--- ray/src/util/dctimestep.c 2013/01/11 05:07:47 2.24 +++ ray/src/util/dctimestep.c 2013/01/11 17:21:39 2.25 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: dctimestep.c,v 2.24 2013/01/11 05:07:47 greg Exp $"; +static const char RCSid[] = "$Id: dctimestep.c,v 2.25 2013/01/11 17:21:39 greg Exp $"; #endif /* * Compute time-step result using Daylight Coefficient method. @@ -107,8 +107,8 @@ getDTfromHeader(FILE *fp) static CMATRIX * cm_load(const char *fname, int nrows, int ncols, int dtype) { - CMATRIX *cm; FILE *fp = stdin; + CMATRIX *cm; if (ncols <= 0) error(USER, "Non-positive number of columns"); @@ -118,6 +118,9 @@ cm_load(const char *fname, int nrows, int ncols, int d sprintf(errmsg, "cannot open file '%s'", fname); error(SYSTEM, errmsg); } +#ifdef getc_unlocked + flockfile(fp); +#endif if (dtype != DTascii) SET_FILE_BINARY(fp); if (dtype == DTfromHeader) @@ -158,7 +161,7 @@ cm_load(const char *fname, int nrows, int ncols, int d cm = cm_alloc(guessrows, ncols); } else cm = cm_alloc(nrows, ncols); - if (cm == NULL) + if (cm == NULL) /* XXX never happens */ return(NULL); if (dtype == DTascii) { /* read text file */ int maxrow = (nrows > 0 ? nrows : 32000); @@ -233,7 +236,7 @@ cm_load(const char *fname, int nrows, int ncols, int d cvp += 3; } } - if (getc(fp) != EOF) { + if (fgetc(fp) != EOF) { sprintf(errmsg, "unexpected data at end of binary file %s", fname); @@ -242,10 +245,13 @@ cm_load(const char *fname, int nrows, int ncols, int d } if (fp != stdin) fclose(fp); +#ifdef getc_unlocked + else + funlockfile(fp); +#endif return(cm); EOFerror: - sprintf(errmsg, "unexpected EOF reading %s", - fname); + sprintf(errmsg, "unexpected EOF reading %s", fname); error(USER, errmsg); not_handled: error(INTERNAL, "unhandled data size or length in cm_load()"); @@ -587,6 +593,7 @@ hasNumberFormat(const char *s) int main(int argc, char *argv[]) { + int skyfmt = DTascii; int nsteps = 1; char *ofspec = NULL; FILE *ofp = stdout; @@ -596,8 +603,8 @@ main(int argc, char *argv[]) progname = argv[0]; /* get options */ - for (a = 1; a < argc-1 && argv[a][0] == '-'; a++) - switch (argv[0][1]) { + for (a = 1; a < argc && argv[a][0] == '-'; a++) + switch (argv[a][1]) { case 'n': nsteps = atoi(argv[++a]); if (nsteps <= 0) @@ -606,6 +613,21 @@ main(int argc, char *argv[]) case 'o': ofspec = argv[++a]; break; + case 'i': + switch (argv[a][2]) { + case 'f': + skyfmt = DTfloat; + break; + case 'd': + skyfmt = DTdouble; + break; + case 'a': + skyfmt = DTascii; + break; + default: + goto userr; + } + break; default: goto userr; } @@ -616,7 +638,7 @@ main(int argc, char *argv[]) CMATRIX *smtx, *Dmat, *Tmat, *imtx; COLOR tLamb; /* get sky vector/matrix */ - smtx = cm_load(argv[a+3], 0, nsteps, DTascii); + smtx = cm_load(argv[a+3], 0, nsteps, skyfmt); /* load BSDF */ Tmat = cm_loadBSDF(argv[a+1], tLamb); /* load Daylight matrix */ @@ -633,7 +655,7 @@ main(int argc, char *argv[]) } cm_free(imtx); } else { /* sky vector/matrix only */ - cmtx = cm_load(argv[a+1], 0, nsteps, DTascii); + cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt); } /* prepare output stream */ if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) { @@ -721,9 +743,9 @@ main(int argc, char *argv[]) cm_free(cmtx); return(0); userr: - fprintf(stderr, "Usage: %s [-n nsteps][-o ospec] DCspec [skyf]\n", + fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-i{f|d}] DCspec [skyf]\n", progname); - fprintf(stderr, " or: %s [-n nsteps][-o ospec] Vspec Tbsdf.xml Dmat.dat [skyf]\n", + fprintf(stderr, " or: %s [-n nsteps][-o ospec][-i{f|d}] Vspec Tbsdf.xml Dmat.dat [skyf]\n", progname); return(1); }
