images and write result to fout */ static int sum_images(const char *fspec, const CMATRIX *cv, FILE *fout) @@ -587,6 +121,7 @@ hasNumberFormat(const char *s) int main(int argc, char *argv[]) { + int skyfmt = DTascii; int nsteps = 1; char *ofspec = NULL; FILE *ofp = stdout; @@ -596,8 +131,8 @@ main(int argc, char *argv[]) progname = argv[0]; /* get options */ - for (a = 1; a < argc-1 && argv[a][0] == '-'; a++) - switch (argv[0][1]) { + for (a = 1; a < argc && argv[a][0] == '-'; a++) + switch (argv[a][1]) { case 'n': nsteps = atoi(argv[++a]); if (nsteps <= 0) @@ -606,6 +141,21 @@ main(int argc, char *argv[]) case 'o': ofspec = argv[++a]; break; + case 'i': + switch (argv[a][2]) { + case 'f': + skyfmt = DTfloat; + break; + case 'd': + skyfmt = DTdouble; + break; + case 'a': + skyfmt = DTascii; + break; + default: + goto userr; + } + break; default: goto userr; } @@ -616,7 +166,7 @@ main(int argc, char *argv[]) CMATRIX *smtx, *Dmat, *Tmat, *imtx; COLOR tLamb; /* get sky vector/matrix */ - smtx = cm_load(argv[a+3], 0, nsteps, DTascii); + smtx = cm_load(argv[a+3], 0, nsteps, skyfmt); /* load BSDF */ Tmat = cm_loadBSDF(argv[a+1], tLamb); /* load Daylight matrix */ @@ -633,7 +183,7 @@ main(int argc, char *argv[]) } cm_free(imtx); } else { /* sky vector/matrix only */ - cmtx = cm_load(argv[a+1], 0, nsteps, DTascii); + cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt); } /* prepare output stream */ if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) { @@ -721,9 +271,9 @@ main(int argc, char *argv[]) cm_free(cmtx); return(0); userr: - fprintf(stderr, "Usage: %s [-n nsteps][-o ospec] DCspec [skyf]\n", + fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-i{f|d}] DCspec [skyf]\n", progname); - fprintf(stderr, " or: %s [-n nsteps][-o ospec] Vspec Tbsdf.xml Dmat.dat [skyf]\n", + fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d}] Vspec Tbsdf.xml Dmat.dat [skyf]\n", progname); return(1); }
